5Q0-937-084 map
david99
Slovakia
C?ID=303026
I would like to ask when more accurate map for 5Q0-937-084 will be available? I have Tiguan AD1 model year 2018 and when downloaded csv admap from this ecu I'm missing some codings, for example I should be able see codings for all lights like front blinkers and front lights but they are missing indicated as not active despite they are working. Examples - 0 BLK VL B36 - left blinker, 1 BLK VR B20 - right blinker, for both I have for all functions from A till F value "not active" but this should be not the case as blinkers are working and default coding for them is "Blinken links (rechts) hellphase" which is in reality the case otherwise they would not work. So I suppose VCDS is not able correctly read those adaptation values. I have used VCDS Beta 17.12.
Thanks,
David
TBAx
C?ID=287144
You will most likely have a LCM in your car and that‘s why those channels are not enabled. This is not a problem of VCDS.
PetrolDave
Westbury, UK
C?ID=1423
LCM?
Uwe - Does that need adding to the Forum list of TLAs?
david99
Slovakia
C?ID=303026
Could you please specify how I will find such module? All light related codings for Tiguan 2 are done via Central Electronic module on address 09.
david99
Slovakia
C?ID=303026
You are probably right I found those:
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 166023AFE929E19A05E-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0003
ROD: EV_LEDModLeftMELCOAU736_VW48.rod
Is that correct one?
And then lights itself:
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH08 0014
VCID: 45C2B4E3C40F9A02BC4-8010
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
TBAx
C?ID=287144
Yep, Light Control Module. Those are commonly used in the Tiguan II for everything the two front headlights are doing.
david99
Slovakia
C?ID=303026
Hi TBAx,
I have checked adaptation channels of LCMs and also Lights addresses D6,D7 and 29,39. There are no adaptation channels like on Central electronics - 09. So my question now is how you could recode front lights in case of need? Will they react when I change functions for front lights from not active to something specific like blinker in Central electronics?
Thanks,
David
TBAx
C?ID=287144
Hi David, as far as I know, it's not available to change anything regarding the lighting of the headlights. Those modules don't deliver much... maybe because they are built by Mitsubishi. :x
hadez16
C?ID=289891
david, what dou you want to change?
If it comes to headlight capabilites, module 4B offers these things as a replacement of module 55.
david99
Slovakia
C?ID=303026
Currently I'm not tryting to change anything I was just curios how is that possible that those settings are not coded in central electronic, I will check later what are options in 4B. Thanks. David
