Seat ibiza downgrade from Xenon to halogen
Jurgens
C?ID=321320
I bought a Seat Ibiza 2012 that had been in a crash. The front side was damaged and the 2 Xenon headlight units were broken beyond repair.
I have replaced the Xenon units for halogen units and all the lights work expect for the parking lights. The parking lights do go on but are very weak.
Also I wrongfully assumed it would be easy to code the BCM to accept the halogen without the indicator light coming on.
After lot's of time searching I still haven't figured out if this is even possible. After deselecting address 55 from the installation list it gives an error that the coding is incorrect. (I didn't touch the coding)
I tried comparing the code to a 2010 Seat ibiza of mine with halogen that has a 088 B instead of 088 F but couldn't figure out what to do yet and the labels don't help with this aspect.
So in short:
1. Is there a way to get the parking light on at normal strength (they are at pin 10 of the connector)
2. Do I need to change the CAN gateway coding as well to properly remove Xenon from the installation list? And will this fix the indicator light?
Tuesday,21,November,2017,20:28:03:19952
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4407.4
VIN: VSSZZZ6JZDR051503   License Plate:
Mileage: 150140km-93292mi6   Repair Order:
Chassis Type: 6J-SE25 (6R0)
Scan: 01 03 08 09 10 15 17 19 25 44 4B 55 56 61
VIN: VSSZZZ6JZDR051503   Mileage: 150140km-93292miles
55-Headlight Range -- Status: Not registered 0011
Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 BC    HW: 03P 906 021 BC
   Component: R3 1.2l TDI   H09 9979
   Revision: 12005001    Serial number:
   Coding: 00114014032401080000
   Shop #: WSC 06402 785 00200
   ASAM Dataset: EV_ECM12TDI03103P906021BC 001010
   ROD: EV_ECM12TDI.rod
   VCID: 6A8D3C7B3CFB3657E5E-803E
15912 - Glow Plug Module 1; Glow Plug Circuit
          P0670 00 [039] - Electrical Malfunction
                    Mileage: 150148 km
                    Date: 2017.11.21
                    Time: 05:23:33
                    Engine speed: 813.50 /min
                    Normed load value: 18.8 %
                    Coolant temperature: 82 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 13.296 V
                    Unlearning counter according OBD: 0
                    Sensor for engine block temperature: raw value: 82 °C
                    Electric auxiliary heater: relay activation: 0
                    Glow status: 09
                    Outside air temperature: 10 °C
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0001
   Revision: --------
   Coding: 110224DB817200B3882A24E281D400521000
   Shop #: WSC 04941 000 00000
   VCID: 025D74DB244BCE174DE-8056
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
   Part No SW: 6J0 820 043 D    HW: 6J0 820 043 D
   Component: Climatronic   H08 0707
   Revision: S0000000
   VCID: 25170F4795E5D92F08C-8070
   Part No SW: 6R0 937 088 F    HW: 6R0 937 088
   Component: BCM PQ25 Re4  H50 0353
   Revision: BU050001    Serial number: 0456 131120432
   Coding: 7A880BE88861010001300EF56CCB8ED80E8067E97E8D3001200000000000
   Shop #: WSC 64564 324 38760
   VCID: 41DFBBD7618D150F144-8014
   Component: RLS 100512 05  54  0403
   Coding: 02242D
   Subsystem 2 - Part No SW: 6R0 959 801 N    HW: 6R0 959 801 N  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 3110
   Coding: 420000
   Subsystem 3 - Part No SW: 6R0 959 802 Q    HW: 6R0 959 802 Q  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 3110
   Coding: 420000
   Subsystem 4 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3121
   Subsystem 5 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3121
Address 10: Park/Steer Assist (J446)       Labels:| 6J0-919-475.clb
   Part No SW: 6J0 919 475 C    HW: 6J0 919 475 C
   Component: PARKHILFE 4K  H09 0012
   Revision: --------    Serial number: 32961214202911
   Coding: 000007
   ASAM Dataset: EV_SE250ParkiAssis2 S01711
   ROD: EV_SE250ParkiAssis2.rod
   VCID: 3635D80B38C3A2B7B16-8062
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10AirbagA09 H10 0020
   Revision: --------    Serial number: 003GX018J6CC
   Coding: 003039
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250_VW31.rod
   VCID: 4ACD9CFB5C3BD657C5E-801E
   Serial number: 3495RRB405518BCIHHP.
   Serial number: 3505RRB404P18B74H93%
   Part No SW: 6J0 920 804 N    HW: 6J0 920 804 N
   Component: KOMBI         H03 0507
   Coding: 510E00
   VCID: 3537DF0725C5A9AFB8C-8060
Address 19: CAN Gateway (J533)       Labels:. 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 E    HW: 1K0 907 951
   Component: J533  Gateway H38 0041
   Revision:   H38       Serial number: 060512F2002207
   Coding: 2532C2
   Shop #: WSC 04941 123 12345
   VCID: 3537DF072545A9AFB8C-8060
                    Mileage: 150141 km
                    Date: 2017.11.21
                    Time: 05:00:42
   Component: IMMO          H03 0507
   Part No: 6R0 423 156 B
   Component: LenkhilfeTRW        V277
   Coding: 11211
   Shop #: WSC 06402
   VCID: 2F3BED6FCE59937FF20-807A
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441 A
   Component: MF-Modul       0007 0001
   Shop #: WSC 77005 000 00000
   VCID: 313FEB17DD2D858FE44-8064
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 C    HW: 7L6 907 357 C
   Component: AFS-Steuergeraet    0147
   Coding: 2688068
   VCID: 3B23C93F0F217FDF4E8-806E
   Subsystem 1 - Part No: ID-L fehlt    Labels: ID-55-01.CLB
   Component: AFS-Lst.-Modul l    ....
   Coding: 00000255
   Subsystem 2 - Part No: ID-R fehlt    Labels: ID-55-02.CLB
   Component: AFS-Lst.-Modul r    ....
   Coding: 00000255
10 Faults Found:
02233 - Left Headlight Power Output Stage (J667)
                    Fault Status: 00101110
                    Reset counter: 235
                    Mileage: 150141 km
                    Date: 2017.10.19
                    Time: 00:49:28
                    Voltage: 11.36 V
                    Speed: -2.6 km/h
                        ABS 1
02627 - Dynamic Cornering Light Motor; Left (V318)
                    Fault Status: 00101010
                    Reset counter: 235
                    Mileage: 150141 km
                    Date: 2017.10.19
                    Time: 00:49:28
                    Voltage: 11.36 V
                    Speed: -2.6 km/h
                        ABS 1
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Reset counter: 195
                        Invalid
                        Invalid
                        Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
            000 -  -  - MIL ON
                    Reset counter: 195
                        Invalid
                        Invalid
                        Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 -  -  - MIL ON
                    Reset counter: 195
                        Invalid
                        Invalid
                        Invalid
                    Fault Status: 11100101
                    Reset counter: 195
                        Invalid
                        Invalid
                        Invalid
                    Fault Frequency: 11
                    Reset counter: 235
                    Mileage: 150141 km
                    Date: 2017.10.04
                    Time: 21:49:41
                    Voltage: 11.79 V
                    Speed: 7.8 km/h
                        ABS 1
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
                    Reset counter: 235
                    Mileage: 150141 km
                    Date: 2017.10.19
                    Time: 00:49:31
                    Voltage: 11.36 V
                    Speed: -2.6 km/h
                        ABS 1
02626 - Dynamic Cornering Light Motor; Right (V319)
                    Fault Status: 00100111
                    Reset counter: 235
                    Mileage: 150141 km
                    Date: 2017.10.04
                    Time: 21:49:40
                    Voltage: 11.64 V
                    Speed: 5.2 km/h
                        ABS 1
02629 - Sensor for Swivel Module Position; Left
                    Reset counter: 235
                    Mileage: 150141 km
                    Date: 2017.10.04
                    Time: 21:49:58
                    Voltage: 12.07 V
                    Speed: -2.6 km/h
                        ABS 1
Address 56: Radio
   Part No SW: 6R0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H38 0041
   Coding: 030B185A
   VCID: 74B122036EBFF0A74F2-8020
   Subsystem 1 - Part No SW: 6R0 915 181 E    HW: 6R0 915 181 E
   Component: J367-BDM  H08 0181
   Serial number: 00000000004970303187
End----------(Elapsed Time: 01:21, VBatt start/end: 13.3V/13.0V)-----------
Jurgens
C?ID=321320
Yes, I compared them but I suspect that the sidelight in the xenon unit was PWM controlled and the halogen sidelight bulb just wants fixed 12V.
Manual range control isn't installed yet because the correct light switch panel hasn't arrived yet.
Jurgens
C?ID=321320
After physically disconnecting the xenon headlight controller I could also turn it off in the gateway. I didn't know this was required.
The sidelights are still very weak though and the light indicator light is still on. The autoscan (I will post the new one later) doesn't show any errors.
Can anybody point me in the right direction?
Jurgens
C?ID=321320
Ok thanks. I'll do some voltage and resistance measurements.
DV52
C?ID=194404
Jurgens: Just as a suggestion - if you want to turn PWM into a "solid-ish" DC voltage and if the wattage of the sidelights isn't too high (which it shouldn't be), have you considered placing a capacitor (probably of an electrolytic type) across the lamp? It will have the effect of dampening the square wave drive signal - which might fool the lamp into believing that it's not PWM.
Jurgens
C?ID=321320
Don, I thought about it but I'm afraid that I will burn out the PWM module because of the increase in current during the pulses. Maybe in combination with a mosfet to a 12V line. First I'll measure if it really is a PWM signal.
current autoscan as promised:
Sunday,26,November,2017,11:59:23:19952
VIN: VSSZZZ6JZDR051503   License Plate: 56XJR7
Mileage: 150190km-93323mi   Repair Order:
Scan: 01 03 08 09 10 15 17 19 25 44 4B 56 61
VIN: VSSZZZ6JZDR051503   Mileage: 150190km-93323miles
          P0670 00 [047] - Electrical Malfunction
                    Fault Frequency: 11
                    Mileage: 150148 km
                    Date: 2017.11.21
                    Time: 05:23:33
                    Unlearning counter according OBD: 1
                    Glow status: 09
15908 - Glow Plug Control Module (J179)
          P0684 00 [047] - Implausible Signal
                    Mileage: 150148 km
                    Date: 2017.11.24
                    Time: 04:54:38
                    Coolant temperature: 7 °C
                    Intake air temperature: 0 °C
                    Voltage terminal 30: 12.359 V
                    Sensor for engine block temperature: raw value: 7 °C
                    Glow status: 02
                    Outside air temperature: 6 °C
17668 - Diesel Particulate Filter; Differential Pressure Sensor
          P2456 00 [096] - Intermittent
                    Mileage: 150170 km
                    Date: 2017.11.25
                    Time: 01:17:42
                    Engine speed: 899.25 /min
                    Normed load value: 13.3 %
                    Vehicle speed: 60 km/h
                    Coolant temperature: 94 °C
                    Intake air temperature: 10 °C
                    Voltage terminal 30: 14.820 V
                    Crankshaft speed (RPM): 896 /min
                    Ambient air pressure: 101 kPa
                    Voltage terminal 30 stabilized: 14.8 V
   Revision: --------
   Revision: S0000000
                    Fault Status: 00101101
                    Reset counter: 236
                    Mileage: 150148 km
                    Date: 2017.11.24
                    Time: 05:07:27
   Coding: 02242D
   Coding: 420000
   Coding: 420000
   Coding: 000007
   Coding: 003039
   Coding: 510E00
   Coding: 2532C2
   Coding: 11211
   Shop #: WSC 06402
Address 56: Radio
   Coding: 030B185A
End----(Elapsed Time: 01:19, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Sunday,26,November,2017,12:15:03:19952
                    Mileage: 150193 km
                    Date: 2017.11.26
                    Time: 12:12:17
                    Engine speed: 817.50 /min
                    Normed load value: 20.8 %
                    Coolant temperature: 39 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 14.734 V
                    Sensor for engine block temperature: raw value: 39 °C
                    Glow status: 09
   Revision: --------
   Revision: S0000000
                    Reset counter: 236
                    Mileage: 150148 km
                    Date: 2017.11.24
                    Time: 05:07:27
   Coding: 02242D
   Coding: 420000
   Coding: 420000
   Coding: 000007
   Coding: 003039
   Coding: 510E00
   Coding: 2532C2
   Coding: 11211
   Shop #: WSC 06402
Address 56: Radio
   Coding: 030B185A
End----------(Elapsed Time: 01:14, VBatt start/end: 14.9V/14.8V)-----------
downtime
C?ID=280813
Have you done any changes to byte18? That is different depending if the car has xenon or halogen lights. Most likely your problem is there.
I don't think it's a problem with PWM or not having PWM.
Now your byte18 is 67 which is Audi R8 Halogen/Xenon USA (SM 0W) LED DRL WITH TAIL
I would try :
02 VW Golf (VW360) Halogen Rest of World TFL_0
08 VW Golf/Jetta Variant (VW362) Halogen Rest of World TFL_0
6C Audi A1 (AU210) Halogen / Xenon TFL without tail, Halogen/Bulb 8.08.08
Here's the complete list for your reference :
Value   Car      Light   Region      Note
01   BCM (default)
3   VW Golf (VW360)      Halogen   NORTH AMERICA   TFL_0
4   VW Golf GTI (VW360)   Halogen   Rest of World      TFL_0_LED+LED_SBBR
5   VW Jetta (VW351)   Halogen   Rest of World      TFL_0
6   VW Jetta (VW351)   Halogen   NORTH AMERICA   TFL_0
7   VW Jetta (VW351C)   Halogen   China      TFL_0
9   VW Golf/Jetta Variant (VW362)   Halogen   NORTH AMERICA   TFL_0
0A   VW Scirocco (VW364) LHD   Halogen   Rest of World       LHD TFL_0
0B   VW Scirocco (VW364) RL   Halogen   Rest of World      RHD TFL_0
0C   VW Caddy Van (VW367)    Halogen   Rest of World      TFL_0
0D   VW Caddy Van (VW367)    Halogen   Rest of World/Ska      TFL_0_Ska
0E   VW Golf Plus (VW369)   Halogen   Rest of World      TFL_0
0F   SEAT Leon (SE350)    Xenon   NORTH AMERICA   TFL_0
0F   SEAT Altea XL II (SE352)   Xenon   NORTH AMERICA   TFL_0   2/7
10   SEAT Toledo (SE351)   Xenon   NORTH AMERICA   TFL_0   9/9
11   SEAT Leon (SE350)    Halogen   NORTH AMERICA   TFL_S
11   SEAT Altea XL II (SE352)   Halogen   NORTH AMERICA   TFL_S   2/7
12   SEAT Toledo (SE351)   Halogen   NORTH AMERICA   TFL_0   9/9
13   VW Sharan (VW428)   Halogen   Rest of World      TFL_1
14   VW Sharan (VW428)   Xenon   Rest of World      TFL_1
15   VW Golf GTI (VW360)   Halogen   Rest of World      TFL_0+ LED SBBR
16   SEAT Leon (SE350   Xenon   Rest of World      TFL_0
16   SEAT Altea XL II (SE352)   Xenon   Rest of World      TFL_0    2/7
17   SEAT Toledo (SE351)   Xenon   Rest of World      TFL_0   9/9
18   SEAT Leon (SE350)    Halogen   Rest of World      TFL_S
18   SEAT Altea XL II (SE352)   Halogen   Rest of World      TFL_S   2/7
19   SEAT Toledo (SE351)   Halogen   Rest of World      TFL_S   9
1A   Skoda Superb Combi (SK462)   Halogen       without TFL, DRL-Low Beams
1B   Skoda Superb (SK461)   Halogen       without TFL, DRL-Low Beams
1C   Skoda Superb (SK461)   Halogen   Rest of World      separate TFL_1
1D   Skoda Superb (SK461)    Xenon   ASUV      TFL_Separate
1D   Skoda Yeti (SK356)   Xenon   ASUV      TFL_Separate
1E   VW Golf (VW360)    Halogen   NORTH AMERICA                           TFL_0 + SMR on SL-back
1E   VW Jetta (VW351)   Halogen   NORTH AMERICA                           TFL_0 + SMR on SL-back
1F   VW Golf (VW360)      Halogen   NORTH AMERICA   TFL_0 + LED SBBR
20   VW Golf (VW360)      Halogen   NORTH AMERICA   TFL_0_LED
21   VW Golf (VW360)      Halogen   NORTH AMERICA                           TFL_0_LED+ LED_SBBR
22   VW Golf (VW360)      Halogen   Rest of World/Japan   Japan + LED_SBBR
23   Audi A3 (AU350PA)    Halogen   NORTH AMERICA                           TFL_0_LED+ LED_SBBR
23   VW Golf (VW360)      Halogen   NORTH AMERICA                           TFL_0_LED+ LED_SBBR
24   Audi A3 (AU350PA)    Halogen   Rest of World      TFL_1
24   VW Golf/Jetta Variant (VW362)   Halogen   Rest of World      TFL_1
25   Audi A3 (AU350PA)    Halogen   Rest of World/Ska LDH   TFL_0 LL_Ska
25   VW Scirocco (VW364)   Halogen   Rest of World/Ska LDH   TFL_0 LL_Ska
26   Audi A3 (AU350PA)    Xenon   Rest of World/Ska RHD   TFL_0 RL_Ska
26   VW Scirocco (VW364)   Xenon   Rest of World/Ska RHD   TFL_0 RL_Ska
27   Audi A3 (AU350PA)    Xenon   Rest of World/Ska      TFL_1_Ska
27   VW Tiguan (VW316)   Xenon   Rest of World/Ska      TFL_1_Ska
28   Audi A3 (AU350PA)    Xenon   Rest of World/Ska      TFL_1_Ska
28   VW EOS (VW465)   Xenon   Rest of World/Ska      TFL_1_Ska
29   Audi A3 (AU350PA)    Halogen   Rest of World/Ska      TFL_0_Ska
29   VW Golf/Jetta Variant (VW362)   Halogen   Rest of World/Ska      TFL_0_Ska
2A   Audi A3 SportBack (AU353PA)   Xenon / ECE   Rest of World   LED DRL with tail, AB2 PA 5door
2B   Audi A3 SportBack (AU353PA)   Xenon / ECE   Rest of World   LED DRL without tail, AB2 PA 5door
2C   Audi A3 SportBack (AU353PA)   Xenon / ECE   Rest of World   LED DRL with tail, AB2 PA 5door
2D   Audi A6 (AU356PA)   Halogen   Rest of World   TFL_0
2E   Audi A6 (AU356PA)   Xenon   Rest of World   TFL_0
2F   VW Tiguan (VW316)   Halogen / Xenon   Rest of World   TFL_0
30   VW Tiguan (VW316)   Halogen / Xenon   Rest of World   TFL_S
31   Skoda Superb Combi(SK462)   Halogen       separate TFL_1
32   Skoda Octavia (SK350)    Halogen   RHD   TFL_LED ROM from TFL
32   Skoda Octavia RS (SK35x-RS)   Halogen   RHD   TFL_LED ROM from TFL
33   Skoda Octavia (SK350)    Halogen   LHD   TFL_LED ROM from TFL
33   Skoda Octavia RS (SK35x-RS)   Halogen   LHD   TFL_LED ROM from TFL
34   Skoda Octavia (SK350)    Halogen   RL   RL from TFL ROM 52 ROM from TFL
34   Skoda Octavia (SK351)   Halogen   RL   RL from TFL ROM 52 ROM from TFL
35   Skoda Octavia (SK350)   Halogen   LHD   TFL_1.separat LL halogen -ROM from TFL
35   Skoda Octavia (SK351)   Halogen   LHD   TFL_1.separat LL halogen -ROM from TFL
36   Skoda Octavia (SK350)   Halogen   RL   DRL-Low Beams (S) (P)
36   Skoda Octavia (SK351)   Halogen   RL   DRL-Low Beams (S) (P)
37   Skoda Octavia (SK350)   Halogen   LHD   DRL LHD-Low Beams (S) (P)
37   Skoda Octavia (SK351)   Halogen   LHD   DRL LHD-Low Beams (S) (P)
38   Skoda Octavia (SK350)   Halogen   RL   TFL_SH
38   Skoda Octavia (SK351)   Halogen   RL   TFL_SH
39   Skoda Octavia (SK350)   Halogen   LHD      TFL_SH
39   Skoda Octavia (SK351)   Halogen   LHD      TFL_SH
3A   Audi A1 (AU210)      Halogen   Rest of World       LHD TFL_S
3A   VW Scirocco (VW364)   Halogen   Rest of World       LHD TFL_S
3B   VW Scirocco (VW364)   Xenon   Rest of World       RHD TFL_S
3C   VW Golf (VW360)      Xenon   Rest of World      TFL_S
3D   VW Golf (VW360)      Xenon   NORTH AMERICA   TFL_S
3E   VW Golf (VW360)      Halogen   NORTH AMERICA
3F   VW Golf (VW360)      Xenon   Ska      TFL_S LED_SBBR
40   VW Golf (VW360)      Halogen   Rest of World
41   VW Golf (VW360)      Xenon   Rest of World      PO_LED
42   VW Golf (VW360)      Xenon   Ska      TFL_S_LED
43   VW Golf (VW360)      Halogen   Ska      TFL_S LED_SBBR
44   VW Golf (VW360)      Xenon   Rest of World      LED_SBBR
45   VW Golf (VW360)      Halogen   Ska      TFL_0_S
46   VW Golf Plus (VW369)   Halogen   Ska      TFL_0_S
47   VW Golf Plus (VW369)   Xenon   Rest of World      PO_LED
48   VW Golf Plus (VW369)   Xenon   Rest of World      TFL_LED
49   VW Golf Plus (VW369)   Halogen   Ska      TFL_S
4A   VW Jetta (VW351)   Xenon   Rest of World      PO_LED
4B   VW Jetta (VW351)   Xenon   Rest of World      TFL_LED
4C   VW Jetta (VW351)   Xenon   NORTH AMERICA   TFL_LED
4D   VW Golf/Jetta Variant (VW362)   Xenon   Rest of World      PO_LED
4E   VW Golf/Jetta Variant (VW362)   Xenon   Rest of World      TFL_LED
4F   VW Golf/Jetta Variant (VW362)   Xenon   NORTH AMERICA   TFL_LED
50   VW Tiguan (VW316)   Halogen / Xenon   NORTH AMERICA   TFL_1
51   VW Tiguan (VW316)   Halogen / Xenon   NORTH AMERICA   TFL_S
52   VW EOS (VW465)   Halogen / Xenon   Rest of World      TFL_1
53   VW EOS (VW465)   Halogen / Xenon   NORTH AMERICA   TFL_1
54   VW EOS (VW465)   Halogen / Xenon   Rest of World      TFL_S
55   VW EOS (VW465)   Halogen / Xenon   NORTH AMERICA   TFL_S
56   Audi TT Coupe (AU354)   Halogen   Rest of World      TFL_S 2 R
56   VW EOS (VW465)   Halogen   Rest of World      TFL_S 2 R
57   Audi TT Coupe (AU354)   Halogen   NORTH AMERICA   TFL_S_II
57   VW EOS (VW465)   Halogen   NORTH AMERICA   TFL_S_II
58   Audi TT Coupe (AU354)   Xenon       LED DRL Choming+ H SL
59   Audi TT Coupe (AU354)   Xenon       LED DRL POL + SL + KZL Choming H SL
5A   Skoda Octavia (SK35x)   Halogen / Xenon   RL   LED, TFL from Shutter
5A   Skoda Octavia RS (SK35x-RS)   Halogen / Xenon   RL   LED, TFL from Shutter
5B   Skoda Octavia (SK35x)   Halogen / Xenon   LHD   LED, TFL from Shutter
5B   Skoda Octavia RS (SK35x-RS)   Halogen / Xenon   LHD   LED, TFL from Shutter
5C   VW EOS (VW465FL)   Halogen   Rest of World   TFL_1_LED 8TA
5D   VW EOS (VW465FL)   Xenon   Rest of World   TFL_1_LED 8TA
5E   VW EOS (VW465FL)   Halogen   Rest of World   TFL_1 8TC_8TD
5F   VW EOS (VW465FL)   Xenon   Rest of World   TFL_1_LED 8TC_8TD
60   VW EOS (VW465FL)   Halogen   NORTH AMERICA   TFL_1 8TA
61   VW EOS (VW465FL)   Xenon   NORTH AMERICA   TFL_1_Ska 8TA
62   VW EOS (VW465FL)   Halogen   Rest of World/Ska   TFL_1_Ska 8TC_8TD
63   VW EOS (VW465FL)   Xenon   Rest of World/Ska   LED_DRLs TFL_1 8TC_8TD
64   Audi R8   Xenon / ECE   Rest of World   LED DRL without tail
65   Audi R8   Xenon / ECE   Rest of World   LED DRL with tail
66   Audi R8   Halogen / Xenon   USA (SM  0W)   LED DRL without tail
67   Audi R8   Halogen / Xenon   USA (SM  0W)   LED DRL with tail
68   Audi R8   Xenon / ECE   Rest of World   Complete LED LED DRL without tail
69   Audi R8   Xenon / ECE   Rest of World   Complete LED, LED DRL with tail
6A   Audi R8   Halogen / Xenon   USA (SM  0W)   Complete LED, LED DRL without tail (LED tail without TFL)
6B   Audi R8   Halogen / Xenon   USA (SM  0W)   Complete LED, LED DRL with tail (LED rear TFL)
6D   Audi A1 (AU210)   Halogen / Xenon       TFL with tail, Halogen/ Bulb 8.08.08
6E   Audi A1 (AU210)   Halogen / Xenon       TFL without tail, Halogen/ LED 8.08.08
6F   Audi A1 (AU210)   Halogen / Xenon       TFL with tail, Halogen/ LED 8.08.08
70   Audi A1 (AU210)   Halogen / Xenon       LED TFL without tail, LED TFL/ Bulb 8.08.08
71   Audi A1 (AU210)   Halogen / Xenon       LED TFL with tail, LED TFL/ Bulb 8.08.08
72   Audi A1 (AU210)   Halogen / Xenon       LED TFL without tail, LED TFL/ LED 8.08.08
73   Audi A1 (AU210)   Halogen / Xenon       LED TFL with tail, LED TFL/ LED 8.08.08
74   Skoda Superb (SK461)   Halogen / Xenon   China      China without DRL SL with BL-function LED SBBR
75   Skoda Superb (SK461)   Halogen / Xenon   China       China without DRL / TFL-ABL SL without BL function LED SBBR
76   Audi TT Coupe (NF) (AU354)   Halogen   NORTH AMERICA              separate TFL without SL in CHO
77   Audi TT Coupe (NF) (AU354)   Xenon   NORTH AMERICA   LED DRL + CHO SL
78   VW Scirocco (VW364)   Halogen / Xenon   Rest of World      LHD TFL_S
79   VW Scirocco (VW364)   Halogen / Xenon   Rest of World      RHD TFL_S
7A   Audi TT Coupe (NF) (AU354)   Halogen / Xenon   NORTH AMERICA   separate DRL with tail
7B   Audi TT Coupe (NF) (AU354)   Halogen / Xenon   NORTH AMERICA   LED DRL with tail
7C   Audi A1 (AU210)   Halogen / Xenon       TFL without tail, Halogen/ Bulb (dimmed DRL as taillight)
7D   Audi A1 (AU210)   Halogen / Xenon       TFL without tail, Halogen/ LED (dimmed DRL as taillight)
7E   Audi Q3 (AU316)      Halogen / Xenon      TFL_0 (from 05)
7E   VW Jetta (VW351)   Halogen / Xenon      TFL_0 (from 05)
7F   Audi Q3 (AU316)      Halogen / Xenon      TFL_S (from 35)
7F   VW Jetta (VW351)   Halogen / Xenon      TFL_S (from 35)
80   Audi Q3 (AU316)      Halogen / Xenon   Rest of World   TFL_0 without NSL
80   VW Scirocco (VW364)   Halogen / Xenon   Rest of World   TFL_0 without NSL
81   Audi Q3 (AU316)      Halogen / Xenon   Rest of World   TFL_S without NSL
81   VW Scirocco (VW364)   Halogen / Xenon   Rest of World   TFL_S without NSL
82   Audi Q3 (AU316)      Halogen / Xenon   LHD   TFL_1 8TC
82   VW Scirocco R-SCI (VW364)   Halogen / Xenon   LHD   TFL_1 8TC
83   Audi Q3 (AU316)      Halogen / Xenon   RHD   TFL_1 8TA/8TD
83   VW Scirocco R-SCI (VW364)   Halogen / Xenon   RHD   TFL_1 8TA/8TD
84   Audi Q3 (AU316)      Halogen / Xenon   Ska LHD   TFL_1 LHD_Ska 8TC
84   VW Scirocco R-SCI (VW364)   Halogen / Xenon   Ska LHD   TFL_1 LHD_Ska 8TC
85   Audi Q3 (AU316)      Halogen / Xenon   Ska RHD   TFL_1 RL_Ska 8TA/8TD
85   VW Scirocco R-SCI (VW364)   Halogen / Xenon   Ska RHD   TFL_1 RL_Ska 8TA/8TD
86   VW Jetta (VW351)   Halogen / Xenon   Rest of World/Ska      TFL_0_Ska
87   VW Golf/Jetta Variant (VW352)   Halogen / Xenon   Rest of World/Ska      TFL_0_Ska
87   VW Golf/Jetta Variant (VW362)   Halogen / Xenon   Rest of World/Ska      TFL_0_Ska
88   VW Scirocco (VW364) LHD   Halogen / Xenon   Rest of World/Ska LDH   TFL_1 LL_Ska
89   VW Scirocco (VW364) RL   Halogen / Xenon   Rest of World/Ska RHD   TFL_1 RL_Ska
8A   VW Tiguan (VW416)   Halogen / Xenon   Rest of World/Ska      TFL_1_Ska
8A   VW Tiguan (VW316)   Halogen / Xenon   Rest of World/Ska      TFL_1_Ska
8B   VW EOS (VW465)   Halogen / Xenon   Rest of World/Ska      TFL_1_Ska
8C   VW Jetta (VW361)   Halogen / Xenon   Rest of World      TFL_1
8D   VW Jetta (VW361)   Halogen / Xenon   NORTH AMERICA   TFL_1
8E   VW EOS (VW465FL)   Halogen / Xenon   Rest of World      TFL_1
8E   VW Touran (VW368)   Halogen / Xenon   Rest of World      TFL_1
8F   VW EOS (VW465FL)   Halogen / Xenon   Rest of World/Ska      TFL_1_Ska
8F   VW Touran (VW368)   Halogen / Xenon   Rest of World/Ska      TFL_1_Ska
90   VW EOS (VW465FL)   Halogen / Xenon   Rest of World      TFL_1_LED
90   VW Touran (VW368)   Halogen / Xenon   Rest of World      TFL_1_LED
91   VW EOS (VW465FL)   Halogen / Xenon   Rest of World/Ska      TFL_1_LED_Ska
91   VW Touran (VW368)   Halogen / Xenon   Rest of World/Ska      TFL_1_LED_Ska
92   SEAT Alhambra (SE428)   Halogen   Rest of World      TFL_1
93   SEAT Alhambra (SE428)   Xenon   Rest of World      TFL_1
94   VW EOS (VW465)   Halogen / Xenon   NORTH AMERICA   TFL_S, 2 Reverse Lights
95   VW Caddy Van (VN337)   Halogen / Xenon   Rest of World      TFL_S
96   VW Passat (VW411)   Halogen / Xenon   NORTH AMERICA   TFL_1
97   VW Passat (VW411)   Halogen   NORTH AMERICA   TFL_S
98   VW Passat (VW411)   Halogen / Xenon   China      TFL_1
99   VW Passat (VW411)   Halogen / Xenon   China      TFL_S
9A   SEAT Leon (SE350)   Xenon   NORTH AMERICA   TFL_0
9B   SEAT Leon (SE350)   Halogen   NORTH AMERICA   TFL_S
9C   SEAT Leon (SE350)   Xenon   Rest of World      TFL_0
9D   SEAT Leon (SE350)   Halogen   Rest of World
TFL_0   daytime running lights and rear fog light, reversing
light
TFL_1   daytime running lights with daytime running light
outputs
TFL_S   daytime running lights via Scandinavia low beam
lights
TFL_SH   daytime running lights via shutter
TFL_LED   LED module with dual function parking lights
TFL_O_S   special Scandinavia derivative solution
PO_LED   LED module
iichel
Netherlands, eastern part
C?ID=284912
Maybe TS can clarify in what way he converted from 14 pin bi-xenon connector to 10 pin halogen connector?
Jurgens
C?ID=321320
@downtime: 67 is the original value for this car. I did try 60 because that is the value my seat ibiza 2010 with halogen light has but that didn't do anything.
Thanks for the elaborate list. :) Is this valid for all 937 BCM's? Can I just go nuts and try them?
@iichel: I just measured the voltage with a scope and it doesn't immediately look like a PWM signal but there is a clear 100Hz pattern. Every period is first a long block of 8V then short block of 12V and then 2 short peaks of 4-5 V. I can't upload any images unfortunately.
I removed the 14 pins sockets from the old Xenon housings and soldered them into the halogen units. I used a wiring scheme to get everything in the right place and everything else worked fine from the start.
downtime
C?ID=280813
It should be valid for all bcms yes. You can try them but some word of warning, it changes some of the eeprom settings with that byte and some have reported broken bcm when changing the value.
I've personally not have encountered this problem ever and I've changed a few bcm byte 18s :)
Did you try 6C what I proposed?
iichel
C?ID=284912
i'd try
7A880BE88861010001300EF56CCB8ED80E8061E97E8C2001200000000000
for the BCM
DV52
C?ID=194404
hmm........... not sure that I would worry about over-current!! If you think about it, the good Burghers @ VW would have needed to cater for a situation where the lamp filament, or the wire/connector would short circuit (and open circuit). I would expect that a properly designed PWM module would be current limiting. My only concern is perhaps generating a back voltage when the capacitor is charged, and the PWM signal is in the low state - but a simple forward biased diode can fix this!
Don.
Jurgens
C?ID=321320
Sorry for the long time absent. It was a busy couple of months. I tried everything you guys suggested and more, but still no luck. Now in 2 weeks the car has to go for the yearly road legal and safety check.
@iichel: your code did turn off the warning light but it also turned off the lights itself and my entire dash lightning unfortunately.
@ downtime: I tried all the Byte 18's you suggested but none of them worked. I also tried a lot of other codes. None off them had the desired affect. Ranging from turning off all light to doing nothing at all.
I also tried replacing the W5W bulbs for LED's but still the light indicator light remained lit.
Anybody got any last suggestions other than buying expensive xenon units that I don't care for?
@DV52: I tried a capacitor in combination with the LED's and that made the light's bright enough but I would really like to get rid of the light indicator light.
