Odd behaviour scanning module 02 on Golf 7 GTI
Adrian E
C?ID=258567
Hi folks
A couple of times when scanning my 2015 Golf GTI I've had a bunch of spurious codes show up under module 02 - interestingly at the top of the scan there's no mention of a malfunction. No fault shows on the instrument cluster and the gearbox is working perfectly. Had it scanned twice in the dealer and nothing shows for them on ODIS.
Latest scan is below:
Thursday,23,November,2017,08:13:59:11450
VCDS Version: 17.8.0.1 (x64)
VIN: WVWZZZAUZGW188097   License Plate:
Mileage: 25876km-16078mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 32 42 44 47 52 55
          5F 69 A9
VIN: WVWZZZAUZGW188097   Mileage: 25876km-16078miles
Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
   Revision: --H13---
   Coding: 091D00124474050B3000
   ROD: EV_ECM20TFS0205G0906259C.rod
   VCID: 2E591471713BFF3628-807A
   Part No SW: 0D9 300 020 J    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H53 4901
   Revision: 06253104    Serial number: TFK01510310784
   ROD: EV_TCMDQ250021_VW37.rod
   VCID: 1C3DCEB917877DA676-8048
21153 - Gear 1
          P072C 00 [002] - Not Selectable
21159 - Gear R
          P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
          P174A 00 [002] - Electrical malfunction
10906 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
   Revision: 00000000    Serial number: 63065000000711
   Coding: 01FA93A1542829740777060941CA6980C92A94E0608296F7184250F9C209
   VCID: 7AF1E821FDF3E396C4-802E
   Revision: 00021000    Serial number: 0385973324
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3A712821BD73239684-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00120004200100011005000000101002
   VCID: 6AD1D8618D53531634-803E
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061531500709
   Coding: 03031A46C24122FB0BA44080B11C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_015_VW37.rod
   VCID: 091387EDA815F80EDD-805C
   Component: WWS    150925  042 0551
   Serial number:         151027030631
   Component: RLHS  037 0059
   Serial number: S5Y15M11D19H19M41S45
   Coding: 90A8DD
   Serial number: 000000000ZY152931J6T
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000033718412
   Revision: --------    Serial number: 39391531506171
   Coding: 0071151111
   Shop #: WSC 22255 002 1048576
   VCID: 438F55C5CAB9625ED7-8016
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 20101503211707
   Coding: 001C1B00FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
1542 - Sensor for Automatic Distance Control
                    Reset counter: 56
                    Mileage: 25665 km
                    Date: 2017.09.24
                    Time: 16:39:33
                    Control Module temperature: 31 °C
                    Voltage terminal 15: 13.2 V
                    Vehicle speed: 6.14 m/s
                    Acceleration: 0.37 m/s²
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 01111541350043
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 377731158E613EFE7B-8062
   Serial number: 003MLR1805EF
   VCID: 7F071935E6D1C6BEF3-802A
   Belt Pretensioner left:
   Component: BeltPretRevFL  H36 0350
   Serial number: 34169677B14111550260
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H36 0350
   Serial number: 34169676B13111540257
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 711 15
   Serial number: 357670000005F1F0C71+
   Subsystem 4 - Part No SW: -----------    HW: 480 001 711 15
   Serial number: 35867000000CB568A713
   Subsystem 5 - Part No SW: -----------    HW: 480 400 911 15
   Serial number: 3516502B31D3F984038E
   Subsystem 6 - Part No SW: -----------    HW: 480 400 911 15
   Serial number: 3526502B11D3F9822237
   Subsystem 7 - Part No SW: -----------    HW: 480 400 911 15
   Serial number: 3556502A91D3F983239P
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 10111504221406
   Coding: 0410
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 071781D5BE018E7ECB-8052
   Part No SW: 5G1 920 956 A    HW: 5G1 920 956 A
   Component: KOMBI         302 6420
   Coding: 27AD09183F80260001886A011400000000000000
   VCID: 2D5B137D7C3D842E11-8078
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1244
   Revision: --------    Serial number: 0004173981
   Coding: 030100343F085900FB00027F9C0F00010001050000000000000000000000
   VCID: 79F3F72DF8F5E88ECD-802C
   Serial number: 29150002253780035457
   Coding: 2DFFFF
   Serial number: 2597508403
   Revision: 00000000    Serial number: 15000243216009
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_004_VW37.rod
   VCID: 346D06199F17D5E65E-8060
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00029.09.15
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 479741D5FE814E7E0B-8012
   Serial number: 240815BHM18837
   Coding: 003F1220D001048000001000
   Serial number: 00000000000008052530
   Coding: 0D0000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   VCID: 3973372DB875288E8D-806C
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H20 0130
   Revision: 00000001    Serial number: VWZ8Z1FBA014VUT
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI_VW37.rod
   VCID: 6DDBD37DBCBD442E51-8038
   Serial number: 011015BIU08245
   Coding: 003F1020DE01048000801000
   VCID: 428150C1D5A36B56DC-8016
   Serial number: 00000000000008080928
   Coding: 150000
   Coding: 029603000B010200
   VCID: 40855AC9DBAF7946CA-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   Part No SW: 3G0 035 020 C    HW: 3G0 035 020
   Component: MU-H-ND-EU    H50 0343
   Serial number: A682K0FB003937
   Coding: 027300010000000051111102008808001F0203F601200100DF
   VCID: 1737D195EEA11EFE5B-8042
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU303WQT
   Subsystem 2 - Part No SW: V03 959 800 QQ    HW: -----------
   Component: ECE 2017  --- 0157
   Component: Gracenote2  --- 1012
   Part No SW: 5Q0 907 383 H    HW: 5Q0 907 383 C
   Component: Anhaenger     H21 0203
   Revision: 8B001003    Serial number: 0385358829
   Coding: 0100000202000000
   VCID: 3C7D2E39B7471DA696-8068
   Serial number: 150918200499
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
   VCID: 6BDFDD6582A94A1E4F-803E
End-------------------------(Elapsed Time: 05:17)--------------------------
There's also a more spectacular looking set of codes from one earlier in the year!
Saturday,18,March,2017,19:38:30:11450
VCDS Version: 17.1.2.1 (x64)
Data version: 20170131 DS267.1
Mileage: 19430km-12073mi   Repair Order:
Chassis Type: AU (5Q0)
          5F 69 A9
VIN: WVWZZZAUZGW188097   Mileage: 19430km-12073miles
Address 01: Engine (J623-CHHA)       Labels: 06K-907-425-V1.clb
   Revision: --H13---
   VCID: 2E591471713BFF3140-807A
   ROD: EV_TCMDQ250021.rod
   VCID: 1C3DCEB917877DA11E-8048
12 Faults Found:
21153 - Gear 1
21154 - Gear 2
          P072D 00 [002] - Not Selectable
21155 - Gear 3
          P072E 00 [002] - Not Selectable
21156 - Gear 4
          P072F 00 [002] - Not Selectable
21157 - Gear 5
          P073A 00 [002] - Not Selectable
21158 - Gear 6
          P073B 00 [002] - Not Selectable
21159 - Gear R
10732 - Valve 3 in Transmission Part 2
          P174E 00 [002] - Electrical malfunction
10909 - Cooling Oil Valve
21207 - Pressure Control Solenoid 3
          P0797 00 [002] - Short to Plus
   VCID: 7AF1E821FDF3E391AC-802E
   Coding: 030C0C
   VCID: 3A712821BD732391EC-806E
1052939 - Touch Sensor on Exterior Door Grip; Driver Side
          B116B 13 [008] - Open Circuit
                    Reset counter: 56
                    Mileage: 1048574 km
                    Time: 00:00:00
   Revision: 00001K08
   VCID: 6AD1D8618D5353115C-803E
   ROD: EV_BCMBOSCH_016_AU37.rod
   VCID: 091387EDA815F809B5-805C
   Coding: 90A8DD
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Coding: 0071051111
   VCID: 438F55C5CAB96259BF-8016
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   ROD: EV_DRCONTITEMIC.rod
   VCID: 377731158E613EF913-8062
   VCID: 7F071935E6D1C6B99B-802A
   Coding: 333135
   Coding: 333135
   Coding: 0410
   ROD: EV_SMLSKLOMQB_SK48.rod
   VCID: 071781D5BE018E79A3-8052
   VCID: 2D5B137D7C3D842979-8078
   ROD: EV_GatewLear_013.rod
   VCID: 79F3F72DF8F5E889A5-802C
   Coding: 2DFFFF
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 346D06199F17D5E136-8060
Address 32: Differential Locks (J492)       Labels: 0CQ-907-554.clb
   Coding: 0001
   VCID: 479741D5FE814E7963-8012
   Coding: 0D0000
   Coding: 8103
   ROD: EV_SteerAssisMQB_VW31.rod
   VCID: 3973372DB8752889E5-806C
   ROD: EV_AMPMst11CGen2ALPI.rod
   VCID: 6DDBD37DBCBD442939-8038
   VCID: 428150C1D5A36B51B4-8016
   Coding: 150000
   VCID: 40855AC9DBAF7941A2-8014
   Coding: 2E0000
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-HGH2.clb
   Coding: 027300010000000051111102008808001F0203E601200100DF
   VCID: 1737D195EEA11EF933-8042
1553 - Function Restriction
          B200D F0 [008] - due to Internal Communcations Error
                    Reset counter: 61
                    Mileage: 19030 km
                    Date: 2017.02.18
                    Time: 07:29:45
                    Voltage terminal 30: 15.0 V
Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
   VCID: 3C7D2E39B7471DA1FE-8068
   VCID: 6BDFDD6582A94A1927-803E
End-------------------------(Elapsed Time: 05:19)--------------------------
I've got 4 other scans where nothing has shown up, so it's not a consistent issue. I wondered if it might be a comms issue with the module?
Cheers
Adrian
It's weirdness in the diagnostic stack of some modules, combined with the fact that VCDS digs a bit deeper for fault codes than ODIS does. You can turn off this off by de-selecting "Use Aggressive Mode".
Bottom line though: When all the faults in a module are flagged, "Intermittent - Not Confirmed" and the Gateway reports the status of that module as "OK" (which it does in this case), I would not worry about those faults.
