Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
Mileage: 278760km-173213miles
Address 01: Engine Labels: None
Part No SW: 06F 906 056 DC HW: Hardware No
Component: MED9.5.10 00 6103
Revision: 00000000 Serial number: SKZ7Z0D2774453
Coding: 0000072
Shop #: WSC 00073 001 13516
VCID: 6DD7707B74D3CE2E4A-8038
18048 - Internal Control Module
P1640 - 008 - EEPROM Error - MIL ON
16535 - Oxygen (Lambda) Sensor B2 S1
P0151 - 002 - Signal too Low
16414 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0030 - 004 - Malfunction / Open Circuit - MIL ON
16575 - Fuel Pressure Sensor (G247)
P0191 - 002 - Implausible Signal - Intermittent
Readiness: 0110 0000
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0021638
Shop #: WSC 06435 000 00000
VCID: 3A7D8B27751DA9969F-806E
Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
Component: KlimavollautomatH12 0150
Revision: 067865 Serial number: 8P0820043D
VCID: 2D57B07BB4530E2E0A-8078
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 62
Mileage: 278279 km
Date: 2016.09.01
Time: 15:21:09
01810 - Actuating Motor for Temperature Flap; Right (V159)
Fault Status: 00100011
Reset counter: 110
Mileage: 278196 km
Date: 2016.08.20
Time: 10:56:27
Voltage: 13.90 V
Temperature: 27.5°C
(no units): 24.0
(no units): 37.0
Temperature: -50.0°C
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-B.lbl
Part No SW: 8P0 907 279 HW: 8P0 907 279 *
Component: Bordnetz-SG 1.0 H30 0501
Revision: 00030000 Serial number: 00000000853158
Coding: 008C4F00A0141000000000000000000000
VCID: 7AFD4B27359D6996DF-802E
Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0180
Coding: 16187408
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 E HW: 8P0 959 655 E
Component: Airbag 8.4EDmin H00 0140
Coding: 0010102
VCID: 4481F5DF07D9EF66F5-8010
Part No SW: 1K0 953 549 HW: 1K0 953 549
Component: Lenksäulenmodul 012 0030
VCID: 6FEB6A737EDF3C3E78-803A
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 900 G HW: 8P0 920 900 G
Component: KOMBIINSTR. VDO H71 0210
Revision: D02 Serial number: 1246DD02000043
Coding: 0004808
Shop #: WSC 03335 996 94201
VCID: 3363A603527758DE5C-8066
010 - Open or Short to Plus
Fault Status: 00000011
Reset counter: 76
Mileage: 278767 km
Date: 2016.11.01
Time: 10:23:17
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 25001046230740
Coding: 3D0F0342070101
Shop #: WSC 06435 123 12345
VCID: 2859416F9BB12B06F9-807C
01304 - Radio
Reset counter: 76
Mileage: 278767 km
Date: 2016.11.01
Time: 10:23:23
Revision: D02 Serial number: AUX7Z0D6FN60FK
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 E
Component: Tuersteuerger. H10 0030
Coding: 0000016
VCID: 3D77803B64339EAEBA-8068
Part No: 1K2 909 144 G
Component: EPS_ZFLS Kl.9 1301
VCID: 3069A90FA36163C621-8064
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 198000186D280F0F489AC67000
VCID: 79FF542B309B628ED6-802C
Subsystem 1 - Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Subsystem 2 - Part No: 1K0 907 719
Component: Neigungssensor 003 0003
Component: Innenraumueberw.H03 0010
00352 - Terminal 30A
01134 - Alarm Horn (H12)
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH25 0160
Revision: 00003 Serial number: 10000001144283
VCID: 70E9690F63E123C661-8024
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 E
Coding: 0000016
VCID: 3E758737693585B6A3-806A
Address 56: Radio
End-------------------------(Elapsed Time: 01:43)--------------------------
