04 Phaeton ABS coding concern
Rob A
C?ID=48058
I work at a garage, our customer has an 04 Phaeton with intermittent brake system warnings. I cannot duplicate the concern by driving car or wiggling harnesses and the fault codes lead me to suspect the ABS module is faulty. I have not installed a new ABS module yet. When I look at Coding-07 the pop up window has a note saying coding is accepted after a specific login has been carried out. I do not see a menu under advanced functions for login. There is a menu for security access, perhaps this is what I would use, but I don't know what the security code would be.
So my questions are: Does a new module need coding? Can I code the new module with Ross-Tech? If I need a login, is it in the security code menu and what is the security code?
Thank you in advance, Rob
Monday,19,June,2017,09:10:28:06280
VCDS Version: 17.1.3.0 (x64)
Dealer/Shop Name: Mellow Motors, Inc.
VIN: WVWAF63D248011416   License Plate: 7NAJ364
Mileage: 299480km-186088mi   Repair Order: 115791
Chassis Type: 3D (3D - VW Phaeton (2002 > 2006))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 2E
          34 36 37 38 39 46 47 55 56 57 65 66 68 69 71 75 76 77
VIN: WVWAF63D248011416   Mileage: 299480km-186088miles
Address 01: Engine        Labels: 4D0-907-560-BGH.lbl
   Part No SW: 4D0 907 560 CS    HW: 8E0 907 560
   Component: 4.2L V8/5V      G   0040
   Coding: 0007873
   Shop #: WSC 01065 000 00000
   VCID: 79F9EBAC33C1DA89AE-5140
18057 - Powertrain Data Bus
            P1649 - 008 - Missing Message from ABS Controller - Intermittent
16885 - Vehicle Speed Sensor
            P0501 - 004 - Implausible Signal - Intermittent
   Part No SW: 09L 927 760 C    HW: GS1 9.0 4.1 *
   Component: AG6 09L 4,2L V8     1003
   Coding: 0001102
   VCID: 377D2D9445550CF918-5140
18259 - Powertrain Data Bus
            P1851 - 000 - Missing Message from ABS Controller - Intermittent
                    RPM: 704 /min
                    RPM: 672 /min
                    (no units): 30.0
                    (no units): 27.0
                    Temperature: 37.0°C
                    T.B. Angle: 0.0°
                    Voltage: 12.88 V
Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
   Part No: 3D0 614 517 AK
   Component: ESP 5.7 allrad  H33 0047
   Coding: 0008376
   VCID: 6BD5C1E4499D78192C-5122
00003 - Control Module
            014 - Defective
   Part No SW: 3D0 909 135 K    HW: 5WK 470 25
   Component:    Kessy            6400
   Coding: 0006376
   VCID: 2D510FFCB709B62972-5140
01316 - ABS Control Module
01176 - Key
Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
   Part No: 3D0 959 759 B
   Component: Sitzmemory D1 BF    1520
   Coding: 0000003
   VCID: 3561279C5F59FEE90A-5140
Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
   Part No: 3D0 035 008 M
   Component:    ZAB COCKPIT      0188
   Coding: 0400305
   VCID: 2447EAD8E4C37761AD-5140
00384 - Optical Databus
Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
   Part No: 3D0 907 040 G
   Component: Climatronic D1      1145
   VCID: 224BECC0FED77951DF-5140
            014 - Defective
00057 - Right B-pillar/Footwell Shut-Off Flap Motor (V211)
            014 - Defective
Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
   Part No: 3D0 937 049 G
   Component: STG.Bordnetz        5001
   VCID: 2E5308F0BA0FCD314B-5140
            000 -  -
Address 15: Airbags        Labels: 3D0-909-601.lbl
   Part No: 3D0 909 601 E
   Component: 0G Airbag 8.4E+ H10 0934
   Coding: 0012359
   VCID: 2541F7DCEFF98E69BA-5140
Address 16: Steering wheel        Labels: 3D0-953-549.lbl
   Part No: 3D0 953 549 D
   Component: Lenksäulenmodul     3401
   Coding: 0000032
Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
   Part No: 3D0 920 981 H
   Component: KOMBIINSTRUMENT RB4 0411
   Coding: 0007221
   VCID: 2C5702F88C13BF2165-5140
   Part No: 6N0 909 901
   Component: Gateway K<>CAN      0101
   Coding: 0000006
   VCID: 70EFD68860BB9BC119-5140
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  X012
   Coding: 0000001
   VCID: 66C3B0D0527F457173-5140
Address 34: Level Control        Labels: 3D0-907-553-V1.clb
   Part No: 3D0 907 553 B
   Component: LUFTFDR.-CDC- 3C1V0 1101
   Coding: 0017700
   VCID: 2643F0D092FF8571B3-5122
Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
   Part No: 3D0 959 760 B
   Component: Sitzmemory D1 F     1520
   Coding: 0000004
Address 37: Navigation        Labels: 3D0-919-887.lbl
   Part No: 3D0 919 887 A
   Component:    NAVIGATION       0147
   Coding: 0400000
   VCID: 326B1C80AE37E9D12F-5140
00625 - Vehicle Speed Signal
Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
   Part No: 3D0 907 135 B
   Component: Dachmodul           0605
   Coding: 0000047
00220 - Connection to Sunroof
Address 39: Right Light        Labels: 3D0-909-158.lbl
   Part No: 3D0 909 158
   Component: EVG GDL+AutoLWR(r)  X012
   Coding: 0000001
   VCID: 67DDBDD455755C7948-5140
01344 - HID (Xenon) Headlight
Address 46: Central Conv.        Labels: 3D0-959-933.lbl
   Part No: 3D0 959 933 F
   Component: 12 HSG              0101
   Coding: 0000034
   VCID: 33651984512DE0D924-4B1A
   Subsystem 1 - Part No: 3D1 959 701 D
   Subsystem 2 - Part No: 3D1 959 702 D
   Subsystem 3 - Part No: 3D0 959 703 D
   Subsystem 4 - Part No: 3D0 959 704 D
   Subsystem 5 - Part No: 7L0 907 719
   Component:    Neigungssensor   0020
00927 - Terminal 30 (Right)
01516 - Terminal 30; Left
00926 - Terminal 30
00316 - Bulbs for Rear Illumination
            009 - Open or Short to Ground
Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
   Part No: 3D0 035 465
   Component: 08K-AUDIOVERST      0111
   VCID: 5EB398308A2F1DB1BB-5140
Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V1.clb
   Part No: 3D1 955 119
   Component: Front Wiper         2005
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 C
   Component: Batteriemanagement  2700
   VCID: 2345E9C4E1CD7059D4-5140
Address 75: Telematics        Labels: 3D0-035-617.lbl
   Part No SW: 3D0 035 617     HW: 3D0 035 617
   Component: Telematik NAR1      0101
   Coding: 0061850
   Shop #: WSC 01035 444 60028
   VCID: 5DB19F3C872906A9A2-5140
End-------------------------(Elapsed Time: 08:04)--------------------------
Control Module Part Number: 3D0 614 517 AK
  Component and/or Version: ESP 5.7 allrad  H33 0047
           Software Coding: 0008376
            Work Shop Code: WSC 01065 000 00000
            014 - Defective
Address 03,3D0 614 517 AK,recoded (Short coding),from,0008376,to,0008376,(01065/000/00000),
Rob A
C?ID=48058
The customer decided not to fix the car, so I never found out about coding the ABS module.
Jef
HQ
Oh wow, no bites on the original post... well, I guess this is better way later than never...and for the next guy working with a Pheaton.....
014 - Defective
99% of the time, that is in fact a failed control module, ABS in this case. If the car comes back, I would verify the powers/grounds can carry load, voltage drop type issues can cause this to happen in some cases... if the electrical paths are to factory design, replace the module.
If the module is replaced, has to be coded and such, VCDS can do this, here is the wiki page with the information:
http://wiki.ross-tech.com/wiki/index.php/VW_Phaeton_(3D)_Brake_Electronics
BTW, where there any dead bodies in the trunk?
