Rns-e plus Q3 Climate control
ch1z64
C?ID=316572
I have recently retrofitted an Rns-e Mk2 ( media button ) and a Q3 2015 climate control into my 2009 s3 but I am having some issues with codes , one I know off which has to do with radio diversity ( 00858 ) and can be sorted by buying a new upper Amp , lower amp and a few repair wires , it is the other ones I am confused with like the 2 about the speakers , 1 about Bose pin ( as it works fine with the Amp in the back left panel inside Boot ).
Now onto the climate control again people I know who have fitted this into there S3's have the same problem ( 00457 ) but everything seems to work fine once you adjust the seat heating again I know how to do this . so could someone with a greater knowledge than me explain how I can go about getting these faults sorted thanks.
Wednesday,03,January,2018,14:43:26:45592
VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4409.4
VIN: WAUZZZ8P5AA039310   License Plate:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 37 42 44 46 52 55 56 77
VIN: WAUZZZ8P5AA039310   Mileage: 152080km-94498miles
Address 01: Engine (CDL)       Labels:. 06F-907-115-CDL.clb
   Part No SW: 8P0 907 115 AP    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: AUX7Z0I6FNN0S8
   Coding: 0103000C180F0160
   Shop #: WSC 04096 557 00059
   VCID: 005A88EC060822875A1-8054
Readiness: 0000 0001
   Revision: 00H45001
   Coding: 1642801249250003680E01E5921900813800
   Shop #: WSC 00857 210 11996
   VCID: 005A88EC0A0822875A1-8054
   Part No SW: 8U0 820 043 G    HW: 8U0 820 043 G
   Component: E87  Klimavoll      0210
   Revision: 00H05000    Serial number: 8U0820043G
   VCID: 35342938094A572FB97-8060
01854 - Heated Seat; Front Right (Z46)
                    Fault Status: 00101100
                    Reset counter: 10
                    Mileage: 152046 km
                    Date: 2017.12.30
                    Time: 19:42:19
                    Temperature: 9.5°C
                    Voltage: 11.80 V
                    Current: 0.000 A
                    (no units): 3.0
                    Temperature: 20.0°C
                    Temperature: 55.0°C
                    Reset counter: 0
Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
   Part No SW: 8P0 907 063 A    HW: 8P0 907 063 A
   Component: BCM PQ35  M   104 0575
   Revision: 00104 AH
   Coding: 0E000A2FB017F000A07241E00000094C437E25AA315DD929E40008840040
   Shop #: WSC 00561 210 89589
   VCID: 323E1224F42440179C5-8066
   Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H10 0040
   Coding: 00DD13
   Subsystem 2 - Part No: 8P0 951 177
   Component: Innenraumuebe  H04 0020
   Subsystem 4 - Part No: 1K0 907 719 C
   Component: Neigungssenso  005 0003
                    Fault Status: 00101010
                    Reset counter: 14
                    Mileage: 152050 km
                    Date: 2018.01.01
                    Time: 12:28:15
                    Voltage: 14.55 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 G    HW: 8P0 919 475
   Component: PARKHILFE 4K  H06 0120
   Revision: 11001001    Serial number: 93640920206918
   Coding: 000003
   Shop #: WSC 06314 000 00000
   VCID: 42DE42E44484F0970C5-8016
Address 15: Airbags (J234)       Labels:| 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
   Component: Airbag AU1042 H06 0140
   Revision: --------    Serial number: 003FB002DSVH
   Coding: 303142413039303030384A55305238503053
   ROD: EV_Airba10AURB4.rod
   VCID: 4FF87BD087560DFF93B-801A
   Serial number: 34928RB400004F10F9D$
   Serial number: 35028RB400004F2618AK
   Serial number: 35128RB400004F10B84I
   Serial number: 35228RB400004F2618DP
   Serial number: 35547RB400004EF08A8$
   Serial number: 35647RB400004EF08A7$
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0004042
   VCID: 46D65EF464ACCCB720D-8012
   Component: E0221           H06 0030
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
   Part No SW: 8P0 920 982 K    HW: 8P0 920 982 K
   Component: KOMBIINSTR. VDO H02 0980
   Revision: D0H02002    Serial number: 2246I002000289
   Coding: 0005428
   Shop #: WSC 00561 067 57207
   VCID: 41DC4DE84D82EB8F15F-8014
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H16 5223
   Revision:   H16       Serial number: 4120K097200630
   Coding: E9A31F06400602004101
   Shop #: WSC 80093 222 69422
   VCID: 6696BE74046CECB7C0D-8032
   Part No SW: 0BR 907 554 A    HW: 0BR 907 554 A
   Component: Haldex 4Motion      3016
   Coding: 0000005
   VCID: 43D047E0579EF99F073-8016
00448 - Haldex Clutch Pump (V181)
                    Fault Status: 00101011
                    Reset counter: 40
                    Mileage: 152042 km
                    Date: 2017.12.30
                    Time: 15:36:59
   Revision: D0H02002    Serial number: AUX7Z0I6FNN0S8
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8P0 035 193 G    HW: 8P0 035 193 G
   Component: RNS-E PU EU     H07 0220
   Revision: 0000013S    Serial number: AUZBZ7MD218544
   Coding: 0209755
   Shop #: WSC 19428 000 104857
   VCID: 3432143C02304E278E9-8060
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 225
                    Mileage: 152042 km
                    Date: 2017.12.30
                    Time: 15:32:18
                    Mileage: 152040 km
                    Count: 3012
                    Clock: 15:31
00878 - Connection to Speaker Front Left
                    Reset counter: 225
                    Mileage: 152042 km
                    Date: 2017.12.30
                    Time: 15:32:09
00879 - Connection to Speaker Front Right
                    Reset counter: 225
                    Mileage: 152042 km
                    Date: 2017.12.30
                    Time: 15:32:09
02005 - Coding Pin
                    Reset counter: 225
                    Mileage: 152042 km
                    Date: 2017.12.30
                    Time: 15:32:18
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8P0 959 801 N    HW: 8P0 959 801 N
   Component: Tuer-SG         H04 0100
   Coding: 0000636
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 234    3001
   Revision: 00H17000
   Shop #: WSC 00561 210 91540
   VCID: 313C1D28FD227B0FE5F-8064
   Part No SW: 8P0 959 802 N    HW: 8P0 959 802 N
   Coding: 0000636
   VCID: 47C853F063A6D5BFDBB-8012
   Part No: 8P3 907 357
   Coding: 0000013
   VCID: 7AAEFA0460D47857145-802E
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0209755
                    Reset counter: 225
                    Mileage: 152042 km
                    Date: 2017.12.30
                    Time: 15:32:18
                    Mileage: 152040 km
                    Count: 3012
                    Clock: 15:31
                    Reset counter: 225
                    Mileage: 152042 km
                    Date: 2017.12.30
                    Time: 15:32:09
                    Reset counter: 225
                    Mileage: 152042 km
                    Date: 2017.12.30
                    Time: 15:32:09
02005 - Coding Pin
                    Reset counter: 225
                    Mileage: 152042 km
                    Date: 2017.12.30
                    Time: 15:32:18
   Part No SW: 8P0 862 335 AA    HW: 8P0 862 335 S
   Component: FSE_256x BT     H34 0600
   Revision: 00000000    Serial number: 00000005109446
   Coding: 0011422
   VCID: 75B4E93849CA172F797-8020
End----(Elapsed Time: 01:24, VBatt start/end: 12.1V/11.8V. VIgn 11.8V)-----
PetrolDave
Westbury, UK
C?ID=1423
Did you swap a Symphony II to the RNS-E?
The pinouts are almost (but not quite) identical - the main difference being the Bose pin - which tells the RNS-E to disable all vehicle specific frequency adjustments, and if you don't move the wire in the Quadlock causes this error.
Check the WD for the RNS-E (Mk1 and Mk2 are identical) - I used to have all the details but lost them when we moved home :cry:
ch1z64
C?ID=316572
I was advised to remove the K-line pin from the blue block B ( as the Rnse came out a a4 ) and move to pin 7 in the same block which I did and the sound plays through the Amp in the boot but I just can't seem to get the car to recognize the pin coding
PetrolDave
Westbury, UK
C?ID=1423
I can see that the coding of the RNS-E includes Bose, but the front speaker connection errors suggest that the Bose pin is not grounded (with Bose all speakers are amplified but with non-Bose the front speakers are driven directly from the RNS-E) - so check that with a multimeter.
http://wiki.ross-tech.com/wiki/index.php/Audi_Radio/Navigation_System_(RNS-E)
ch1z64
C?ID=316572
I did have some ground wires soldered recently to one massive Brown ground wire and I think I missed one as I did see a Black wire hanging about but didn't know what it was for so could this be the culprit as the Bose seems to work fine with no crackling
