Friday,26,January,2018,19:50:01:36667
VCDS Version: 18.1.0.2
VIN: WVWGD71K19W106933 License Plate:
Mileage: 169600km-105384mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 62 72
VIN: WVWGD71K19W106933 Mileage: 169600km-105384miles
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AF HW: 1K0 907 115 AD
Component: 2.0l R4/4V TFSI 0010
Revision: E3H13--- Serial number: VWX7Z0H83N483G
Coding: 0403010818070160
Shop #: WSC 61394 001 1048576
VCID: 6AD0082345F0D2150B-803E
000769 - Cylinder 1
P0301 - 000 - Misfire Detected
Mileage: 169609 km
Time: 19:17:15
RPM: 766 /min
Load: 17.2 %
Temperature: 96.0°C
Temperature: 39.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.970 V
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0109
Revision: 00H45001
Coding: 113B600D49220000881406E7921C00413400
Shop #: WSC 49915 001 104857
VCID: 7EF83473E9784EB5C7-802A
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
VCID: 78F4226B0B5C70858D-802C
Revision: 00H54000 Serial number: 00000008792528
Coding: 078C8F214004150047140000001400000068770B5C000100000000000000
Shop #: WSC 12345 785 00200
VCID: 336ED54752BA53DD78-8066
Component: Wischer 220808 021 0501
Coding: 00038805
Shop #: WSC 12345
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0382049
Coding: 0000100
Reset counter: 121
Mileage: 169557 km
Time: 22:36:06
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0BVT5N
Coding: 0013899
VCID: 6CDC0E3B4F04CC2579-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME3F012E06C
Subsystem 3 - Serial number: 6342MSME3F555621E
Subsystem 4 - Serial number: 6352QSME78642535H
Subsystem 5 - Serial number: 6362QSME7C084506K
Subsystem 6 - Serial number: 63727SME18142871Z
Subsystem 7 - Serial number: 63827SME18135B51$
Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP
Component: J0527 051 0101
Coding: 0002022
VCID: 01024F8F5886314DBA-8054
Component: E0221 002 0010
Part No SW: 1K6 920 974 H HW: 1K6 920 974 H
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0003000 Serial number: VWX7Z0H83N483G
Coding: 0001403
Shop #: WSC 00000 785 00200
VCID: 3972E76F70D6A98DB2-806C
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 220808F2000564
Coding: E9817F060013020002
VCID: 356AEB5F5CCE4DED56-8060
Mileage: 169609 km
Time: 19:15:32
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T44G203
VCID: 7DFA337F247E55ADDE-8028
Component: IMMO VDD 2416
Address 42: Door Elect, Driver Labels: None
Part No SW: 1K0 959 701 AK HW: 1K0 959 701 AK
Component: Tuer-SG 006 1203
Coding: 0001205
VCID: 77F6215706427FFD84-8022
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Shop #: WSC 00000 028 00001
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 13900C885103003F2D02058FB0080F0488FE00
VCID: 040C469B4794246591-8050
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Component: Tuer-SG 006 1219
Coding: 0001204
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74EC165B173414E5A1-8020
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio PM6 019 0037
Revision: 00019000 Serial number: VWZ5Z7H2255685
Coding: 0040421
VCID: 2952372F8076190DC2-807C
Reset counter: 121
Mileage: 169557 km
Time: 22:36:05
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1302
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 3874E26B4BDCB0854D-806C
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Component: Tuer-SG 006 1305
Coding: 0001168
End-------------------------(Elapsed Time: 02:10)--------------------------
