Update to Beta 17.10.0 firmware update required
turbocip
Moon
C?ID=80803
I made update today from 17.8 to 17.10.0 Beta and after successfully test interface - i have this message : Firmware Update Required. I press OK and nothing happen.
Normally is to firmware made update. Or not ?
Look at the picture attached into this links:
https://imgur.com/a/ZwkB4
https://imgur.com/a/x2NIM
golfi_vend
Tartu, Estonia
C?ID=195131
Open the VC utility and try update there?
turbocip
Moon
C?ID=80803
You did that and work?
For me - not made update firmware.
You see te firmware version : is still the same.
Regards
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Not exactly sure why you blocked out the exact firmware version information you're asking about in your pics. That isn't exactly a secret. You are likely on CB 4401.
Looks like what happened is the VCDS Beta got pushed to public but the accompanying CB 4407 hasn't, which I'm sure will be fixed momentarily. When that happens, the VCIConfig utility will upgrade you. Sit tight for a bit and keep using Release 17.8 if you need VCDS right this second.
Edit: what Eric says below instead. :)
Eric
HC800000
Yeah we overlooked something, but it's a little more complicated. The new VCIConfig lets people choose whether they want to be on the Release (currently 4401) or Beta (currently 4407) channel. Except for this to work, they need to be at least on 4402 :facepalm: We didn't catch it because all of us and our testers are on Beta or Alpha channels, or have newer CBs in their interfaces. We're trying to get to the right people (mostly Shaun) so we can put something 4402+ on the release channel :).
Hey turbocip and Al Bundy -- I have both of you guys in our records but only for older HEX+CAN interfaces. If you have a HEX-NET or HEX-V2 I can manually put it on the Beta channel for you, but only if I have the serial number. Feel free to PM me your serial number (HN1-nnnnnn or H1x-nnnnnn).
turbocip
Moon
C?ID=80803
Thank you Uwe
I will send SN in 1h via PM
Now i am to the phone.
Al Bundy
Bucharest, Romania
C?ID=80804
Yes Uwe, now I use the V2 interface, HEX-V2, not NET. I will send to you SN on PM.
PM sent.
turbocip
Moon
C?ID=80803
Already sent PM to you Uwe
Both of you guys should be able to update now.
CB 0.4407 will probably go on Release soon -- that's the cleanest way to avoid this for now.
turbocip
Moon
C?ID=80803
This version of software works very very fast than version 17.8.
I will test tomorrow on the car.
Regards
turbocip
Moon
C?ID=80803
Here is my feedback ...
I tested on VW G6 / Crafter 2.5 / Tiguan 2.0 / Audi A6 4G - all function works very very fast than previous versions. Better
icardiag
Europe
C?ID=113031
Anybody else having "internal rod error" issues after update to the latest 17.10.0?
Some errors from my latest log:
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 001 0285
Serial number: #
Coding: 000000070100046200003D01010000000000000000000000000000000000
Shop #: WSC 73430 790 00063
ROD: EV_MultiModulContiVW48X_SK37.rod
VCID: F2A889B72520A0BA3AD-80A6
Internal ROD error:
IV_EV_AllWheelContrHA1VW37X_003_VW37_F2.ROD:FFMUX,IV_EV_MultiModulContiVW48X_A3.ROD:ADP,.\UDS_EV\IV_EV_MultiModulContiVW48X_D.ROD:DTC,IV_EV_MultiModulContiVW48X_G3.ROD:GES,IV_EV_MultiModulContiVW48X_S3.ROD:SOT,IV_EV_MultiModulContiVW48X_SK37_X2.ROD:XPL
Eric
HC800000
Sounds like a corrupt install, so please try a clean reinstall and post your complete autoscan.
Dana
Western PA, USA
Serial number: #
Internal ROD error:
Please post the complete Auto-Scan from that vehicle. If you don't want the VIN online you can e-mail it to support instead.
icardiag
Europe
C?ID=113031
@Dana, Eric:
Thanks for hint, problem was solved with complete reinstall. The cause of problem was the OneDrive - while syncing, there were returned some remains of previous version files to the UDS_EV directory (more than 13000), while the 17.10 UDS_EV contains just 7580 files.
Eric
HC800000
Silly onedrive :)
