VCDS Mobile with Sharan 7N
sbrimmers
C?ID=308484
Hello I am new and tried the VCDS Mobile on my Sharan 7N.
I have the Problem that when I try to display the advanced measuring blocks, diffrent blocks are displayed as I ticked.
Exsample when I choose engine RPM, selector lever position is displayed.
Regards,
Stefan
#hndoc:?docid=00003218&xt=hnh:7375572EC997A3735D1535AD14556087ED26150874C992B4A6ED83D9FFD7BC87
VCDS Mobile 0.4401.0.4
VIN: WVWZZZ7NZFV000463
Scan: 01 03 08 09 10 15 16 17 18 19 22 25 42 44 46 4C 52 53 56 61
	 62 69 6C 6D 72 BE BF
BE-Sliding Door Left -- Status: OK 0000
BF-Sliding Door Right -- Status: OK 0000
Address 01: Engine  (CFFB J623)	Labels: 03-01.clb
	Part No SW: 03L 906 018 HK	HW: 03L 907 309 Q
	Component: R4 2.0l TDI   H28 9978
	Revision: 44H28---
	Coding: 0019001A043601080000
	Shop #: WSC 00240 216 00000
	ASAM Dataset: EV_ECM20TDI01103L906018HK 003013
	ROD: EV_ECM20TDI01103L906018HK.rod
	VCID: 7AB761EB46C9D1EFB3C740AA04-802F
No fault codes found.
Address 03: ABS Brakes	Labels: 7N0-614-109.clb
	Part No SW: 7N0 614 109 S	HW: 7N0614109S
	Component: J104   C3 450M VDE2  0040
	Revision: --H07---	Serial Number: 00000008126427
	Coding: 0018973
	Shop #: WSC 00020 790 00000
	VCID: 3D3DAAF71767BED7D665A3CE2D-8068
Address 08: Auto HVAC  (J255)	Labels: 5K0-907-044.clb
	Part No SW: 7N0 907 044 R	HW: 7N0 907 044 R
	Component: Clima-Sharan  H02 0404
	Revision: 00001K02
	Coding: 021000C449
	Shop #: WSC 00020 999 00000
	ROD: EV_ClimatronicSharan.rod
	VCID: 3FC1D0FF1D6B34C7C479B9E607-806A
Address 09: Cent. Elect.  (J519)	Labels: 1K0-937-08x-09.clb
	Part No SW: 5K0 937 084 K	HW: 5K0 937 084 K
	Component: BCM PQ35 B    122 0173
	Revision: BA122001
	Coding: 40590A3F8125F3C0508800C05400006443D11308426D2D226480872000C1
	VCID: 3A37A1EB064909EFF34780AAC4-806F
	Subsystem 1 - 	Part No SW: 7N1-955-119-A	Labels: 1Kx-955-119.clb
	Component: WWS    140401033 0044
	Coding: 004DBD
	Subsystem 2 - 	Part No SW: 5Q0-955-547	Labels: 5Q0-955-547.clb
	Component: RLFS         024 0042
	Coding: 0228BB
	Subsystem 3 - 	Part No SW: 7N0-951-171-A
	Component: DWA-Sensor 00002 0206
	Subsystem 4 - 	Part No SW: 1K0-951-605-C
	Component: LIN BACKUP HOH05 1501
03789 - Terminal 75 Limp Mode Active
Address 10: Park/Steer Assist  (J446)	Labels: 1Q0-919-475.clb
	Part No SW: 7N0 919 475 A	HW: 7N0 919 475
	Component: PARKHILFE 8K  H06 0012
	Revision: --------
	Coding: 318001
	ASAM Dataset: EV_EPHVA18VW4280000 001005
	ROD: EV_EPHVA18VW4280000.rod
	VCID: 3935BEE7034F1AF7FA3D77BED9-806C
Address 15: Airbags  (J234)	Labels: 5K0-959-655.clb
	Part No SW: 7N0 959 655 C	HW: 7N0 959 655 C
	Component: VW10Airbag00N H12 0014
	Coding: 00304E
	ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
	ROD: EV_AirbaVW10TS6VW428.rod
	Subsystem 1 - 	Part No SW: ----
	Component: S.Sens.Fahr.V--- ---
	Serial Number: 3493ETS607DFCCC199DR
	Subsystem 2 - 	Part No SW: ----
	Component: S.Sens.Beif.V--- ---
	Serial Number: 3503ETS60B2EBCD19DDF
	Subsystem 3 - 	Part No SW: ----
	Component: S.Sens.Fahr.H--- ---
	Serial Number: 3513ETS608DF5B519DDA
	Subsystem 4 - 	Part No SW: ----
	Component: S.Sens.Beif.H--- ---
	Serial Number: 3523ETS607A5CD119DD2
Address 16: Steering wheel  (J527)	Labels: 5K-16.lbl
	Part No SW: 5K0 953 501 CT	HW: 5K0 953 569 AL
	Revision: FF010042
	Coding: 5180240000
	VCID: 7EBF6DFB5AE1FDCF8FEF6CFA58-802B
Address 17: Instruments  (J285)	Labels: 5K0-920-xxx-17.clb
	Part No SW: 7N0 920 870 L	HW: 7N0 920 870 L
	Component: KOMBI         H03 0905
	Coding: 140F01
	ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
	VCID: 3B39A4EF097328E7E8518DD633-806E
Address 18: Aux. Heat	Labels: 1K0-815-071.clb
	Part No SW: 7N0 963 271 G
	Component: Zuheizer        051  3041
	Revision: 00051000	Serial Number: 09028242000000
	Coding: 0000041
	VCID: 3833BBE338459BFF05336AB2EA-806D
Address 19: CAN Gateway  (J533)	Labels: 7N-19.clb
	Part No SW: 7N0 907 530 AQ	HW: 7N0 907 530 AL
	Component: J533  Gateway H58 1653
	Revision:   H58
	Coding: 468002
	VCID: 7F4190FF5DEBECC784F979E647-802A
Address 22: AWD  (J492)	Labels: 0CQ-907-554.clb
	Part No SW: 0AY 907 554 F	HW: 0AY 907 554 F
	Component: Haldex4Motion H52 7521
	Coding: 0401
	ROD: EV_AllWheelContrHA1VW37X_VW36.rod
	VCID: 4EDFFD3BAAC1AD4F3F0F5CBAC8-801B
Address 25: Immobilizer  (J334)	Labels: 5K0-920-xxx-25.clb
	Part No SW: 5K0 953 234	HW: 5K0 953 234
	Component: IMMO          H03 0905
	ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
	VCID: EA97D1ABB669E16FC32710EAD4-80BF
Address 42: Door Elect, Driver  (J386)	Labels: 7N0-959-793.clb
	Part No SW: 7N0 959 793 F	HW: 7N0 959 793 F
	Component: TSG FA        H03 0553
	Revision:
	Coding: 01102E208000411011
	VCID: 45CDC2177FB776178EB5FB2EB5-8010
Address 44: Steering Assist	Labels: 5N1-909-144.clb
	Part No SW: 5N1 909 144 R	HW: 5N1909148J
	Component: J500__APA-BS KL.325  1401
	Revision: 1BH04739	Serial Number: 00141220089601
	Coding: 0000258
	VCID: 41C5D6076B9FDA37B28DCF1E61-8014
Address 46: Failed to respond
Address 52: Door Elect, Pass.  (J387)	Labels: 7N0-959-792.clb
	Part No SW: 7N0 959 792 F	HW: 7N0 959 792 F
	Component: TSG BF        H03 0553
	Revision:
	Coding: 01102C208000411011
	VCID: 44CBDF13748D4F1F99ABEE2246-8011
Address 53: Parking Brake	Labels: 3AA-907-801.clb
	Part No SW: 3AA 907 801 J	HW: 3AA907801J
	Component: J540 EPB4  VW-63206  0012
	Revision:   H19   	Serial Number: 00000000003355
	Coding: 0024167
Address 56: Radio  (J0503)	Labels: 5M0-035-1xx-56.clb
	Part No SW: 3C8 035 190 C	HW: 3C8 035 190 C
	Component: Radio RCD510  052 0213
	Revision: 00000001
	Coding: 0500040004000D
	VCID: 23097C8F91C36827C06185B6FB-8076
Address 61: Battery Regul.  (J840)	Labels: 1K0-907-534.clb
	Part No SW: 7N0 907 534	HW: 7N0 907 530 AL
	Component: Batt.regelung H58 1653
	Coding: 330F7859
	VCID: F1A5C6C79BBF0AB7826D5F5E71-80A4
	Subsystem 1 - 	Part No SW: 1K0-915-181-H
	Component: J367-BDM     H07 0180
Address 62: Door, Rear Left  (J388)	Labels: 7N0-959-794.clb
	Part No SW: 7N0 959 794 J	HW: 7N0 959 794 H
	Component: TSG HL        H01 0556
	Revision:
	Coding: 01006C200000411001
	VCID: 4AD7F12B56A9996F63E7306AF4-801F
Address 69: Trailer  (J345)	Labels: 7N0-907-383.clb
	Part No SW: 7N0 907 383	HW: 7N0 907 383
	Component: Anhaenger     H09 0120
	Revision: 3I001003
	Coding: 410C040001000000
	VCID: F3A9CCCFE1A338A7708175766B-80A6
Address 6C: Back-up Cam.	Labels: 5N0-907-441.clb
	Part No SW: 7N0 907 441	HW: 7N0907441
	Component: J772__Rearview       0020
	Revision: 00H13000	Serial Number: 525 PA8J441339
	Coding: 0030011
	VCID: EE9FDDBB8A81954F9F4F3C3A28-80BB
Address 6D: Trunk Elect.  (----)	Labels: 7N0-959-107.clb
	Part No SW: 7N0 959 107 E	HW: 7N0 959 107 A
	Component: HDSG-Modul    H11 0243
	Revision: 41011001
	Coding: 0733334003
	ASAM Dataset: EV_HDSGVW428 201138
	ROD: EV_HDSGVW428_VW36.rod
Address 72: Door, Rear Right  (J389)	Labels: 7N0-959-794.clb
	Component: TSG HR        H01 0556
	Revision:
Address BE: Sliding Door Left  (J558)	Labels: 7N0-959-244.clb
	Part No SW: 7N0 959 244 B	HW: 7N0 959 244 B
	Component: Schiebetuer_l 005 2414
	Shop #: WSC 00000 000
	ASAM Dataset: EV_AST A03704
	ROD: EV_AST.rod
	VCID: 3833BBE3384503FF05336AB2EA-806D
Address BF: Sliding Door Right  (J731)	Labels: 7N0-959-244.clb
	Component: Schiebetuer_r 005 2414
	ROD: EV_AST.rod
Could you post some screen-shots of this behavior please?
sbrimmers
C?ID=308484
Here are the Screenshots.
I cross checked the same result with I Phone.
Regards, Stefan
Shaun
Try in vcds-mobile [Options] -> [Clear Dataset Cache] and then check what it shows in measuring values.
sbrimmers
C?ID=308484
Hi Shaun,
I tried it but same result, it loaded the ASAM new but still selected and displayed values do not match.
I checked the ABS Group there the measuring values works fine.
I did some screenshots maybe it helps.
Regards,
Stefan
sbrimmers
C?ID=308484
Nobody an Idea? I especially procured the Hex Net Version to Log Data with my mobile.
Regards,
Stefan
Shaun
What happens if you try going through the "live data hud" function in mobile?
sbrimmers
C?ID=308484
The same Problem wir HUD
Detlef Trapp
World
C?ID=56993
Problem confirmed on a 2015 Alhambra, on several control modules, VCDS mobile on my HEX-NET with CB 4408 will just show random measuring values instead of the ones selected, also some ASAM data can not be loaded even though I am on 4G, and the Ross-Tech Cloud times out immediately, of course I can send specific infos if requested.
sbrimmers
C?ID=308484
Hello Detlef,
I tried today with CB 4407.
I had to clear the Cache to be able to load the ASAM.
But the same Problem as before.
Stefan
sbrimmers
C?ID=308484
Still the same with CB 4409.
Stefan
