hello from italy
marco_gti
Pirate
Walking the Plank
Italy
000000000000000000000000000000000
hello i'm marco from italy hello to evryone and thanks for help
marco_gti
Pirate
Walking the Plank
Italy
i try to activate ccs on my tiguan 5n 2016 but this si impossible with vcds can some one help me ? on 01 motor there isn't a long coding helper my motor is czdb this is my autoscan
i will try to code 16 with helper and 01 motor byte 5 from 04 to 24 but still not working. i verify the cable from pin5 to ecu motor.
Removed.   Data from clone/pirate copies of VCDS is not welcome here.
iichel
Netherlands, eastern part
C?ID=284912
what is the version of your vcds?
ps, benvenuto, ciao Marco
marco_gti
Pirate
Walking the Plank
Italy
Tomorrow i will make an autoscan with my friend's original vcds cable in my friend garage. On the 16 steering wheels there is a code for cruise control on side lever and i activate it and code acepted. On a 01 motor i will try to use similar code from 1.4 tsi golf mk7 on a byte 5 bit 5-6 20 cruiee control install and the ecu acept the codin but still not working. Do you think thete is some activation on a can gatway?
Post scan from legitimate VCDS first, then you may receive advice. ;)
marco_gti
Pirate
Walking the Plank
Italy
hello this is a complete scan with genuine vcds Tuesday,07,November,2017,09:41:46:11334
VCDS Version: 17.8.0.1 (x64)
VIN: WVGZZZ5NZGW55xxxx   License Plate:
Chassis Type: 5N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 4C 52 53 5F 61 62 72
VIN: WVGZZZ5NZGW55xxxx   Mileage: 23150km-14384miles
Address 01: Engine (J623-CZDB)       Labels: None
   Part No SW: 04E 906 027 HR    HW: 04E 907 309 BK
   Component: R4 1.4l TFS   H23 9030
   Revision: R9H23---
   Coding: 00190032232411080000
   ASAM Dataset: EV_ECM14TFS01104E906027HR 001003
   ROD: EV_ECM14TFS01104E906027HR.rod
   VCID: 7BF1000BF2C9269EDF-802E
17165 - Databus
                    Mileage: 23084 km
                    Date: 2017.10.28
                    Time: 18:11:17
                    Coolant temperature: 56 °C
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 11.756 V
                    Unlearning counter according OBD: 32
                    Acceleration: 0.000 m/s²
                    Cruise Control System (CCS): status-Bit 0: 0
                    Cruise_control_shutoff_conditions_irreversible-Bit 0: 0
                    Cruise_control_shutoff_conditions_irreversible-Bit 8: 0
                    Cruise control system: temporary deactivation-Bit 0: 255
                    Cruise control switch actuation-Bit 0: 0
                    Cruise control switch actuation-Bit 8: 32
Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
   Part No SW: 5N0 614 109 BN    HW: 5N0 614 109 BN
   Component: J104   C6 450M VD2B 0021
   Revision: --H07---    Serial number: 00000009019727
   Coding: 0037893
   VCID: 78FB1F070BFF0D86B2-802C
   Part No SW: 561 907 426 F    HW: 561 907 426 F
   Component: AC Manuell    H03 0506
   Revision: 00001K02
   Coding: 0010004003
   ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 1E37299F019B93B698-804A
   Part No SW: 5K0 937 086 T    HW: 5K0 937 086 T
   Component: BCM PQ35 M    122 0183
   Revision: BC122001
   Coding: 60180A3B80250AC4408800C0100081644B01AA88424D89606480C7000041
   VCID: 4585A6F3CC8DA06EF9-8010
   Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS316 011015  24  0664
   Coding: 009795
   Part No SW: 1K8 919 465     HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0479
   Revision: --------    Serial number: 39231528900873
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14VW364GP00 001006
   ROD: EV_EPHVA14VW364GP00.rod
   VCID: 76E7113FC9EB7BF6A0-8022
   Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
   Component: J234__20J VW10 HI   3018
   Revision: 32022000    Serial number: 003L7PLM03X6
   Coding: 0012362
   VCID: 7CF303173FC721A6D6-8028
   Subsystem 1 - Serial number: 6332MTS664932715
   Subsystem 2 - Serial number: 6342MTS615812665
   Subsystem 3 - Serial number: 6351HTS6K8CGUDKJ
   Subsystem 4 - Serial number: 6361HTS6LQIQTDKR
   Part No SW: 5K0 953 501 DH    HW: 5K0 953 569 AN
   Revision: FF010042    Serial number: 20151016101602
   Coding: 118A140000
   VCID: 73E1282BDA996EDE87-8026
   Component: E221__MFL-TAS  H31 0037
   Serial number: 0901244
   Coding: 820000
   Part No SW: 5N0 920 873 F    HW: 5N0 920 873 F
   Component: KOMBI         H04 1008
   Coding: 111F010000
   VCID: 3667D13F896B3BF660-8062
   Part No SW: 7N0 907 530 BE    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1674
   Revision:   H58       Serial number: 300915F1001501
   Coding: 356022
   Shop #: WSC 53136 001 1048576
   VCID: 74E32B37D79769E69E-8020
   Component: IMMO          H04 1008
   VCID: 6ADF354F8D53AF1634-803E
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0503
   Revision: 13110009    Serial number: 0010115791
   Coding: 0204B4
   VCID: 387BDF07837FCD8672-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  010 1505
   Serial number: 00000009576772
   Coding: 000490
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.284 1401
   Revision: 1BH04841    Serial number: 00152660057901
   Coding: 0000258
   VCID: 418DB2E318A58C4EC5-8014
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0503
   Revision: 15110009    Serial number: 0010137340
   Coding: 0204B4
   VCID: 397DDA03B875D48E8D-806C
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  010 1505
   Serial number: 00000009566033
   Coding: 000490
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000899075
   Coding: 0026167
   VCID: 387BDF074B7FCD8672-806C
   Part No SW: 5K7 035 200 D    HW: 5K7 035 200 D
   Component: MU-S--ER      H22 0245
   Serial number: VWZAZ2R8913429
   Coding: 02130600FF00000011110001000808001F0100840020010003
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 2545067324CD406ED9-8070
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
   Component: Batt.regelung H58 1674
   Coding: 032F7856
   VCID: 71ED2223A8855CCE75-8024
   Component: J367-BDM  H07 0180
   Serial number: 42274H57101491768289
End-------------------------(Elapsed Time: 02:44)--------------------------
marco_gti
Pirate
Walking the Plank
Italy
Anyone can help me?
PetrolDave
Westbury, UK
C?ID=1423
Anyone can help me?
I'm assuming that as we now have a genuine scan it's OK to help marco_gti?
You need to find the cause of the database error on the engine ECU first.
Checking the CAN bus wires to the engine ECU is where I would start, maybe you should get a WD from erWin?
marco_gti
Pirate
Walking the Plank
Italy
I have only installa new lever with ccs button. I have clear the dtc. I think that i miss some code, but i don't where or what other i have to code.
Yeah sure...........get verified first.....:rolleyes:
marco_gti
Pirate
Walking the Plank
Italy
I have post a valid autoscan if you don't want help me please don't write ;-)
