VCDS With Mk3.5 Facelift Leon FR
dmcmsn
New Member
Hello everyone. I have a few questions before purchasing the cable.
I have a MK3.5 Leon FR it’s the facelift 2017 version, I have heard from some people that the long coding helper does not work with the facelift. Can anyone confirm this? Just want to be sure before I buy
I only want to do a few things such as
- Needle Sweep
- Enabling auto lights ( I will buy switch and sensor)
- Carbon Dash Screen
- Enabling visual of rear PDC
Has anyone used it with a mk7.5 golf as it should be mostly the same.
Many thanks
Bruce
Near Philadelphia, PA, USA
We need to make a slight correction to information those not informed have given you. The Long Coding helper works. However, the information you seek may not be in the coding any longer owing to changes the boys at VAG have made. The information you seek may be found in "Adaptations". They have also introduced something referred to as "Parameterization". We are still working to figure out what the VAG engineers have done with this.
The current release, 17.8.x has something we refer to as "Experimental Coding". To use it, you must be using one of our latest and newest interface systems. A good description of Experimental Coding can be found on this page: http://www.ross-tech.com/vcds/download/beta/current.php
Our guess is that for your Leon, between Adaptations and Experimental Coding, much of your list can be accomplished. We won't know for sure until we see scans from the vehicle and you may have to help us increase the data we have for the MK 3.5 Leon platform. That is how VCDS gets to be the tool all have come to expect. Our users are in partnership with us to work the details. No one should expect VAG to hand anything to us. All information has to be derived from our users cars.
Let us know if we can help further.
dmcmsn
New Member
Thank you, i tried this morning and was able to get the visual park pilot up :)
Am going to try the auto lights code tomorrow. I have a full autoscan here of my car if it could benefit you guys in any way?
dmcmsn
New Member
Sunday,15,October,2017,09:57:57:57399
VCDS Version: 17.8.0.1 (x64)
VIN: VSSZZZ5FZJR026299   License Plate: VJI 737
Mileage: 994km-617mi   Repair Order:
Chassis Type  5F-SE37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: VSSZZZ5FZJR026299   Mileage: 994km-617miles
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H26 4418
   Revision: R7H26---
   Coding: 01190032232419082000
   Shop #: WSC 00049 770 00124
   ASAM Dataset: EV_ECM14TFS01104E906027HB 001006
   ROD: EV_ECM14TFS01104E906027HB.rod
   VCID: 6BD266E08265C71E4F-803E
   CAN Converter 01:
   Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0643
   Revision: 00000000    Serial number: 61727000001269
   Coding: 18EE8A92242221720779060940CC2418512484E0600224733020F078C002430000000012121212B835351919323200
   Shop #: WSC 00049 770 00222
   ROD: EV_Brake1UDSContiMK100IPB_036_SK37.rod
   VCID: 78F849ACC3337C86B2-802C
   Part No SW: 5F0 907 044 AK    HW: 5F0 907 044 AK
   Component: Climatronic   H05 1801
   Revision: 00001K09
   Coding: 04100004200114011005000000101020
   VCID: 6FEA72F0B67D3B3E63-803A
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [008] -  -
                    Reset counter: 51
                    Mileage: 36 km
                    Date: 2017.09.29
                    Time: 07:32:26
                    Dynamic environmental data: 02 86
                    Voltage terminal 30: 12.8 V
                    Compressor shut-off requirement: Shut-off of engine control module via CAN (T > 15 sec.)
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001718401419
   ROD: EV_BCMBOSCH_018.rod
   VCID: 091E3C68A8D9750EDD-805C
   Subsystem 1 - Part No SW: 5F2 955 119 A    HW: 5F2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 170529  041 0574
   Serial number:         170619115642
   Coding: 0BC5FD
   Subsystem 2 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY17102146R
   Subsystem 3 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000070101860
   Subsystem 4 - Part No SW: 81A 907 658     HW: 81A 907 658
   Component: G397_FSS  H02 0003
   Serial number: 20007341X81A90765800
   Coding: 40006C
7 Faults Found:
10506 - Bulb for Left Tail Light
          B12BE 15 [008] - Open or Short to Plus
                    Reset counter: 81
                    Mileage: 876 km
                    Date: 2017.10.10
                    Time: 16:41:18
10762 - Bulb for Right Tail Light
          B12BF 15 [008] - Open or Short to Plus
                    Reset counter: 81
                    Mileage: 876 km
                    Date: 2017.10.10
                    Time: 16:41:18
11018 - Bulb for Left Brake Light
          B12C2 15 [008] - Open or Short to Plus
                    Reset counter: 81
                    Mileage: 876 km
                    Date: 2017.10.10
                    Time: 16:41:39
11530 - Bulb for Right Brake Light
          B12C3 15 [008] - Open or Short to Plus
                    Reset counter: 81
                    Mileage: 876 km
                    Date: 2017.10.10
                    Time: 16:41:39
919560 - Light Switch
          B126A 29 [008] - Signal Implausible
                    Reset counter: 63
                    Mileage: 441 km
                    Date: 2017.10.03
                    Time: 10:39:01
1050628 - Lamp 1 for Contour Lighting of Door; Front Right
          U1178 00 [008] - No Communications
                    Reset counter: 50
                    Mileage: 35 km
                    Date: 2017.09.26
                    Time: 16:28:03
1050884 - Lamp 2 for Contour Lighting of Door; Front Right
          U1205 00 [008] - No Communications
                    Reset counter: 50
                    Mileage: 35 km
                    Date: 2017.09.26
                    Time: 16:28:03
   Part No SW: 5QA 919 283 B    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0044
   Serial number: 000308419617179
   Coding: 0600040001
   ASAM Dataset: EV_EPHVA14AU3700000 009033
   ROD: EV_EPHVA14AU3700000_009_VW37.rod
   VCID: 499EFC68E859350E1D-801C
1080083 - Rear Parking Aid Sensor(s)
          B107B 13 [008] - Open Circuit
                    Reset counter: 81
                    Mileage: 876 km
                    Date: 2017.10.10
                    Time: 16:41:36
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Component: ACC BOSCH MQB H10 0620
   Coding: 2D00008151FF8428949C814500300400000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002005
   ROD: EV_ACCBOSCHVW416.rod
   VCID: 3C7095BCB78B90A696-8068
2172 - Databus
                    Reset counter: 81
                    Mileage: 876 km
                    Date: 2017.10.10
                    Time: 16:41:41
                    Dynamic environmental data: 02 8D
                    Control Module temperature: 16 °C
                    Voltage terminal 15: 13.3 V
                    Velocity_vehicle_reference: -0.97 m/s
                    Longitudinal_acceleration_vehicle_reference: 1.20 m/s²
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W4PCXEFEN
   Coding: 98CCC000000000005C0000CC008800000065
   ROD: EV_AirbaVW21TS6VW48X_VW27.rod
   VCID: 0506305884C1116EB9-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 002 006 17
   Serial number: 357000000001C9303729
   Subsystem 2 - Part No SW: -----------    HW: 454 002 006 17
   Serial number: 35800000000BF3D4172T
   Subsystem 3 - Part No SW: -----------    HW: 454 802 806 17
   Serial number: 351004D7832100000004
   Subsystem 4 - Part No SW: -----------    HW: 454 802 806 17
   Serial number: 3520045C92F10000000F
   Subsystem 5 - Part No SW: -----------    HW: 454 801 306 17
   Serial number: 3550094A912100000006
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 GD    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 04071704220653
   Coding: 1400
   VCID: 7EF45FB4E11742B6F8-802A
   Part No SW: 5F0 920 950 E    HW: 5F0 920 950 E
   Component: KOMBI         303 0310
   Coding: 27A40A002B80060001886A011000000080000000
   ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
   VCID: 295E5CE84819150EFD-807C
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   433 4303
   Revision: --------    Serial number: 0006563502
   Coding: 030100F42F085700EB000248080F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3362BE809AD55FDE47-8066
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Serial number: 000000000G1050300617
   Coding: 002000
   Serial number: 75886000001706221CCC
   Serial number: 0000263940871
   Coding: 00100220DC01040100001000
   VCID: 479AFA50FE4DC37E0B-8012
          B122D 29 [009] - Signal Implausible
                    Reset counter: 10
                    Mileage: 1048574 km
                    Time: 00:00:00
65652 - Motors for Central Locking
          B122B 13 [008] - Open Circuit
                    Reset counter: 50
                    Mileage: 1048574 km
                    Time: 00:00:00
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 8107
   ROD: EV_SteerAssisMQB_013_VW37.rod
   VCID: 4586F058C441D16EF9-8010
   Serial number: 0000264928913
   Coding: 00100220DE01040100001000
   VCID: 4684F754F947DA76F0-8012
   Part No SW: 5QA 035 858 B    HW: 5QA 035 858 B
   Component: MU-S-ND-ER    H41 0462
   Serial number: SEZAZ2T1154425
   Coding: 04736001D70A000011110101008808002F0101C601200500C6
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SE26.rod
   Subsystem 1 - Part No SW: 5F0 919 606     HW: 5F0 919 606
   Component: ABTm-2_8-CR  H41 1042
   Serial number: SEZ8Z9T6C00L46
   Subsystem 2 - Part No SW: 6P0 919 866 R    HW: -----------
   Component: ECE1 2017/18  --- 0820
End-------------------------(Elapsed Time: 03:51)--------------------------
Was the above scan made with a cable you are considering purchasing?
That HEX+CAN (which is a few years old) isn't 100% compatible with your car.
dmcmsn
New Member
That's the cable i got, and was able to enable
- Carbon dash FIS/Media screen
- Visual parking sensors.
However when i try to code the autolights it comes up with an error ' no coding information is availible for this module' cant remember the wording exactly. No long coding showed up in the module just the bits and bites but no information beside them, is there anyway to find the information for the bytes?
golfi_vend
Tartu, Estonia
C?ID=195131
Only if RT team is able to work through that module to be certain about each bit description. If You had a "NEW GENERATION" interface, that means Hex-V2 or Hex-NET VCDS would problably show You experimental coding. It may not be 100% correct, but at least there would be something.
dmcmsn
New Member
I’ll see if Ross Tech can determine the values of the bits, I don’t mind a bit of a wait. Might try obdeleven as well to see if it’s any different but I’d imagine it’s the same.
Failing that, I’ll have to try and find someone with a new cable.
