VW Polo 6R. Idle speed specified value.
Tinerfe30
New Member
Spain
9b9ed9-9d2264
Hello.
I need up the Idle speed specified value, now is 780 rpm.
Spark plugs, air filters and gasoline have changed. The car works properly, but when it is at 780 rpm it makes a small vibration, if it goes up to 850 rpm approximately that vibration disappears.
In adaptation, the option to adjust the Idle speed Value does not appear.
Any help is well come
Thursday,08,March,2018,14:45:38:40665
VCDS Version: 18.2.0.3
Dealer/Shop Name: No name
Workshop Code: 222 12345 054321
VIN: WVWZZZ6RZFY048968   License Plate:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44
VIN: WVWZZZ6RZFY048968   Mileage: 82498km-51261miles
Address 01: Engine (J623-CHYB)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 057 A    HW: 04C 907 309 J
   Component: R3 1.0l MPI   H22 7750
   Revision: 31H22000
   Coding: 01110012020408080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM10MPI01104C906057A 001011
   ROD: EV_ECM10MPI01104C906057A.rod
   VCID: 234069F22A4B215C25-8076
Readiness: 0000 0001
Well, if VW does not specify a channel for it in their data for the ECU, which appears to be the case here, then there's not much we can do to help you with this.
Oh, and since this is a 3-cylinder engine, I would expect a bit of vibration at idle. :)
