Hello I have a 2007 Passat wagon with a used replacement EPB module, lost all coding when doing the replacement and now the dash is lit up like a christmas tree (abs, airbag,ses, etc). This is my first time using VCDS. It is my understanding that I need to code the ABS module first, and then code the EPB module, and also calibrate other sensors that lost their calibration. I have tried the "coding helper" in abs section but every time it says "coding accepted" but then when I read fault codes it shows up as not coded correctly.
I have read many threads on here where people have posted the Auto scan and you provided the coding they needed. I would like to understand what I am doing wrong and how to find the coding on my own in the future (I have another 2006 Passat with the same issue because I thought swapping from one vehicle to the other was a good way to diagnose if the part had failed, and it did help me to diagnose the failure but now I have two vehicles with lost coding hence the purchase of the VCDS software!)
Thanks in advance for any assistance you can offer.
Monday,11,December,2017,10:47:09:38514
VCDS Version: 17.8.0.1 (x64) HEX-NET CB: 0.4407.4
VIN: WVWLK73C67E005156 License Plate:
Mileage: 222270km-138112mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 6D
72
VIN: WVWLK73C67E005156 Mileage: 222270km-138112miles
08-Auto HVAC -- Status: Malfunction 1010
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 3C0 907 115 F HW: 3C0 907 115 F
Component: 2.0l R4/4V TFSI 0030
Revision: --H14--- Serial number: VWZCZ000000000
Coding: 040C010A19070160
Shop #: WSC 08139 444 85856
VCID: 23060729E2438A5EB7-8076
P1653 - 004 -
Mileage: 222279 km
Date: 2017.11.19
Time: 01:10:16
Load: 0.0 %
Temperature: 1.0°C
Temperature: 5.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.192 V
Readiness: 0110 0101
Part No SW: 09G 927 750 CJ HW: 09G 927 750 CJ
Component: AQ 250 6F 0841
Revision: 00H38000 Serial number:
Coding: 0000072
Shop #: WSC 05311 000 00000
VCID: 7BB61F493A73129EDF-802E
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0100004425
Coding: 0000000
VCID: 3228F26DADB913D64C-8066
7 Faults Found:
Mileage: 222279 km
Date: 2017.11.19
Time: 19:14:46
00532 - Supply Voltage B+
Mileage: 222279 km
Date: 2017.11.19
Time: 19:18:29
Mileage: 222279 km
Date: 2017.11.19
Time: 19:18:29
Mileage: 222279 km
Date: 2017.11.19
Time: 19:18:29
Mileage: 222279 km
Date: 2017.11.19
Time: 19:18:29
Mileage: 222279 km
Date: 2017.11.19
Time: 19:18:29
Mileage: 222279 km
Date: 2017.11.19
Time: 19:18:29
Part No: 1K0 820 047 EB
Component: Climatic PQ35 090 0505
VCID: 689C50055BE5A90622-803C
00898 - Control Circuit A/C compressor
010 - Open or Short to Plus
009 - Open or Short to Ground
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000002330124
Coding: 108C0F0340041A00470A00000F00000000285D435C0000
VCID: 373EC37946DBF6FE7B-8062
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 05311
Fault Status: 01101100
Reset counter: 181
Mileage: 222117 km
Date: 2017.09.14
Time: 09:31:00
Voltage: 14.35 V
Fault Status: 00101010
Reset counter: 210
Mileage: 221681 km
Date: 2017.09.06
Time: 19:37:00
Voltage: 13.95 V
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 N HW: 3C0 909 605 N
Component: 0B AIRBAG VW8R 031 2522
Revision: 12031000 Serial number: 003B2P2A47AV
Coding: 0012354
Shop #: WSC 08139 444 54185
VCID: 312AFD61A8BF28CE35-8064
Subsystem 1 - Part No: 3C0 959 339 A
Component: BF-Gewichtsens. 006 0002
Subsystem 2 - Serial number: 00000000032Z5T
Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME0E1332576ÿ†63
Subsystem 5 - Serial number: 332576ÿ†6342MSME0E11001D2ÿ†63
Subsystem 6 - Serial number: 1001D2ÿ†6351HTS63IKU1M43Oÿ†63
Subsystem 7 - Serial number: U1M43Oÿ†6361HTS64IKIT682Tÿ†63
Subsystem 8 - Serial number: IT682Tÿ†63727TS6PLLMPI038ÿ†63
Subsystem 9 - Serial number: MPI038ÿ†63827TS63IKEQ2G2Iÿ
Subsystem 10 - Serial number: EQ2G2Iÿ
03032 - Supply Voltage for Seat Occupied Recognition Control Module
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - MIL ON
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 H HW: 3C0 953 549 H
Component: J0527 0015
Revision: 00005000 Serial number: 3C9953507R
Coding: 0002014
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 970 R HW: 3C0 920 970 R
Component: KOMBIINSTRUMENT VD1 4240
Revision: X0033000 Serial number: 00000000000000
Coding: 0007205
Shop #: WSC 08080 444 180738
VCID: 3326F76952A31ADE47-8066
Fault Frequency: 14
Reset counter: 221
Mileage: 211727 km
Date: 2017.04.03
Time: 13:53:12
Reset counter: 221
Mileage: 222259 km
Date: 2017.10.16
Time: 21:00:18
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C062010E0E
Coding: 3FFD0E0CD22002
VCID: 210A0D21F85F984EA5-8074
Reset counter: 220
Mileage: 222259 km
Date: 2017.10.16
Time: 20:27:21
Fault Status: 01100010
Reset counter: 181
Mileage: 222279 km
Date: 2017.11.19
Time: 19:17:14
Part No SW: 3C0 919 965 A HW: 3C0 919 965 A
Component: Kompass 001 0002
Revision: 00001000 Serial number: 1339817TQ1RD02
VCID: 2E10E61DB981373628-807A
Part No SW: 3C0 959 433 C HW: 3C0 959 433 C
Component: IMMO 041 0364
Revision: 00041000 Serial number: VWZCZ000000000
VCID: 2A18EA0D85695B16F4-807E
Component: ELV 029 0380
3C0905861J ELV 029 0380
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Fault Frequency: 6
Reset counter: 221
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2365
Coding: 0001205
VCID: 3620CE7D41D10FF660-8062
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
Mileage: 2240 km
Temperature: 14.0°C
Voltage: 5.10 V
Voltage: 5.90 V
Component: KSG PQ46 RDK 041 0213
Coding: 13900E88D1032E521804141FF00A0F0E081800
Reset counter: 220
Mileage: 222259 km
Date: 2017.10.16
Time: 20:27:21
Fault Status: 00110010
Reset counter: 221
Mileage: 222259 km
Date: 2017.10.16
Time: 21:00:08
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001204
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0010000
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 98
Voltage: 11.90 V
Count: 170
Reset counter: 221
Mileage: 222272 km
Date: 2017.11.19
Time: 19:17:18
Voltage: 8.07 V
Count: 200
000 - - - MIL ON
Reset counter: 181
Mileage: 222272 km
Date: 2017.11.19
Time: 18:24:21
Voltage: 11.08 V
Count: 171
02443 - Control Head
Fault Status: 00111100
Reset counter: 221
Voltage: 11.90 V
Count: 40
01316 - ABS Control Module
Fault Status: 11101101
Reset counter: 181
Mileage: 298424 km
Date: 2017.09.21
Time: 00:00:01
Voltage: 11.59 V
Count: 236
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 A HW: 1K0 035 161 A
Component: Radio DE2 012 0014
Revision: 00012000 Serial number: VWZ4Z7E6057364
Coding: 0040402
Shop #: WSC 08355 444 79355
VCID: 1D7231D1C427BCAE81-8048
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 3C9 959 703 A
Component: Tuer-SG 021 2505
Coding: 0000144
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Component: RDK 0391
Coding: 0100101
Fault Frequency: 35
Reset counter: 221
Mileage: 222272 km
Date: 2017.10.17
Time: 18:22:18
00625 - Vehicle Speed Signal
Reset counter: 221
Mileage: 222279 km
Date: 2017.11.19
Time: 19:19:34
00667 - Ambient Temperature Signal
Fault Frequency: 255
Reset counter: 221
Mileage: 222279 km
Date: 2017.11.19
Time: 01:07:27
Address 6D: Trunk Elect. Labels: None
Part No SW: 3C9 827 383 B HW: 3C9 827 383 C
Component: J605 HECKDECKEL 0405
Revision: 00H20001
Shop #: WSC 23250 384 715754
VCID: 302CF865A3B521C63A-8064
Subsystem 1 - Part No: 3C9 827 384 B
Component: J756 HECKDECKEL 0405
Subsystem 2 - Serial number: 0800H21001001A0109ÿ
Reset counter: 221
Mileage: 222259 km
Date: 2017.10.16
Time: 20:59:10
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 3C9 959 704 A
Coding: 0000144
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End----------(Elapsed Time: 01:22, VBatt start/end: 12.2V/12.2V)-----------
