Hi everyone,
I am having a couple of issues with my Discover Media retrofit into my VW Passat B6. The biggest problem is that I have no volume control apart from turning the unit off. When the unit is on the volume must be approx. 2/3 up so is really loud! I have changed all the settings and it has not cured the problem. Resetting the unit doesn't fix it either. However when I clear all the vehicle fault codes I have temporary volume control so I am fairly sure its a coding issue or module conflict problem. To be honest I am at my wits end, I have removed a perfectly good RNS510 with OPS, Highline reverse cam and premium Bluetooth to do this for it not to work!
The Park Pilot is the next issue, I have carried out the adaptions and there are no faults on the module however I just get the "Park Pilot not available" message. Maybe the module I have is not compatible?
The unit is a Discover Media part number: 5C0035680C DAB with the CP removed, it also has App Connect, Voice control, Auxillary inputs and everything is wired up and working. I have full Dynaudio setup which has no faults.
I know you are all going to say there is a lot of faults on the car but any help would be very appreciated.
Here is a full scan:
Sunday,15,October,2017,16:50:12:15788
VCDS Version: 17.8.0.1 (x64) HEX-NET CB: 0.4401.4
Dealer/Shop Name: LIZARD RACING LTD
VIN: WVWZZZ3CZ8E144384 License Plate: MH08CHJ
Mileage: 38600km-23984mi Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 42 44 46 47 52 53 55 5D
5F 62 65 6D 72
VIN: WVWZZZ3CZ8E144384 Mileage: 38600km-23984miles
5D-Operations -- Status: Not registered 0001
6D-Trunk Elect. -- Status: Not registered 0001
Address 01: Engine Labels: 03G-906-018-BKP.clb
Part No SW: 03G 906 018 FG HW: 03G 906 018 FG
Component: R4 2.0l PPD1.5 G 2146
Revision: --H55--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 66565 257 00032
VCID: 6FAE33357EA0A03E63-803A
012593 - EGR System
P3131 - 006 - Regulation Range not Reached - Intermittent - MIL ON
Fault Status: 10100001
Reset counter: 40
Mileage: 127158 km
Date: 2020.03.04
Time: 14:55:33
RPM: 832 /min
Torque: 40.0 Nm
0.00 %
Lambda: 50.8 %
Battery Volts: 1.0 V
001650 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 006 - Electrical Fault - MIL ON
Fault Status: 11100001
Fault Frequency: 188
Reset counter: 40
Mileage: 127158 km
Date: 2020.03.04
Time: 17:06:22
Torque: 0.0 Nm
0.00 %
Voltage: 12.09 V
Bin. Bits: 00110000
Temperature: 18.0°C
005685 - Powertrain Data Bus
P1635 - 009 - Missing Message from A/C Controller - Intermittent
Fault Status: 00000100
Reset counter: 23
Mileage: 38431 km
Date: 2017.10.08
Time: 16:25:49
Torque: 0.0 Nm
0.00 %
Voltage: 11.98 V
Bin. Bits: 00000000
Bin. Bits: 00000000
Readiness: N/A
Part No SW: 02E 300 050 D HW: 02E 927 770 AD
Component: GSG DSG 082 1404
Revision: 04808020 Serial number: 00000902030957
Shop #: WSC 04940 001 00001
VCID: 13665FC5324824DE27-8046
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
Component: J104 C4 440 V2 0003
Revision: --020--- Serial number: 00000776663169
Coding: 0001294
Shop #: WSC 05311 000 00000
VCID: 1F0E03F5CE8070BE93-804A
Part No SW: 7N0 907 426 L HW: 7N0 907 426 L
Component: AC Manuell H17 0202
Revision: 00012001
Coding: 0000001002
ROD: EV_ClimaBasis_VW36.rod
VCID: 3D32D97DAC4C02AEA1-8068
Revision: 00H54000 Serial number: 01000007852032
Coding: E28A9F0700041A004F0A00000F000000000A41435C000110000000000000
Shop #: WSC 05124 123 12345
VCID: 71AA354D6894B6CE75-8024
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 221107 022 0601
Coding: 00046997
Shop #: WSC 05124
Component: RLS 200914 054 0403
Coding: 00209069
Shop #: WSC 05124
02390 - Control / Regulation for Ambience Lighting (E400)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 26
Mileage: 38601 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.00 V
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 56D 919 475 A HW: 56D 919 475
Component: PARKHILFE 8K H02 0006
Revision: -------- Serial number: 35821328001223
Coding: 100103
ASAM Dataset: EV_EPHVA18VW4110000 001007
ROD: EV_EPHVA18VW4110000.rod
VCID: 3326FF459A08C4DE47-8066
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__003 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPQRDHKO
Coding: 0012339
VCID: 3B36D7657A580C9E9F-806E
Subsystem 1 - Serial number: 6333FTS658443197
Subsystem 2 - Serial number: 6343FTS606383187
Subsystem 3 - Serial number: 6353ETS6KS6310KH
Subsystem 4 - Serial number: 6363ETS6DJM310KH
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AK HW: 3C0 953 549 AK
Component: J0527 0025
Revision: 00029000 Serial number: 3C5953507BR
Coding: 0200612
VCID: 75A2015D1CFC9AEEA9-8020
Subsystem 1 - Part No: 6C0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H03 0015
Coding: 00000041
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb
Part No SW: 3C8 920 981 D HW: 3C8 920 981 D
Component: KOMBI H04 0611
Coding: 461D01
Shop #: WSC 05314 115 12345
VCID: 2F2EF3357620E03E23-807A
Part No SW: 7N0 907 530 BC HW: 7N0 907 530 AN
Component: J533 Gateway H56 1663
Revision: H56 Serial number: 111115F1000586
Coding: 462007
VCID: 72A83A41AD928DD68C-8026
Mileage: 38601 km
Date: 2017.10.15
Time: 17:16:18
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 00404 210 92331
VCID: 393ACD6D70643E8E8D-806C
Component: ELV 029 0380
3C0905861J ELV 029 0380
02823 - Requirements for Locking the Steering Column Lock not met
Reset counter: 26
Mileage: 38601 km
Date: 2017.10.15
Time: 16:58:41
Address 36: Seat Mem. Drvr (J810) Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 B HW: 3C8 959 760 B
Component: Sitzmemory H02 1001
Revision: 00H02000
Coding: 000039
VCID: 3424FC599706C3E65E-8060
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1130
Revision: 31008001 Serial number: 00000515969127
Coding: 0000757
Shop #: WSC 06441 785 00200
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.135 H08 1901
VCID: 3620C651417AD1F660-8062
Component: KSG PQ46 ELV 042 0472
Coding: 00910A005103007F0004941570085FCE107801
Shop #: WSC 05311 123 08193
Component: LIN BACKUP HORN H07 9001
Component: Neigungssensor 004 0611
Address 47: Sound System Labels: 3C0-035-456.clb
Part No SW: 3C8 035 456 C HW: 3C8 035 456 C
Component: DSP 10 Kanal 0070
Revision: 00H06001 Serial number: 75805001905807
VCID: 281C18299BCEB706E2-807C
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1130
Revision: 31008001 Serial number: 00000018969124
Coding: 0000756
VCID: 3C34D4797F560BA696-8068
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000271893
Coding: 0000057
Shop #: WSC 05311 000 08193
VCID: 291A1D2D80C48E0EFD-807C
Component: AFS-Steuergeraet 0148
Coding: 2311169
VCID: 3424FC595706C3E65E-8060
Subsystem 1 - Part No: 7L6 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l X018
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 330
Component: AFS-Lst.-Modul r X018
Coding: 00000035
Address 5D: Operations Labels: 3C0-035-151.lbl
Part No SW: 3C0 035 151 C HW: 3C0 035 151 C
Component: J738 011 0018
Revision: 00011000
VCID: 187C28E92BAE078652-804C
Part No SW: 5C0 035 680 C HW: 5C0 035 680 C
Component: MU-S-ND-ER H22 0245
Serial number: --------------
Coding: 02240801AA00000001111103008808001F01008600200100CF
Shop #: WSC 38403 001 104857
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 210A050D30F4464EA5-8074
Subsystem 1 - Part No SW: 3G0 919 866 BC HW: -----------
Component: ECE1 2017/18 --- 0820
7179 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 26
Mileage: 38601 km
Date: 2017.10.15
Time: 16:57:51
Voltage terminal 30: 12.0 V
BAP-BAP_Function_ID: 02
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0307
Revision: 41004101 Serial number: 00000000073229
Coding: 0000208
VCID: 70AC3049639EBFC67A-8024
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 D HW: 3AA 907 273 D
Component: RDKBERU30 H09 0010
Serial number: 10000000073171
ASAM Dataset: EV_RDKBERU30 003012
ROD: EV_RDKBERU30_003.rod
VCID: 3522C15D947CDAEE69-8060
Part No SW: 3C9 827 383 G HW: 3C9 827 383 G
Component: J605 HECKDECKEL 0730
Revision: 00H27001
VCID: 3522C15D5C7CDAEE69-8060
Subsystem 1 - Part No: 3C9 827 384 G
Component: J756 HECKDECKEL 0730
Subsystem 2 - Serial number: 0800H27001001A0155ÿ
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0307
Revision: 41004101 Serial number: 00000000083890
Coding: 0000208
End----------(Elapsed Time: 01:48, VBatt start/end: 12.1V/12.1V)-----------
