Here is a scan of my vehicle. Had 639 miles at time of scan (which was yesterday). Will make another post with mods applied
Monday,15,January,2018,15:47:31:17061
VCDS Version: 17.8.1.0 (x64) HEX-V2 CB: 0.4409.4
VIN: 1V2LR2CA7JC540981 License Plate:
Mileage: 639 Repair Order:
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 22 2B 3C 42 44 4B 52 5F 69
6C 6D 75 A5 D6 D7
Address 01: Engine (0-32-CDVC) Labels: None
Part No SW: 03H 906 026 F HW: 03H 907 309 K
Component: VR6 3.6l FSI H21 4745
Revision: 52H21000
Coding: 012A001244740108F0000000000000000000000000000000
Shop #: WSC 09003 957 00200
ASAM Dataset: EV_ECM36FSI01103H906026F 001003
ROD: EV_ECM36FSI01103H906026E.rod
VCID: 2809059BF2773117321-807C
CAN Converter 01:
Address 02: Auto Trans (J217) Labels: None
Part No SW: 09G 927 158 A HW: 09G 927 158
Component: AISIN AQ8 206 3387
Coding: 0000000100000000000000000000000000000000
ROD: EV_TCMAQ450031.rod
VCID: 313FE8FFC1AD70DFE5F-8064
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 52877000000759
Coding: 44FC6B8D84241A6CC5800308A2C46922D62158A3C045967E18415058C2AA4200002F641C12141A118DDB45506CC8CF
ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
VCID: 77AB16E76F496EEF6BB-8022
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0906
Revision: 00037000 Serial number: 0457500243
Coding: 1F20000723
ROD: EV_KessyHellaMQBAB_VW41.rod
VCID: 3E25C3C300F39FA768D-806A
65794 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 58
Mileage: 688 km
Date: 2018.01.07
Time: 07:39:12
Terminal_15_Kessy_specified_value: OFF
Terminal_15_Kessy_actual_value: OFF
Terminal_15_central electric_actual_value: OFF
Terminal_15red_Kessy_specified_value: OFF
Terminal_15red_Kessy_actual_value: OFF
Terminal_S_Kessy_specified_value: OFF
Terminal_S_Kessy_actual_value: OFF
Terminal_S_central electric_actual_value: OFF
ZAT_pressed: OFF
Park selector lever position: Not engaged and not locked
Enabling immobilizer: Condition not met
8.218 V
Vehicle locked externally
Coding information: coded
Driver door: closed
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: Init
ID sensor 1 authentication: status: No response
ID sensor 2 authentication: status: No response
ID sensor 3 authentication: status: No response
ID sensor 4 authentication: status: No response
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 3CN 907 044 G HW: 3CN 907 044 G
Component: Climatronic H04 2002
Revision: 00001K01
Coding: 1602060620001C00110421001210140C
ASAM Dataset: EV_ACClimaBHBVW416 002011
ROD: EV_ACClimaBHBVW416.rod
VCID: 43D3B2376B11F24F073-8016
Fresh Air Blower Back:
Part No SW: 5Q0 937 085 BN HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H36 0253
Serial number: 7277030002ÿÿÿÿ
ROD: EV_BCMBOSCH_018.rod
VCID: 06556B2318A3076760D-8052
Subsystem 1 - Part No SW: 5Q0 955 555 HW: 5Q0 955 555
Component: RLHSS 046 0120
Serial number: S6Y17M10D02H08M38S49
Coding: 00382D
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 320007C911FFC728949C810530401600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
ROD: EV_ACCBOSCHVW416.rod
Part No SW: 3Q0 959 655 BN HW: 3Q0 959 655 BN
Component: Airbag VW21 006 0703
Revision: -------- Serial number: 003SUMHHI2KS
Coding: 8CCCDC00000000005000001A420800000065
ROD: EV_AirbaVW21TS6VW48X_VW27.rod
VCID: 0B435A1703C17A0F3F3-805E
Occupant Detection:
Component: Occ.Detection H13 0022
Serial number: IBH0000J170007YGQO08
Coding: 303030
Subsystem 2 - Part No SW: ----------- HW: 454 000 709 17
Serial number: 3570000000057489792N
Subsystem 3 - Part No SW: ----------- HW: 454 001 209 17
Serial number: 35800000000B44A4892P
Subsystem 4 - Part No SW: ----------- HW: 454 801 109 17
Serial number: 3510076162D120000004
Subsystem 5 - Part No SW: ----------- HW: 454 801 109 17
Serial number: 3520066152D120000003
Subsystem 6 - Part No SW: ----------- HW: 454 800 209 17
Serial number: 355005172C5100000003
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 454 800 209 17
Component: FrontSensor_P 304 0149
Serial number: 35600586EC510000000M
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Revision: -------- Serial number: 26101708490341
Coding: 0C10
ROD: EV_SMLSKLOMQB_VW41.rod
VCID: 094F601F09BD681F0DF-805C
Address 17: Instruments (J285) Labels:* None
Part No SW: 3CN 920 850 A HW: 3CN 920 850 A
Component: KOMBI 370 0310
Coding: 0BA4171DEF88CF0502882B0B50000000A0000000
ROD: EV_DashBoardVDDMQBAB_VW27.rod
VCID: 3D27C4CF0DF584BF717-8068
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 02101700840398
Coding: 030500347F087300FB0322581E0F00010001070000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 3333E2F73BB142CF973-8066
Subsystem 2 - Part No SW: 5G0 959 442 R HW: 5G0 959 442 R Labels: 3C8-959-537.CLB
Serial number: 26170001848660121439
Coding: 34FFFF
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 6117335404
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7084
Serial number: HA1-00004.09.17
Coding: 0301
ROD: EV_AllWheelContrHA1VW37X_004_VW37.rod
VCID: 4CC1990B464F3D37F69-8018
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBB H05 0032
Serial number: 17000239804018
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB_VW41.rod
VCID: 71BF28FF012D30DFA5F-8024
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0080
Serial number: 0454125610
Coding: 01012103
ROD: EV_HREntryHella_VW32.rod
Component: TSG FS 020 0041
Serial number: 041017A0080C21
Coding: 00341B200000020000000000
ROD: EV_DCUDriveSideEWMAXCONT_VW27.rod
Serial number: 00000000000007079085
Coding: 011000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2051
Revision: 00000000 Serial number: 0002098811
Coding: 01000311004001
ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
VCID: 40D9BD3B7A07E9571A1-8014
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 21091700840508
Coding: 000000070100135200010000000000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_VW27.rod
VCID: 72BD27F3042B0BC75C5-8026
Component: TSG BFS 020 0041
Serial number: 011017A0080174
Coding: 003413200000020000000000
ROD: EV_DCUPasseSideEWMAXCONT_VW27.rod
VCID: 42DDB733740BFB470C5-8016
Serial number: 00000000000006816651
Coding: 091000
Part No SW: 3Q0 035 844 B HW: 3Q0 035 844 B
Component: MU-S-S-US 722 0867
Coding: 02140600FF00000051220001001808001F0500C40120050002
ROD: EV_MUStd4CDELP_VW27.rod
VCID: 2E05F383D0936F27F8D-807A
Subsystem 1 - Part No SW: 5G6 919 605 C HW: 5G6 919 605 C
Component: ABT_Std-2 H50 8130
Serial number: VWZ6ZJT2585490
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 L HW: 5Q0 907 383 L
Component: Anhaenger H27 0260
Revision: 8C001004 Serial number: 0449794767
Coding: 0200000200000000
ROD: EV_TrailFunctGener2Hella_VW27.rod
Component: RVC Compact H12 0231
Coding: 01150602A1002017300040
VCID: 392FD0DF19DDB89F5DF-806C
Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0261
Revision: -------- Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Coding: 0988
ROD: EV_DeckLidCONTIAU736_VW27.rod
VCID: 41DFB83F710DE05F15F-8014
Component: OCULowMQBUS 009 0570
Coding: 02140602C2821A017F1E06020000
ROD: EV_OCULowMQB_VW32.rod
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H07 0272
Serial number: 04101711K12765
Coding: 0004010600010201002200558150490084000E200100
ROD: EV_MFKBoschMQBB_VW36.rod
VCID: 3C21C9CB16EF8DB7469-8068
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AA HW: 7P5 941 591 A
Component: LED1L H06 0003
ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
VCID: 7BA30AD753614A8F0F3-802E
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0003
End----(Elapsed Time: 02:03, VBatt start/end: 11.6V/11.7V. VIgn 11.7V)-----
Address 05: DTCs cleared
