Sunday,18,February,2018,13:23:29:14785
VCDS Version: 18.1.0.2 (x64)
VIN: WV1ZZZ2KZDX001929 License Plate: DL12
Mileage: 85650km-53220mi Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WV1ZZZ2KZDX001929 Mileage: 85650km-53220miles
Address 01: Engine (J623-CAYD) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 PC HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 0869
Revision: --H43--- Serial number: 00000000000000
Coding: 00114014030500080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023PC 003002
ROD: EV_ECM16TDI02103L906023PA.rod
VCID: 76E45BF6C9FEFCF59F-8022
Readiness: 0100 0000
Part No SW: 1K0 907 379 BK HW: 1K0 907 379 BK
Revision: 00H31001
Coding: 433C400D092203FBC21402E69022C081300000
Shop #: WSC 35110 377 08192
VCID: 7CF049DEFFD2A6A5E9-8028
Fault Status: 00101110
Reset counter: 67
Mileage: 85652 km
Date: 2012.07.10
Time: 16:53:14
Count: 3
Count: 2
Count: 4608
Count: 292
Count: 44288
Count: 64768
Part No SW: 7N0 907 426 BG HW: 7N0 907 426 BG
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010004002
ROD: EV_ACManueBHBVW36X_VW32.rod
VCID: 7AFC4FC6FDE69895FB-802E
Part No SW: 5K0 937 085 R HW: 5K0 937 085 R
Component: BCM PQ35 B+ 021 0068
Revision: BB021001
Coding: 411A583A8025186A088000829000006403017288524F8160648000000040
VCID: 428CF726DDB61055E3-8016
Subsystem 1 - Part No: 1T2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 07051 26 0512
Coding: 009795
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag02A H07 0013
Revision: -------- Serial number: 003HL00BW1XW
Coding: 000000000000000000000000000000003241
VCID: 35669CFA9478B7ED56-8060
Part No SW: 5K0 953 507 AR HW: 5K0 953 549 C
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422LEF001FS
Coding: 1080060000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 00083D2E9B3AC245B5-8054
Part No SW: 2K0 920 965 G HW: 2K0 920 965 G
Component: KOMBI H05 0705
Coding: 480001
VCID: 3362A2E29A0CA9DD78-8066
Part No SW: 7N0 907 530 R HW: 7N0 907 530 H
Component: J533 Gateway H42 1632
Revision: H42 Serial number: 140512F2001155
Coding: 357401
VCID: 3F8AFED2AE447DBD8C-806A
Component: IMMO H05 0705
VCID: 6ADC7F868D4628150B-803E
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2110
Coding: 0000560
VCID: 4898E50E3B8A3A053D-801C
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 140 3305
Revision: 00H22000
VCID: 377A96F2467445FD44-8062
16372 - Control Module; Unspecified Internal Error
Fault Status: 00101010
Voltage: 12.63 V
PD
Temperature: 12.0癈
Error Code: 721
Error Code: 984
Error Code: 23
Error Code: 23
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 12.6 V
PD
Temperature: 9.0癈
Count: 2
Steering Angle: 0.00?
Count: 1
SteerAng n.Init
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000560
VCID: 479AE6323694357D34-8012
Part No SW: 5K0 035 156 A HW: 5K0 035 156 A
Component: Radio H42 0105
Revision: R0000000 Serial number: VWZAZ1M2178178
Coding: 0500020001
VCID: 25464CBA2CD8C76DE6-8070
Hi looking for some advise with this vw caddy that has a intermittent problem with the power steering not working, red steering light on and rock hard steering, sometimes you can clear codes and the steering will return to normal, you can drive for a few miles fine but when you switch off and come back awhile later the problem returns.
The fault code i'm having trouble with is the 16372 I can't find any good info for this.
Is this the control module on the steering rack itself?
Wiring diagram shows a 80a fused wire to the electric motor and a ground point behind the left headlamp.
A 3 pin plug with can bus high and can bus low and also a 15a fused switched feed. Is this wire the power for the module I guess it is? I've done a good wiggle test on the wiring to see if I can get it to drop out but my test light stays bright. Could this be an internal short/open in the module also causing the other fault codes. I know you can't change the steering angle sensor on these the whole rack has to be swapped out so I need to make the right call.
Thanks in advance
