Here is my autoscsan from my A4 2011 2.0 TDI Avant Quattro UK spec
The A/C has stopped producing cool air quite recently however the red a/c light on the switch panel behaves as normal,
lighting when a/c is on and extinguishing when it is off, so I'm thinking the problem is not the low pressure sensor in front of the radiator.
Nor are there any related fault codes on the scan.
I have looked at the output test on module 08 Auto HVac and find that the current reading with engine running fluctuates between about 0.700 and zero, which I believe is not what it should do.
The absolute pressure shown before starting the engine is about 6.0 bar but it only climbs a very little with engine running- to about 7.4ish and is seen to rise and fall with the current-i.e. falls when current drops to zero and rises when current returns to about 0.700.
Are there other tests I can do with vcds?
I looked for a security code in this module but none popped up in a bubble, so I assume that I cannot make an adaptation map to post here.
Any suggestions will be appreciated.
Saturday,14,October,2017,17:22:08:60719
VCDS Version: 17.8.0.1 (x64)
VIN: WAUZZZ8K0CA045541 License Plate: YR61ETE
Mileage: 255060km-158486mi Repair Order: 14102017
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 56 5F 62 72
VIN: WAUZZZ8K0CA045541 Mileage: 255060km-158486miles
Address 01: Engine (J623-CAHA) Labels:. 03L-906-019-CAG.clb
Part No SW: 03L 906 022 RM HW: 03L 906 019 AL
Component: R4 2,0L EDC H35 8422
Revision: 25H35---
Coding: 12194012242701080000
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_ECM20TDI03L906022RM A02005
ROD: EV_ECM20TDI03L906022NP.rod
VCID: 010289C590E4254E85-8054
U1113 00 [032] - -
U1113 00 [032] - -
4987 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 00 [109] - Electrical Fault
Mileage: 231361 km
Date: 2017.01.01
Time: 12:12:07
Engine speed: 420.50 /min
Normed load value: 100.0 %
Coolant temperature: 6 °C
Intake air temperature: 5 °C
Voltage terminal 30: 10.780 V
Electric auxiliary heater: shut-off conditions-Bit 0: 00000000
Electric auxiliary heater: shut-off conditions-Bit 8: 00000000
Electric auxiliary heater: relay activation-Bit 0: 00000000
Preheat time: 2500 ms
Glow status-Bit 0: 00000000
Glow status-Bit 8: 00000000
Ambient temperature: 4.1 °C
Fuel temperature: 5.9 °C
Eng Da ti Eng Off CAN: 0 s
Part No SW: 8K0 907 379 BG HW: 8K0 907 379 BG
Component: ESP8 quattro H04 0020
Coding: 180504
VCID: 7F060F3DEE1053BEF3-802A
Part No SW: 8K0 907 064 CN HW: 8K0 907 064 CN
Component: BCM2 2.0 H05 0435
Coding: 033200
Shop #: WSC 06335 000 00000
VCID: 7EF8F239E91A5AB6F8-802A
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0811000127098017
Component: J764 ELV MLB H37 0042
Serial number: 2311000166502004
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
Component: KLIMA 3 ZONEN H08 0180
Revision: D0000000 Serial number: 01090820110307
Coding: 34340000
VCID: 76E8EA19C12A12F6A0-8022
Part No SW: 8K0 907 063 K HW: 8K0 907 063 K
Component: BCM1 1.0 H30 0392
Revision: 06030001 Serial number: 00000001176745
Coding: 6900C0B10034A7010001000000005F5F001D060806000141000000
Shop #: WSC 06335 123 12345
VCID: 3776271D86A0ABFE7B-8062
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 120811 H06 0070
Serial number: SWF11080125434
Coding: 00FD11
Component: RLS H04 0003
Serial number: 11612086
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000000708110062
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 AA HW: 8P0 919 475 N
Component: PARKHILFE 8K H01 0081
Revision: 11001001 Serial number: 12501122201008
Coding: 100203
VCID: 78F4E421CB3E6486B2-802C
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 L HW: 8K0 959 655 L
Component: AirbagVW-AU10 H44 0610
Serial number: 003JMD0FAY0U
Coding: 30533435363030303030554A3052384B3053
VCID: 46885AD9F94AC276F0-8012
Serial number: 6334MSME625511687
Serial number: 6344MSME62452D4CM
Serial number: 6352QSME785C365E.
Serial number: 6362QSME195D2F78
Serial number: 63732SME544F4E4EK
Serial number: 63832SME544F036E8
Part No SW: 8R0 953 568 K HW: 8R0 953 568 K
Component: Lenks.Modul H07 0156
Revision: 00000000 Serial number: 20110818000351
Coding: 000017
VCID: 499251E5E0542D0E1D-801C
Component: E221 - MFL H02 0010
Part No SW: 8K0 920 981 D HW: 8K0 920 981 D
Component: KOMBIINSTR. H70 0402
Revision: 00000000 Serial number: KI271AG8C
Coding: 2F05110002002600010000
VCID: 346C101197D640E65E-8060
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E11803805C
Coding: 00CF07
VCID: 030E83CD82F8375E97-8056
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650252795
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 11224000217011200181
Part No SW: 8K0 959 793 N HW: 8K0 959 793 N
Component: TSG FA H12 0357
Revision: Serial number: 0000011685779
Coding: 011002204001410001
VCID: 4B9E6BEDEA283F1E2F-801E
Revision: 00002001 Serial number: 0155769401
Coding: 013B062220B904408020023680000000
Part No SW: 8K0 959 792 N HW: 8K0 959 792 N
Component: TSG BF H12 0357
Revision: Serial number: 0000011369488
VCID: 4A906EE9E552261614-801E
00110 - Right Mirror Turn Signal Lamp (L132)
Reset counter: 172
Mileage: 249873 km
Date: 2017.07.30
Time: 17:24:03
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 20000000080881
Part No SW: 4G0 035 056 H HW: 4G0 035 056
Component: Radio U STD H52 0134
Revision: AB001007 Serial number: 469H90B7787901
Coding: 010003020100000001
VCID: 2648FA59510A2276D0-8072
Part No SW: 8T2 035 652 L HW: 8T2 035 652 D
Component: B-BN-EU H61 0188
Revision: -------- Serial number: 305H-0B7529083
Coding: 01010101000681ED01000B0E000000030000
VCID: 3F864F3DAE9093BEB3-806A
Subsystem 1 - Part No: 4G0 919 884 J
Component: EUR 2011 1204
Subsystem 2 - Part No SW: 8T0 919 604 HW: 8T0 919 604
Component: DU6 Basic H42 0098
Serial number: 9465H.0B0361369
Subsystem 3 - Part No SW: 8T0 919 609 HW: 8T0 919 609
Component: E0380 Bedient H08 0100
Serial number: 00000000901762
Part No SW: 8K0 959 795 F HW: 8K0 959 795 F
Component: TSG HL H11 0357
Revision: Serial number: 0000011712908
Coding: 010002204001210001
VCID: 458A5DD5CC4CC96EF9-8010
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H11 0357
Revision: Serial number: 0000011712941
End-------------------------(Elapsed Time: 02:57)--------------------------
