- Joined
- Aug 10, 2016
- Messages
- 3,768
- Reaction score
- 4,182
- Location
- Netherlands, eastern part
- VCDS Serial number
- C?ID=284912
Polo 6C
Model year G
4 doors
LHD
1.0 TSI 105hp
6 speed manual
Halogen headlights with separate DRL and cornering lights
Auto light switch
Climatronic
Seat heating
MFS
ACC
Discover Media
Front passenger airbag deactivation
Headlight washers
8K PDC with OPS
Model year G
4 doors
LHD
1.0 TSI 105hp
6 speed manual
Auto light switch
Climatronic
Seat heating
MFS
ACC
Discover Media
Headlight washers
8K PDC with OPS
Monday,11,September,2017,11:53:17:62066
VCDS Version: 17.8.0.1
VIN: WVWZZZ6RZGY149340 License Plate:
Mileage: 16588km-10307mi Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F
VIN: WVWZZZ6RZGY149340 Mileage: 16588km-10307miles
Address 01: Engine (J623-CHZC) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 026 Q HW: 04C 907 309 AE
Component: R3 1.0l TFS H25 2307
Revision: W1H25---
Coding: 01190032234411080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM10TFS01104C906026Q 001005
ROD: EV_ECM10TFS01104C906026AH_001.rod
VCID: 2F6715C376EF3E3E23-807A
CAN Converter 01:
Part No SW: 6C0 907 379 M HW: 6C0 907 379 B
Component: ESP9.0i H01 ESP9.0i H01 00040004
Serial number: 08507712150930
Coding: 21DD4885492733C90917106D0051841292CC90080005CBFB8F00
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: N/A
VCID: 39732B9BB8ABE08E8D-806C
Address 08: Auto HVAC (J255) Labels:| 6C0-907-044.clb
Part No SW: 6C0 907 044 B HW: 6C0 907 044 B
Component: Climatronic H02 0202
Serial number: 1510271A-0595
Coding: 200000001011000001
ASAM Dataset: EV_ACClimaValeoPQ26 003001
ROD: EV_ACClimaValeoPQ26_VW26.rod
VCID: 234FE9F32A278A5EB7-8076
590081 - Control Circuit for A/C Compressor
B10A9 11 [008] - Short to Ground
Reset counter: 25
Mileage: 16006 km
Date: 2017.08.16
Time: 15:39:47
Compressor shut-off requirement: Compressor activation: malfunction in activation path
Compressor current: actual value: 1.275 A
Compressor current: specified value: 0.000 A
Voltage terminal 30: 13.5 V
Outside air temperature: 30.5 ∞C
Engine speed: 2957.5 /min
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 D HW: 6C0 937 089
Component: BCM PQ26 Hi4R H08 0094
Serial number: 001588100939
Coding: 0000085042530AFB4F844000402F07C800005B0253010000000000000000
ASAM Dataset: EV_BCMA0 006002
ROD: EV_BCMA0_006_VW26.rod
VCID: 316313BB60DB28CE35-8064
Subsystem 1 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y15M11D09H00M17S31
Coding: 9038DD
Drivers Door Control Module:
Subsystem 2 - Part No SW: 6R0 959 801 DJ HW: 6R0 959 801 DJ Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 0610
Serial number: KU0KU021101552944560
Coding: 0400A1
Subsystem 3 - Part No SW: 6R0 959 802 DN HW: 6R0 959 802 DN Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 0610
Serial number: KU0KU021101552941086
Coding: 1400A1
Subsystem 5 - Part No SW: 6R0 959 811 AA HW: 6R0 959 811 AA
Component: J388__TSG_HL 003 0610
Serial number: KU0KU026101552998457
Coding: 0400A0
Subsystem 6 - Part No SW: 6R0 959 812 AA HW: 6R0 959 812 AA
Component: J389__TSG_HR 003 0610
Serial number: KU0KU024101552972809
Coding: 1400A0
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391530105686
Coding: 0031051001
ROD: EV_EPHVA18AU3700000_VW26.rod
VCID: 438F4973CA67AA5ED7-8016
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 25101503210127
Coding: 00000000FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
VCID: 3A713497BDADEB9684-806E
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 E HW: 6C0 959 655 E
Component: VW20Airbag00P 001 0360
Revision: -------- Serial number: 003RH007DCZS
Coding: 88C0C000000000005C0000CA000800000000
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 356B27AB94B304EE69-8060
Subsystem 1 - Part No SW: ----------- HW: 410 821 810 15
Component: SideSensor_Df 151 0800
Serial number: 3575H00322943B035294
Subsystem 2 - Part No SW: ----------- HW: 410 823 010 15
Component: SideSensor_Pf 151 0800
Serial number: 3585H00C31E801531101
Subsystem 3 - Part No SW: ----------- HW: 442 151 710 15
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A002A293D3B7B5FV
Subsystem 4 - Part No SW: ----------- HW: 442 151 710 15
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A009F1D72E5493CZ
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 6C0 920 740 C HW: 6C0 920 740 C
Component: KOMBI 201 1420
Coding: 072409002580000801886A011000000000000000
VCID: 2241ECF7353D8356BC-8076
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 089
Component: GW MQB A0 H08 0094
Revision: -------- Serial number: 001588100939
Coding: 030100046F0A560071000000000000010001010000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_VW26.rod
VCID: 2649F0E759157F76D0-8072
Subsystem 1 - Part No SW: 6C0 959 442 B HW: 6C0 959 442 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0023
Serial number: 2861500593300081AF2B
Coding: 2C0000
Subsystem 2 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 62304L23542821987904
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 AG HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3232
Serial number: PFBA0618
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW.rod
VCID: 6DDBCFCBBC638C2E51-8038
Part No SW: 3Q0 035 874 A HW: 3Q0 035 874 A
Component: MU-S-ND-ER H24 0245
Serial number: VWZAZ2R0447380
Coding: 02620001BE00000051111101008808001F0100C401200100CF
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 306516BF6BD121C63A-8064
Subsystem 1 - Part No SW: 6C0 919 603 A HW: 6C0 919 603 A
Component: ABTm_Std2_Nav H53 1031
Serial number: VWZ8Z9RKX00341
Subsystem 2 - Part No SW: 3G0 919 866 M HW: -----------
Component: ECE 2016 --- 0521
End-------------------------(Elapsed Time: 03:22)--------------------------
