2018 RS3 blindspot indicator brightness
thedru13
C?ID=67849
Was looking to see if anyone knew how to change the brightness for the blindspot indicators. I had an issue and had to have the control module replaced. I used to be able to adjust the brightness for the blindspot indicators via the MMI but after the module was replaced I no longer have the option. Was curious if anyone knew how to enable that option or change the brightness via VAG COM. Thanks.
D-Dub
US 2014 GTI Drivers Edition/DSG
C?ID=272151
you will need to provide a full auto scan, ideally before and after your module replacement.
so that anyone who can help, can see what exact modules are installed and any coding differences.
thedru13
C?ID=67849
Thanks @D-Dub. Sorry about not posting the scans. Here they are .
Old Scan
Saturday,02,December,2017,13:38:39:28124
VCDS Version: 17.10.0.2
Data version: 20171026 DS283.3
Mileage: 4572km-2840mi   Repair Order:
Chassis Type  FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 3C 42 44 47 52 5F
          6C BB BC
Address 01: Engine (------DAZA)       Labels: None
   Part No SW: 8V0 907 404 G    HW: 07K 907 309 E
   Component: 2.5l R5/4V TF H22 0002
   Revision: 53H22000
   Coding: 0A250032242600053620
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM25TFS0118V0907404G 001002
   ROD: EV_ECM25TFS0118V0907404G.rod
   VCID: 3D7AE86DAC1C72C297F-8068
   Part No SW: 0DL 300 012 H    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2112
   Revision: 00H06V07
   VCID: 2E58DF21717A995A1E5-807A
   Part No SW: 8V0 614 517 C    HW: 8V0 614 517 C
   Component: ESC           H25 0621
   Revision: 00000000    Serial number: 61897000000824
   Coding: 2EAA6B7DD4990BAA89970B6681966974D62BD091D0819636024150D4828812
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
   ROD: EV_Brake1UDSContiMK100IPB_035_VW27.rod
   VCID: 3972FC7DB8344EE2BB7-806C
8362 - Databus
                    Reset counter: 143
                    Mileage: 4316 km
                    Date: 2017.12.01
                    Time: 15:38:31
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0448153803
   Coding: 030C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002020
   VCID: 3C7CE569B7067BCAA01-8068
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0130
   Revision: 20002000    Serial number: 00000001297266
   Coding: 03000015010000000000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
   VCID: 40849199DBEE1F2AFC9-8014
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 4C00D8B800PAG0MUFU03
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001721200247
   ROD: EV_BCMBOSCH_018.rod
   VCID: 06084781B94AF11A865-8052
   Component: WWS371 170608  043 0585
   Serial number:         170628031212
   Coding: 0A47F7
   Serial number: 62938507
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 18 03 2017  00002218
   Serial number: 00000000000070231710
   Sun Roof:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST001P0PAP00000
   Coding: 101F00
   Serial number: 000308418617194
   Coding: 0470155011
   Shop #: WSC 12345 123 61029
   ROD: EV_EPHVA18AU3700000_009_AU37.rod
   VCID: 4B9EB6B5E2A8CC7219B-801E
13688835 - Databus
                    Reset counter: 108
                    Mileage: 4572 km
                    Date: 2017.12.02
                    Time: 13:25:53
   Part No SW: 8V0 907 376 G    HW: 8V0 907 376 F
   Component: DAEMPFUNGS-SG H11 0082
   Serial number:       100517004
   ASAM Dataset: EV_AudiMagneRide 002008
   ROD: EV_AudiMagneRide.rod
   VCID: 458A808DC4CC3A02CFF-8010
   Serial number: 003GCR08HMAT
   Coding: 9DFCFCC0008000005000001AC24800000065
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 47968A85FEC028123D3-8012
   Belt Pretensioner left:
   Component: BeltPretRevFL  H37 0350
   Serial number: 34258931A11071740072
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H37 0350
   Serial number: 34258932A12071750003
   Coding: 333135
   Occupant Detection:
   Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
   Serial number: 694000000000001MP2XG
   Coding: 303337
   Subsystem 4 - Part No SW: -----------    HW: 480 000 308 17
   Serial number: 35700000000F0988172M
   Subsystem 5 - Part No SW: -----------    HW: 480 000 308 17
   Serial number: 35800000000EF888172-
   Subsystem 6 - Part No SW: -----------    HW: 480 400 307 17
   Serial number: 35100019D2600D5525D/
   Subsystem 7 - Part No SW: -----------    HW: 480 400 407 17
   Serial number: 3520001A125F5886B499
   Subsystem 8 - Part No SW: -----------    HW: 480 402 306 17
   Serial number: 35500029B24F3854A112
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 402 306 17
   Serial number: 35600029B24F3855F119
   Part No SW: 8V0 953 521 KK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 17071704400386
   Coding: 2018
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 0D1A78ADDC3C8242C7F-8058
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 890 A    HW: 8V0 920 890 A
   Component: FBenUSA       H16 0066
   Coding: 086D18533B80CF050204EC045800001000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001027
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 3B7EE675B2087CF2A9B-806E
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 GW MQB High   518 53045304
   Serial number: 27061710803012
   Coding: 03010004340860005B00802EB80B00000001010000000000000000000000
   ROD: N/A
   VCID: 336ECE559A58B4B271B-8066
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20170726152456 22093
   Subsystem 3 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
   Serial number: 9960034404
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7762
   Serial number: HA1-00009.06.17
   Coding: 0601
   VCID: 4D9AB8AD1CBCC24207F-8018
   Revision: 00000000    Serial number: 17000203468008
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 346CCD499F56B38A681-8060
Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 F    HW: 3Q0 907 566
   Component: MRR1Rear      H21 0610
   Revision: --------
   Coding: 040002
729349 - Control Module for Lane Change Assistance
          C1114 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 108
                    Mileage: 4572 km
                    Date: 2017.12.02
                    Time: 13:26:21
                    Control Module temperature: 19 ∞C
                    Voltage terminal 30: Measured value not available
                    Vehicle speed: 0.00 km/h
                    Terminal 15 status: Measured value not available
                    Voltage terminal 15: 12.00 V
729605 - Control Module 2 for Lane Change Assistance
          C1115 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 108
                    Mileage: 4572 km
                    Date: 2017.12.02
                    Time: 13:26:21
   Serial number: 240517EEO19082
   Coding: 005D1B205C00048000000002
   VCID: 438E9E95CAF80432E1B-8016
   Coding: 8106
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A70E371BD3245FAB2D-806E
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAH5F00MJ1Z
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 244C3D092FB6230AF81-8070
   Serial number: 300617EFT39127
   Coding: 005D13205E00048000000002
   VCID: 42809B91D5E20D3AEAD-8016
   Part No SW: 8V1 035 880 B    HW: 8V1 035 880
   Component: MU-P-LNS-US   054 1110
   Serial number: A702H0H2502424
   Coding: 017361020000000011220002041A00102F0028E5017001047E
   Subsystem 2 - Part No SW: -----------    HW: -----------
   Component: -------------  --- ----
   Subsystem 3 - Part No SW: -----------    HW: -----------
   Subsystem 4 - Part No SW: V03 959 801 GH    HW: -----------
   Component: NAR 2017/2018  --- 0060
   Subsystem 7 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
   Component: DU High  H49 0014
   Serial number: AUZ8Z9H1Y04NFT
   Subsystem 8 - Part No SW: -----------    HW: -----------
   Subsystem 9 - Part No SW: -----------    HW: -----------
   Subsystem 12 - Part No SW: -----------    HW: -----------
   Subsystem 13 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL125051700050683
   Subsystem 14 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 3012
   Subsystem 15 - Part No SW: -----------    HW: -----------
   Coding: 0273010102002001400040
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW41.rod
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 200617EFK03358
   Coding: 000C13204000048000000002
   Serial number: 200617EFK03351
End-------------------------(Elapsed Time: 07:30)--------------------------
Gateway Installation List:  3Q0 907 530 G
Scan with replacment Module
Friday,02,February,2018,15:48:19:62266
VCDS Version: 18.1.0.2 (x64)  HEX-NET CB: 0.4411.4
VIN: WUABWHFF7J1901625   License Plate:
Mileage: 5243km-3257mi   Repair Order:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 29 2B 39 3C 42 44 47
          4B 52 5F 6C BB BC CF D6 D7
VIN: WUABWHFF7J1901625   Mileage: 5243km-3257miles
Address 01: Engine (------DAZA)       Labels:. 07K-907-309-V1.clb
   Revision: 53H22000
   VCID: 3D32D149AC8294AD9E-8068
Readiness: 0000 0100
   Revision: 00H06V07
   VCID: 2E10E60571E47F3517-807A
   ROD: EV_Brake1UDSContiMK100IPB_070.rod
   VCID: 393AC559B8AAA88DB2-806C
   Coding: 030C0C
   VCID: 3C34DC4DB7989DA5A9-8068
   VCID: 40CCA8BDDB70F945F5-8014
   VCID: 06407EA5B9D417758F-8052
   Coding: 0A47F7
   Coding: 00006C
   Light switch:
   Sun Roof:
   Coding: 101F00
   Coding: 0470155051
   VCID: 4BD68F91E2362A1D10-801E
   VCID: 45C2B9A9C452DC6DC6-8010
   VCID: 47DEB3A1FE5ECE7D34-8012
   Coding: 333135
   Coding: 333135
   Occupant Detection:
   Coding: 303337
   Coding: 2018
   VCID: 0D524189DCA2642DCE-8058
   VCID: 3B36DF51B2969A9DA0-806E
   Component: GW MQB High   518 5304
   ROD: EV_GatewNF_VW48.rod
   VCID: 3326F7719AC652DD78-8066
   Coding: 0601
   VCID: 4DD281891C22242D0E-8018
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H06 0017
   ASAM Dataset: EV_LCMLeftCONTIAU426 001009
   ROD: EV_LCMLeftCONTIAU426_VW41.rod
   VCID: 42C8A2B5D57CEB55E3-8016
   VCID: 3424F46D9FC855E561-8060
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   ASAM Dataset: EV_LCMRightCONTIAU426 001009
   Revision: --------
   Coding: 040002
   Shop #: WSC 55313 001 1048576
   VCID: 43C6A7B1CA66E25DE8-8016
   Coding: 8106
   VCID: 3A38DA55BDACA395BB-806E
   VCID: 2404042D2F28C565F1-8070
   Serial number: 26061710523223
   Coding: 000000050100143206112300040000000000000000000000000000000000
   VCID: 72A83275A55C1BD5B3-8026
Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
   Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 590 F    HW: 3Q0 907 590
   Revision: --------
   Coding: 040002
   VCID: 383CC05D83A0B1854D-806C
   Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
   Component: LED1L         H09 0008
   VCID: 177E23E1EE7E9EFD64-8042
   Component: LED1R         H09 0008
End----------(Elapsed Time: 02:03, VBatt start/end: 12.1V/12.1V)-----------
                Address 3C: Lane Change       Labels: 3Q0-907-566.CLB
Control Module Part Number: 3Q0 907 566 F    HW: 3Q0 907 566
  Component and/or Version: MRR1Rear      H21 0610
           Software Coding: 040002
            Work Shop Code: WSC 55313 001 1048576
              ASAM Dataset: EV_RearRadarS1BoschVW48X 001007 (AU37)
hadez16
C?ID=289891
There is an adaptation channel in unit 3C. It should be named something like "Brightness level of warning indicator" or something.
Check out the options you have there.
thedru13
C?ID=67849
I will check it out. I am a bit hesistant to mess around with the 3c module since the last time I made a change it blew the module.
Should be:
IDE05394 - Brightness characteristic of warning display.
( Bright, Dark, Normal, Very bright, Very dark)
thedru13
C?ID=67849
Thaks Uwe... Do you happen to know if this will enable me to adjut it via the MMI? Used to have that option but no longer have it.
Should be:
No, I do not know.
thedru13
C?ID=67849
Will adjust via vagcom from what you posted above. thanks again for the help. fingers crossed I don't mess it up lol
No, I do not know.
hadez16
C?ID=289891
Is this a Sedan or a Hatchback?
He's in the US, so it's a sedan.
The only hatchback / sportback 8V car in this market is the e-tron.
thedru13
C?ID=67849
Uwe is correct. US 2018 RS3 Sedan.
thedru13
C?ID=67849
