Passat CC 2011 BCM J689 J519
Dudi_1981
C?ID=252840
Hi, I spent 2 days to find a place for J689 and it looks like it fit inside in J519.
Could someone more experienced onfirm this?
The problem is that the power of the pin for internal light is only 9 volts
Thank You
iichel
Netherlands, eastern part
C?ID=284912
Terminal 30 voltage supply relay 2 -J689
B4 on onboard supply control unit
Dudi_1981
C?ID=252840
Thanks IIchel but my car is 2011 ,after 2010 they change BCM
iichel
C?ID=284912
Can you show a VCDS autoscan so it's visible what parts are fitted?
Dudi_1981
C?ID=252840
 Monday,29,January,2018,10:00:19:08366
VCDS Version: 18.1.0.2 (x64)
Dealer/Shop Name: Duda-Garage
Workshop Code: 000 15042 150421
VIN: WVWZZZ3CZBE750604   License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56
          61 62 72 77
VIN: WVWZZZ3CZBE750604   Mileage: 154670km-96107miles
   Part No SW: 03L 906 018 BF    HW: 03L 907 309 N
   Component: R4 2,0L EDC   H24 7852
   Revision: 41H24---    Serial number: VWZCZ000000000
   Coding: 00190012042501080000
   Shop #: WSC 00450 210 91475
   ASAM Dataset: EV_ECM20TDI01103L906018BF 003005
   ROD: EV_ECM20TDI01103L906018BF.rod
   VCID: 6FEA75A0B6BDA23D5C-803A
   Part No SW: 3AA 614 109 N    HW: 3AA 614 109 N
   Component: J104   C2 450M VDE4 0005
   Revision: --H07---    Serial number: 00000003885897
   Coding: 0004016
   Shop #: WSC 05311 000 00000
   VCID: 38788EFC4B7325854D-806C
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000003
   Shop #: WSC 00015 115 00000
   VCID: 6ED468A4B1B7AB3557-803A
   Part No SW: 3AA 937 087 B    HW: 3AA 937 087 B
   Component: BCM PQ47 H+   413 0452
   Revision: BC413001
   Coding: 0000000000000000009800209400802443517788406005600080C7200041
   VCID: 397E8BF8B0793C8DB2-806C
   Subsystem 1 - Part No SW: 3C8 955 119 E    HW: 3C8 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 08011  10  0603
   Coding: 00B795
   Component: RLS 090311 05  54  0403
   Coding: 0330ED
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475     HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0009
   Revision: --------    Serial number: 28291104820152
   Coding: 108003
   ASAM Dataset: EV_EPHVA18VW47X0000 001003
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 7CF052ECF7CBC9A5E9-8028
   Revision: 00000000    Serial number: 22021101870002
   Coding: 010180
   Shop #: WSC 05314 000 00000
   VCID: 275A5D8056CDBA7DD4-8072
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__306 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0P4486RB
   Coding: 0012342
   VCID: 4C90C22C2FEBB92519-8018
   Subsystem 1 - Serial number: 6332MTS676650401
   Subsystem 2 - Serial number: 6342MTS677520401
   Subsystem 3 - Serial number: 6351HTS633SHP9KR
   Subsystem 4 - Serial number: 6361HTS6K08HP9KR
   Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
   Revision: FF010040    Serial number: 20110228300610
   Coding: 018A270000
   VCID: 72EC7CD4A58F8FD5B3-8026
   Coding: E20000
   Part No SW: 3C8 920 970 P    HW: 3C8 920 970 P
   Component: KOMBI         H20 0420
   Coding: 440F01
   Shop #: WSC 05314 115 00000
   VCID: 397E8BF8B8793C8DB2-806C
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 160211F2001798
   Coding: 469007
   VCID: 316EB3D86809F4CD0A-8064
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0400
   VCID: 76E440C401E793F59F-8022
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Component: SG EXT.PLAYER H13 0150
   Revision: A1001003    Serial number: 7669569251
   VCID: 28585EBC5BD3B505DD-807C
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
   Component: RNS-MID       H50 2850
   Revision: AB001001    Serial number: VWZ6Z7L7066019
   Coding: 04000402040000A000
   Shop #: WSC 62085 001 1048576
   VCID: 2E54A8A47937EB3517-807A
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0502
   Revision: 12110009    Serial number: 0002382098
   Coding: 0202B5
   Shop #: WSC 05311 115 00000
   VCID: 6DD66FA8BCB1502D6E-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 704 C    HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0401
   Serial number: 00000001991048
   Coding: 000090
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 207    3201
   Revision: 00H20000
   VCID: 3460BACC571BC1E561-8060
   Component:    KSG PQ47 ELV 043 0631
   Coding: 01910A0001860E763604941570085FCE107C01
   Subsystem 1 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HORN H11 9005
   Component: EZE_2         H35 0614
   Coding: 00000008
   VCID: 6FEA75A0BEBDA23D5C-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0502
   Revision: 14110009    Serial number: 0002387252
   Coding: 0202B4
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 703 C    HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0401
   Serial number: 00000001956150
   Coding: 000090
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000226809
   Coding: 0022067
   VCID: 3362B9D05215C6DD78-8066
   Component: Batt.regelung H35 0614
   Coding: 030B185A
   VCID: 71EE73D8A889B4CD4A-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370724457
   Part No SW: 7P6 035 730 B    HW: 7P6 035 730 B
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007669527168
   Coding: 0A01000000010101
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 316EB3D86009F4CD0A-8064
End-------------------------(Elapsed Time: 03:42)--------------------------
Dudi_1981
C?ID=252840
So no one know how read ELSA ?
iichel
C?ID=284912
of course we know.
ELSA info
Passat model year B CFFB engine:
your BCM from Google:
So somehow ELSA is not consistent with your BCM. There should be some wiring in ELSA instead of the direct plug into the BCM.
Either that or the J689 is directly into the PCB of your BCM. in that case you cannot fit it or replace it.
Dudi_1981
C?ID=252840
I already replace J519 for second hand one but still same problem . Voltage drop to 9 volt scene you turn on any interior light . There is no resist on wiring to light or short to ground .
iichel
C?ID=284912
OK voltage drop under load could indicate bad fuse, dodgy connector or broken wire. did you measure at the light or at T52b/43
Dudi_1981
C?ID=252840
I take pin out from plug and supply power direct from battery and works 100% fine , take about 1,6 amp . I think the problem is in J689 but where ...?
iichel
C?ID=284912
and if I understand it correctly, it shows this behaviour both with the original BCM and a another second hand BCM?
Dudi_1981
C?ID=252840
Yes , on both same . The other one was second hand so you never know.... but hard to believe both with same fault .
eng.mfr
Middle East
C?ID=317341
Im have polo 2005 1.4l when it walke some times engine off im check it by vcds no code fuelt
Dudi_1981
C?ID=252840
Sorted other way but working 2 weeks now without any problems .
Regards
