Chassis Type AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F 65
VIN: WVWZZZAUZDP030596 Mileage: 67830km-42147miles
65-Tire Pressure -- Status: Cannot be reached 0100
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC H22 4943
Revision: 83H22---
Coding: 111D0032042505082000
Shop #: WSC 00028 028 00073
ASAM Dataset: EV_ECM20TDI01104L906021DT 002003
ROD: EV_ECM20TDI01104L906021DT_002.rod
VCID: 7AFB10C5FD0D3D96C4-802E
5250 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 67830 km
Date: 2017.12.01
Time: 09:12:18
Coolant temperature: 82 °C
Intake air temperature: 69 °C
Voltage terminal 30: 12.180 V
Longitudinal acceleration: raw value: 32.767 m/s²
Vehicle inclination acceleration angle: raw value: -12.557 m/s²
Status: incline angle-Bit 0: 1
Longitudinal acceleration: 0.000 m/s²
Longitudinal acceleration sensor: status-Bit 0: 1
Vehicle lateral acceleration: raw value: 0.01 g
Vehicle lateral acceleration: 0.01 g
17158 - Databus
U1123 00 [039] - Received Error Message
Mileage: 67830 km
Date: 2017.12.01
Time: 09:12:17
Drivetrain coordinator: ACC fault status-Bit 0: 0
Drivetrain coordinator: ACC fault status-Bit 8: 0
Drivetrain coordinator: brake fault status-Bit 0: 4
Drivetrain coordinator: brake function status-Bit 0: 0
Drivetrain coordinator: brake function status-Bit 8: 0
Acceleration: 0.000 m/s²
Part No SW: 0D9 300 040 A HW: 02E 927 770 AN
Component: DQ250-6F MQB H52 3613
Revision: 05652103 Serial number: TFK01210210095
Shop #: WSC 00028 028 00308
ROD: EV_TCMDQ250021_VW37.rod
VCID: 15212379F453F2EE49-8040
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 01FA8AA120230A6C037C060901C92980510450C0608094F3006A0028C1
Shop #: WSC 00028 028 00205
ROD: EV_Brake1UDSContiMK100IPB_008.rod
VCID: 7DF11BD9EC230AAEE1-8028
7 Faults Found:
0212 - Longitudinal Acceleration Sensor
C1017 54 [137] - Missing Calibration / Basic Setting
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:21:06
0270 - Lateral Acceleration Sensor
C1079 54 [137] - Missing Calibration / Basic Setting
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:21:06
0295 - Steering angle sensor
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:21:06
8277 - Databus
U1122 00 [009] - Implausible Message
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:21:06
8299 - Databus
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:21:06
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:21:15
33000 - Longitudinal Acceleration
C10B1 29 [137] - Signal Implausible
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:21:06
Address 08: Auto HVAC (J255) Labels:. 5G0-907-044.clb
Part No SW: 5G0 907 044 Q HW: 5G0 907 044 Q
Component: Climatronic H02 0503
Revision: 00001K06
Coding: 00120104200100011005000012101800
ROD: EV_ACClimaBHBVW37X_002.rod
VCID: 3561C3F9949312EE69-8060
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 N HW: 5Q0 937 084 N
Component: BCM MQBAB M H14 0106
Serial number: 00011233300327
Coding: 03001842C2C102EB0FA4400000040308101A000000000000000000000000
ROD: EV_BCMBOSCH_010.rod
VCID: 4385AD21CA47BC5ED7-8016
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 121113 042 0551
Serial number: 121116131946
Coding: 0E4DD5
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y12M12D28H10M35S54S1
Coding: 00A8DD
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K 002 0026
Revision: -------- Serial number: 94231233000839
Coding: 0031150051
ASAM Dataset: EV_EPHVA18AU3700000 002016
VCID: 3A7BD0C5BD8DFD9684-806E
13637426 - Databus
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:12:17
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Component: AirbagVW20 011 0361
Serial number: 003F5R01MVEW
Coding: 98CCC000000000005C00000000C800000065
Shop #: WSC 00028 028 00053
VCID: 408FA22DDB51A746CA-8014
Subsystem 1 - Part No SW: ----------- HW: 480 001 112 12
Serial number: 35767000000DA2856C0+
Subsystem 2 - Part No SW: ----------- HW: 480 001 112 12
Serial number: 35867000000178553C0R
Subsystem 3 - Part No SW: ----------- HW: 480 401 012 12
Serial number: 3516502B90CAF160E17M
Subsystem 4 - Part No SW: ----------- HW: 480 401 412 12
Serial number: 3526502A90CD5EC6014N
Subsystem 5 - Part No SW: ----------- HW: 480 401 012 12
Serial number: 3556502B50CAF164F0DW
Part No SW: 5Q0 953 507 AE HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 10121208491446
Coding: 0410
Shop #: WSC 41110 002 1048576
ROD: EV_SMLSKLOMQB_009_VW37.rod
VCID: 79F90FC9F80B368ECD-802C
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5G0 920 860 A HW: 5G0 920 860 A
Component: KOMBI 236 0555
Coding: 27A401882B900A0801886A05040000
VCID: 264314B559356976D0-8072
6 Faults Found:
16776960 - Databus
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:12:17
16776961 - Databus
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:12:17
16776970 - Databus
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:12:17
16776989 - Databus
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:12:17
16776980 - Databus
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:12:17
16776987 - Databus
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:12:17
Part No SW: 5Q0 907 530 E HW: 5Q0 907 530 E
Component: GW MQB Mid 121 1109
Revision: -------- Serial number: 0000148890
Coding: 030100340B087300EF0006481C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 006010
ROD: EV_GatewLear_006.rod
VCID: 3365FDE19AE70CDE47-8066
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H13 0035
Serial number: 23120002711490100291
Coding: 280000
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 4452378601
131585 - No Communications with Undefined Control Module
U1126 00 [009] - -
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:12:18
Supply voltage: Terminal 30: 12.0 V
Terminal 15: On
131586 - No Communications with Undefined Control Module
U1126 00 [009] - -
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:12:18
Terminal 15: On
131595 - Tire Pressure Monitoring Module
U0127 00 [009] - No Communications
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:12:18
Terminal 15: On
131748 - Control Module for Auxiliary Heater
U1099 00 [009] - No Communications
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:12:18
Terminal 15: On
U1101 00 [009] - Active
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:12:18
Terminal 15: On
Part No SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000054678700
Coding: 003F0220FC01028000001001
Shop #: WSC 00028 028 00310
VCID: 020B682595DD75569C-8056
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000000458258
Coding: 0D0000
65604 - Door Warning Lamp
B1326 01 [009] - Electrical Failure
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:12:17
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 80
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D71DBD9ACA3CAAEA1-8068
19204 - Databus
Reset counter: 229
Mileage: 67830 km
Date: 2017.12.01
Time: 09:12:17
Motor status: 00
Supply voltage: 12.00 V
Temperature: 68.0 °C
KFC: 4B
KFA: 00 04
Environmental conditions: 7F
uAdSensI_U5VFiltered_xdu16: 5.05865 V
uioUdNotFilt_xdu16: 12.14 V
uAdSensI_SwitchedKl30_xdu16: 12.14 V
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000056100389
Coding: 003B1020DE01028000801001
VCID: 0109672990DB6E4E85-8054
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000000453641
Coding: 050000
Address 65: Tire Pressure
