Hi All,
I have bought and fitted genuine VW front and rear parking sensors to my VW Transporter 2015 and experiencing issues with the front sensors.
The rear sensors work correctly and the fronts also when in close proximity to an object, but when moving forward after being in reverse, the front sensors flash\bleep away with nothing in front of the vehicle, until they switch off after about 7mph.
PDC module part no: 7E0 919 475 J
Front parking sensors part no: 1S0 919 275 C
I believe the PDC module is a slightly older variant as it covers various VW models, so I'm not too sure if I need a newer PDC module or the settings within it.
The company I bought the retro kit from said they would re-flash the PDC module but I'm not sure that will resolve the issue.
Any help or advice would be greatly appreciated, plus I've added my VCDS output.
Saturday,30,September,2017,12:44:17:15268
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
VIN: WV2ZZZ7HZFH139336 License Plate: N4VWV
Mileage: 17920km-11134mi Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 18 19 25 37 56 61 69 6C 0B
VIN: WV2ZZZ7HZFH139336 Mileage: 17920km-11134miles
Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 GQ HW: 03L 907 309 L
Component: R4 2,0L EDC H38 6305
Revision: 22H38--- Serial number: 00000000000000
Coding: 0119401A233401080000
Shop #: WSC 02757 790 50316
ASAM Dataset: EV_ECM20TDI01103L906019GQ 003004
ROD: EV_ECM20TDI01103L906019FH_003.rod
VCID: 005A8841FA80B9475BA-8054
Address 03: ABS Brakes (-----) Labels:. 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 L HW: 7E0 907 379 L
Component: ESP MK25A XT H50 0113
Revision: 00H50001
Coding: 608724AD09A7069E24A59074B96492
Shop #: WSC 02757 790 49152
VCID: 3B203FADD3661A9F4E8-806E
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 20031504650683
Coding: 01
ROD: EV_LWSKLOVW25X_VW25.rod
VCID: 7EA6F6B98074CFB7296-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BM HW: 7E5 907 047 BM
Component: Climatic-T5 H20 0506
Revision: 00001012
Coding: 0000000003
ROD: EV_ClimaT5Basis.rod
VCID: 7BA0FFAD9366DA9F0E8-802E
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 D HW: 7H0 937 090
Component: BCM PQ25 Max4 H78 0725
Revision: B9078001 Serial number: 0671 080151050
Coding: B8A4393A0A613412922049706E2B9CD40790602F7E844440320000020800
Shop #: WSC 61584 001 104857
VCID: 2F381BFD171EF63FF20-807A
Subsystem 1 - Part No SW: 7E0 959 801 K HW: 7E0 959 801 K Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8653
Serial number: KU0KU013031550722788
Coding: 1400B0
Subsystem 2 - Part No SW: 7E0 959 802 K HW: 7E0 959 802 K Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8653
Serial number: KU0KU013031550726115
Coding: 0400A0
Subsystem 3 - Part No: 7E1 951 172
Subsystem 5 - Part No: 7E1 951 172
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 J HW: 7N0 919 475
Component: PARKHILFE 8K H06 0105
Revision: -------- Serial number: 28261201602080
Coding: 318002
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_VW75XParkAssis8K 001003
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 392C25A5D9DA288F5C4-806C
Part No SW: 7E0 959 655 C HW: 7E0 959 655 C
Component: VW10Airbag00P H07 0013
Revision: -------- Serial number: 003HM0064X21
Coding: 000000000000000000000000000000003050
Shop #: WSC 02754 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 36362E99E8C4C7F7B16-8062
Serial number: 3495ZRB400U52PK4F9UN
Serial number: 3505ZRB405533RVQN0VT
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 7E0 920 970 N HW: 7E0 920 970 N
Component: KOMBI H04 0805
Coding: 460B01
Shop #: WSC 02737 790 50316
ROD: EV_Kombi_UDS_VDD_RM09_004_VN35.rod
VCID: 35342995F5C2CCEFB8C-8060
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 C
Component: J737__Standheizung 0605
Revision: 00087000 Serial number: 09024900A00000
Coding: 0020031
Shop #: WSC 02757 790 00000
VCID: 2514F9D549E2BC6F08C-8070
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H78 0725
Revision: B9078001
Coding: 042300
VCID: 70BAD881CAA0A9C7ABA-8024
Component: IMMO H04 0805
VCID: 6A8ECAE9ECFC5317E5E-803E
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 H HW: 1T0 035 680 H
Component: RNS-MID H64 4020
Revision: AB001001 Serial number: VWZ6Z7M6132157
Coding: 04000400040000900014
Shop #: WSC 00704 210 90535
VCID: 3330178DFB36D2DF968-8066
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Part No SW: 7H0 907 534 HW: 7H0 937 090
Component: Batt.regelung H78 0725
Coding: 330B1A73
Shop #: WSC 02737 790 00000
VCID: 6B80CFEDE3864A1F9E8-803E
Subsystem 1 - Part No SW: 7E0 915 181 E HW: 7E0 915 181 E
Component: J367-BDM H08 0223
Serial number: 62064248594261657485
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 G HW: 1K0 907 383 G
Component: Towbar module H10 0110
Revision: 3A001001 Serial number: ÀÁ006789000000
Coding: 0100000100000000
VCID: 313C1D85012AE0CFE44-8064
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7E0 907 441 HW: 7E0 907 441
Component: J772__Rearview 0040
Revision: 00H13000 Serial number: 525PA8-J470733
Coding: 0030015
Shop #: WSC 02637 002 1048576
VCID: 6594B9D509627C6FC8C-8030
End----------(Elapsed Time: 01:59, VBatt start/end: 12.1V/12.1V)-----------
