Long coding decrypting.
Bones21
Pirate
Walking the Plank
LP/IP
Hi guys New to this. My original control module part No. 1K0907379AD failed and so replaced it with 1K0907379AN. There's no long coding on the module just zeros and the helper says limited info in this controller. what info do I need to to come up with the code? Any help would be greatly appreciated thanks.
PetrolDave
Westbury, UK
C?ID=1423
First thing is to post a VCDS Auto-Scan with the current module fitted, and if you have one with the previous module fitted as well that would help.
Bones21
Pirate
Walking the Plank
LP/IP
Ok thanks will do.
Bones21
Pirate
Walking the Plank
LP/IP
Removed.   Data from a clone/pirate copy of VCDS is not welcome here.
Bones21
Pirate
Walking the Plank
LP/IP
This the scan with the old module.
downtime
C?ID=280813
Have you tried just inputting the old ABS coding to new module? They're same generation and so close to each other in product code that it should go in without problems.
Bones21
Pirate
Walking the Plank
LP/IP
This is with the new module on.
Bones21
Pirate
Walking the Plank
LP/IP
Yes I tried just said code rejected out of range
Yeah man crap out........
downtime
C?ID=280813
Hah, fooled me. I looked that the SW version is 17.8.0.1 so thought new enough and fine.
