I've got a 2007 VW Passat Wagon with a 2.5L 5-Cyl. installed in place of the original (failed) 2.0t FSI. I've posted here because the engine / intake system / ECU is completely stock 2.5L Jetta. If you'd rather I post this in retrofits ... I can do that.
I keep getting a P2279 engine code (Leak in Air Intake System) ... I can clear the code and the car is fine for about a week ... then the code reappears.
I've done an internet search, and I keep coming up with the common problem for these engines, failed PCV diaphragm ... but I've already replaced the PVC with a Dorman unit. I've visibly checked all the vacuum tubes and hoses ... the intake manifold gaskets are new ... I can see no visible tears or damage to the intake tube ... and the air filter element was recently replaced. The intake system is stock factory.
What's strange is, based upon the freeze frame data ... it always seems to happen when the engine is near idle speed (670 RPM) ... and the car is moving, but very slowly (16-22 kph / 10 - 15 MPH). Almost like it's happening when I just begin to accelerate from a dead stop.
I've read where a throttle body can cause this ... although I've gone through the adaption process (with VCDS) for the throttle body.
The car runs and idles fine ... starts fine, and gets great gas mileage. Any other ideas? Anyone else ever have this problem with the 2.5 engine where it was NOT the PVC diaphragm?
Here's the typical fault code I'm getting ...
Thursday,27,July,2017,15:11:09:23114
VCDS Version: 17.1.3.0 (x64) HEX-V2 CB: 0.4336.4
VIN: WVWBA71K78W315062 License Plate:
Chassis Type: 1K (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 6D 72
VIN: WVWBA71K78W315062 Mileage: 221730km-137776miles
Address 01: Engine (CBT) Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 BJ HW: 07K 906 032 Q
Component: 2,5l R5/4V G 1567
Revision: 1NH01--- Serial number: VWX7Z0H33N97Z2
Coding: 0000003
Shop #: WSC 01279 785 00200
VCID: 72BED2CB78AA85372BD-8026
008825 - Leak in Air Intake System
P2279 - 008 - - Intermittent - MIL ON
Fault Status: 10101000
Fault Frequency: 7
Mileage: 221667 km
Date: 2017.07.25
Time: 17:21:19
RPM: 670 /min
Load: 17.2 %
Speed: 16.0 km/h
Temperature: 74.0°C
Temperature: 43.0°C
Absolute Pres.: 970.0 mbar
Voltage: 13.843 V
Readiness: 0000 1100
Part No SW: 09G 927 750 LF HW: 09G 927 750 LF
Component: AQ 250 6F 1914
Revision: 00H90000 Serial number:
Coding: 0000840
VCID: 005A88034606A7A72D9-8054
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0021122
VCID: 73B0D7CF07B08C3F20B-8026
Part No: 1K0 820 047 EB
Component: Climatic PQ35 090 0505
VCID: 688AB0A34E767FE7859-803C
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000005468122
Coding: 008C0F0340041A00470A00000F00000000285D435C0000
Shop #: WSC 05311 123 12345
VCID: 372823DF5348201FDC3-8062
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 05311
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 0N AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3P2W7PWA
Coding: 0012366
Shop #: WSC 05311 000 08193
VCID: 2E0606BBAC12E1D78F5-807A
Subsystem 1 - Part No: 3C0 959 339 A
Component: BF-Gewichtsens. 006 0002
Subsystem 2 - Serial number: 00000000032EPS
Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME0E716159Eÿ†63
Subsystem 5 - Serial number: 16159Eÿ†6342MSME105B60746ÿ†63
Subsystem 6 - Serial number: B60746ÿ†6351HTS64IKQTM627ÿ†63
Subsystem 7 - Serial number: QTM627ÿ†6361HTS6TLLE15C3Uÿ†63
Subsystem 8 - Serial number: E15C3Uÿ†63727TS63IK2T6C39ÿ†63
Subsystem 9 - Serial number: 2T6C39ÿ†63827TS63IKEPNQ25ÿ
Subsystem 10 - Serial number: EPNQ25ÿ
Part No SW: 3C0 953 549 H HW: 3C0 953 549 H
Component: J0527 0015
Revision: 00005000 Serial number: 3C9953507R
Coding: 0102014
Shop #: WSC 05311 000 00000
VCID: 313C1DC7BD2CFE2F927-8064
Part No SW: 3C0 920 970 R HW: 3C0 920 970 R
Revision: V0033000 Serial number: 00000000000000
Coding: 0007205
Shop #: WSC 01119 067 57207
VCID: 333017CF4730CC3FE0B-8066
Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C0631304F6
Coding: 3BFC0C0CD22002
VCID: 211CED87EDCC4EAF027-8074
No Fault code Found
Part No SW: 3C0 919 965 A HW: 3C0 919 965 A
Component: Kompass 001 0002
Revision: 00001000 Serial number: 1339817TQ3XP02
Part No SW: 3C0 959 433 C HW: 3C0 959 433 C
Component: IMMO 041 0364
Revision: 00041000 Serial number: VWZCZ000000000
Shop #: WSC 64713 001 1048576
VCID: 2A0E0AAB90FA8DF753D-807E
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
No Fault code Found
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2801
Coding: 0001205
VCID: 36362EDB5442D917C75-8062
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 RDK 041 0213
Coding: 13900E88D1032E521804141FF00A0F0E082C00
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001204
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 A HW: 1K0 035 161 A
Component: Radio DE2 012 0015
Revision: 00012000 Serial number: VWZ4Z7F6117447
Coding: 0040400
VCID: 1D64D177D1B46A4F26F-8048
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 3C9 959 703 A
Component: Tuer-SG 021 2507
Coding: 0000144
Part No SW: 3C9 827 383 B HW: 3C9 827 383 C
Component: J605 HECKDECKEL 0405
Revision: 00H20001
Shop #: WSC 23250 384 715754
VCID: 303A18C3B626F7279D9-8064
Subsystem 1 - Part No: 3C9 827 384 B
Component: J756 HECKDECKEL 0405
Subsystem 2 - Serial number: 0600H20001001C0055ÿ
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 3C9 959 704 A
Coding: 0000144
VCID: 323E12CBB82AC537EBD-8066
End----------(Elapsed Time: 01:10, VBatt start/end: 13.9V/13.5V)-----------
