New Audi S5 - What functions are possible using older Hex-Can cable
gwakef
HC805181 Rev B
Hi All,
I just took delivery of new Audi S5 more or less fully loaded but as always something missing what in my opinion is quite useful
I refer to the function where by placing the gear to Park Position automatically engages the electromechanical handbrake.
Below is the scan from my hex-can cable, however I have very limited use of the functions unable to modify most modules due to access limitation
Would this be due to the older version cable or the updated Audi software ?
If not, can anyone advise me where to implement this change ?
Previously on my Audi A6 Avant 63 Plate, I was able to adjust most convenience modules
Many Thanks...........
Saturday,30,September,2017,14:32:18:01150
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: WAUZZZF54HA001xxx   License Plate:
Chassis Type  F5 (8W7)
Scan: 01 02 03 06 08 09 13 15 16 17 19 1B 2B 32 36 3C 42 44 47 52
          5F 6C 81 82 8B A5 A9 BB BC
BB-Door Rear Drv -- Status: Not registered 0001
BC-Door Rear Pass -- Status: Not registered 0001
Address 01: Engine (------CWGD)       Labels: None
   Part No SW: 8W0 907 559 G    HW: 06M 907 309 D
   Component: 3.0l V6 TFSI  H21 0007
   Revision: B2H21000
   Coding: 1A2A00322366050B34380000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM30TFS0118W0907559G 001010
   ROD: N/A
   VCID: 4999971AE8BD7C0A37-801C
No ASAM data for: "EV_ECM30TFS0118W0907559G" ()
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 8W0 927 158 B    HW: 0D5 927 156 H
   Component: 0D5  30TSIRdW H03 1004
   Revision: --H03---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 41898F3AD08DB44AEF-8014
   Part No SW: 8W0 907 379 F    HW: 8W0 907 379 D
   Component: ESP9 Premium  H09 0593
   Coding: 1CAA149A30A20A9715A64898407E58A2E6A59A38280C50A812021A4567A559
   Shop #: WSC 06324 790 00001
   ASAM Dataset: EV_ESP9BOSCHAU49X 012014
   ROD: EV_ESP9BOSCHAU49X.rod
   VCID: 489F921EF3B7850228-801C
   Part No SW: 4M0 959 760 A    HW: 4M0 959 760 A
   Component: MEM-BFS       008 0031
   Serial number: 00000216261499
   Coding: 00321004000CB0010003010141010000000000000000000000000000802003
   Shop #: WSC 06325 790 00001
   ROD: EV_SCMDriveSideCONTIAU736_AU73.rod
   VCID: 3663ECE6894303F24A-8062
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 8W0 820 043 G    HW: 8W0 820 043 G
   Component: Klima Zone 3  H32 0071
   Coding: 4608000D5544450D02020100880000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 377DE1E28E49FAFA51-8062
   Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000001024603
   Serial number: FC19464800PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: Klima Heck  H40 0073
   Part No SW: 8W0 907 063 BG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0248
   Coding: 07501143C13900CD050D59191BAD84B9130B31040000000000000000600016810A4502ABA2B70A
   ASAM Dataset: EV_BCM1BOSCHAU736 016006
   ROD: N/A
   VCID: 01094F3A900D744AAF-8054
   Subsystem 1 - Part No SW: 8W6 955 119 A    HW: 8W6 955 119 A
   Component: 494 RL 160331  036 0471
   Serial number: 00000001603290300435
   Coding: 5FC7F7
   Serial number: 20038066X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AB    HW: 4M0 941 531 AB
   Component: E1 - LDS  H06 0008
   Serial number: 31 05 2016  00386899
   Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Serial number: GX1CE127061612010148
   Coding: 230000
   Subsystem 5 - Part No SW: 8W0 947 135 BQ    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B10236860
   Subsystem 6 - Part No SW: 8W0 925 301 BF    HW: 8W0 925 301 BF
   Component: SL-B9/Q5NF  H15 0010
   Serial number: 2615000152367004
   Subsystem 7 - Part No SW: 8W0 907 182     HW: 8W0 907 182
   Component: J873 MKS_FSv  H03 0033
   Serial number: 7008174235B161902885
   Coding: BF0500
   Subsystem 8 - Part No SW: 8W0 907 182     HW: 8W0 907 182
   Component: J872 MKS_BFSv  H03 0033
   Serial number: 7008174235B161902867
   Coding: B30500
No ASAM data for: "EV_BCM1BOSCHAU736" ()
   Part No SW: 8W0 907 561 B    HW: 8W0 907 561
   Component: LRR4          H09 0220
   Coding: 3477FFF358FFEC06747860A0
   ASAM Dataset: EV_ACCBOSCHAU49X 002018
   ROD: EV_ACCBOSCHAU49X.rod
   VCID: 3D71F3CAAC75D0AA8B-8068
Address 15: Airbags (J234)       Labels: None
   Part No SW: 8W0 959 655 B    HW: 8W0 959 655 B
   Component: Airbag10.44   H73 0086
   Serial number: 003QQ000521K
   Coding: AACCF0C00C800000985000F3C0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: N/A
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 8W6857705A0033R00703
   Coding: 88001B
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 8W6857706A0235Q00449
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 442 062 508 16
   Component: SideSensor_Df  1E2 0887
   Serial number: 3577Y00C31FBD72214EC
   Subsystem 4 - Part No SW: -----------    HW: 442 062 508 16
   Component: SideSensor_Pf  1E2 0887
   Serial number: 3587Y00C11FBD7204240
   Subsystem 5 - Part No SW: -----------    HW: 442 0B2 307 16
   Component: SideSensor_Dr  1C7 0148
   Serial number: 35177009D2106CB602BA
   Subsystem 6 - Part No SW: -----------    HW: 442 0B2 307 16
   Component: SideSensor_Pr  1C7 0148
   Serial number: 3527700B92106CB26277
   Subsystem 7 - Part No SW: -----------    HW: 442 0C0 308 16
   Component: FrontSensor_D  1C5 014A
   Serial number: 3557500A920F7C25F11I
   Subsystem 8 - Part No SW: -----------    HW: 442 0C0 308 16
   Component: FrontSensor_P  1C5 014A
   Serial number: 3567500A920F7C24E07M
   Subsystem 9 - Part No SW: -----------    HW: 442 0C0 308 16
   Component: PedP_Sensor_C  1C5 014A
   Serial number: 2307500A1211FA12F17/
   Subsystem 10 - Part No SW: -----------    HW: 442 430 808 16
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00991FB75F3B21V
   Subsystem 11 - Part No SW: -----------    HW: 442 430 808 16
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00991FB75F202DW
No ASAM data for: "EV_AirbaAU10BPAAU736" ()
   Part No SW: 4M0 907 129 HH    HW: 4M0 907 129 HH
   Component: Lenks.Modul   H11 0009
   ROD: EV_SMLSKLOAU736_AU49.rod
   VCID: 7DF133CAECF510AACB-8028
Address 17: Instruments (J285)       Labels: None
   Part No SW: 8W5 920 790 C    HW: 8W5 920 790 C
   Component: FBenRDW       H15 0299
   Coding: 248D19DA7CB8060001B3E9601000400000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   ROD: EV_DashBoardAU736.rod
   VCID: 428B8036D58BAF52F6-8016
   Part No SW: 8W7 907 468 C    HW: 8W7 907 468 C
   Component: Gateway       H27 1298
   Revision: 4M090005    Serial number: 0584M273516905
   Coding: 0301000100008E405407000000590012F4900007920000000175078E00000000
   ASAM Dataset: EV_CGateCONTIAU491 002060
   ROD: EV_CGateCONTIAU491.rod
   VCID: 4B95AD12E2C16E1A05-801E
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20160816183416 21071
   Serial number: 0528641304
   Part No SW: 8W0 907 144 E    HW: 8W0 907 144 C
   Component: SCU_MLBevo    H03 0706
   Coding: 40
   ASAM Dataset: EV_SCUZFLSAU49X 002014
   ROD: EV_SCUZFLSAU49X.rod
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 16000145953006
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 326BD0F6652B1FD266-8066
Address 32: Differential Locks (J187)       Labels: None
   Part No SW: 8W0 907 163     HW: 8W0 907 163
   Component: QSP QCU Gen2  H07 0030
   Revision: 5WK12700    Serial number: 605633215250607
   Coding: 0001
   ASAM Dataset: EV_TVDCQSP22 001007
   ROD: N/A
   VCID: 79F927DAF8DD2C8AE7-802C
No ASAM data for: "EV_TVDCQSP22" ()
   Component: MEM-FS        008 0031
   Serial number: 00000213647679
   Coding: 00621004000CB0010003010141010000000000000000000000000000802003
Address 3C: Lane Change (J769)       Labels: None
   Part No SW: 4M0 907 566 B    HW: 4M0 907 566
   Component: MRR1Rear      H13 0230
   Revision: --------
   Coding: 4EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001015
   VCID: 3467D6EE9F3F11E274-8060
   Part No SW: 4M0 959 793 E    HW: 4M0 959 793 C
   Component: TSG FS        009 0055
   Serial number: 0000214928819
   Coding: 005D5A4250010085000034B2
   ROD: EV_DCU2DriveSideMAXHCONT.rod
   VCID: 408F8A3EDB87BD42E0-8014
196660 - Motor for Window Regulator
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 40
                    Mileage: 42 km
                    Date: 2017.06.08
                    Time: 00:00:06
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 8W0 909 144 F    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0407
   Coding: 85888380008080
   ASAM Dataset: EV_EPSZFAU49X 002015
   ROD: EV_EPSZFAU49X.rod
   Part No SW: 8W0 035 465     HW: 8W0 035 465
   Component: MIB2_amp_P_B9 H11 0420
   Revision: 00000001    Serial number: AUZ8ZAGJA00EG7
   Coding: 0194040800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: N/A
   VCID: 76E32CE6C9C343F28A-8022
No ASAM data for: "EV_AMPMst16C2Gen2ALPI" ()
   Part No SW: 4M0 959 792 E    HW: 4M0 959 792 C
   Component: TSG BFS       009 0055
   Serial number: 0000216016087
   Coding: 005D5A425C010085000034B0
   ROD: EV_DCU2PasseSideMAXHCONT.rod
   VCID: 3F8D89C2A679C2BA99-806A
                    Reset counter: 40
                    Mileage: 42 km
                    Date: 2017.06.08
                    Time: 00:00:06
   Part No SW: 8W0 035 035 C    HW: 8W0 035 035 A
   Component: MU-P-LND-EU   052 0678
   Serial number: A791H0G2501883
   Coding: 019454010000000053111102000A00332F0012E7017001009E
   ROD: N/A
   Subsystem 1 - Part No SW: V03 959 801 FB    HW: -----------
   Component: ECE 2016/2017  --- 0153
   Subsystem 2 - Part No SW: 8W2 919 605     HW: 8W2 919 605
   Component: AU49x_DU_HIGH  H40 0008
   Serial number: AUZ8Z9GBK008XN
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK110081600040235
   Component: Gracenote2---  --- 1013
No ASAM data for: "EV_MUHig6C3Gen2HBAS" ()
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 4M0 907 428 D    HW: 4M0 907 428
   Component: Areaview 2    H12 0311
   Serial number: C854607JG002497
   Coding: 02940401BE0FA10008404080
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_AU49.rod
   VCID: 3365D5F29A3116DA6D-8066
   Part No SW: 8W2 713 041 D    HW: 4M2 713 041 D
   Component: GSM-LL        H08 0068
   Revision: 0L0D5012    Serial number: 20160709000396
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: N/A
   VCID: 3561EBEA944508EA43-8060
No ASAM data for: "EV_GSMWaehlZFAU736" ()
Address 82: Heads Up Display (J898)       Labels: None
   Part No SW: 8W6 919 617 A    HW: 8W6 919 617 A
   Component: HeadUpDisplay H07 1603
   Coding: 4F01C0
   ASAM Dataset: EV_HudNSEIKAU736 001015
   ROD: EV_HudNSEIKAU736.rod
   VCID: 479D9122FEA98A7A21-8012
Address 8B: Adaptive Cruise 2 (J850)       Labels: None
   Part No SW: 8W0 907 541 B    HW: 8W0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU49X 002018
   ROD: EV_ACC2BOSCHAU736_AU73.rod
   VCID: 3B75FDD2B261DE9AB5-806E
Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
   Part No SW: 8W6 907 217     HW: 8W6 907 217
   Component: BVS           H14 0042
   Coding: 0404090400000404014023A6CD0000FCB0F0C020E280
   ROD: N/A
   VCID: 7F0DC9C2E6F902BAD9-802A
No ASAM data for: "EV_BVSMLBevKOSTAAU736" ()
1123600 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 42
                    Mileage: 47 km
                    Date: 2017.06.12
                    Time: 15:10:10
1123601 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 42
                    Mileage: 73 km
                    Date: 2017.06.24
                    Time: 12:07:41
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 8W0 907 159 F    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0005
   Serial number: 160318200957
   VCID: 4487862ECF9FA162C4-8010
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End-------------------------(Elapsed Time: 05:53)--------------------------
It's a combination of things:
The very first thing to do with a brand-new car is to update to a current version of VCDS. 16.8 isn't current at all. There have been two major releases since then; 17.1 and 17.8... Anyway, the update is free, so there's no reason not to.
Next, it looks like there's some stuff in that car that the old HEX+CAN interface you're using can't talk to at all and you really should consider upgrading to a current interface.
Lastly, with a brand-new car there is always the question of how much is documented.
gwakef
HC805181 Rev B
Updated VCDS 17.80.1
Thanks UWE
I've updated the software and just took the following scan
I appears that I can open more modules now but still not allowing entry to coding.
When it does, obviously with the new Audi software we are still in catch up to understand all of the functions
I contacted Gendan today to purchase the latest Hex V2. However, would be interesting to know if I am able to change the coding with existing cable to active the handbrake when selecting park function on the gear stick ?
Many Thanks
gwakef
Friday,20,October,2017,16:37:01:01150
VCDS Version: 17.8.0.1 (x64)
Mileage: 657km-408mi   Repair Order: S5 20.10.2017
Chassis Type  F5-AU49 (8W7)
VIN: WAUZZZF54HA001xxx   Mileage: 657km-408miles
   Revision: B2H21000
   ROD: EV_ECM30TFS0118W0907559G.rod
   VCID: 4999971AE8BD7C0E1D-801C
Address 02: Auto Trans (J217)       Labels:* None
   Revision: --H03---
   Coding: 100000
   ROD: EV_TCMALX52011_AU49.rod
   VCID: 41898F3AD08DB44EC5-8014
Address 03: ABS Brakes (J104)       Labels:. 8W0-907-379-PRE-V1.clb
   ROD: EV_ESP9BOSCHAU49X_012.rod
   VCID: 489F921EF3B7850602-801C
Address 06: Seat Mem. Pass (J521)       Labels:* None
   ROD: EV_SCMPasseSideCONTIAU736_AU37.rod
   VCID: 3663ECE6894303F660-8062
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   VCID: 377DE1E28E49FAFE7B-8062
   ROD: EV_BCM1BOSCHAU736_016_AU49.rod
   VCID: 01094F3A900D744E85-8054
   Coding: 5FC7F7
   Coding: 02005D
   Coding: 230000
   Interior Light Module:
   Valve Block 1 In Driver Side Front Seat:
   Coding: BF0500
   Valve Block 1 In Passenger Side Front Seat:
   Coding: B30500
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 3D71F3CAAC75D0AEA1-8068
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   Belt Pretensioner left:
   Coding: 88001B
   Belt Pretensioner right:
   Coding: 88001B
   Front Sensor Passenger:
   Pedestrian Protection Center:
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 7DF133CAECF510AEE1-8028
Address 17: Instruments (J285)       Labels:* 8W5-920-xxx-17.clb
   VCID: 428B8036D58BAF56DC-8016
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 4B95AD12E2C16E1E2F-801E
   Coding: 40
   ROD: EV_SCUZFLSAU49X_002.rod
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 326BD0F6652B1FD64C-8066
   Coding: 0001
   ROD: EV_TVDCQSP22_AU49.rod
   VCID: 79F927DAF8DD2C8ECD-802C
   ROD: EV_SCMDriveSideCONTIAU736_AU37.rod
   Revision: --------
   Coding: 4EC002
   VCID: 3467D6EE9F3F11E65E-8060
   ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
   VCID: 408F8A3EDB87BD46CA-8014
   ROD: EV_EPSZFAU49X_002.rod
   ROD: EV_AMPMst16C2Gen2ALPI_AU49.rod
   VCID: 76E32CE6C9C343F6A0-8022
   ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
   VCID: 3F8D89C2A679C2BEB3-806A
   Multimedia Operating Unit:
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   VCID: 3365D5F29A3116DE47-8066
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 3561EBEA944508EE69-8060
Address 82: Heads Up Display (J898)       Labels:* None
   Coding: 4F01C0
   ROD: EV_HudNSEIKAU736_AU49.rod
   VCID: 479D9122FEA98A7E0B-8012
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 3B75FDD2B261DE9E9F-806E
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 7F0DC9C2E6F902BEF3-802A
1123600 - predictive route data
          B1630 02 [008] - Signal Failure
                    Reset counter: 61
                    Mileage: 539 km
                    Date: 2017.10.18
                    Time: 13:46:28
                    Control Module temperature: 24 °C
                    Voltage terminal 15: 14.90 V
   VCID: 4487862ECF9FA166EE-8010
Virus-free. www.avg.com
Quite a few of those modules will have "experimental" coding information available with the new cable.
I do not know what would be involved in getting the EPB to auto-set when you put the transmission in park, or even whether this is possible at all, sorry.
