Electric folding mirrors
paddyz1
C?ID=273783
Hi all.
We have just got a 2017 scirocco and it has electric folding mirrors. They only fold when you ask them to on the mirror adjustment switch.
My question is, can they be programmed to fold/unfold when you lock/unlock the car
I will post an autoscan when i get home from work later but so far haven't been able to find an option to do this (or if it is even possible)
downtime
C?ID=280813
On PQ35 cars no. But some control modules support comfort operation of mirrors. You can fold them by holding the lock button on the remote. After I think 2 - 3 seconds the mirrors should fold.
If they don't then your door control modules don't support them :(
TBAx
C?ID=287144
Depending on the modules generation you can either do it with VCDS or need to modify the EEPROM (not possible with VCDS) to enable mirror folding.
You can determine the version by checking the label file name for module 42 in the Autoscan:
MAX3 - will require EEPROM change
GEN4 - possible through adaption
For GEN4 it goes like this:
ECU 42 > Login: 04354 > Adaption > Channel "(9)-System_Parameter_0-System Parameter Byte8" > set value to "95" or "99"
90 = default value
95 = mirror folding via keyfob and automatic opening on ignition on
99 = mirror folding via keyfob and automatic opening on driver door open
paddyz1
C?ID=273783
Thanks. It is a Max 3 unfortunately. Full autoscan posted in reference scans
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.clb
Part No SW: 1Q0 959 701 H HW: 1Q0 959 701 H
Component: Tuer-SG 009 2162
Coding: 0152119
Shop #: WSC 00020 790 00000
VCID: 39795FCF70C46589EE-806C
TBAx
C?ID=287144
Well then the easiest way is to use VCP.
paddyz1
C?ID=273783
Unfortunately I have no idea what this means. Will have a google.
DGMotors
C?ID=57532
Try Vag Can Pro (VCP) in google as you will get better results.
PetrolDave
Westbury, UK
C?ID=1423
Why?........
Because with a Max 3 you need to modify the EEPROM:
welshkaiboy
H11-2H
90 = default value
Only on LHD, I have RHD details.
DGMotors
C?ID=57532
welshkaiboy
90 = default value
Would you mind posting them please as I want to do my Wife's Tiguan with Gen4 controllers,
I had a quick play and noticed that 42 seemed to be the passenger door? as it had no measuring blocks for mirrors switches etc, but never seems to get it working.
welshkaiboy
H11-2H
OK, so this took a lot of time and effort to find out and thanks goes to my mate n4s on the Tiguan forum who I worked with to get the right settings.
Goto module 42, unlock by going to security tab (VCDS will tell you the code).
Goto adaptation
find
(2)-System_Parameter_14-System Parameter Byte1, change E0 to E5 - open with ignition
or
(2)-System_Parameter_14-System Parameter Byte1,change E0 to E9 - open with door
Save
Make sure convenience is set in the MFD.
Dana
Western PA, USA
paddyz1's car had the older Gen 3 window modules with PQ35 BCM so everything suggested previously applies. This is his car: http://forums.ross-tech.com/showthread.php?11211-2017-Scirocco-2-0tdi-150
DGMotors, please post the Auto-Scan in addition to Adaptation function maps from 42 and 52 from your wife's Tiggy. My 2012 SEL (WVGBV7AX1CW000438 has the older Gen modules like the Scirocco so that isn't possible on my Tiggy.
Edit, I didn't see welshkaiboy's reply when I posted but the maps/scan from the car with UDS / Gen 4 modules couldn't hurt.
welshkaiboy
H11-2H
What I have posted is for GEN4 RHD, confirmed on my MK1 Tig and other GEN4 VAG Marques.
paddyz1
C?ID=273783
It is a bit of a bummer that as the car is using old stuff. It is a 2017 reg but I will have to see what year it was manufactured.
DGMotors
C?ID=57532
Here the scan as asked for:
Was from earlier this year when I tried the LHD adaption change. Will get the adaption channel map this weekend.
Thursday,23,February,2017,10:06:34:63837
VCDS Version: 17.1.3.0
Data version: 20170220 DS267.3
Dealer/Shop Name: DG Motor Services
VIN: WVGZZZ5NZDW027923   License Plate:
Chassis Type: 5N (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 25 2B 2E 37 42 44 46 47
          4C 4F 52 53 56 61 62 6C 72 77
VIN: WVGZZZ5NZDW02****   Mileage: 55870km-34716miles
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 FQ    HW: 03L 907 309 AE
   Component: R4 2.0l TDI   H28 9979
   Revision: 41H28---    Serial number: 00000000000000
   Coding: 00250032042701080000
   Shop #: WSC 00188 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018FQ 003015
   ROD: EV_ECM20TDI01103L906018FQ.rod
   VCID: FEF9BBA3610EA8B11B-80AA
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0BH 300 011 S    HW: 0BH 927 711 C
   Component: DSG DQ500-7A  H07 1806
   Revision: 00H07V01
   ROD: EV_TCMDQ500021_VW41.rod
   VCID: B2615F93E5D6BCD1AF-80E6
Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
   Part No SW: 5N0 614 109 AR    HW: 5N0 614 109 AR
   Component: J104   C6 450M VD4C 0006
   Revision: --H07---    Serial number: 00000006118023
   Coding: 0056641
   VCID: FBFFB2B7BA1CBD993C-80AE
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Revision: 00085000    Serial number: 0183924823
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_VW01.rod
   VCID: B46D598B1FC2B2E1BD-80E0
   Part No SW: 5K0 907 044 GK    HW: 5K0 907 044 GK
   Component: Climatronic   H19 1313
   Revision: 00001004
   Coding: 0010004003
   VCID: FAF1B7B37D26849127-80AE
   Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
   Component: BCM PQ35 M    021 0068
   Revision: BC021001
   Coding: 48180A3B8825F1C0408800C0340081644B79AA88476D85F06480C700A041
   VCID: BE797BA3298E68B15B-80EA
   Subsystem 1 - Part No SW: 5N2 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 25081  013 0204
   Serial number: N2955119   °204!
   Coding: 009795
   Component: RLS 200712 05  54  0403
   Coding: 02304D
Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
   Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56261224101131
   Coding: 349303
   ASAM Dataset: EV_EPHVA2C000000000 002008
   ROD: EV_EPHVA2C000000000_VW41.rod
   VCID: C48D094B4F6202610D-8090
   Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
   Component: J234__20E VW10 HI   2118
   Revision: 24017000    Serial number: 003L7PHCSWU3
   Coding: 0012357
   VCID: FCFDB1ABBF12BAA135-80A8
   Subsystem 1 - Serial number: 6332MTS638632302
   Subsystem 2 - Serial number: 6342MTS610392302
   Subsystem 3 - Serial number: 6351HTS642S3BBKJ
   Subsystem 4 - Serial number: 6361HTS6RU45BBKJ
   Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20120523200094
   Coding: 100A140000
   ROD: EV_SMLSNGVOLWSXS.rod
   VCID: FDFBBCAF6C08B3A902-80A8
   Component: E221__MFL-TAS  H31 0033
   Coding: 820000
   Part No SW: 5N0 920 983 A    HW: 5N0 920 983 A
   Component: KOMBI         H05 0505
   Coding: 411F01
   VCID: B36F5A971ACCB5D9A4-80E6
   Part No SW: 7N0 907 530 T    HW: 7N0 907 530 K
   Component: J533  Gateway H40 1632
   Revision:   H40       Serial number: 070812F1002001
   Coding: 356003
   VCID: C183005F5870174926-8094
   Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
   Component: Haldex 4Motion      0043
   Coding: 0000005
   VCID: CD9B2C6F5428C329D2-8098
   Component: IMMO          H05 0505
   Coding: 000007
   VCID: EAD187F30D863411D7-80BE
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 12000183135005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: AF6756E7F6E49139C0-80FA
   Component: SG EXT.PLAYER H18 0546
   Revision: A1001003    Serial number: 7663274057
   Coding: 010100
   VCID: AA5147F3C506F41117-80FE
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 H    HW: 1T0 035 680 H
   Component: RNS-MID       H70 4120
   Revision: AB001001    Serial number: VWZ6Z7M4240056
   Coding: 0405000201000080000C
   VCID: B36F5A9712CCB5D9A4-80E6
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V8  7690
   Part No SW: 5N0 959 701 G    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0504
   Revision: 12110009    Serial number: 0005372186
   Coding: 0212BE
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: B97368BF38A04F896E-80EC
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1504
   Serial number: 00000007100178
   Coding: 000090
   Part No: 5N0 909 144 P
   Component: EPS_ZFLS Kl. 203    3305
   Revision: 00H22000
   Shop #: WSC 01324 785 00200
   VCID: BE797BA3E98E68B15B-80EA
   Part No SW: 5K0 035 456 C    HW: 5K0 035 456 C
   Component: KonzernAmp 8K H07 0202
   Revision: --------    Serial number: EAA086A0019951
   VCID: AA5147F3CD06F41117-80FE
   Part No SW: 7N0 907 532     HW: 7N0 907 530 K
   Component: EZE_2         H40 1632
   Coding: 050B0500
   VCID: EFE796E73E64D13980-80BA
   Component: J245EE20SKB13  H03 0220
   Component: J394EE20SKB13  H03 0220
   Part No SW: 5N0 959 702 G    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0504
   Revision: 14110009    Serial number: 0005373986
   Coding: 0213BE
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: BA7177B33DA6449167-80EE
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1504
   Serial number: 00000007107751
   Coding: 000090
   Revision:   H19       Serial number: 00000000383425
   Coding: 0026167
   VCID: B6696383C1BEA0F183-80E2
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 7N0 907 530 K
   Component: Batt.regelung H40 1632
   Coding: 030F1859
   VCID: F1E3909F2850C7C996-80A4
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900016996
   Part No SW: 5N0 907 441 A    HW: 5N0 907 441 A
   Revision: 00H11000    Serial number: 525PA8-J274293
   Coding: 0020010
   VCID: AD5B4CEF34E8E329F2-80F8
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
   Revision: 1B001001    Serial number: 00007663266664
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
End-------------------------(Elapsed Time: 04:02)--------------------------
DGMotors
C?ID=57532
Cheers welshkaiboy
Will give this a try at the weekend.
DGMotors
C?ID=57532
I changed it to E9 and works fine.
The only real issue I have is that with Kessy (Keyless) you have to press the remote button for 2 seconds to get them to fold. Would be nice to have them fold with touching the door handle but think this cant be done.
42 Adaption map - .CSV file
52 Adaption map - .CSV file
