Updating broke my ability to read a non-standard measuring block
Not sure why it would do that.
Can you post some screen-shots that show the problem?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Please post both an Auto-Scan from VCDS and VCDS-Mobile, might be related to the label file used...
Shaun
As a side note, if you just enter 133 in the search field and click submit, it will pull up that whole group whether it shows in the list or not. You don't need the check boxes for this to work. However, it would still be good to see an autoscan for this so we can look into the labels.
--Shaun
mjc
C?ID=277805
Here's what the search looks like https://imgur.com/gallery/6KfTx
I'm working on getting the auto scan results. For the record I'm the person who posted that ethanol sensor guide so it used to work that way for me.
mjc
C?ID=277805
scan from computer
Here's the log from the computer
Wednesday,19,July,2017,12:58:10:31670
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
VCDS Version 17.6.0.2  HEX-NET CB: 0.4401.4
Data version: 20170602 DS274
VIN: WVWPF7AJ5DW069413   License Plate: JQD367
Mileage: 135530km-84214mi   Repair Order:
Chassis Type: AJ (7N0)
Scan: 01 03 05 08 09 15 16 17 19 22 25 2B 2E 37 42 44 46 47 52 55
          56 62 72
VIN: WVWPF7AJ5DW069413   Mileage: 135530km-84214miles
Address 01: Engine (CRZ)       Labels:. 06F-907-115-CDL.clb
   Part No SW: 5K0 907 115 M    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSIŠ 02 2109
   Revision: 5BH21---    Serial number:
   Coding: 0403010A180F0160
   VCID: 3424D9AC5740D9E715-8061
012555 - Low Pressure Fuel regulation
               P310B - 004 - Fuel Pressure Outside Specification - Intermittent - MIL ON
                    Fault Status: 10100100
                    Fault Frequency: 244
                    Mileage: 132736 km
                    Date: 2017.07.04
                    Time: 16:42:46
                    RPM: 835 /min
                    Load: 8.2 %
                    Speed: 17.0 km/h
                    Temperature: 85.0°C
                    Temperature: 56.0°C
                    Absolute Pres.: 840.0 mbar
                    Voltage: 13.589 V
   Revision: 00H31001
   Coding: 144BE00C49288003280F07E5921C0141B70000
   VCID: 7DB23C88E48AD8AFAA-8029
   Revision: 00085000    Serial number: 0182310123
   Coding: 030010
   ROD: EV_KESSYPQ35G.rod
   VCID: 3424D9AC9F40D9E715-8061
   Part No SW: 5K0 907 044 GP    HW: 5K0 907 044 GP
   Component: Climatronic   H19 1212
   Revision: 00001004
   Coding: 0010002002
   VCID: 7F4EC680E686CABFB8-802B
   Part No SW: 1K0 937 084 J    HW: 1K0 937 084 J
   Component: BCM PQ35  B   111 0709
   Revision: AB111709
   Coding: 67180ABF9C232AC4108800C171000CC44FF52086775D8DB0E48460248040
   VCID: 3522E4A89C3AC0EF22-8061
   Component: Wischer 12071  26  0512
   Coding: 009F95
                    Fault Status: 00101010
                    Reset counter: 143
                    Mileage: 134599 km
                    Date: 2017.07.15
                    Time: 02:21:48
                    Voltage: 14.00 V
                        Term 50 Off
00061 - Footwell Lights
                    Reset counter: 147
                    Mileage: 135315 km
                    Date: 2017.07.17
                    Time: 12:22:36
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R00CW0D
   Coding: 00004733
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C34F18CB71011A7DD-8069
   Serial number: ---0000R--00004QJR00
   Serial number: 3572MSME6A62156EZZZ0
   Serial number: 3582MSME0C05646FZZZ%
   Serial number: 3512QSME7C111C03ZZZS
   Serial number: 3522QSME603B1C03ZZZS
   Serial number: 35527SME631B3A2EZZZQ
   Serial number: 35627SME492D3B2EZZZZ
   Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20120717200507
   Coding: 1002140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DB23C88EC8AD8AFAA-8029
   Component: E221__MFL-TAS  H31 0033
   Coding: 820000
   Part No SW: 5K6 920 973 E    HW: 5K6 920 973 E
   Coding: 270F01
   VCID: 393AE898B822248FC6-806D
   Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
   Component: J533  Gateway H42 1632
   Revision:   H42       Serial number: 140712F1001635
   Coding: 350002
   VCID: 3FCE8680AE060ABFF8-806B
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      T303
   Coding: 0000005
   Shop #: WSC 00001 000 00000
   VCID: 45C294680CDA506FB2-8011
   Coding: 000007
   VCID: 6A9807D48D045F177F-803F
Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 12000166955003
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2F2ED6C07666FA3F68-807B
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7663121426
   Coding: 020100
   VCID: 2A18C7D445849F17BF-807F
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H53 0319
   Serial number: VWZAZ2M4258269
   Coding: 04050041010005000000100A
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 250234E8249AB06F92-8071
1048646 - Rear View Camera
          B1102 31 [008] - No Signal
                    Reset counter: 147
                    Mileage: 130627 km
                    Date: 2017.06.09
                    Time: 19:11:08
          B11CF 53 [009] - Deactivated
                    Reset counter: 53
                    Mileage: 130627 km
                    Date: 2017.06.09
                    Time: 18:00:42
   Coding: 0001268
   VCID: 312AD0B8A852ECCF7E-8065
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 251    3305
   Revision: 00H22000
   VCID: 373EEEA0463632FF30-8063
   Part No SW: 5K0 035 456 B    HW: 5K0 035 456 B
   Component: KonzernAmp 8K 0368
   Revision: --------    Serial number: EAA085A0036095
   VCID: 291A38D84882940FB6-807D
   Coding: 0001268
   VCID: 3228DFB4AD54D7D707-8067
00121 - Outside Warning Light/Door exit Light Passenger Side
   Coding: 1479708
   Coding: 00000022
   Coding: 00000022
   Coding: 0001232
   Shop #: WSC 01357 011 1012551
   VCID: 3522E4A85C3AC0EF22-8061
00122 - Outside Warning Light/Door exit Light; Rear Left
   Coding: 0001232
   VCID: 3620E3A4413CCBF72B-8063
00123 - Outside Warning Light/Door exit Light; Rear Right
End----------(Elapsed Time: 01:11, VBatt start/end: 13.4V/13.4V)-----------
mjc
C?ID=277805
Log from VCDS-Mobile:
Wed,Jul,19,2017,12:31:49
VCDS Mobile 0.4336.0.4
	 56 62 72
Address 01: Engine	Labels: 06F-907-115-CDL.clb
	Part No SW: 5K0 907 115 M	HW: 8P0907115B
	Revision: 5BH21---	Serial Number:
	VCID: 342B8FD303047FEA970B3E6357-8061
Address 03: ABS Brakes  (J104)	Labels: 1K-03.clb
	Revision: 00H31001
	VCID: 7DBD6AF770CEFEA228E563CFAC-8028
No fault codes found.
Address 05: Acc/Start Auth.  (J518)	Labels: 5K0-959-434.clb
	Revision: 00085000
	Coding: 030010
	VCID: 342B8FD30304E7EA970B3E6357-8061
Address 08: Auto HVAC  (J255)	Labels: 5K0-907-044.clb
	Revision: 00001004
	Coding: 0010002002
	ROD: EV_Climatronic_VW36.rod
	VCID: 7F4190FF7AC2F4B23AF979E786-802A
Address 09: Failed to respond
Address 15: Airbags  (J234)	Labels: 5K0-959-655.clb
	Coding: 00004733
	VCID: 3C3BA7F32B542FAA5F5B96C3FF-8069
	Subsystem 1 - 	Part No SW: 5K0-959-339-B
	Component: BF-Gewichtss.006 0001
	Serial Number: ---0000R--00004QJR00
	Subsystem 2 - 	Part No SW: 5K0-959-354
	Component: S.Sens.Fahr.VH02 ----
	Serial Number: 3572MSME6A62156EZZZ0
	Subsystem 3 - 	Part No SW: 5K0-959-354
	Component: S.Sens.Beif.VH02 ----
	Serial Number: 3582MSME0C05646FZZZ
	Subsystem 4 - 	Component: S.Sens.Fahr.H--- ----
	Serial Number: 3512QSME7C111C03ZZZS
	Subsystem 5 - 	Component: S.Sens.Beif.H--- ----
	Serial Number: 3522QSME603B1C03ZZZS
	Subsystem 6 - 	Component: F.Sens.Fahr  --- ----
	Serial Number: 35527SME631B3A2EZZZQ
	Subsystem 7 - 	Component: F.Sens.Beif  --- ----
	Serial Number: 35627SME492D3B2EZZZZ
Address 16: Steering wheel  (J527)	Labels: 5K-16.lbl
	Revision: FF010041
	Coding: 1002140000
	ROD: EV_SMLSNGVOLWSXS.rod
	VCID: 7DBD6AF770CEE6A228E563CFAC-8028
Address 17: Instruments  (J285)	Labels: 5K0-920-xxx-17.clb
	Coding: 270F01
	ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
	VCID: 3935BEE724661A82443D77BF18-806C
Address 19: CAN Gateway  (J533)	Labels: 7N-19.clb
	Revision:   H42
	Coding: 350002
	VCID: 3FC1D0FF3A422CB27A79B9E7C6-806A
	Part No SW: 0BR 907 554 C	HW: 0BR907554C
	Coding: 0000005
	VCID: 45CDC217589EF66230B5FB2F74-8010
Address 25: Immobilizer  (J334)	Labels: 5K0-920-xxx-25.clb
	Coding: 000007
	ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
	VCID: EA97D1AB9140E11A7D2710EB15-80BF
Address 2B: Steer. Col. Lock  (J764)	Labels: 5K0-905-861.clb
	Revision: 00000000
	VCID: 2F2180BFEA22C432EAD9092796-807A
Address 2E: Media Player 3  (J650)	Labels: 5N0-035-342.lbl
	Revision: A1001003
	Coding: 020100
	VCID: 2A1791ABD1C0B91A3DA7D0EBD5-807F
Address 37: Navigation  (J794)	Labels: 1K0-035-27x-37.clb
	VCID: 250D6297B8DE8E6210759BAF14-8070
1048646 - Heater Element for Fuel Warming
	B1767 12 [008] - Short to Plus
1048669 - Control Module for Roof Shade
	B13C7 F4 [009] - Supply Voltage too High
Address 42: Door Elect, Driver	Labels: 1K0-959-701-MIN3.lbl
	Part No SW: 5K0 959 701 B	HW: 5K0959701B
	Coding: 0001268
	VCID: 312586C7FC164AC2FCED1F5F70-8064
Address 44: Steering Assist	Labels: 1Kx-909-14x-44.clb
	Part No SW: 1K0 909 144 P
	Revision: 00H22000
	VCID: 3731B8DF127294F2B22961873E-8062
Address 46: Failed to respond
	Component: KonzernAmp 8K H07 0368
	Revision: --------
	Shop #: WSC 00000 000
	VCID: 29156EA7D4C6AA02349DC7FFE8-807C
Address 52: Door Elect, Pass.	Labels: 1K0-959-702-MIN3.lbl
	Part No SW: 5K0 959 702 B	HW: 5K0959702B
	Coding: 0001268
	VCID: 322789CBF91071DA85F7284B7D-8067
Address 55: Xenon Range	Labels: 5M-55.clb
	Part No SW: 5M0 907 357 C	HW: 7L6941329B
	Revision: 00H04000	Serial Number:
	Coding: 1479708
	Subsystem 1 - 	Part No SW: 7L6-941-329-B	Labels: 3D0-941-329.clb
	Coding: 0000022
	Subsystem 2 - 	Part No SW: 7L6-941-329-B	Labels: 3D0-941-329.clb
	Coding: 0000022
Address 62: Door, Rear Left	Labels: 1K0-959-703-GEN3.lbl
	Part No SW: 5K0 959 703 D	HW: 5K0959703D
	Coding: 0001232
	VCID: 352DB2D7087E66E2A0154B6F44-8060
Address 72: Door, Rear Right	Labels: 1K0-959-704-GEN3.lbl
	Part No SW: 5K0 959 704 D	HW: 5K0959704D
	Coding: 0001232
	VCID: 362FB5DB15786DFAA91F549B31-8063
Shaun
Now click submit. It should bring up that group, even if it doesn't have checkboxes shown in the list.
mjc
C?ID=277805
Didn't work on previous version, does now. It used to be in the list though, just without a label
