Wednesday,15,November,2017,18:08:51:28697
VCDS Version: 17.8.0.1
VIN: WVGZZZ7PZED031486 License Plate:
Mileage: 76828km-47738mi Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 34 36 3C 40 42 44 46
47 51 52 53 55 56 5F 62 65 69 6C 6D 72 85 8B 8C 8E 8F 90
VIN: WVGZZZ7PZED031486 Mileage: 76828km-47738miles
40-AC Compressor -- Status: OK 0000
51-Electric Drive -- Status: Malfunction 0010
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CGEA) Labels: None
Part No SW: 06E 906 023 N HW: 06E 907 309 B
Component: 3.0l V6h EU5 H16 6262
Revision: M6H16---
Coding: 002A0012437E01000000
Shop #: WSC 61661 002 1048576
ASAM Dataset: EV_ECM30TFS01106E906023N 002006
ROD: EV_ECM30TFS01106E906023N_002.rod
VCID: 2D5A19017C61272E11-8078
6 Faults Found:
14492 - Auxiliary Coolant Pump in High-Temp Circuit
P192A 00 [036] - Running Dry
Mileage: 76828 km
Date: 2017.11.14
Time: 17:35:53
Engine speed: 791.00 /min
Normed load value: 20.8 %
Coolant temperature: 55 °C
Intake air temperature: 33 °C
Voltage terminal 30: 14.606 V
Median injection timing: 0.957 ms
Engine operating condition-Channel 87: Idling
Relative load value: 20.20 %
Engine torque: 59.6 Nm
18187 - Service Mode Active
U1106 00 [175] - -
Mileage: 76828 km
Date: 2017.11.14
Time: 08:42:53
Engine speed: 795.00 /min
Normed load value: 25.9 %
Coolant temperature: 25 °C
Intake air temperature: 15 °C
Voltage terminal 30: 14.866 V
Unlearning counter according OBD: 0
Outside air temperature via CAN: 143.3 °C
Engine oil temperature: 10.6 °C
Time since ignition off: 53196 s
Adjustment requirements for basic setting-Bit 0: 54
Rear cat conv temp main cat conv model value: 272.33 °C
Coolant temperature at engine start: 10.5 °C
17324 - MIL Request Signal Active (Check TCM for errors too!)
P1624 00 [047] - -
Mileage: 76828 km
Date: 2017.11.14
Time: 08:42:53
Rear cat conv temp main cat conv model value: 272.26 °C
8993 - Intake Manifold Flap; Bank 2
P2007 00 [109] - Stuck Closed
Mileage: 76828 km
Date: 2017.11.14
Time: 08:43:00
Engine speed: 803.00 /min
Normed load value: 26.3 %
Coolant temperature: 27 °C
Voltage terminal 30: 14.889 V
Median injection timing: 1.259 ms
Relative load value: 25.38 %
Engine torque: 74.8 Nm
2978 - Intake Manifold Flap; Bank 1
P2006 00 [109] - Stuck Closed
Mileage: 76828 km
Date: 2017.11.14
Time: 08:43:00
Intake air temperature: 30 °C
Median injection timing: 0.962 ms
Relative load value: 20.48 %
Engine torque: 60.3 Nm
7786 - Sensor for Ambient Air Temperature (G17)
P0070 00 [175] - Malfunction
Mileage: 76828 km
Date: 2017.11.14
Time: 08:43:23
Engine speed: 804.50 /min
Coolant temperature: 28 °C
Engine torque: 72.2 Nm
Irregular shutdown of the counter control mod-Bit 0: 0
Current system status: SYC_DRIVE
Readiness: 1110 1001
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 BR HW: 0C8 927 750 BR
Component: AL1000 AISIN 002 2473
Coding: 003168
ASAM Dataset: EV_TCMAL991031 002115
ROD: EV_TCMAL991031_002.rod
VCID: 7DFAE941EC8177AEE1-8028
Address 03: ABS Brakes (J104) Labels:| 7P0-907-379.clb
Part No SW: 7P0 907 379 P HW: 7P0 907 379 A
Component: MK25A H36 0446
Revision: -------- Serial number: 428030010EC010
Coding: 6B6B53C30B276F54D6F8CA9BD0D8F660F700
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 008001
ROD: EV_ESPMK25A00800.rod
VCID: 4A90729DEDCF101614-801E
Part No SW: 4H0 907 064 EH HW: 4H0 907 064 EH
Component: BCM2 2.0 H36 0521
Coding: 05C60016000000000000
VCID: 73EECF79D2C531DE87-8026
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Serial number: 0213000382119013
013 - Check DTC Memory
Fault Status: 01101101
Fault Frequency: 106
Reset counter: 27
Mileage: 76828 km
Date: 2017.11.01
Time: 16:28:13
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000084886367
Coding: 0018330000004201000001010101202020202121202020
VCID: 346C0C65974B76E65E-8060
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BR HW: 7P6 907 040 BR
Component: Klima 2 Zonen H21 1306
Coding: 6686000E92
VCID: 050A81A184513F6EB9-8050
0315 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 63
Mileage: 76828 km
Date: 2017.11.01
Time: 13:51:53
Voltage terminal 30-Data: 11.9 V
Outside air temperature-Data: 77.50 °C
Engine speed-Data: 0 /min
0267 - Sensor for Refrigerant Pressure and Temperature
B10C2 21 [008] - Signal Amplitude Too Low
Fault Frequency: 30
Reset counter: 67
Mileage: 76828 km
Date: 2017.11.02
Time: 09:49:58
Compressor current: actual value-Data: 1016 mA
Temperature after evaporator-Data: 13.00 °C
Engine speed-Data: 880 /min
0243 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Fault Frequency: 42
Reset counter: 27
Mileage: 76828 km
Date: 2017.11.01
Time: 13:51:48
Voltage terminal 30-Data: 12.0 V
0246 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 65
Mileage: 76828 km
Date: 2017.11.12
Time: 17:06:14
Voltage terminal 30-Data: 14.9 V
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0130
Revision: 15012002 Serial number: 00000001813925
Coding: 22001010D1B45D010021000780005D0C431C670848000241800000020000
VCID: 6CDCD4058FFBEE2646-8038
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 131207 033 0021
Serial number: 90243400131210142950
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20227320
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 D HW: 7P6 941 431 D
Component: E1 - LDS H04 0031
Serial number: 00000000000902110838
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA107205000005471991
Coding: 020300
6 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
Fault Status: 00101100
Reset counter: 67
Mileage: 76828 km
Date: 2017.11.13
Time: 09:22:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Reset counter: 67
Mileage: 76828 km
Date: 2017.11.13
Time: 09:22:00
Reset counter: 67
Mileage: 76828 km
Date: 2017.11.13
Time: 14:01:00
Fault Frequency: 24
Reset counter: 27
Mileage: 76828 km
Date: 2017.11.13
Time: 09:22:00
Reset counter: 67
Mileage: 76828 km
Date: 2017.11.13
Time: 14:00:00
01771 - Control Module for Headlight Range (J431)
Fault Status: 00101101
Reset counter: 67
Mileage: 76828 km
Date: 2017.11.13
Time: 09:22:00
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 C HW: 7N0 919 475
Component: PARKHILFE 8K H05 0026
Revision: -------- Serial number: 28231333400860
Coding: 518D01
ASAM Dataset: EV_VW526ParkiAssis2 001012
ROD: EV_VW526ParkiAssis2.rod
VCID: 438E5FB9CAE5C15ED7-8016
1113107 - Front Parking Aid Sensor(s)
B10FC 13 [009] - Open Circuit
Reset counter: 21
Mileage: 76828 km
Date: 2017.11.01
Time: 13:51:49
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 7P6 907 561 B HW: 7P6 907 561
Component: ACC3 H19 0340
Coding: 3F04010101
ASAM Dataset: EV_AdaptCruisContrVW526 002011
ROD: EV_AdaptCruisContrVW526_002.rod
VCID: 3B7E2759B215B99E9F-806E
7 Faults Found:
105984 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Fault Frequency: 26
Reset counter: 67
Mileage: 76828 km
Date: 2017.11.01
Time: 15:14:23
Control Module temperature: 13 °C
Voltage terminal 15: 11.774 V
Velocity_vehicle_reference: -0.02 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
106240 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Fault Frequency: 47
Reset counter: 67
Mileage: 76828 km
Date: 2017.11.01
Time: 13:51:55
Control Module temperature: 18 °C
Voltage terminal 15: 11.881 V
144896 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 21
Mileage: 76828 km
Date: 2017.11.01
Time: 13:51:50
Voltage terminal 15: 11.886 V
143616 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 21
Mileage: 76828 km
Date: 2017.11.01
Time: 13:51:48
Voltage terminal 15: 11.903 V
143360 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 61
Mileage: 76828 km
Date: 2017.11.02
Time: 09:46:51
Control Module temperature: 10 °C
Voltage terminal 15: 11.880 V
144128 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Reset counter: 61
Mileage: 76828 km
Date: 2017.11.02
Time: 09:46:49
Voltage terminal 15: 11.991 V
92416 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 65
Mileage: 76828 km
Date: 2017.11.12
Time: 09:34:34
Control Module temperature: 0 °C
Voltage terminal 15: 11.543 V
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 D HW: 7P0 959 655 D
Component: VW10Airbag02U H06 0026
Revision: -------- Serial number: 003L5003T87X
Coding: 000000000000000000000000000000003255
VCID: 42805ABDD5FFC856DC-8016
Serial number: 3575LRB40572AIFS9HJ+
Serial number: 3585LRB40592AIFS89K-
Serial number: 3515RRB400U50PG659IP
Serial number: 3525RRB400S50PG6IOOF
Serial number: 3555NRB40532G2OA5P8B
Serial number: 3565NRB40610ODIS298L
Part No SW: 4H0 953 568 H HW: 7P6 953 507 T
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 99999MKU0005I
Coding: 000CBD
VCID: 387438558B23928672-806C
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0027151 TRW 20131118
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb
Part No SW: 7P6 920 884 A HW: 7P6 920 884 A
Component: Kombi H13 0419
Revision: 13240270 Serial number: 658121213592049
Coding: 131730007F0D000807010C
ASAM Dataset: EV_KombiUDSRBVW526 001020
ROD: EV_KombiUDSRBVW526_VW52.rod
VCID: 3D7A2941AC01B7AEA1-8068
1048578 - No Basic Setting
B2010 00 [009] - -
Reset counter: 27
Mileage: 76828 km
Date: 2017.11.13
Time: 12:25:37
16776976 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 27
Mileage: 76828 km
Date: 2017.11.13
Time: 12:25:37
Part No SW: 7P6 907 530 K HW: 7P6 907 530 G
Component: GW-CAN-L-FR-M H13 6032
Revision: -------- Serial number: 00000001201616
Coding: 0011020000
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
VCID: 408450B5DBF3DA46CA-8014
Subsystem 1 - Part No SW: 7P0 915 181 B HW: 7P0 915 181
Component: Batt_Sensor H07 0190
Serial number: 40337B02205701343789
Address 34: Level Control (J197) Labels:. 7P0-907-553.clb
Part No SW: 7P0 907 553 AA HW: 7P0 907 553 AA
Component: PASM H04 1800
Revision: 00000000 Serial number: 00000133330451
Coding: 15210001
ASAM Dataset: EV_PASMConti 001004
ROD: EV_PASMConti.rod
VCID: 76E8F66DC9B724F6A0-8022
12656788 - Databus
Fault Priority: 8
Fault Frequency: 27
Reset counter: 1
Mileage: 793600 km
Date: 2061.12.22
Time: 04:20:56
Default: 00
Default: 6B
Default: 00
12656790 - Databus
Fault Priority: 9
Fault Frequency: 27
Reset counter: 1
Mileage: 793600 km
Date: 2061.12.22
Time: 04:20:56
Default: 00
Default: 6B
Default: 00
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000083815827
Coding: 00183B0000004201000001010101202020202121202020
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 7P6 907 566 HW: 4H0 907 566
Component: J769 SWA MasterH04 0110
Revision: 00H04000 Serial number: 6PZ 010 316-01
Coding: 0010151
VCID: 7EF8EE4D29876CB6F8-802A
Subsystem 1 - Part No: 7P6 907 568
Component: J770 SWA Slave H02 0110
Subsystem 2 - Serial number: 6PZ 010 316-21
Subsystem 3 - Serial number: 5F26.11.1300H02000AMS14114˙
Subsystem 4 - Serial number: S14114˙
Address 40: AC Compressor (J842) Labels: None
Part No SW: 7P0 820 803 H HW: 7P0 820 803 H
Component: ES34 H01 0001
ASAM Dataset: EV_AirCondiCompr_ES34 S03001
ROD: EV_AirCondiCompr_ES34.rod
VCID: 346C0C659F4B76E65E-8060
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H02 0306
Revision: -------- Serial number: 0000085332592
Coding: 011F1620DE00459205080003
VCID: 7AF0E25DF5AF4096C4-802E
Address 44: Steering Assist (J500) Labels: None
Part No SW: 7P0 423 155 D HW: 7P0 423 155 D
Component: EPHS H01 0005
Revision: A1003003 Serial number: 62354408
Coding: 04
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_SteerContrUnit 001003
ROD: EV_SteerContrUnit.rod
VCID: 2F660309766D553E23-807A
Revision: 00002001 Serial number: 0321343452
Coding: 019A1E2028B91095833006203F0A17000000000000000000000000000000
Subsystem 1 - Part No: 7P6 951 171
Component: DWA-Sensor 002 0204
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.055 H01 0008
Serial number: WOO2483017%
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.055 H01 0008
Serial number: WOO2602904/
Coding: 191100
Subsystem 5 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Serial number: 93111277
Fault Frequency: 53
Reset counter: 27
Mileage: 76828 km
Date: 2017.11.13
Time: 10:03:11
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 7P6 035 466 HW: 7P6 035 466
Component: DSP Prem H01 0090
Revision: 00001001 Serial number: 10811002834407
VCID: 75EAF161DCB12FEEA9-8020
Address 51: Electric Drive (J841) Labels: None
Part No SW: 7P0 907 080 D HW: 7P0 907 080 D
Component: INV CON 2.1H22 0490
Revision: 00H22000
Shop #: WSC 01608 125 28888
ASAM Dataset: EV_DMCM03430117P0907080D 014001
ROD: EV_DMCM03430117P0907080D.rod
VCID: 336E0F799A4571DE47-8066
15798 - Unauthorized Software/Coding Detected
P064F 00 [175] - -
Mileage: 76828 km
Date: 2017.11.14
Time: 08:42:54
Voltage terminal 30: 14.639 V
Drive control condition: TrqCtl
Intermediate circuit voltage: 321.34 V
Intermediate circuit current: -4.66 A
Temperature of electric machine: 16.88 °C
Power electronics heat sink temperature: 14.66 °C
Torque: current value: -19.94 Nm
Desired_torque: -19.47 Nm
14392 - Control Module
P151A 00 [175] - Incorrectly Coded
Mileage: 76828 km
Voltage terminal 30: 0.000 V
Drive control condition: Initialization
Intermediate circuit voltage: 0.00 V
Intermediate circuit current: 0.00 A
Temperature of electric machine: 0.00 °C
Power electronics heat sink temperature: 0.00 °C
Torque: current value: 0.00 Nm
Desired_torque: 0.00 Nm
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000085348174
Coding: 011F1620DE00459205080000
VCID: 48944895FBC3E20602-801C
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C13C0600529
Coding: 00000000
Shop #: WSC 35557 001 104857
ROD: EV_ParkbA7.rod
VCID: 3668366D893764F660-8062
0025 - No Calibration
B2010 F0 [008] - Deviation From Expected Range
Reset counter: 27
Mileage: 76828 km
Date: 2017.11.14
Time: 08:44:11
Voltage: 14.6 V
0003 - Function Restriction
B2008 F0 [008] - due to Over-Temp Protection
Reset counter: 27
Mileage: 76828 km
Date: 2017.11.13
Time: 12:51:53
Voltage: 11.8 V
0024 - No Basic Setting
B2010 00 [009] - -
Mileage: 76828 km
Voltage: 12.2 V
12652550 - Control Module Incorrectly Coded
U1014 00 [009] - -
Mileage: 76828 km
Voltage: 12.2 V
12656790 - Databus
Reset counter: 27
Mileage: 76828 km
Date: 2017.11.13
Time: 14:01:45
Voltage: 11.8 V
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 012A00104F000200
VCID: 7CFCE445F79B7EA6D6-8028
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0001
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0003
Coding: 130000
U1014 00 [137] - -
Reset counter: 27
Mileage: 76828 km
Date: 2017.11.14
Time: 08:33:10
5276145 - Power Output Module for Left Headlamp
C1081 F1 [137] - Incorrectly Coded
Reset counter: 27
Mileage: 76828 km
Date: 2017.11.14
Time: 08:33:10
5276401 - Power Output Module for Right Headlamp
C1082 F1 [137] - Incorrectly Coded
Reset counter: 27
Mileage: 76828 km
Date: 2017.11.14
Time: 08:33:10
Part No SW: 4G0 035 061 J HW: 4G0 035 061
Component: Radio U DAB H60 0123
Revision: AB001007 Serial number: 109L$0D7830424
Coding: 010105010000000003
VCID: 244CFC2527ABE666CE-8070
Part No SW: 7P6 035 670 E HW: 7P6 035 670
Component: H-BNT-EU H47 0593
Revision: -------- Serial number: 478L20D7631162
Coding: 020100050040E9EF79312B8E00000003F80401030000000000
VCID: 37763B69863D9DFE7B-8062
Subsystem 1 - Part No: 8R0 060 884 AR
Component: ECE 2013 1505
Subsystem 2 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: DU8 SV Touch H26 0045
Serial number: VWZ8Z9NA200TQ2
Subsystem 3 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: CD-Database 4949
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H03 0306
Revision: -------- Serial number: 0000085377737
Coding: 011E14200000259005080000
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000120994
ROD: EV_RDKBERU25_VW52.rod
VCID: 3F865349A60DA5BEB3-806A
Address 69: Trailer (J345) Labels: None
Part No SW: 7P0 907 383 G HW: 7P0 907 383 C
Component: Anhaenger H11 0110
Revision: 5H001001 Serial number: 00000195002337
Coding: 0106040000000000
VCID: 3C7C2445BF1BBEA696-8068
Address 6C: Back-up Cam. (J928) Labels:| 7P6-907-441-V1.clb
Part No SW: 7P6 907 441 E HW: 7P6 907 441 D
Component: TopView H05 0100
Revision: 11001001 Serial number: 82330JF0122048
Coding: 0100000001010000010102000000
ASAM Dataset: EV_CamerSysteTopViewVW 001014
ROD: EV_CamerSysteTopViewVW.rod
9616922 - Supply Voltage for Front Surroundings Camera
B1284 14 [009] - Open or Short to Ground
Fault Frequency: 27
Voltage terminal 30: 12.0 V
Terminal 15 status: Terminal 15 off
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 322300328
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
Component: TSG HR H03 0306
Revision: -------- Serial number: 0000085376127
Address 85: On Board Cam. (J852) Labels:* None
Part No SW: 7P6 907 217 B HW: 7P6 907 217
Component: DPC-SG H25 0035
Revision: -------- Serial number: 262130025421000
Coding: ED070000
ASAM Dataset: EV_OnBoardCamerDTR 001001
ROD: EV_OnBoardCamerDTR.rod
VCID: 39723D51B8298B8E8D-806C
Slave 1:
Subsystem 1 - Part No: 7P6 .90 7.6 58
Component: NICKRATENSENS H02 0001
Serial number: 000000007059132_4149
0710 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Fault Frequency: 112
Reset counter: 27
Mileage: 76828 km
Date: 2017.11.01
Time: 13:55:00
Outside air temperature: -11.5 °C
Voltage terminal 15: 11.7 V
Control Module temperature: 28.0 °C
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 7P6 907 541 B HW: 7P6 907 541
Coding: 3F04010101
ASAM Dataset: EV_AdaptCruisContr2VW526 002010
ROD: EV_AdaptCruisContr2VW526_002.rod
6 Faults Found:
U1113 00 [008] - -
Fault Frequency: 26
Reset counter: 67
Mileage: 76828 km
Date: 2017.11.01
Time: 15:14:23
Voltage terminal 15: 11.759 V
Velocity_vehicle_reference: -0.01 m/s
U1113 00 [008] - -
Fault Frequency: 46
Reset counter: 67
Mileage: 76828 km
Date: 2017.11.01
Time: 14:32:42
Control Module temperature: 15 °C
U1113 00 [009] - -
Reset counter: 21
Mileage: 76828 km
Date: 2017.11.01
Time: 13:57:25
Control Module temperature: 20 °C
Voltage terminal 15: 11.853 V
U1113 00 [009] - -
Reset counter: 21
Mileage: 76828 km
Date: 2017.11.01
Time: 13:57:25
U1113 00 [008] - -
Reset counter: 61
Mileage: 76828 km
Date: 2017.11.02
Time: 09:46:51
Control Module temperature: 11 °C
Voltage terminal 15: 11.875 V
U1112 00 [008] - -
Reset counter: 61
Mileage: 76828 km
Date: 2017.11.02
Time: 09:46:49
Voltage terminal 15: 11.976 V
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 7P0 915 182 E HW: 7P0 915 182 E
Component: HVBMS H07 0910
Coding: C90100
ASAM Dataset: EV_BECM24010117P0915182 007002
ROD: EV_BECM_7P0915182.rod
Address 8E: Image Processing (J851) Labels:* None
Part No SW: 7P6 907 107 B HW: 7P6 907 107
Component: BV-SG H32 0035
Serial number: 005000012111137
Coding: 0AA03F040000
ASAM Dataset: EV_BTR 002001
ROD: EV_BTR_002.rod
VCID: 37763B698E3D9DFE7B-8062
0034 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 26
Mileage: 76828 km
Date: 2017.11.01
Time: 13:56:48
Outside air temperature: 77.5 °C
Control Module temperature: 26.0 °C
Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 006606000317037F00033811594097000000
Shop #: WSC 00001 790 00001
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 31620571605943CE35-8064
Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
Coding: 00660600031F037F00033811594097000000
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 32600A7D655F78D64C-8066
