- Aug 12, 2017
- 18
- 8
- Czech Republic
- C?ID=138706
Hi there,
I replaced my old one HEX-CAN cable by new HEX-V2. After that I tried set up connection to Peugeot 307 (2004) by VCDS 17.1.3 with error.
VCDS show error message like (sorry for poor translate, I use VCDS with Czech translation): Vehicle is not ISO/OBD2 compatible. But it's not true, because I connect older HEX-CAN cable and everything working well again. During almost 1 hour I tried substract new configuration for HEX-V2 cable: Settings > Bypass OBD2 Fastinit without success.
Is there any option how to set for HEX-V2 cable and OBD2 vehicle direct reading by Bypass instead connection to Address 30?
In other topic on this board I've seen post about "protection" ECU for scan - is it this case?
Thank you so much!
Thank you so much!
