Tweaking Matrix light (speed / brightness activation) S3 8V MY18
mikek
Australia
C?ID=172031
Hello all
I wanted to try and tweak some of the settings for my matrix lights activation or find out if its even possible. I did seem to find some information on changing the high beam assist which referenced these adaptions in the A5 module (or 55 which I don't have)
Activation speed for high beam assistant
Speed threshold for high beam recommendation off
Night vehicle detection activation brightness 3 lx
Night vehicle detection deactivation brightness 20 lx
Main_Beam_Assist_Urban_Area_Detection On
Urban_Leaving_Velocity 255 km/h
However these adaptions are not in my A5 module. I can only assume this is because I have matrix lights and these settings are somewhere else... but I have no idea where they are, or if they even exist.
At the moment, the matrix auto high beams will ONLY turn on when its dark, has 1 or 2 streetlights visible and I am travelling approximate 60km/h or faster. It will disengage when you drop below 40km/h. I would much prefer it to come on with more light sources, and about half the speed.
I found some data to read in the A5 module - Loc IDE09436 (Recognized street illumination)... the matrix lights would only activate when this data was coming back as "no streetlight"... otherwise it was displaying "more than one streetlight" and they weren't turning on.
I understand that matrix lights aren't allowed in the USA so this might be a problem that you don't care about, but hopefully someone, somewhere can help me. Have attached an autoscan which is pretty much factory... I did a few things like enabling oil temp in MMI
Mike
Friday,01,September,2017,13:47:04:25065
VCDS Version: 17.8.0.1 (x64)
VIN: WAUZZZ8V0JA011297   License Plate:
Chassis Type  8V-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
          5F 6C A5 A9 BB BC
VIN: WAUZZZ8V0JA011297   Mileage: 55km-34miles
Address 01: Engine (J623-DJHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 J    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 0A2500322466010B3004
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM20TFS0208V0906259J 001005
   ROD: EV_ECM20TFS0208V0906259J_AU37.rod
   VCID: 479D9026FECC1D7E0B-8012
Readiness: 0000 0001
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0GC 300 012 A    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1402
   Revision: 00H06V07
   ASAM Dataset: EV_TCMDQ381061 001
   ROD: EV_TCMDQ381061_AU37.rod
   VCID: 21492EBE30A8034EA5-8074
   Part No SW: 8V0 614 517 C    HW: 8V0 614 517 C
   Component: ESC           H25 0621
   Revision: 00000000    Serial number: 61627000000111
   Coding: 329C938D549A13AA8B930B6D4198694CC92AC8D1D0829677184150B482A812
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
   ROD: EV_Brake1UDSContiMK100IPB_035_AU37.rod
   VCID: 3979E6DEB8387B8E8D-806C
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0444262001
   Coding: 030C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002020
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3C77FFCAB70A4EA696-8068
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0130
   Revision: 20002000    Serial number: 00000001267613
   Coding: 03100014110000011000000000001500
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
   VCID: 408F8B3ADBE22A46CA-8014
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 7BE1D1B800PAG0MUFU03
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001716701787
   ROD: EV_BCMBOSCH_018.rod
   VCID: 081F531AB352D206C2-805C
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 170429  043 0580
   Serial number:         170511081811
   Coding: 0A47F7
   Serial number: 62868242
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 17 03 2017  00000092
   Serial number: 000000000ZY171383D0B
   Serial number: 00000000000069907049
   Sun Roof:
   Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST001MS7ZL00000
   Coding: 901E00
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Serial number: 000308417617145
   Coding: 0370167851
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 50AFBB7A0B82DAC65A-8004
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: 3500E7C11DFFC42474988055000026
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
   VCID: 3B75FCD6B204499E9F-806E
   Part No SW: 8V0 907 376 G    HW: 8V0 907 376 F
   Component: DAEMPFUNGS-SG H11 0082
   Serial number:       310517029
   ASAM Dataset: EV_AudiMagneRide 002008
   ROD: EV_AudiMagneRide_002_AU37.rod
   VCID: 45819A2EC4C00F6EF9-8010
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Serial number: 003VWR33BXJX
   Coding: 98CCC000000000005C54000000C800000065
   VCID: 0919561EA858AB0EDD-805C
   Subsystem 1 - Part No SW: -----------    HW: 480 001 606 17
   Serial number: 357000000005BA34252E
   Subsystem 2 - Part No SW: -----------    HW: 480 001 606 17
   Serial number: 358000000003BA34252D
   Subsystem 3 - Part No SW: -----------    HW: 480 401 706 17
   Serial number: 3510001B526441E3272S
   Subsystem 4 - Part No SW: -----------    HW: 480 401 706 17
   Serial number: 3520001B526441E635D%
   Subsystem 5 - Part No SW: -----------    HW: 480 400 205 17
   Serial number: 3550002A924F3844614%
   Part No SW: 8V0 953 521 KF    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 15061704401573
   Coding: EC18
   Part No SW: 8V0 920 790 A    HW: 8V0 920 790 A
   Component: FBenRDW       H16 0066
   Coding: 248D08527F9800080181E8001000000000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001027
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 3A7BF9D2BD3E709684-806E
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   433 4303
   Revision: --------    Serial number: 0006397500
   Coding: 030100043F085A005B00827ABC0B00000001010000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 3365D4F69A5481DE47-8066
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20170606101547 21204
   Serial number: 758860000017061309B1
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7756
   Serial number: HA1-00028.04.17
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
   Revision: 00000000    Serial number: 17000156627007
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_004_VW37.rod
   VCID: 3467D7EA9F5A86E65E-8060
Address 3C: Lane Change (J769)       Labels:* None
   Part No SW: 3Q0 907 566 D    HW: 3Q0 907 566
   Component: MRR1Rear      H20 0410
   Revision: --------
   Coding: 44C002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
   Serial number: 310517EEV03416
   Coding: 005D1A205C01040000001003
   VCID: 43858436CAF4315ED7-8016
   Coding: 9307
   ROD: EV_SteerAssisMQB_013_VW37.rod
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAH5F00F4KW
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 244727AA2FBA1666CE-8070
   Serial number: 150417EDF28353
   Coding: 005D12205E01040000001003
   VCID: 428B8132D5EE3856DC-8016
   Part No SW: 8V1 035 041 B    HW: 8V1 035 041
   Component: MU-P-LND-RW   054 1106
   Serial number: A838D0HB004494
   Coding: 017353080000000011511102000A00312F0027E6017001045E
   VCID: 2E53C5827176AC3628-807A
   Subsystem 1 - Part No SW: V03 959 801 PT    HW: -----------
   Component: ROW 2017/2018  --- 0065
   Component: DU High  H49 0014
   Serial number: AUZ8Z9H1Y03G2P
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL124041700050287
   Component: Gracenote2  --- 4012
   Coding: 0273100102002001400040
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 07061712K23748
   Coding: 040307030000010101022346C14EA90088000E200080
   ROD: EV_MFKBoschMQBB_VW36.rod
   Part No SW: 8V0 907 159 A    HW: 4H0 907 159 A
   Serial number: 170513202305
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
   VCID: 3E73F5C2A1165CB6B8-806A
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 220517EEM07837
   Coding: 000C12204001040000001002
   ROD: EV_DCURearDriveMAXCONT_VW37.rod
   Serial number: 220517EEM0783A
   ROD: EV_DCURearPasseMAXCONT_VW37.rod
End-------------------------(Elapsed Time: 05:33)--------------------------
TBAx
C?ID=287144
You have a MQB_B_MFK, which does not have (some of) the mentioned adaption channels.
mikek
Australia
C?ID=172031
So are you saying nothing can be done on my car? Or could these settings be hidden elsewhere
