How do I calibrate on back-up camera 7N0 907 441 B (MQB platform) ?
How do I use a security access?
Thursday,04,January,2018,15:52:27:23882
VCDS Version: 17.8.1.0 (x64) HEX-V2 CB: 0.4409.4
Dealer/Shop Name: jokir
Workshop Code: 785 01872 000200
VIN: WVGZZZ1TZ9W028134 License Plate:
Chassis Type: 1T-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 3C 42 44 46 52 55 5F 62 65
69 6C 72 A5
VIN: WVGZZZ1TZ9W028134 Mileage: 228270km-141840miles
5F-Information Electr. -- Status: Malfunction 1010
6C-Back-up Cam. -- Status: Malfunction 1010
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 021 RN HW: 03G 906 021 AB
Component: R4 1,9L EDC G000SG 1989
Revision: --H08--- Serial number: VWX7Z0H63NL0YQ
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 7CA005123AEEB347069-8028
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: 323B801689240E024C0C01E7911D7041A1095098
VCID: 75B6103615C4E20F797-8020
Part No SW: 3AA 907 044 BS HW: 3AA 907 044 BS
Component: Climatronic H05 0505
Revision: 00001K02
Coding: 001C000002
Shop #: WSC 00015 115 00001
VCID: 025C7BEA548AC5B74C5-8056
13701424 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Frequency: 27
Reset counter: 246
Mileage: 228161 km
Date: 2017.12.29
Time: 10:09:26
Revision: 00H54000 Serial number: 00000008706060
Coding: F78B8F2110040A0047120C0000000000801B7F076410010C00 0000000000
Shop #: WSC 04941 000 00000
VCID: 3332EE2E5730BC3F973-8066
Subsystem 1 - Part No: 2K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 040708 021 0501
Coding: 00038805
Shop #: WSC 04941
Component: RLS 210909 054 0402
Coding: 00408813
Shop #: WSC 04941
Fault Status: 00101001
Fault Frequency: 26
Reset counter: 31
Mileage: 228161 km
Voltage: 13.40 V
02071 - Local Databus
Reset counter: 28
Mileage: 228183 km
Voltage: 12.20 V
Reset counter: 28
Mileage: 228183 km
Voltage: 12.20 V
Address 10: Park/Steer Assist (J791) Labels:| 1Q0-919-475.clb
Part No SW: 7N0 919 475 E HW: 5Q0 919 298 B
Component: PLA 3.0 12KH08 0005
Coding: 0071167101
Shop #: WSC 00070 123 12345
ASAM Dataset: EV_EPHVA3CVW428GP00 001005
ROD: EV_EPHVA2CVW428GP00.rod
VCID: 3D26C8166DF47A4F717-8068
12648480 - Databus
Reset counter: 25
Mileage: 228161 km
Date: 2017.12.29
Time: 10:09:27
12658720 - Databus
Reset counter: 236
Mileage: 228161 km
Date: 2017.12.29
Time: 10:09:26
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 D HW: 1T0 909 605 D
Component: 04 AIRBAG VW8 021 0100
Revision: 02021000 Serial number: 003B9D09SR2G
Coding: 0012340
Shop #: WSC 01324 785 00200
VCID: 3634D73A4442A917B0D-8062
Subsystem 1 - Serial number: 6332QSME7A0B0F3F-
Subsystem 2 - Serial number: 6342QSME79372227F
Subsystem 3 - Serial number: 6352QSME722150352
Subsystem 4 - Serial number: 6362QSME796C030DS
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 056 0111
Coding: 0000532
VCID: 7AAC030A30DA8D77145-802E
Subsystem 1 - Part No: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0033
Coding: 00000130
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 5N0 920 883 G HW: 5N0 920 883 G
Component: KOMBI H04 1008
Coding: 110D010800
VCID: 3828D90242D65F67A21-806C
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 5K0 963 272 E
Component: Standheizer 043 4709
Revision: 00043000 Serial number: 09021534000000
Coding: 0031012
Shop #: WSC 36105 001 1048576
VCID: 323CEB2AA82AB5379C5-8066
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 101013F1001833
Coding: 350032
Shop #: WSC 01324 020 00200
VCID: 7BA2060E33E0B47F0F3-802E
1 Faults Found:
03158 - Control Module for Information Electronics 1 (J794)
Fault Status: 00110100
Fault Frequency: 11
Reset counter: 28
Mileage: 228173 km
Date: 2017.12.30
Time: 12:07:56
Component: IMMO H04 1008
VCID: 6A8C334A4CFA3DF7E45-803E
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0400017880
Coding: 01011102
Shop #: WSC 00046 000 00000
ROD: EV_HREntryHella_VW32.rod
VCID: 3C20C51276EE7347469-8068
Lane Change Assistant 2:
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2121
Coding: 0135415
VCID: 76B4173A04C2E91770D-8022
00120 - Outside Warning Light/Door exit Light Driver Side
00131 - Outside Door Handle Illumination/mirror Light Driver Side
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 239 3501
Revision: 00H15000
VCID: 392EDC06755C466F5DF-806C
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 82900A885103CC7F2D020F0F6008CFCA70DD00
VCID: 03527EEE4710CCBF473-8056
Subsystem 5 - Part No: 1K0 947 291 F
Component: Innenraumueberw.009 4809
Coding: 00000000
Shop #: WSC 01324
Subsystem 6 - Part No: 1K0 951 605 C
Subsystem 7 - Part No: 1K0 907 719 C
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Coding: 0135671
VCID: 48C8A9C23EB62FE7D21-801C
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Component: AFS-Steuergeraet 0148
Coding: 3293204
VCID: 3430ED32523EBB078E9-8060
Subsystem 1 - Part No: 1K0 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0001
Coding: 00000050
Subsystem 2 - Part No: 1K0 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0001
Coding: 00000050
Part No SW: 5C0 035 680 B HW: 5C0 035 680 B
Component: MU-S-N-ER H22 0252
Serial number: VWZAZ2R8122281
Coding: 02240801BE00000011110001000908001F0106D400200105CF
Shop #: WSC 12345 011 12345
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 20181162FA4637A77A1-8074
Subsystem 1 - Part No SW: 3G0 919 866 BJ HW: -----------
Component: ECE1 2018 --- 0915
6714 - Databus
Reset counter: 236
Mileage: 228161 km
Date: 2017.12.29
Time: 10:09:30
Voltage terminal 30: 14.1 V
0001 - Antenna 1 for Radio
B1119 13 [009] - Open Circuit
Reset counter: 246
Date: 2018.01.04
Time: 15:49:42
Voltage terminal 30: 11.8 V
Status of antenna 1 for radio-Antenna current: 0 mA
Status of antenna 1 for radio-Connection between radio and antenna amplifier: Electrical OK
Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Electrical OK
Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
Part No SW: 1K0 959 703 AK HW: 1K0 959 703 AK
Component: Tuer-SG 007 2002
Coding: 0001232
Shop #: WSC 01357 011 1012552
VCID: 79AE1C0635DC866F1DF-802C
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 D HW: 3AA 907 273 D
Component: RDKBERU30 H09 0010
Serial number: 30000000013079
ASAM Dataset: EV_RDKBERU30 003012
ROD: EV_RDKBERU30_003.rod
VCID: 3536D03655C4A20FB97-8060
Address 69: Trailer Labels: RETROFIT69.lbl
Part No SW: 5F0 01V 000 6 HW: 8P0 907 383
Component: TRAILER ECS V0006 0010
Shop #: WSC 00164 211 66245
VCID: 280809429EF6CFE7321-807C
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 7N0 907 441 B HW: 7N0 907 441 B
Component: VW428 RVC Mid H04 0040
Coding: 012408012301000700
Shop #: WSC 00020 999 39850
ASAM Dataset: EV_CamSysRearPANAVW428 002002
ROD: EV_CamSysRearPANAVW428.rod
VCID: 3038E122AAA68727EA1-8064
10489856 - No Basic Setting
B2010 13 [009] - Open Circuit
Reset counter: 236
Mileage: 228161 km
Date: 2017.12.29
Time: 10:08:04
passive
Part No SW: 1K0 959 704 AK HW: 1K0 959 704 AK
Coding: 0001232
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 F HW: 3Q0 980 654
Component: MQB_B_MFK H04 0220
Serial number: 09021511P10527
Coding: 000406060000040100220153C080800090000E100000
ROD: EV_MFKBoschMQBB_VW36.rod
VCID: 3A2CC30A7CDA4D77545-806E
End----------(Elapsed Time: 01:27, VBatt start/end: 12.1V/12.1V)-----------
