Hello everyone, this is my first post as well as my first time using the Hex-Net VCDS. Prior I have always used my Snap On Modis Ultra, but for my Audi, the Hex-Net is a far superior product! I have a 2004 A8L and didn't realize my sunroof leaked until after returning from out of town my center console cupholders were full of water. The car started and everything seemed fine until I noticed that there was no response from any buttons on the MMI control panel. When I returned home I pulled out the entire panel and let it dry, then cleaned up any residue with alcohol. I reinstalled it and still the same, no buttons worked and stayed lit even when the car was not running. Like a fool I disconnected the battery and have not been able to correct the blinking red Brake light, other then by removing the 2 30Amp fuses in the trunk so I could at least drive it without the ear piercing sound from the parking brake warning. So I bought a used control panel from Ebay. I confirmed it was the same part number as my original one. I installed it and everything except the "Car" and "Return" buttons work. I took it back out and disassembled it to see if there was a physical issue with the buttons. The gel pad is good and the buttons are pressing down the contacts on the circuit board, so there seems to be no physical issue with the buttons. I searched through the posts and saw there were a few others that had issues with the "Car" button but the thread seemed to end with no solution due to no input from the person who posted the issue.
Anyones help would be very much appreciated and please keep in mind I am still getting familiar with the Hex-Net. Below are the results from the scan I ran.
Problem: The Car and Return buttons do not work on the MMI control.
Wednesday,17,January,2018,12:07:38:18320
VCDS Version: 17.8.1.0 (x64) HEX-NET CB: 0.4409.4
VIN: WAUML44E04N016226 License Plate:
Mileage: 228950km-142262mi Repair Order:
Gateway Installation List: 4E0 910 468 A
16-Steering wheel -- Status: Sporadic communication error 1000
53-Parking Brake -- Status: Malfunction 1010
65-Tire Pressure -- Status: Sporadic communication error 1000
75-Telematics -- Status: Malfunction 1010
76-Park Assist -- Status: Sporadic communication error 1000
Wednesday,17,January,2018,13:14:26:18320
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E04N016226 Mileage: 228950km-142262miles
65-Tire Pressure -- Status: Malfunction 1010
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0CD530002
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 9F0E8FB34EFACCBE08-80CA
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Readiness: 0110 1101
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0025894
VCID: A404805F679CEF6655-80F0
18290 - Powertrain Data Bus
P1882 - 000 - Missing Message from Electric Parking Brake Controller - Intermittent
RPM: 1664 /min
RPM: 1440 /min
(no units): 30.0
(no units): 32.0
Temperature: 33.0∞C
T.B. Angle: 0.0∞
Voltage: 10.72 V
Part No SW: 4E0 910 517 B HW: 4E0 614 517 N
Component: ESP 5.7 allrad H44 0500
Coding: 0007597
Shop #: WSC 01507 000 00000
VCID: A20886477D88E15627-80F6
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 C
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0CD530002
Coding: 0263168
Shop #: WSC 01507 444 94845
VCID: D8FCE4AF6B547B8609-808C
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
Shop #: WSC 00000 785 00200
VCID: A30683436292E85E2C-80F6
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 729 J HW: 4E0 035 729
Component: Interfacebox H43 0600
Revision: 00000000 Serial number: 346LW037508228
Coding: 0000103
Shop #: WSC 08212 444 58910
VCID: AF2E7F733E5A5C3EB8-80FA
Subsystem 1 - Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
Subsystem 2 - Serial number: 301JT037528099
Subsystem 3 - Serial number: 7427.10.030000000000010018ˇ
Subsystem 4 - Serial number: 010018ˇ
Part No SW: 4E0 910 043 HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0240
Revision: 00000022 Serial number: 00000000031788
Coding: 1085761
Shop #: WSC 02311 785 00200
VCID: DAF8FEA7155869963F-808E
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO27112003065A000000000014ˇÜ89
Subsystem 5 - Serial number: 000014ˇÜ898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO27112003065A00000000
Subsystem 7 - Serial number: 65A000000000011ˇ
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 S HW: 4E0 907 279 S
Component: ILM Fahrer H16 0240
Coding: 0111003
Shop #: WSC 01507 551 00000
VCID: B83C442FCB149B86E9-80EC
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000036
Shop #: WSC 01507
Reset counter: 228
Mileage: 227449 km
Date: 2017.12.30
Time: 12:44:35
Part No SW: 4E0 910 111 C HW: 4E0 035 111
Component: CD-Changer H43 0340
Revision: 00000501 Serial number: AUZ5ZBC1028903
VCID: 997AA1AB50DEA28EF6-80CC
Address 0F: Digital Radio Labels: None
VCID: D5E2ED9B3C4646EE12-8080
No Faults Found
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenks‰ulenmodul H13 0040
Coding: 0012241
VCID: E582DD5B2C26D66E82-80B0
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H44 0090
Revision: D14 Serial number: AUDID3CD005137
Coding: 0016233
Shop #: WSC 10722 067 57207
VCID: DCF4F8BF1F6C97A62D-8088
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0030
Revision: 07 Serial number: 0200503B200FD2
Coding: FCFE7BDD1B2B04
Shop #: WSC 08212 444 01171
VCID: A6009A5711A01D764B-80F2
Fault Frequency: 114
Reset counter: 7
Mileage: 227015 km
Date: 2017.12.23
Time: 22:36:14
Reset counter: 228
Mileage: 227449 km
Date: 2017.12.30
Time: 12:41:27
01327 - Control Module for Parking Aid (J446)
Reset counter: 228
Mileage: 227449 km
Date: 2017.12.30
Time: 12:44:19
Reset counter: 228
Mileage: 227449 km
Date: 2017.12.30
Time: 12:44:35
00465 - Control Module for Telephone/Telematic (J526)
Reset counter: 228
Mileage: 227449 km
Date: 2017.12.30
Time: 12:44:46
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: A5029D5B6CA6166E42-80F0
Reset counter: 228
Mileage: 227449 km
Date: 2018.01.01
Time: 21:36:57
Component: Sitzmemory FS H07 0060
Coding: 4071522
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H42 1100
Revision: 00000000 Serial number: 355LL037511421
02261 - Data Medium
Fault Status: 00101110
Fault Frequency: 127
Reset counter: 9
Mileage: 227008 km
Date: 2017.12.23
Time: 15:38:20
Hex Value: 0x5A5D
Hex Value: 0xA49D
Hex Value: 0x0F00
Hex Value: 0xD7F9
00862 - Antenna for GPS Navigation (R50/R52)
Fault Status: 00101011
Reset counter: 250
Mileage: 227795 km
Date: 2018.01.08
Time: 14:46:58
03183 - Data Media not Compatible
Fault Frequency: 255
Reset counter: 8
Mileage: 227008 km
Date: 2017.12.23
Time: 15:57:21
Hex Value: 0x5A5D
Hex Value: 0x4B88
Hex Value: 0x0000
Hex Value: 0x9494
02927 - DVD Read Error
Reset counter: 235
Mileage: 227015 km
Date: 2017.12.23
Time: 17:39:34
Hex Value: 0x5A4D
Hex Value: 0xA1E6
Hex Value: 0x04FF
Hex Value: 0x0000
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H01 0090
Serial number: 00000331000106
Coding: 0003861
Shop #: WSC 01507 444 100073
VCID: 9D72B5BB44F6DEAE1A-80C8
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: T¸rsteuer.FS BRM005 0110
Coding: 0028196
VCID: DEF0F2B7097085B643-808A
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H08 0020
Revision: 00200008 Serial number: W040705230243
Coding: 0065086
Shop #: WSC 08252 444 54597
VCID: AA186E6705B839166F-80FE
Component: Heckdeckel H06 0060
Component: Neigungssensor H02 0020
01134 - Alarm Horn (H12)
Reset counter: 223
Mileage: 213870 km
Date: 2017.03.10
Time: 21:31:57
01828 - Bulb for Tail-Lamp; Left
Fault Status: 00101001
Reset counter: 228
Mileage: 227449 km
Date: 2017.12.30
Time: 12:25:00
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 H HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0370
Revision: Dev_D01 Serial number: 00000000602542
Coding: 0000016
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H08 0020
Revision: Serial number: 00000000029037
Coding: 0010111
VCID: 9E70B2B749F0C5B603-80CA
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T09XVE
Reset counter: 228
Mileage: 227448 km
Date: 2017.12.30
Time: 12:44:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: T¸rsteuer.BF BRM005 0110
Coding: 0028196
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
Shop #: WSC 01507 067 57207
02433 - Supply Voltage for Right Parking Brake Motor (V283)
012 - Electrical Fault in Circuit - MIL ON
Fault Status: 11111100
Fault Frequency: 35
Reset counter: 60
Mileage: 218344 km
Date: 2017.07.31
Time: 12:49:13
Voltage: 12.53 V
Count: 87
02596 - Rear Brake Pads Worn
Fault Status: 01111000
Reset counter: 181
Mileage: 227000 km
Date: 2017.12.23
Time: 14:35:55
Voltage: 10.56 V
Count: 61
02432 - Supply Voltage for Left Parking Brake Motor (V282)
Reset counter: 181
Mileage: 227000 km
Date: 2017.12.23
Time: 14:35:55
Voltage: 10.56 V
Count: 86
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
VCID: E288C6473D08A15667-80B6
Part No SW: 4E0 910 541 C HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 304LT037553861
VCID: A00C8C4F7384F34631-80F4
00856 - Radio Antenna
Reset counter: 128
Mileage: 172561 km
Date: 2016.02.08
Time: 12:06:04
Reset counter: 128
Mileage: 172561 km
Date: 2016.02.08
Time: 12:06:04
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 A HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0230
Revision: 00000000 Serial number: 00000005570579
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 1311070471
Coding: 303030393135313035414B56413031333131303730343731
Shop #: WSC 00000 128 00289
02256 - Quiescent Current
Fault Status: 00100001
Reset counter: 9
Mileage: 228958 km
Date: 2018.01.16
Time: 13:25:22
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: T¸rsteuer.HL BRM005 0110
Coding: 0028196
VCID: DDF2F5BB04769EAE5A-8088
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
Shop #: WSC 02445 823 56289
VCID: DF8ECFB30E7A8CBE48-808A
01467 - Front Left Tire Pressure Sensor (G222)
Fault Status: 11100100
Fault Frequency: 29
Reset counter: 224
Mileage: 228958 km
Date: 2018.01.17
Time: 12:48:44
Voltage: 11.00 V
(no units): 46.0
Temperature: 11.0∞C
Temperature: 10.0∞C
Temperature: 9.0∞C
Temperature: 9.0∞C
01468 - Front Right Tire Pressure Sensor (G223)
Fault Frequency: 29
Reset counter: 224
Mileage: 228958 km
Date: 2018.01.17
Time: 12:48:45
Voltage: 11.00 V
(no units): 49.0
Temperature: 11.0∞C
Temperature: 10.0∞C
Temperature: 9.0∞C
Temperature: 9.0∞C
01469 - Rear Left Tire Pressure Sensor (G224)
Fault Frequency: 29
Reset counter: 224
Mileage: 228958 km
Date: 2018.01.17
Time: 12:48:45
Voltage: 11.20 V
(no units): 52.0
Temperature: 11.0∞C
Temperature: 10.0∞C
Temperature: 9.0∞C
Temperature: 9.0∞C
01470 - Rear Right Tire Pressure Sensor (G225)
Fault Frequency: 28
Reset counter: 224
Mileage: 228958 km
Date: 2018.01.17
Time: 12:48:46
Voltage: 11.00 V
(no units): 55.0
Temperature: 11.0∞C
Temperature: 10.0∞C
Temperature: 9.0∞C
Temperature: 9.0∞C
02214 - Tire Pressure Warning
Reset counter: 225
Mileage: 227237 km
Date: 2017.12.29
Time: 09:22:43
Temperature: 2.0∞C
Error Code: 1
Pressure: 1.57 bar
Pressure: 2.30 bar
Pressure: 2.30 bar
Pressure: 1.90 bar
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: T¸rsteuer.HR BRM005 0110
Coding: 0028196
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616 A
Component: Telematik USA1 0070
Revision: 00000004 Serial number: 0000ATD3006511
Coding: 0000005
VCID: E08CCC4F3204B34671-513C
01531 - Emergency Battery
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H11 0010
Revision: --.--.-- Serial number: 00000333700246
Coding: 0001208
VCID: A10A894B788EFA4E3E-80F4
End----(Elapsed Time: 06:49, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
