MK6 2014 GTI, able to set Comfort Blinks to 2, but not 1? (valid range: 1..5)
TedJohnson
C?ID=273469
I've got a 2014 GTI and want to change the "comfort blink" (aka, "Comfort Turn Signal Cycles")
to a value of 1. It's currently set to 3.
Using VCDS, I'm able to set it to 2, but not to 1.
Whenever I enter 1 in the "New Value" box, VCDS grays out (disables) the "Save" button..
VCDS on my car reports that valid range is 1->5, so it should take 1.
(This range agrees with other online docs)
I'm following these instructions: http://www.myturbodiesel.com/1000q/a6/change-number-blinks-turn-signal-vw.htm
Any suggestions on how I can get my car to accept a value of 1 for "comfort blink"?
Thanks in advance!
VCDS autoscan follows:
Thursday,11,January,2018,18:18:50:09576
VCDS Version: 17.8.1.0 (x64)
VIN: WVWHD7AJ2EW000268   License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: WVWHD7AJ2EW000268   Mileage: 47400km-29452miles
   Part No SW: 1K0 907 115 AT    HW: 1K0 907 115 AK
   Revision: E3H26---    Serial number:
   Coding: 040301081C070160
   VCID: 78D111830BF62386A9-802C
   Part No SW: 02E 300 058 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 3513
   Revision: 05652104    Serial number: 00001307180293
   VCID: 277302FF96C87C7EF0-8072
   Revision: 00H31001
   Coding: 114B600C492200FA880D06EA92210041B70800
   VCID: 7DDF0097E4D406AEFA-8028
   Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
   Component: AC Manuell    H20 0505
   Revision: 00001019
   Coding: 0010002002
   VCID: 7BDB0E8FF2C0089EC4-802E
   Part No SW: 1K0 937 086 T    HW: 1K0 937 086 T
   Component: BCM PQ35  M   111 0709
   Revision: AC111709
   Coding: 6F180A1A90252AC4008800C17000054448010386434D8D60648020200040
   VCID: 41A7BC67D8ACA24EDE-8014
   Component: Wischer 20061  26  0512
   Coding: 009795
01259 - Fuel Pump Relay (J17)
                    Fault Status: 00101001
                    Reset counter: 231
                    Mileage: 46438 km
                    Date: 2017.12.07
                    Time: 08:31:33
                        Term 15 Off
                    Voltage: 12.40 V
                        Term 50 Off
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R02933T
   Coding: 00004737
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C59CD93B74ECFA68D-8068
   Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00008FCN00
   Serial number: 3572MSME68585478ZZZ1
   Serial number: 3582MSME6D585478ZZZ7
   Serial number: 3512QSME66483049ZZZV
   Serial number: 3522QSME4A04321EZZZU
   Serial number: 35527SME5B755C2FZZZ
   Serial number: 35627SME2C6E5C2FZZZ2
   Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90440MGN000BG
   Coding: 189A140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76CD1FBBC9E255F6BB-8022
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0032
   Serial number: 0151632
   Coding: 830000
   Part No SW: 5K6 920 973 C    HW: 5K6 920 973 C
   Component: KOMBI         H05 0705
   Coding: 270F01
   VCID: 3753D2BF8E68ECFE60-8062
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 200513F1000362
   Coding: 350002
   VCID: 74C925B3D79E47E685-8020
   Component: Kompass         002 0002
   Revision: 00002000    Serial number: 1225223RP3TQ07
   VCID: 7EDD079B29D21DB6E3-802A
   Component: IMMO          H05 0705
   VCID: 6AF53BCB8D5A81162F-803E
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Revision: A1001003    Serial number: 7665021244
   Coding: 010100
   VCID: 2B7BFECF4A20581E14-807E
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2105
   Coding: 0001204
   VCID: 3753D2BF4668ECFE60-8062
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 74     3501
   Revision: 00H22000
   VCID: 3957D487707CFA8E96-806C
   Part No SW: 5K0 959 702 H    HW: 5K0 959 702 H
   Coding: 0001204
   VCID: 3851D1834B76E38669-806C
   Part No SW: 1K0 035 164 F    HW: 1K0 035 164 F
   Component: LOW NAR SDARS H03 0005
   Revision: -----07S    Serial number: VWZ4Z6N3583861
   Coding: 01000400040005
   VCID: 256F08F72CC46E6EC2-8070
            000 -  -
                    Reset counter: 67
                    Mileage: 27348 km
                    Date: 2015.12.21
                    Time: 21:06:08
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 354FD8B75C641EEE72-8060
   Coding: 0001168
   VCID: 364DDFBB416215F67B-8062
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664987885
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A55CB8BBD7AF1969F-806E
End-------------------------(Elapsed Time: 01:55)--------------------------
Additional info: I expected my change (switching Comfort Blinks from 3 --> 2) to have
resulted in a change in the VCDS long coding for Address 09: Cent. Elect. (J519) ",
however the long coding (before the change, and after the change) is identical:
-Ted
Comfort blinks changes an Adaptation channel not the Coding string, hence why there is no change to the Coding - the instructions you link to show the is an Adaptation change :thanks:
TedJohnson
C?ID=273469
Thanks for the quick reply PetrolDave, much appreciated!
Q#1/2) are Adaptation parms in the VCDS Autoscan output? I did an Autoscan before and after making the change, and the Autoscan output was identical (other than the timestamp in the header).
Q#2/2) more importantly, do you know of a way I can get VCDS to let me write a value of 1 to the Comfort blink Adaptation channel? When I enter 1 into the "New value" TextEdit box, the "Save" button goes grey, which prevents that value from taking effect.
Thanks in advance,
-Ted
TBAx
C?ID=287144
I wish there would be the possibility to automatically save adaption channel maps along the Auto-Scan, but there isn‘t
When you want to set comfort blinking to 1 you are essentially disabling it. So I would recommend (since value 1 seems implausible) to just disable comfort blinking alltogether. This should be possible via coding in the BCM.
TedJohnson
C?ID=273469
Thanks for the info TBAx, much appreciated. Your suggestion gave me something else to google for and eventually I came across a thread which suggested that Comfort blinks might be defeatable via the MFD (ie, by changing the car settings from the console display w/o even using VCDS).
Lo and behold, it's actually true. In my case, it's under: Settings | Convenience | Lights & Vision | Conv. turn sig.
There was a checkbox beside "Conv. turn sig.", and when I unchecked it, it accomplished what I wanted: set the "Comfort blink" to 1. Nice! Now I don't look as much like an idiot when I signal, then cancel the signal (due to someone else grabbing the lane, usually). Before (with default settings), there was no way to cancel the turn signal w/o having it signal 3 blinks in the opposite direction.
Thanks again for all your help folks, I'm a happy camper now.
