I just got my new Kodiaq and bought a VCDS HEX-V2.
I could manage to change already some nice features but I’m just starting to learn.
There are some label-files missing and I have two specific things that I did not manage to change but which are quite annoying:
a) The tip-function to close the rear door with just a short tip on the key or the front switch.
Right now I have to hold the button. Only the button at the rear-door itself works with just a short tip.
b) The Start/Stop funktion. I found many references in many modules.
I would like to have it default „off“ instead of default „on“.
Right now it’s „on“ again after every ignition off. It should stay „off“.
Any hint I found so far, switches it off completely and generates error messages.
Do you have any idea that could help me?
Sonntag,17,Dezember,2017,14:50:41:38869
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x64
VCDS Version: PCI 17.8.1.0 HEX-V2 CB: 0.4409.4
Datenstand: 20171211 DS276.6
www.VCDSpro.de
Fahrzeug-Ident.-Nr.: TMBLK9NS5J8041507 KFZ-Kennzeichen:
Kilometerstand: 1560km Reparaturauftrag:
Fahrzeugtyp: NS-SK37 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 18 19 22 2B 36 3C 42 44
4B 52 5F 69 6C 6D 75 A5 CA D6 D7
Fahrzeug-Ident.-Nr.: TMBLK9NS5J8041507 Kilometerstand: 1560km
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
06-Sitzverst. Beifah. -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
18-Standheizung -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
22-Allrad -- Status: i.O. 0000
2B-Lenksäulenverrieg. -- Status: i.O. 0000
36-Sitzverst. Fahr. -- Status: i.O. 0000
3C-Spurwechsel -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
4B-Multifunktionsstg. -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
69-Anhänger -- Status: i.O. 0000
6C-Rückfahrkamera -- Status: i.O. 0000
6D-Heckklappe -- Status: i.O. 0000
75-Telematik -- Status: i.O. 0000
A5-Front-/Vorfeldkamera -- Status: i.O. 0000
CA-Schiebedachelektronik -- Status: i.O. 0000
D6-Lichtsteuerung links 2 -- Status: i.O. 0000
D7-Lichtsteuerung rechts 2 -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-DFHA) Labeldatei:. DRV\04L-907-309-V1.clb
Teilenummer SW: 04L 906 026 EJ HW: 04L 907 309 P
Bauteil: R4 2.0l TDI H25 3916
Revision: B4H25---
Codierung: 0125003A04761D083000
Betriebsnr.: WSC 33361 790 00157
ASAM Datensatz: EV_ECM20TDI01104L906026EJ 004004
ROD: EV_ECM16TDI01104L906026HM_004.rod
VCID: 76B416A6284E40E770D-8022
Adresse 02: Getriebe (J743) Labeldatei:. DRV\0BH-927-711.clb
Teilenummer SW: 0DL 300 011 N HW: 0GC 927 711 G
Bauteil: GSG DQ500 H06 2014
Revision: 00H06V07
Codierung: 0014
Betriebsnr.: WSC 00000 000 00000
ASAM Datensatz: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_SK37.rod
VCID: 3332EFB27BBC15CF973-8066
Adresse 03: Bremsenelektronik (J104) Labeldatei:. 5Q0-907-379-IPB-V1.clb
Teilenummer SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Bauteil: ESC H25 0513
Revision: 00000000 Seriennummer: 62647000000767
Codierung: 60076A9F54240B6D477C070062CA4906562AD0E2E046927D38615078E2AA4200002F641A1B13111435351919323200
ASAM Datensatz: EV_Brake1UDSContiMK100IPB 036010
ROD: EV_Brake1UDSContiMK100IPB_036_SK37.rod
VCID: 77AA1BA22F4439EF6BB-8022
Adresse 05: Zugangs-/Startber. (J518) Labeldatei:| DRV\5Q0-959-435.clb
Teilenummer SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Bauteil: VWKESSYMQB 037 0906
Revision: 00037000 Seriennummer: 0457521268
Codierung: 032C0C070F
ASAM Datensatz: EV_KessyHellaMQBAB 004041
VCID: 3E24CE8640FEC8A768D-806A
Steuergerät für Heckklappenöffnung:
Subsystem 1 - Teilenummer SW: 3G0 962 243 B HW: 3G0 962 243 B
Bauteil: GEB.F.Heckoef H17 0904
Seriennummer: 58271126
Adresse 06: Sitzverst. Beifah. (J521) Labeldatei:* Keine
Teilenummer SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Bauteil: Sitzmemory H08 0022
Seriennummer: Y0006QJ716432
Codierung: 0010000000000500018281818181000000008181000000D400
ASAM Datensatz: EV_SeatMemorPasseSide 002022
ROD: EV_SeatMemorPasseSide_VW41.rod
VCID: 3C20C48E56E2DAB7469-8068
Adresse 08: Klima-/Heizungsel. (J255) Labeldatei:| DRV\5G0-907-044.clb
Teilenummer SW: 565 907 044 AS HW: 565 907 044 AS
Bauteil: Climatronic H04 2001
Revision: 00001K00
Codierung: 1601010400411101110510480010102A
Betriebsnr.: WSC 33361 790 00111
ASAM Datensatz: EV_ACClimaBHBVW37X 006146
VCID: 6C8034CE66028A37969-8038
Steuergerät für Frischluftgebläse (vorn):
Geber für Kältemitteldruck und Kältemitteltemperatur:
Sensor für Luftgüte:
Subsystem 3 - Teilenummer SW: 5Q0 907 659 C HW: 5Q0 907 659 C
Bauteil: G238 _AQS H30 0119
Seriennummer: 62176580
Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\5Q0-937-08X-V2.clb
Teilenummer SW: 5Q0 937 086 BM HW: 5Q0 937 086 BH
Bauteil: BCM PQ37BOSCH 034 0242
Revision: -------- Seriennummer: 865813101700LX
ASAM Datensatz: EV_BodyContrModul1UDSBosc 018001
ROD: EV_BCMBOSCH_018.rod
VCID: 0654666658AE506760D-8052
Steuergerät für Wischermotor:
Subsystem 1 - Teilenummer SW: 566 955 119 HW: 566 955 119 Labeldatei: DRV\5QX-955-119-V1.CLB
Bauteil: WWS326 170922 051 0907
Seriennummer: 887353F0401726500481
Codierung: 164DDD
Sensor für Regen- und Lichterkennung:
Subsystem 2 - Teilenummer SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labeldatei: DRV\5Q0-955-547.CLB
Bauteil: RLHS 047 0105
Seriennummer: S4Y17M10D16H10M52S21
Codierung: 00885D
Geber für Luftfeuchtigkeit: innen:
Adresse 10: Einparkhilfe 2 (J791) Labeldatei:| DRV\5Q0-919-298.clb
Teilenummer SW: 3Q0 919 298 B HW: 3Q0 919 298
Bauteil: PLA 3.0 12K H09 0029
Seriennummer: 002109177478010
Codierung: 0231267A51
ASAM Datensatz: EV_EPHBO2CVW3260000 010016
ROD: EV_EPHBO2CVW3260000.rod
Adresse 13: Distanzregelung (J428) Labeldatei:| 2Q0-907-572.clb
Teilenummer SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Bauteil: ACCCONTIMQB H02 0233
Codierung: 320067CB54FF8728749C8145804087
ASAM Datensatz: EV_ACCMRRCONTIVW376 002012
Adresse 15: Airbag (J234) Labeldatei:| DRV\5Q0-959-655.clb
Teilenummer SW: 3Q0 959 655 BK HW: 3Q0 959 655 BK
Bauteil: Airbag VW21 006 0703
Revision: -------- Seriennummer: 003W6PLQ0C1/
Codierung: 98FCC0C0000000005C5400CF000840000065
ASAM Datensatz: EV_AirbaVW21TS6VW48X 001014
ROD: EV_AirbaVW21TS6VW48X_SK37.rod
VCID: 0848685E52BA4617121-805C
Gurtstraffer links:
Subsystem 1 - Teilenummer SW: 4M0 980 945 A HW: 4M0 980 945 A
Bauteil: BeltPretRevFL 106 1032
Seriennummer: 566857705A0285R01066
Codierung: 80000D
Gurtstraffer rechts:
Subsystem 2 - Teilenummer SW: 4M0 980 946 A HW: 4M0 980 946 A
Bauteil: BeltPretRevFR 106 1032
Seriennummer: 566857706A0285R01608
Codierung: 80000D
Crashsensor für Seitenairbag Fahrerseite:
Subsystem 3 - Teilenummer SW: ----------- HW: 454 002 609 17
Bauteil: SideSensor_Df 008 0887
Seriennummer: 3570000000095A3C882T
Codierung: 2D2D2D
Crashsensor für Seitenairbag Beifahrerseite:
Subsystem 4 - Teilenummer SW: ----------- HW: 454 002 609 17
Bauteil: SideSensor_Pf 008 0887
Seriennummer: 35800000000F2358292J
Codierung: 2D2D2D
Crashsensor für Seitenairbag hinten Fahrerseite:
Subsystem 5 - Teilenummer SW: ----------- HW: 454 800 310 17
Bauteil: SideSensor_Dr 301 0148
Seriennummer: 35100BE411F12000000F
Codierung: 2D2D2D
Crashsensor für Seitenairbag hinten Beifahrerseite:
Subsystem 6 - Teilenummer SW: ----------- HW: 454 800 510 17
Bauteil: SideSensor_Pr 301 0148
Seriennummer: 35200E00B3E12000000C
Codierung: 2D2D2D
Crashsensor für Frontairbag Fahrerseite:
Subsystem 7 - Teilenummer SW: ----------- HW: 454 801 709 17
Bauteil: FrontSensor_D 304 0149
Seriennummer: 355006F8B3C11000000R
Codierung: 2D2D2D
Adresse 16: Lenkradelektronik (J524) Labeldatei:| DRV\5Q0-953-549.clb
Teilenummer SW: 5Q0 953 521 GE HW: 5Q0 953 569 A
Bauteil: Lenks.Modul 075 0235
Revision: FF035035 Seriennummer: 20171012500095
Codierung: 6414
ASAM Datensatz: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB_VW37.rod
VCID: 7BA20792136C1D8F0F3-802E
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\5G0-920-XXX-17.clb
Teilenummer SW: 565 920 751 A HW: 565 920 751 A
Bauteil: KOMBI 304 0312
Codierung: 07A4001CEF84000801887B0B5001000800000000
Betriebsnr.: WSC 73430 031 00157
ASAM Datensatz: EV_DashBoardVDDMQBAB 009060
ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
VCID: 196E3D1AF910CF9FBDF-804C
Adresse 18: Standheizung (J364) Labeldatei:| DRV\5Q0-963-272.clb
Teilenummer SW: 5Q0 963 272 G HW: 5Q0 963 272 G
Bauteil: STH-MQB 008 0075
Codierung: 9309
ASAM Datensatz: EV_AuxilParkiHeateWOS 002018
ROD: EV_AuxilParkiHeateWOS_VW37.rod
VCID: 3A2CC2965CD6E487545-806E
Funkfernbedienung Standheizung:
Subsystem 1 - Teilenummer SW: 3Q0 963 513 HW: 3Q0 963 513
Bauteil: R64 D208L 004 0401
Seriennummer: 00000000000000332646
Adresse 19: Diagnoseinterface (J533) Labeldatei:| DRV\3Q0-907-530-V1.clb
Teilenummer SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Bauteil: GW MQB High 518 5304
Seriennummer: 17101710520466
Codierung: 0B0100345F087300EB03225E1E0F00010001070000000000000000000000
Betriebsnr.: WSC 33361 790 00114
ASAM Datensatz: EV_GatewNF 013023
ROD: EV_GatewNF_SK37.rod
Generator:
Steuergerät für Multifunktionslenkrad:
Subsystem 2 - Teilenummer SW: 3V0 919 719 B HW: 3V0 919 719 B
Bauteil: E221__MFL-PR6 H02 0160
Seriennummer: 000000000C1858021017
Steuergerät für Batterieüberwachung:
Subsystem 3 - Teilenummer SW: 5QA 915 181 C HW: 5QA 915 181 C
Bauteil: J367-BDMConti H03 1050
Seriennummer: 758861000017101212EC
Wechselrichter für Netzsteckdose:
Subsystem 4 - Teilenummer SW: 5Q0 907 155 H HW: 5Q0 907 155 H
Bauteil: U13DCAC H25 0780
Seriennummer: 0036619
Adresse 22: Allrad (J492) Labeldatei:* DRV\0CQ-907-554.clb
Teilenummer SW: 0CQ 907 554 H HW: 0CQ 525 130
Bauteil: Haldex4Motion H52 7083
Seriennummer: HA1-00010.08.17
Codierung: 0101
ASAM Datensatz: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_004_VW48.rod
VCID: 4ACC92560C367407C45-801E
Adresse 2B: Lenksäulenverrieg. (J764) Labeldatei:| DRV\5Q0-905-861.clb
Teilenummer SW: 3Q0 905 861 HW: 3Q0 905 861
Bauteil: ELV-MQBB H05 0032
Seriennummer: 17000262490007
Codierung: 0800000000000000
ASAM Datensatz: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB_AU58.rod
VCID: 71BE25BA412067DFA5F-8024
Adresse 36: Sitzverst. Fahr. (J810) Labeldatei:* Keine
Seriennummer: Y0006QJ817477
ASAM Datensatz: EV_SeatMemorDriveSide 002021
ROD: EV_SeatMemorDriveSide_VW41.rod
Adresse 3C: Spurwechsel (J1086) Labeldatei:| DRV\5Q0-907-686.clb
Teilenummer SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Bauteil: HRE_Master H12 0080
Seriennummer: 0456086611
Codierung: 02012103
ASAM Datensatz: EV_HREntryHella 001028
ROD: EV_HREntryHella_VW32.rod
VCID: 3D26C98A4DF8D3BF717-8068
Steuergerät 2 für Spurwechselassistent:
Adresse 42: Türelektr. Fahrer (J386) Labeldatei:| 5QX-959-X93-42.clb
Teilenummer SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Bauteil: TSG FS 011 0032
Seriennummer: 0000283221976
Codierung: 00150920DE00048000001100
ASAM Datensatz: EV_DCUDriveSideEWMAXCONT 006001
VCID: 47CAAB621F24896FDBB-8012
Türsteuergerät Fahrerseite hinten:
Subsystem 1 - Teilenummer SW: 5Q0 959 811 E HW: 5Q0 959 811 E Labeldatei: DRV\5QX-959-81X-V1.CLB
Bauteil: FOND_FHSG_DRV 006 0007
Seriennummer: 00000000000016741140
Codierung: 010200
Adresse 44: Lenkhilfe (J500) Labeldatei:| DRV\5Q0-909-143.clb
Teilenummer SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Bauteil: MQB_PP_APA 204 2051
Revision: 00000000 Seriennummer: 0002075923
Codierung: 01010011004001
ASAM Datensatz: EV_SteerAssisVWBSMQBA 009129
ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
VCID: 40D8B07E3A0ABE571A1-8014
Adresse 4B: Multifunktionsstg. (J745) Labeldatei:* Keine
Teilenummer SW: 3Q0 907 338 HW: 3Q0 907 338
Bauteil: FCM MQB Low 002 0286
Seriennummer: 11101710520363
Codierung: 000000070100037200002D01190000000000000000000000000000000000
ASAM Datensatz: EV_MultiModulContiVW48X 001010
ROD: EV_MultiModulContiVW48X_SK37.rod
VCID: 72BC2AB644265CC75C5-8026
Adresse 52: Türelektr. Beifahr. (J387) Labeldatei:| 5QX-959-X92-52.clb
Teilenummer SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Bauteil: TSG BFS 011 0032
Seriennummer: 0000282937773
Codierung: 00150120DE00048000001100
ASAM Datensatz: EV_DCUPasseSideEWMAXCONT 006001
VCID: 46D4A666182E906720D-8012
Türsteuergerät Beifahrerseite hinten:
Subsystem 1 - Teilenummer SW: 5Q0 959 812 E HW: 5Q0 959 812 E Labeldatei: DRV\5QX-959-81X-V1.CLB
Bauteil: FOND_FHSG_PSG 006 0007
Seriennummer: 00000000000016853697
Codierung: 190200
Adresse 5F: Informationselek. I (J794) Labeldatei:| 3V0-035-MIB-HGH2.clb
Teilenummer SW: 565 035 021 A HW: 565 035 021
Bauteil: MU-H-LND-EU H54 1163
Seriennummer: A853J0HB040789
Codierung: 03231601FF0000005111120100880A332F0100C4012085009E
ASAM Datensatz: EV_MUHig4CGen2HBAS 001001
VCID: 0C40544E46C22A37369-8058
Anzeige- und Bedienungseinheit 1 für Informationselektronik:
Subsystem 1 - Teilenummer SW: 565 919 606 D HW: 565 919 606 D
Bauteil: ABT_High-2 H50 9130
Seriennummer: SKZ6ZHT2832513
Datenträger:
Subsystem 2 - Teilenummer SW: V03 959 801 JN HW: -----------
Bauteil: ECE 2017/2018 --- 0161
Seriennummer: --------------------
Compact Disc Datenbank:
Subsystem 3 - Teilenummer SW: V03 959 800 EG HW: -----------
Bauteil: Gracenote2 --- 1016
Adresse 69: Anhänger (J345) Labeldatei:| DRV\5Q0-907-383.clb
Teilenummer SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Bauteil: Anhaenger H27 0264
Revision: 8A001003 Seriennummer: 0457857304
Codierung: 0100000202000000
ASAM Datensatz: EV_TrailFunctGener2Hella 001008
VCID: 42DCBA763406AC470C5-8016
Adresse 6C: Rückfahrkamera (J928) Labeldatei:* Keine
Teilenummer SW: 5Q0 907 556 C HW: 5Q0 907 556
Bauteil: Areaview 2 H13 0608
Seriennummer: C854707JG020586
Codierung: 04231601A70FA00000604014
ASAM Datensatz: EV_CamSysRVAV2ARCE2MQBAB 006017
VCID: 392EDD9A59D0EF9F5DF-806C
Adresse 6D: Heckklappe (J605) Labeldatei:| DRV\5Q0-959-107.clb
Teilenummer SW: 5Q0 959 107 L HW: 5Q0 959 107 J
Bauteil: HDSG-Modul H13 0261
Revision: -------- Seriennummer: 31595996800000
Codierung: 1B88
ASAM Datensatz: EV_DeckLidCONTIAU736 001014
VCID: 41DEB57A3100B75F15F-8014
Adresse 75: Telematik (J949) Labeldatei:| 5QE-035-285.clb
Teilenummer SW: 5NA 035 284 B HW: 5NA 035 284 B
Bauteil: OCULowMQBLGE H17 0717
Revision: --------
Codierung: 03231601EA423A0D3B1CBE020045400382E608
ASAM Datensatz: EV_OCULowMQBLGE 004044
ROD: EV_OCULowMQBLGE_004_VW25.rod
Adresse A5: Front-/Vorfeldkamera (R242) Labeldatei:* Keine
Teilenummer SW: 3QD 980 654 HW: 3Q0 980 654 A
Bauteil: MQB_B_MFK H08 1272
Seriennummer: 13091741K11177
Codierung: 020307060000040100222355C150A90098000E200020
ASAM Datensatz: EV_MFKBoschMQBB 001001
ROD: EV_MFKBoschMQBB_VW27.rod
Adresse CA: Schiebedachelektronik (J245) Labeldatei:| 4M0-907-594.clb
Teilenummer SW: 4M0 907 594 J HW: 4M0 907 594
Bauteil: SAD_STG_1 014 0005
Codierung: 608040632612
ASAM Datensatz: EV_SunRoofCONTIAU736 006008
ROD: EV_SunRoofCONTIAU736.rod
Adresse D6: Lichtsteuerung links 2 (A31) Labeldatei: 7P5-941-591.clb
Teilenummer SW: 7P5 941 591 AD HW: 7P5 941 591 A
Bauteil: LED1L H06 0005
ASAM Datensatz: EV_LED_PLUS_L_KEBODAVW416 001003
ROD: EV_LED_PLUS_L_KEBODAVW416_SK26.rod
VCID: 7EA40E86007E08A728D-802A
Adresse D7: Lichtsteuerung rechts 2 (A27) Labeldatei: 7P5-941-591.clb
Bauteil: LED1R H06 0005
ASAM Datensatz: EV_LED_PLUS_R_KEBODAVW416 001003
Ende----(Dauer: 18:22, Batt.-Spannung Start/Ende: 12.2V/12.1V, Deb=2)------
