Retrofitting bi-xenon Amarok 2013
Rikardhalen
Sweden
C?ID=36446 (NRRT)
Hi
I have installed Oem xenon in my Rok after some instructions I have found from Eballs28 on this forum.
This is how I want the lights to operate:
Led Drl have to be on at the same time as the rear parking lights (Swedish rules)
When it's getting dark outside the Led Drl should be dimming when the headlight comes on.
My -13 have all options available at the time inc Nav Rns510
And my BCM module have the number 7H0 937 090.
With no coding done everything worked as before with the halogen lights except for the Led Drl.
I have been installing new wires from the BCM T73b/5 and 6 to each headlight connector 10.
Now to the coding I will need some help with that as the coding instructions from Eballs28 doesn't seem to work for my car.
This is what worked for Eballs28
Central electric module 9
Byte11, bit0 needs to be a 1
Byte12, bit0 needs to be a 1
Byte22, bit4 needs to be a 1
Byte18, needs to have a hex value of 67
One problem for me is that I cant see all the "byte" checkboxes In my vcds
When I did the complete Eballs28 coding nothing worked and the xenon was strobing/flashing.
But when I did Byte22 coding alone and nothing else the Led Drl started working
But it's no parking light in the rear.
If I go to byte12 and do bit 0 to 1 the Led Drl comes off and the rear parking lights starts working instead.
When I cover the light sensor the LED Drl comes off and the Xenon headlight starts working instead . When the Led is suppose to be dimming.
My Pc crashed today and after a reinstall of windows I can't get explorer to access the internet so I had to take a picture of the coding with my phone and post this from my iPad I hope that's ok
Coding pic.
http://forumbilder.se/G8VVP/img-3971
http://forumbilder.se/G8VVP/img-3972
marcello032
New Member
Ecuador
Hi
I bought the bi-xenon DRLs for my Amarok'16 2HBB3A TDI 2.0.
I went to my local dealer to install them but we are having some issues.
First of all I follow all the instructions I could find about the installation, this means I connected the t73b pin 5 to the left light and the t73b pin 6 to the right light, both on pin 10.
n 5 Mass
n 10 BCM
n 6 Low
n 8 high
n 9 Turn
n 4 Position
Also the configuration on my Comfort Module 09 is:
Byte 11 bit 0 to 1 to activate high beam shutter
Byte 18 changed to 67 or 65 if using LED number plate lights
Byte 22 bit 4 to 1 to enable LED module for DRL and Parking Lights.
Doing this, when the motor is running the led DRL's start flashing as strobe lights, the DRL doesn't work (daylight), and when I turn on the middle lights the LED DRL DIMs which it should do but still flashes all the time. I also have the light bulb fault on my dashboard.
Could you please help me, do you have any guide, wiring diagram and instructions including codification, on what I should do in order for this to work properly?, what can I do to fix this.
marcello032
New Member
Ecuador
Hi iichel, sorry for the late response, I had an accident earlier this year and still haven't been able to fit the bi-xenon headlights on my AMAROK, once the car is ready I will continue with the retrofit as nothing has changed so far.
Thanks in advance for your help.
Aronclb
New Member
Romania
Tuesday,29,May,2018,12:17:03:11999
VCDS Version: 18.2.1.2
VIN: WV1ZZZ2HZB8062680   License Plate: XXX
Mileage: 173470km-107789mi   Repair Order: 1234
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 32
VIN: WV1ZZZ2HZB8062680   Mileage: 173470km-107789miles
32-Differential Locks -- Status: Malfunction 0010
Address 01: Engine (J623-CDCA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 FC    HW: 03L 907 309 K
   Component: R4 2.0l BTD   H40 9978
   Revision: 26H40---    Serial number: 00000000000000
   Coding: 01194012232600080000
   Shop #: WSC 28315 001 1048576
   ASAM Dataset: EV_ECM20BTD01103L906019FC 004006
   ROD: EV_ECM20BTD01103L906019FC_004.rod
   VCID: 71E9EE97A087C5CCD8-8024
8 Faults Found:
4332 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [036] - -
                    Fault Frequency: 10
                    Time: 00:00:00
                    Coolant temperature: 18 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 11.800 V
                    ACC target acceleration: 0.000 m/s²
                    ACC control module received status-Bits 0-7: 6
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_READY
4481 - Cruise Control Switch (E45)
          P0568 00 [044] - Implausible Signal
                    Time: 00:00:00
                    Coolant temperature: 26 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 13.200 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 129
                    Cruise Control System (CCS): status-Bits 0-7: 232
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Engine control module reset status-Bits 0-7: 2
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4482 - Function Restriction due to Implausible Message(s)
          U1112 00 [044] - -
                    Fault Frequency: 15
                    Time: 00:00:00
                    Cruise Control System (CCS): switch position-Bits 0-7: 193
4483 - Function Restriction due to Faults in Other Modules
          U1113 00 [044] - -
                    Time: 00:00:00
                    Coolant temperature: 22 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 14.240 V
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [036] - -
                    Time: 00:00:00
                    Coolant temperature: 21 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 12.600 V
                    Cruise Control System (CCS): status-Bits 0-7: 200
                    selected gear-Bits 0-7: 0
4717 - Body Control Module (Central Electric)
          U0140 00 [036] - No Communications
                    Time: 00:00:00
4719 - No Communication with Diagnostic Gateway
          U0146 00 [036] - -
                    Time: 00:00:00
                    Cruise Control System (CCS): status-Bits 0-7: 201
4629 - ECM Power Relay Load Circuit
          P068A 00 [040] - Opens Too Early
                    Time: 00:00:00
                    Coolant temperature: -40 °C
                    Intake air temperature: -40 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 0.000 V
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 0
                    Engine status: COENG_STANDBY
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
Readiness: 1010 0000
Address 03: ABS Brakes (-----)       Labels:. 2H0-907-37x-ESP.clb
   Part No SW: 2H0 907 379 G    HW: 2H0 907 379 D
   Component: ESP MK25A XT  H44 0106
   Revision: 00H44001
   Coding: C07324B69A9A039724A859AB6F5010
   Shop #: WSC 07456 790 49164
   VCID: 346727839715B0E4F3-8060
            000 -  -  - Intermittent
                    Reset counter: 0
                    Count: 32768
                    Count: 4097
                    Count: 8280
                    Count: 514
03095 - Diagnostic interface for databus (J533) implausible messa.:
                    Reset counter: 0
                    Count: 32768
                    Count: 4097
                    Count: 8257
                    Count: 514
                    Reset counter: 0
                    Count: 32832
                    Count: 4097
                    Count: 8233
                    Count: 514
Address 08: Auto HVAC
   Part No SW: 7H0 937 090 D    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H78 0725
   Revision: B9078001    Serial number: 9000 219150127
   Coding: 350006380C211000003008312ECB96DD0F80664E60003040300000030003
   VCID: 2F6D28EF7E33933C8E-807A
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3321
   Coding: 100000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3321
   Coding: 100000
   Subsystem 3 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 4 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3321
   Coding: 100000
   Subsystem 5 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3321
   Coding: 100000
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 0
   Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
   Component: VW10Airbag00B H06 0013
   Revision: --------    Serial number: 003HN002N3WH
   Coding: 000000000000000000000000000000003042
   Shop #: WSC 07446 790 50316
   VCID: 3365249F9A1BB7DCEA-8066
   Serial number: 3495RRB40590BTBE4GV5
   Serial number: 3505RRB40590BTBE7OT6
   Serial number: 3555YRB405F060GK4GPT
   Serial number: 3565YRB405H060GKP98T
                    Time: 00:00:00
12666368 - Databus
                    Reset counter: 40
   Part No SW: 2H0 920 863 A    HW: 2H0 920 863 A
   Component: KOMBI         H05 0304
   Coding: 150A00
   Shop #: WSC 07456 790 50316
   VCID: 275DC0CF5EC3CB7C46-8072
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 0
13635840 - Supply voltage
                    Reset counter: 40
                    Time: 00:00:00
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H78 0725
   Revision: B9078001
   Coding: 742200
   VCID: 70EFEB93A38DCCC4D7-8024
                    Fault Frequency: 21
                    Reset counter: 40
                    Reset counter: 0
   Component: IMMO          H05 0304
   VCID: 6ADBF9FB8D51361499-803E
Address 32: Differential Locks (J647)       Labels:* 2H0-927-771.clb
   Part No SW: 2H0 927 771     HW: 2H0 927 771
   Component: Quersperre    H04 0014
   Revision: 11001001    Serial number: 4DG 18.11.10 00
   Coding: 000001
   ASAM Dataset: EV_QuersUDSAAMVN817 A01005
   ROD: EV_QuersUDSAAMVN817.rod
   VCID: 6BD5FCFF82AB2F1CE2-803E
12666368 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 40
                    Time: 00:00:00
                    Voltage terminal 30: 12.4 V
                    Voltage at sensor: 1.1 V
                    Actuator: coil current: 0.0 A
End-------------------------(Elapsed Time: 03:54)--------------------------
Aronclb
New Member
Romania
I have the auto scan on my car
i have the daylight running but when it goes to turn on the lights the drl stops working
Aronclb
New Member
Romania
@iichel if you can help me, i am in the service with the car
PetrolDave
Westbury, UK
C?ID=1423
Do you mean the DRLs turn off when the other lights turn on?
If you do then that is normal behaviour - because when it's dark enough for the other lights to be on then there is no need for the DRLs to be on (as it's no longer Daylight!).
Aronclb
New Member
Romania
Normaly the drl lowers the intensity when the ligjts are on, for me stops at all.
iichel
Netherlands, eastern part
C?ID=284912
Are you sure your BCM supports bi-xenon?
Are you mounting bi-xenon with LED DRL or with a halogen bulb?
PetrolDave
Westbury, UK
C?ID=1423
Is that what happened on your car before?
On many cars the DRLs turn off, not dim - both behaviours are allowed and manufacturers can choose which to implement.
