Guys got myself a 2015 vw polo that has had a few faults but managing to clear them eventually with the help of the great people on this forum...
I have a new one now and was wondering if anyone can help?
Sunday,23,July,2017,22:39:18:48600
VCDS Version: 17.1.3.0
Dealer/Shop Name: VCDS
Workshop Code: 444 03743 000001
VIN: WVWZZZ6RZFU042052 License Plate: SP15 MDO
Mileage: 104331km-64828mi Repair Order:
Chassis Type: 6R (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZFU042052 Mileage: 104331km-64828miles
Address 01: Engine (J623-CHYA) Labels: 04C-906-020-CHY.clb
Part No SW: 04C 906 057 HW: 04C 907 309 J
Component: R3 1.0l MPI H23 8071
Revision: 31H23000
Coding: 01110052020401080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM10MPI01104C906057 001012
ROD: EV_ECM10MPI_VW26.rod
VCID: 62C0BA9975F269519F-8036
10088 - Neutral Gear Sensor
P15A1 00 [032] - Implausible Signal
Mileage: 104297 km
Date: 2017.07.23
Time: 14:24:39
Engine speed: 3317.50 /min
Normed load value: 98.0 %
Vehicle speed: 99 km/h
Coolant temperature: 88 °C
Intake air temperature: 40 °C
Voltage terminal 30: 14.442 V
Neutral position sensor: current transmission angle: 11.10 °
Neutral position sensor: adapted transmission angle: -2.35 °
Adaptation status for transmission neutral position sensor-Bit 0: 60
Transmission neutral position sensor voltage: 3200 mV
Neutral position sensor: upper adaptation value: 3260 mV
Neutral position sensor: lower adaptation value: 1360 mV
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 HW: 6R0 907 379 BA
Component: ESP9.0i H03 0002
Serial number: 08510702140901
Coding: 23DD2485492733C20914106E0053C42492CC90080005C7090C00
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100015
VCID: 6CDCD4A187362F2125-8038
Address 08: Auto HVAC (J301) Labels: 6C0-820-045.clb
Part No SW: 6C0 820 045 A HW: 6C0 820 045 A
Component: AC Manuell H02 0105
Serial number: 1408251B-0159
Coding: 200000001000100000
ROD: EV_ACManueKMMValeoPQ26_VW26.rod
VCID: 1D3AC9650C0C16A9E2-8048
Address 09: Cent. Elect. (J519) Labels: 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 A HW: 6C0 937 089
Component: BCM PQ26 Hi4R H06 0047
Serial number: 009458005500
Coding: 03000840425300530BA44080B10703880000580257010000000000000000
ASAM Dataset: EV_BCMA0 004003
ROD: EV_BCMA0_004_VW26.rod
VCID: 2E581EA971AA9D314B-807A
Drivers Door Control Module:
Subsystem 1 - Part No SW: 6R0 959 802 AT HW: 6R0 959 801 BB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU025091442685434
Coding: 1400A0
Subsystem 2 - Part No SW: 6R0 959 801 BB HW: 6R0 959 802 AT Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU006101442793131
Coding: 0400A0
Subsystem 3 - Part No SW: 6C0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY141900AM3
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000060144761
Subsystem 5 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N
Component: J389__TSG_HR 003 8610
Serial number: KU0KU015101442885103
Coding: 1400A0
Subsystem 6 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
Component: J388__TSG_HL 003 8610
Serial number: KU0KU019091442622788
Coding: 0400A0
Address 15: Airbags (J234) Labels: 6C0-959-655.clb
Part No SW: 6C0 959 655 A HW: 6C0 959 655 A
Component: VW20Airbag011 001 0330
Revision: -------- Serial number: 003LM004JBD7
Coding: 88C0C000000000005C000000008800000000
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 316205D5609482C956-8064
Subsystem 1 - Part No SW: ----------- HW: 410 820 808 14
Component: SideSensor_Df 151 0800
Serial number: 3575H009915C41F2101B
Subsystem 2 - Part No SW: ----------- HW: 410 820 808 14
Component: SideSensor_Pf 151 0800
Serial number: 3585H00B716376A1930G
Subsystem 3 - Part No SW: ----------- HW: 442 151 508 14
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00A116C1CE473EP
Subsystem 4 - Part No SW: ----------- HW: 442 151 508 14
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A009B16C1CE5E2D+
Part No SW: 6C0 920 940 A HW: 6C0 920 940 A
Component: KOMBI 211 0290
Coding: 232509002180260001083A001000000000000000
Shop #: WSC 03743 444 00001
VCID: 2240FA9935722951DF-8076
Address 19: CAN Gateway (J533) Labels: 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 089
Component: GW MQB A0 H06 0047
Revision: -------- Serial number: 009458005500
Coding: 030100046F0A640071000000000000010001000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 001001
ROD: EV_GatewA0Lear_VW26.rod
VCID: 65CAA18564DC1E697A-8030
Subsystem 1 - Part No SW: 6C0 959 442 HW: 6C0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H04 0019
Serial number: 2321415585601470AB1B
Coding: 240000
Subsystem 2 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 61247F40302821697543
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 M HW: 6C2 909 144 D
Component: EPS_TRW_ALow 322 3211
Serial number: CE8M0038
Coding: 0007
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_011.rod
VCID: 336E0FDD9A88B0D924-8066
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 820 HW: 3Q0 035 820
Component: MU-S-D-ER H11 0133
Serial number: VWZAZ2P4561909
Coding: 02620000BE00000011111201000808001F0100C60120010000
ASAM Dataset: EV_MUStd4CTSAT 001018
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 66C8A68999DA157173-8032
Subsystem 1 - Part No SW: 6C0 919 603 HW: 6C0 919 603
Component: ABTm_Std2 H41 1015
Serial number: VWZ8Z9PH000VF3
Any help would be great
cheers
scott
End-------------------------(Elapsed Time: 02:52)--------------------------
