My name's Tony and I live in Switzerland;
I'm building this car for track purpose and I have buy the HEX-NET interface to help me for this job.
I plan to :
- Disable DCC suspensions
- Disable some airbags and seatbelts
- Set the ESP if the button not fully disable it
- Disable some speakers etc..
My questions are :
- DCC :
- Can I do something to not buy the KW's 350€ resistor kit ?
- Does I need to set others things like headlights after lowering the car ?
- Other ?
Airbags + Seatbelts :
- I plan to put resistors in the plugs BUT can I do something with VCDS i.e. disable an airbag without disassembling it ?
ESP :
- In my last car ( AUDI TT-RS 8J ) when I pushed the button and ESP shows " full deactivated " in reality it wasn't. At high speed ESP was still working. I've found the solution by selecting a byte in a module for the rear spoiler after hours and hours of research ( it's not a joke ).
- Do you have a solution for this car ?
I plan to :
My questions are :
- DCC :
- Other ?
ESP :
Friday,07,July,2017,14:31:04:20634
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 17.1.3.0 HEX-NET CB: 0.4341.4
VIN: VSSZZZ5FZGR110897 License Plate:
Mileage: 1313km-815mi Repair Order:
Chassis Type: 5F (5Q0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 32 42 44 52 55 5F A9
VIN: VSSZZZ5FZGR110897 Mileage: 1313km-815miles
Address 01: Engine (J623-CJXH) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 F HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0B1D00122424010B0000
Shop #: WSC 00049 770 00123
ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
ROD: EV_ECM20TFS0205G0906259F_SE37.rod
VCID: B12A48BAE07940C9D6-80E4
Part No SW: 0D9 300 020 K HW: 02E 927 770 AQ
Component: DQ250-6V MQB H53 4903
Revision: 06253104 Serial number: TFK01512100645
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 9D72840A8CE1D4A962-80C8
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 60126000000671
Coding: 18EE6B925421296C007F060941CA6818D62A9400608216F6004100F1C006
Shop #: WSC 00049 770 00106
ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
VCID: CBD63A5262950A19CC-809E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5F0 907 044 Q HW: 5F0 907 044 Q
Component: Climatronic H05 1202
Revision: 00001K09
Coding: 04000004200100011005000000101000
ASAM Dataset: EV_ACClimaBHBVW37X 005137
ROD: EV_ACClimaBHBVW37X_005_VW37.rod
VCID: B42441AE1F6B75E1BD-80E0
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061601501486
Coding: 08001A46C20102F34B644000401C07281000000000000000000000000000
Shop #: WSC 00049 770 00130
ROD: EV_BCMBOSCH_016_AU37.rod
VCID: 895AC05A286958093E-80DC
Subsystem 1 - Part No SW: 5F1 955 119 A HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 151219 041 0574
Serial number: 160114233642
Coding: 0BC5FD
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S3Y16M01D15H16M51S34
Coding: 00095D
558100 - Databus
Reset counter: 17
Mileage: 1156 km
Date: 2017.07.04
Time: 10:55:25
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39291535703234
Coding: 0000040011
ASAM Dataset: EV_EPHVA14AU3700000 002024
ROD: EV_EPHVA14AU3700000_AU37.rod
VCID: BC34698E373BBDA175-80E8
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0120
Serial number: 19121541350082
ROD: EV_DRCONTITEMIC.rod
VCID: B73E76A20E1D9EF998-80E2
Part No SW: 3Q0 959 655 AS HW: 3Q0 959 655 AS
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SQPRSJA3/
Coding: 98CCC000000000005C0000CC000800000065
ROD: N/A
VCID: 8F6EEE42560D7639E0-80DA
Subsystem 1 - Part No SW: ----------- HW: 454 001 101 16
Serial number: 3576U00000065DACF81Z
Subsystem 2 - Part No SW: ----------- HW: 454 001 301 16
Serial number: 3586U000000B6429581C
Subsystem 3 - Part No: -----------
Component: SideSensor_Dr 0148
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
9447187 - Seat Occupied Sensor; Passenger's Side
B1027 13 [137] - Open Circuit
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 GP HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 06011608490280
Coding: 1410
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_SK48.rod
VCID: 8A58FF562D6F531137-80DE
Part No SW: 5F0 920 863 F HW: 5F0 920 863 F
Component: KOMBI 203 6420
Coding: 07AD09083980000800082A001000000000000000
ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
VCID: AD1254CAFC412429F2-80F8
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 18011610802375
Coding: 030100F42F085900EB0002E99C0F00010001050000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: F9BAB09A788948892E-80AC
Subsystem 2 - Part No SW: 5F0 959 537 A HW: 5F0 959 537 A
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000B0450201015
Coding: 012000
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185704001601062169
Address 32: Differential Locks (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 E HW: 0CQ 907 554 E
Component: Quersperre H52 8042
Serial number: HA1-00009.11.15
Coding: 0101
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
VCID: C7DE06627EFDEE79E8-8092
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0031
Serial number: 0000180845164
Coding: 00100320DC00040100001000
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8103
ROD: EV_SteerAssisMQB_VW31.rod
VCID: B93A709A380988896E-80EC
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0031
Serial number: 0000181338540
Coding: 00100320DE00040100001000
VCID: C6C00B6679F7F77113-8092
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 0492030009000000
ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
VCID: F5A2BCAA54912CE94A-80A0
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 5QA 035 824 HW: 5QA 035 824
Component: MU-S--ER H24 0245
Serial number: SEZAZ2S3729801
Coding: 04731000D70A00001111000100080A002F0302840120010002
ASAM Dataset: EV_MUStd6C1TSAT 001015
ROD: EV_MUStd6C1TSAT_SE26.rod
VCID: FDB2A48A6CA174A902-80A8
Subsystem 1 - Part No SW: 5F0 919 604 E HW: 5F0 919 604 E
Component: ABTm_Std2 H44 1031
Serial number: SEZ8Z9RLN0009U
0512 - Rear Right Bass Speaker
B1067 13 [009] - Open Circuit
Reset counter: 17
Mileage: 1156 km
Date: 2017.07.04
Time: 10:47:27
Voltage terminal 30: 12.3 V
0527 - Rear Left Bass Speaker
B1065 13 [009] - Open Circuit
Reset counter: 17
Mileage: 1156 km
Date: 2017.07.04
Time: 10:47:27
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5F0 907 159 C HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 151201201837
ROD: EV_SoundActuaGen2AU64X_VW26.rod
End----------(Elapsed Time: 02:20, VBatt start/end: 12.1V/12.0V)-----------
