Newbie requiring a bit of guidance please.
Paul Woods
Guernsey
C?ID=328336
Hi All.
Just got myself a late 2017 Golf GTI mk7.5 facelift, which happens to have been built for Japanese market (RHD), but has ended up in UK,presumably a cancelled factory order!
Also just got myself HEX V2, with VCDS 18.2 which i am trying to get familiar with.
I have scanned the car AS BELOW, but I am having problem understanding address (module) 09, Central Electronics, which appears to be uncoded..it seems i can only access via secure code, and then adaptations only. Does this seem correct?(Everything on the car is working ok)
There are a couple of changes i would like to try-:
1)I would like to enable DRL option on MID, with DRL's to dim when main lights are on, and to change to orange indicators when indicating. Is this possible, and how?
2)Also i want to enable locking/unlocking "plip" from alarm siren, which i assume is fitted, again is this possible and how?
Any help/suggestions welcome, and thanks in advance guys!
Paul.
          4B 52 57 5F A5 A9 D6 D7
VIN: WVWZZZAUZJW058241   Mileage: 1920km-1193miles
29-Left Light -- Status: Malfunction 0010
4B-Multifunc. Module -- Status: Malfunction 0010
57-TV Tuner -- Status: Cannot be reached 0100
Address 01: Engine (J623-DLBA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 N    HW: 06K 907 425 J
   Revision: --H13---
   Coding: 092500124464050B3000
   ASAM Dataset: EV_ECM20TFS0205G0906259N 002003
   ROD: EV_ECM20TFS0205G0906259N_002_VW37.rod
   VCID: 392EDDCBE9D2F61F756-806C
   Part No SW: 0GC 300 020 A    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1401
   Revision: 00H06V07
   ASAM Dataset: EV_TCMDQ381061 001
   ROD: EV_TCMDQ381061.rod
   VCID: 201810AF6A4887D7528-8074
   Revision: 00000000    Serial number: 62067000002031
   Coding: 01FA93A1542521744779060440C46980C92A84E260029677384250F9C2A9430000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
   VCID: 77AA1BF39F46206F432-8022
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0449954327
   Coding: 032C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002020
   VCID: 3C20C4DFE6E0C3376E0-8068
   Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
   Revision: 00001K08
   Coding: 0012000410010001110500001010102A
   VCID: 6C80349FD60093B7BE0-8038
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001721200291
   ROD: EV_BCMCONTI.rod
   VCID: 06546637E8AC49E7484-8052
   Component: WWS    170713  042 0551
   Serial number:         170801053923
   Component: RLHS  042 0105
   Serial number: S9Y17M08D14H17M12S46
   Coding: 31E8DD
   Serial number: 000308418617222
   Coding: 0471155811
   VCID: 4BC29703B34E748FD7A-801E
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 330007C159FFC728949C810580400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E24CED7F0FCD127404-806A
   Serial number: 12071741350111
   ROD: EV_DRCONTITEMIC_VW27.rod
   VCID: 3828D8CFD2D8EF178A8-806C
   Part No SW: 5Q0 959 655 BK    HW: 5Q0 959 655 BK
   Serial number: 003VXR34XL4U
   Coding: 98FCC0C0000000005C5400CF008800000065
   VCID: 0A4C5207FCB42D872CC-805E
   Belt Pretensioner left:
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169677E11081750142
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169676E13081780284
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 808 17
   Serial number: 357000000002C0B4272C
   Subsystem 4 - Part No SW: -----------    HW: 480 000 808 17
   Serial number: 358000000005634C652G
   Subsystem 5 - Part No SW: -----------    HW: 480 400 208 17
   Serial number: 35100019B26D7C0502E5
   Subsystem 6 - Part No SW: -----------    HW: 480 400 308 17
   Serial number: 3520001BD26D7C02F1BI
   Subsystem 7 - Part No SW: -----------    HW: 480 400 308 17
   Serial number: 3550001A1268F0C282D7
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 17071704221216
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 094E6D0BF9B2269F256-805C
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         407 3193
   Coding: 27AD11187F88060202886B0B5400000080000000
   VCID: 2A0CF2871C744D870CC-807E
16777056 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_SDS_0x46 keine Kommunikation]
                    Reset counter: 6
                    Mileage: 53 km
                    Date: 2017.10.27
                    Time: 00:12:54
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   433 4303
   Revision: --------    Serial number: 0006658378
   Coding: 030100047F085900FB00027F9C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 3332EFE3CBBE0C4FBFA-8066
   Serial number: 29170001602780037312
   Coding: 2DFFFF
   Serial number: 5400184604
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   VCID: 47CAAB33AF2690EFF32-8012
0033 - Supply voltage
          [Supply voltage - lower limit exceeded]
                    Reset counter: 82
                    Mileage: 1649 km
                    Date: 2018.01.30
                    Time: 15:32:16
0035 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [functional limitation due to supply voltage - lower limit exceeded]
                    Reset counter: 88
                    Mileage: 1715 km
                    Date: 2018.02.12
                    Time: 09:47:03
0036 - Terminal 15
          U1405 00 [008] - Implausible signal
          [Clamp 15 implausible signal]
                    Reset counter: 88
                    Mileage: 1715 km
                    Date: 2018.02.12
                    Time: 09:47:03
   Revision: 00000000    Serial number: 17000198960010
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3430ECFFCEB00B77A60-8060
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00011.06.17
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   Component: HRE_Master    H12 0080
   Serial number: 0450336657
   Coding: 02011203
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D26C9DBFDFACA3F59E-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0450045364
   Coding: 020112
   Serial number: 100717EG401491
   Coding: 003F1320D001048000001000
   VCID: 43D2BF239B1EBCCF2FA-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000015849573
   Coding: 0D0000
   Coding: 9107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2CC2C7ECD4FD077CC-806E
   Serial number: 02081710523095
   Coding: 000000050100164E07204F01020000000000000000000000000000000000
   VCID: 72BC2AE7F424454774C-8026
66680 - Databus
          [LCM_LWR_L_allg_Fehler received error value]
                    Reset counter: 88
                    Mileage: 1715 km
                    Date: 2018.02.12
                    Time: 09:47:04
   Serial number: 240617EFO22481
   Coding: 003F1120DE01048000801000
   VCID: 42DCBA278404B5C724C-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Component: FOND_FHSG_PSG  005 0007
   Serial number: 00000000000015683864
   Coding: 150000
Address 57: TV Tuner
   Part No SW: 5NA 035 043     HW: 5NA 035 043
   Component: MU-H-N-EU     053 1121
   Serial number: K5F AW7U80O8KF
   Coding: 02840101FF00000051110001000808001F0100D401200100FE
   ASAM Dataset: EV_MUHig4CGen2AW7 001081
   ROD: EV_MUHig4CGen2AW7_VW27.rod
   VCID: 73B22FE38B3E4C4F7FA-8026
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT2116196
   Subsystem 2 - Part No SW: V03 959 800 QR    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Component: Gracenote2  --- 2014
          B201A 00 [009] -  -
                    Fault Frequency: 27
                    Reset counter: 73
                    Mileage: 53 km
                    Date: 2017.10.27
                    Time: 00:12:59
                    Voltage terminal 30: 15.0 V
                    Status_Software_Version_Management-module_name: MDUV624/Main
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 0272
   Serial number: 03081711P10821
   Coding: 0003070000000501000223548150A90084000E300040
   ROD: EV_MFKBoschMQBB_VW27.rod
   Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
   Serial number: 170720201072
   VCID: 323CEAE734A40547B4C-8066
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
1061 - Supply Voltage for Logic
          C121F 13 [040] - Open Circuit
                    Reset counter: 0
                    Mileage: 1715 km
                    Date: 2018.02.12
                    Time: 09:47:02
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxR_KEBODAVW481.rod
End----(Elapsed Time: 02:01, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
MasterTommy
Amsterdam
C?ID=295586
Its normal that 09 - Central Electrics module has an all zero coding string. All setting are in adaptations.
Before changing any adaptation channels, make an adaptation channel map!
Main screen > applications > controller channel map. Checkbox 'adaptation channels' on the left and 'CSV file' on the right should be checked, enter the control module number (09 in this case) and the security access code if available (31347 in this case) and press 'Go!'.
Adaptation channel values are not saved in an auto-scan, but some modules rely heavily (13, 17, 4B, 5F, A5 and others) or exclusively (09 for example) on adaptation channel settings. If you screw something up, and if you've read some topics here and there you know you most likely will at some point, a map is your last resort if all else fails. You seriously want to have one, and in stock condition would be ideal.
Now, if you've done that, lets see if i can get you started:
1:
a. I'm not sure what you mean with MID. If you mean you want to enable a checkbox under vehicle settings to allow you to turn the DRL's on and off, this is done in 09 central elec. Under adaptation channels > ENG141647-ENG116594-Auflenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich. Set this to active, and check the box 'soft reset. Next, in order to actually make it appear in the vehicle settings menu, reboot the infotainment unit by holding the power button until you see the startup screen.
b. DRL's should revert to 'city lights' (about half the brightness) by default when you engage the normal headlights. If it doesnt, check these channels (my settings in bold):
ENG141647-ENG116592-Auflenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,9 <<< EDIT
ENG141647-ENG116594-Auflenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,9
ENG141647-ENG115734-Auflenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9
ENG141647-ENG116593-Auflenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,9
With these settings:
- DRL's are 'on' only with lightswitch set to 'OFF' or 'Auto' (when the lightsensor deems it to actually be 'day').
- DRL's setting in infotainment menu (see above)
- Citylights when lightswitch set to 'citylights'. Normally my car would switch to DRL when the engine was off and the lightswitch was in 'citylights' position, then dim them to actual citylights but only when the engine was running.
c. I'm not sure what the current situation is. Front/rear/both? Which color/what is blinking now? You have to elaborate on that.
2:
I don't see any alarm horn or interior monitoring sensor installed (normally they are listed in you autoscan under 09 - central electrics as slave modules. It is possible to activate a confirmation sound when locking/unlocking the car, but you will hear your horn honk instead and that is a much less pleasant sound to many. Menu controls are also available for this function.
3: (my 2 cents)
As its a Japanese car, a TV tuner is common there. It doesnt work in the EU because of a different broadcasting technique, so I assume they disabled that. Your autoscan reports a TV tuner but the gateway cannot reach the module.
If this were my car, I'd visually confirm if the module is physically present in the car, and if not, remove it from the installation list in 19 - CAN gateway and the relevant adaptation channel in 5F - Infotainment electronics. But visual check first.
Edit: If you post autoscans between
 [/ code] tags, they don't take up as much space.
MasterTommy
Amsterdam
C?ID=295586
Made a small edit to the adaptation channels I listed in the above postunder 1b, I mistakenly used data from an old admap, and one setting was different. I’ve marked the change, please check your settings if you already changed these channels.
Paul Woods
Guernsey
C?ID=328336
Hi Master Tommy,
Thanks for your input and time, much apprdciated!
My mistake, should have read MIB, . MIB II stands for modular infotainment platform. This is where i want to enable DRL on/off, which i will try following your instructions.setting the DRL lines looks a bit more complicated, but hey ho! Got to have a go!
I will also do an adaptation map, sound advice, didn't know this could be done!
1c, i just want front DRL'S to blink orange when indicating a turn, i am assuming this will happen automatically once set up.
Havn't time to try the above today, hopefully tomorrow, and i will let you know how things go.
Thanks again,
Paul.
