New Here
BMoneyBrett
Good morning all,
I have been lurking this forum, but finally decided to join.
I own a 2015 Audi A3 8V.
I am having errors pop up in 09 Central Electronics.
Can I post my full report here so we can work on the resolve?
Best,
Brett
BMoneyBrett
Yes, by all means, please do.
Thank you for being able to help me with this! I will be able to get the auto scan within 5 hours or so. It's crunch time at work!
BMoneyBrett
Please post a full Auto-Scan - copy the .txt file and place it in CODE tags.
Please fine below the auto-scan results:
 Monday,08,January,2018,18:59:33:46278
VCDS Version: 17.8.1.0 (x64)
VIN: WAUEFGFF9F1033300   License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 47 52 55 5F BB BC
VIN: WAUEFGFF9F1033300   Mileage: 79738km-49546miles
Address 01: Engine (J623-CNTC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0105
   Revision: --H13---
   Coding: 0A1D00124426000F3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001007
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C57E89647BFF1261D-8078
Readiness: 0000 0100
   Part No SW: 0D9 300 012 K    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H52 4513
   Revision: 05852204    Serial number: TFK01405050793
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021_VW37.rod
   VCID: 1E33325E010313B683-804A
   Revision: 00000000    Serial number: 61584000001803
   Coding: 13FF6A9234230A6F017A030081C329C8562C5080C08194B4024100588608
   ROD: EV_Brake1UDSContiMK100IPB_033_VW48.rod
   VCID: 4581BD32C415206EE2-8010
   Revision: 00021000    Serial number: 0336424077
   Coding: 130C1C
   Shop #: WSC 12345 123 61029
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3A7BDECEBDEB5F969F-806E
1053192 - Touch Sensor on Exterior Door Grip; Passenger Side
          B116C 29 [009] - Signal Implausible
                    Reset counter: 154
                    Mileage: 79738 km
                    Date: 2018.01.08
                    Time: 08:47:14
   Revision: 20026000    Serial number: 00000000352088
   Coding: 03000014110000000000000000001400
   VCID: 3365F3EA9A81AEDE5C-8066
   Serial number: 51594137000000000001
   Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
   Component: BCM MQBAB MNA H18 0134
   Serial number: 01011414200106
   Coding: 04151A46C04122F541C04004511007000800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 79F901C2F86D948ED6-802C
   Component: WWS371 140604  042 0585
   Serial number:         140607030124
   Coding: 0A47F7
   Serial number: 22735077
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 K    HW: 8V0 941 531 K
   Serial number: 10 04 2014  00001013
   Serial number: 00000000000029984738
   Sun Roof:
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO29915178
   Coding: 101F00
526359 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 151
                    Mileage: 79672 km
                    Date: 2018.01.07
                    Time: 13:17:25
   Serial number: 003GCR00FHSW
   Coding: 9DCCFCC0000000005000001AC24800000065
   VCID: 479DB73AFE19327E10-8012
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0341
   Serial number: 34178311A10061440566
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0341
   Serial number: 34178312A10061470754
   Coding: 333135
   Occupant Detection:
   Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
   Serial number: 6940000Y1400015E3S0N
   Coding: 303139
   Subsystem 4 - Part No SW: -----------    HW: 480 001 106 14
   Serial number: 35700000000682452010
   Subsystem 5 - Part No SW: -----------    HW: 480 001 006 14
   Serial number: 358000000002F110201
   Subsystem 6 - Part No SW: -----------    HW: 480 402 605 14
   Serial number: 3510002AF15C4211818-
   Subsystem 7 - Part No SW: -----------    HW: 480 400 206 14
   Serial number: 3520002A915C421331DX
   Subsystem 8 - Part No SW: -----------    HW: 480 400 804 14
   Serial number: 35500029D1524DC1E29E
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 400 804 14
   Serial number: 35600029D1524DC19199
   Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 10061408490334
   Coding: A018
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 0A1B4E0EAD8B8F16CF-805E
   Part No SW: 8V0 920 971 D    HW: 8V0 920 971 D
   Component: KOMBI         H02 4291
   Coding: 0BED18192B80D7050200EA001800000000000000
   VCID: 3E73D2DEA1C373B6A3-806A
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2186
   Revision: --------    Serial number: 10061410801431
   Coding: 0101000820085A005B00020C180B00000001010000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 428BA62ED53B1756C7-8016
   Serial number: 04 06 2014  E0005777
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00012.05.14
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
   VCID: 4683BA3EF9132B76EB-8012
   Revision: 00000000    Serial number: 14000153141003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_004_VW37.rod
   VCID: 3467F0F69F8FA9E645-8060
   Serial number: 26051402090917
   Coding: 00511F204000048000000002
   VCID: 408FAC26DB370546D1-8014
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 0102
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 4189A922D03D0C4EDE-8014
   Part No SW: 8V0 035 465 C    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0410
   Serial number: AUZ8ZAFN901TSN+
   Coding: 01000000AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
   VCID: 387FC4C683E74D8669-806C
0605 - Loudspeaker 2 in Double-Subwoofer
          B130D 13 [008] - Open Circuit
                    Reset counter: 189
                    Mileage: 79509 km
                    Date: 2018.01.06
                    Time: 13:09:18
                    Voltage terminal 30: 11.8 V
0600 - Loudspeaker 1 in Double-Subwoofer
          B130C 13 [008] - Open Circuit
                    Reset counter: 189
                    Mileage: 79509 km
                    Date: 2018.01.06
                    Time: 13:09:18
   Serial number: 13061404081213
   Coding: 005117204000048000000002
   VCID: 3F8DAFDAA6C97ABEA8-806A
   Coding: 012A000101000000
   ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
   VCID: 75E10DF2D475F0EEB2-8020
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-HGH1.clb
   Part No SW: 8V0 035 038     HW: 8V0 035 038
   Component: MU-H-LNS-US   H42 0289
   Serial number: A302F0E7508737
   Coding: 017301020000000021220002041A00102F000125010001047E
   ROD: EV_MUHig6C3HBAS_AU37.rod
   VCID: 71E939E2A01DDCCE6E-8024
   Subsystem 1 - Part No SW: V03 959 800 SE    HW: -----------
   Component: NAR 2014  --- 0024
   Component: DU High  H49 0013
   Serial number: AUZ8Z9EY2015WR
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 S    HW: 8V0 919 614 E
   Component: ControlUnit_H  H64 0766
   Serial number: C1000022051400020088
   Component: Gracenote  --- 3005
   Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0025
   Serial number: 10061403110561
   Coding: 004117204000048000000002
   ROD: EV_DCURearDriveMAXCONT_VW37.rod
   Component: TSG HBFS      020 0025
   Serial number: 10061401100561
   ROD: EV_DCURearPasseMAXCONT_VW37.rod
End-------------------------(Elapsed Time: 04:43)--------------------------
The only fault in the 09 Cent. Elect. / BCM module is "Control Module Incorrectly Coded".
Have you changed the coding in that module?
BMoneyBrett
I did modify the coding in this module. I turned on the emergency brake flashing via turn lights active and emergency flashing via brake lights active. I also adjusted LED brightness.
I'm sure I fiddled around with other codes in 09.
Is there an approach to dial in what is causing the error?
BMoneyBrett
None that I can think of. If it was me, I'd start by putting the coding back to stock...
That's a sound approach. My only question in doing so is that if it's not affecting my CEL nor affecting any electrical component that I can identify in the car, would it be worth reverting it back to stock and then rebuilding 09 with the modifications I installed?
Best,
Brett
