Lost coding for abs pump 1K0907379BE on a Cupra (MK60EC1)
mohsin52
HC701777 (2nd hand?)
Hi there,
I am having some trouble with the ABS code for a 2011 Seat Leon Cupra 2.0 tfsi.
The car has the CDL engine with a KO4.
The code on VCDS for the ABS pump shows 000** all the way through and a fault shows saying incorrect coding. I have tried a few various codes from others posts and have had no luck and continuously get error 31: coding rejected with every code. It won't accept anything at all.
The pump part no. is 1K0907379BE
My cars VIN is VSSZZZ1PZBR049310
The car is in the UK and right hand drive.
It has a tyre pressure monitoring button to set the pressure.
It also has a traction control button installed.
I will post a full autoscan log as soon as I get home.
Is there any way I can get a new code for the module?
Any help would be greatly appreciated.
Thanks!
mohsin52
Wednesday,04,October,2017,17:00:29:48324
VCDS Version: 17.8.0.1
VIN: VSSZZZ1PZBR049310   License Plate:
Chassis Type: 1P-SE35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 62 72
VIN: VSSZZZ1PZBR049310   Mileage: 55250km-34330miles
Address 01: Engine (CDL)       Labels:. 06F-907-115-CDL.clb
   Part No SW: 1P0 907 115 AB    HW: 8P0 907 115 B
   Revision: 5BH20---    Serial number:
   Coding: 0303000C18070160
   Shop #: WSC 80093 222 69422
   VCID: 6BD3F1FE4A39341E4F-803E
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage - Intermittent - MIL ON
                    Fault Status: 10100100
                    Mileage: 55249 km
                    Date: 2012.02.14
                    Time: 02:30:08
                    Temperature: 12.0°C
                    Temperature: 15.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 16.002 V
008208 - Intake Manifold Flap; Bank 1
               P2010 - 001 - Short to Plus
                    Fault Status: 01100001
                    Mileage: 55257 km
                    Date: 2012.02.24
                    Time: 00:01:03
                    RPM: 202 /min
                    Load: 71.0 %
                    Temperature: 14.0°C
                    Temperature: 15.0°C
                    Voltage: 9.017 V
008852 - Fuel Pressure Regulator Valve (N276)
               P2294 - 004 - Open Circuit - MIL ON
                    Fault Status: 11100100
                    Mileage: 55257 km
                    Date: 2012.02.24
                    Time: 00:01:03
                    RPM: 202 /min
                    Load: 71.0 %
                    Temperature: 14.0°C
                    Temperature: 15.0°C
                    Voltage: 9.906 V
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 008 - Implausible Signal
                    Mileage: 55257 km
                    Date: 2012.02.24
                    Time: 00:01:03
                    RPM: 202 /min
                    Load: 70.6 %
                    Temperature: 14.0°C
                    Temperature: 15.0°C
                    Voltage: 9.906 V
012423 - Voltage Supply Relay for Engine Components
               P3087 - 002 - Electrical Malfunction - Intermittent
                    Mileage: 55257 km
                    Date: 2012.02.24
                    Time: 00:01:03
                    RPM: 203 /min
                    Load: 70.6 %
                    Temperature: 14.0°C
                    Temperature: 15.0°C
                    Voltage: 9.652 V
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Shop #: WSC 04941 000 00000
   VCID: 76E5D08AC17BF9F6A0-8022
                    Reset counter: 203
                    Mileage: 55257 km
                    Date: 2012.02.24
                    Time: 00:00:09
                    Count: 7
                    Count: 3
                    Count: 4608
                    Count: 128
                    Count: 23552
                    Count: 64768
03306 - Coding Not Valid
            000 -  -  - Intermittent
                    Reset counter: 203
                    Mileage: 55251 km
                    Date: 2012.02.23
                    Time: 22:23:55
                    Count: 3
                    Count: 2
                    Count: 29440
                    Count: 4161
                    Count: 49408
                    Count: 64768
                    Reset counter: 203
                    Date: 2012.02.23
                    Time: 21:55:21
                    Count: 3
                    Count: 20992
                    Count: 195
                    Count: 50176
                    Fault Status: 01100101
                    Reset counter: 203
                    Mileage: 55251 km
                    Date: 2012.02.23
                    Time: 21:55:06
                    Count: 3
                    Count: 2
                    Count: 29440
                    Count: 295
                    Count: 49920
                    Count: 65024
   Part No SW: 5P0 907 044 P    HW: 5P0 907 044 P
   Component: Climatronic   H15 0702
   Revision: 00001001
   Coding: 0000000002
   Shop #: WSC 06402 785 00200
   ROD: EV_ClimaAutoBasis_SE35.rod
   VCID: 3D770FA6ACCD6AAEA1-8068
          B10AB F0 [009] - Too Low
                    Reset counter: 207
                    Mileage: 55257 km
                    Date: 2017.10.04
                    Time: 05:52:25
Address 09: Cent. Elect.        Labels: None
   VCID: 55A7B706BCBD92EE89-FFFE
   Part No SW: 5P0 919 475 B    HW: 5P0 919 475
   Component: PARKHILFE 4K  H07 0005
   Revision: --------    Serial number: 89341101804492
   Coding: 000004
   VCID: 3A7D04BAB5E35D9684-806E
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__A0E VW10 HI   1918
   Revision: 22014000    Serial number: 003K0P14FAZR
   Coding: 0012357
   VCID: 4C9152622F77D32626-8018
   Subsystem 1 - Serial number: 6332MTS641470081
   Subsystem 2 - Serial number: 6342MTS609430081
   Subsystem 3 - Serial number: 6351HTS6HRHNM9KJ
   Subsystem 4 - Serial number: 6361HTS62FVRM9KJ
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
                    Fault Status: 11100001
                    Mileage: 55257 km
                    Date: 2012.02.25
                    Time: 05:52:24
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
                    Mileage: 55257 km
                    Date: 2012.02.25
                    Time: 05:52:24
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20110129201251
   Coding: 1082140002
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79FFDBB6F865968ECD-802C
   Subsystem 1 - Part No SW: 1P0 959 538 D    HW: 1P0 959 538 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP  H02 0102
   Coding: E20000
227395 - Windshield Wiper Switch
          B1145 07 [009] - Mechanical Failure
                    Reset counter: 207
                    Mileage: 55257 km
                    Date: 2017.10.04
                    Time: 05:52:21
   Part No SW: 1P0 920 952 D    HW: 1P0 920 952 D
   Component: KOMBI         H06 0420
   Coding: 620B00
   VCID: 306926926B9F97C63A-8064
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 240111F1001659
   Coding: 350203
   VCID: 30692692639F97C63A-8064
   Component: IMMO          H06 0420
   VCID: 6ADDF4FA8DC32D1634-803E
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Component: SG EXT.PLAYER H13 0150
   Revision: A1001003    Serial number: 7669274872
   VCID: 2859CEF25B4FDF06E2-807C
   Part No SW: 5P0 035 191 D    HW: 5P0 035 191 D
   Component: RNS315        H05 0010
   Serial number: SEZAZ2L9115125
   Coding: 040004010402000000000000
   ASAM Dataset: EV_RNS315SeatEUV1UDS A01005
   ROD: EV_RNS315SeatEUV1UDS.rod
   VCID: 2C5132E247B7F32606-8078
   Part No SW: 1T0 959 701 AG    HW: 3C0 959 793 A
   Component: TUER-SG FT    002 0312
   Revision: 12101005    Serial number: 0001564740
   Coding: 0012B0
   ASAM Dataset: EV_DCU42BroseDriveSide A03004
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 7CF1C2A2F757A3A6D6-8028
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 704 AF    HW: 1K0 959 794 S
   Component: J389__TSG-HR  006 1401
   Serial number: 00000005221545
   Coding: 000290
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 142    3201
   Revision: 00H20000
   Shop #: WSC 06403 785 00200
   VCID: 34612A825787ABE65E-8060
Address 46: Central Conv.
   Part No SW: 1T0 959 702 AC    HW: 3C0 959 792 A
   Component: TUER-SG BT    002 0312
   Revision: 14101005    Serial number: 0001641860
   Coding: 0012B0
   ASAM Dataset: EV_DCU52BrosePasseSide A03004
   ROD: EV_DCU52BrosePasseSide.rod
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 703 AF    HW: 1K0 959 795 S
   Component: J388__TSG-HL  006 1401
   Serial number: 00000005442992
   Coding: 000290
End-------------------------(Elapsed Time: 03:25)--------------------------
mohsin52
Most of the faults regarding voltage are only on the log due to starting the car with a battery charger when I read the faults. Once cleared they don't come back until it needs starting again a week later due to the weak battery.
downtime
C?ID=280813
Try, should work :
143B801209260803800E01E590190481350800
Edit, fixed noticed that you mentioned right hand drive :)
mohsin52
Will give it a shot. Thanks!
Can i just ask how you got that code? 🙄 Just curious
downtime
C?ID=280813
Just look for autoscans of Seat Cupra with google and there's also an unofficial mk60ec xpl label file for vcds long coding helper which you can use to inject your VIN numbers.
The difficulty in the mk60EC1 coding is that the code contains parts of your VIN number so you cannot just copy a code from another EC1 pump.
iichel
Netherlands, eastern part
C?ID=284912
The VIN is part of any recent ABS pump of the VW group, not just the MK60EC1... :-)
downtime
C?ID=280813
Yes, true. Good point. Let's say from EC1 onwards we've had the pleasure of having VIN encoded in the coding :)
mohsin52
Thanks for the replies, I haven't had time to try it today so will try it in the morning and get back! Really hope it takes the code!
downtime
C?ID=280813
If not there are some small tweaks that can be done. Now there's hillhold and XDS enabled also in the code.
mohsin52
As far as I am aware the car in question does not have hillhold unless this is something that just needs coding in?
downtime
C?ID=280813
Usually it's just coding. Not all pumps support that so but according to the table I have, BE should support Hillhold.
mohsin52
*sigh*
So I tried the code and unfortunately it has rejected that code too! The fault is still the same as before "coding rejected. Error 31: request out of range"
downtime
C?ID=280813
Try this one, it has HHC disabled
143B801209260803800E01E590190481340800
downtime
C?ID=280813
And here's another one to try.
143B801209260803280E01E590194481340800
langers2k
C?ID=224085
Wasn't able to find many other UK Seats to compare with.
I'd try 163B801209260003680E01E590190081350800
mohsin52
Hi guys,
So after a long search of a code, I eventually have managed to get the ABS module to take a code with no errors and full functionality.
For some reason all the codes provided on here kept giving me error 31.
Eventually after leaving it for a week and going back to it, I had a friend advise me I could use Abrites software which has a built in code calculator for all modules. I entered the VIN, part number of the abs module and other details of the car spec such as disc dia. and TPMS etc.
Then I copied and pasted the code into VCDS expecting it to not work with error 31 but magically it said "coding accepted!"
I think there may have been something wrong with my module instead of your codes. Thanks for all the help people, it is very appreciated.
downtime
C?ID=280813
Could you post the accepted code here so we could see how far off we were originally? :) Also it would help us to understand the ABS codings probably a little bit better once more.
Hi guys,
It would probably be useful to everyone here who tried to help you with this to know what code worked. ;)
mohsin52
The code which worked for me was 133B801209260003C80E01E59019002300C00
It has TPMS and XDS activated and is also for RIGHT HAND DRIVE.
Engine code is CDLD with front brakes at 345mm and rears 310mm.
Pump no. Is 1k0907379BE
Again thanks to everyone for all your help
