Installed an OEM trailer hitch and control module. I followed the steps but was unable to complete 13 since no coding table was available. I'm currently getting an error on address 13. I'm not sure what the updated code should be in order to get back braking guard and ACC.
Thanks,
matt
Thanks,
matt
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 17.1.3(x64) Data version: 20170320 DS267.7
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Wednesday,14,June,2017,19:50:15:13648
VIN: WA1VMAFE2DD008287 License Plate:
Mileage: 87220km-54195mi Repair Order:
Chassis Type: FE (4F0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3C 42 46 47 4C 4F
52 55 56 5F 62 69 6C 6D 6F 72
VIN: WA1VMAFE2DD008287 Mileage: 87220km-54195miles
Self-Diagnosis Log
Page 2
Address 01: Engine (J623-CNRB) Labels: 059-907-401-V2.clb
Part No SW: 4L2 910 401 A HW: 4L0 907 401 E
Component: 3.0TDI EDC17 H21 0004
Revision: 54H21--- Serial number:
Coding: 2A2A4012257600050000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114L2910401A 001005
ROD: EV_ECM30TDI0114L2910401A.rod
VCID: 22082F4D35FAA151DF-8076
Readiness: 0 0 0 1 1 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb
Part No SW: 0C8 927 750 AQ HW: 0C8 927 750 AQ
Component: AL1000 AISIN 001 2222
Coding: 001378
Shop #: WSC 29122 001 1048576
ASAM Dataset: EV_TCMAL991031 002114
ROD: EV_TCMAL991031_002.rod
VCID: 7BB63229F2D03099BC-802E
No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0623713
VCID: 3424D915570E3FE13D-8060
Self-Diagnosis Log
Page 3
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0200
Revision: 00H08000 Serial number: 10603702023215
Coding: 0000135
VCID: 25023451ECD45669BA-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H04 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
Component: KLIMA 4 ZONEN H15 0070
Revision: 00---031 Serial number: 00000030261392
Coding: 0304A036
VCID: 250234512CD45669BA-8070
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0040050511
Coding: 070000
Self-Diagnosis Log
Page 4
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Coding: 0139123
VCID: 6E900B7D79A255310B-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55961230400253
Coding: 28011E
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 3424D9159F0E3FE13D-8060
Self-Diagnosis Log
Page 5
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4L0 910 561 A HW: 4L0 907 561
Component: ABSTANDSREGELUNGH07 0160
Revision: -------- Serial number: 00000000000000
Coding: 0031118
VCID: 271E3E5996D8447988-8072
Reset counter: 183
Mileage: 87224 km
Date: 2017.06.14
Time: 19:45:14
Temperature: 46.0°C
Voltage: 12.03 V
Bin. Bits: 01000
Hex Value: 0x0411
Hex Value: 0x0006
Speed: -3.6 km/h
Lateral Accel.: 0.00 m/s^2
Self-Diagnosis Log
Page 6
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH43 0230
Revision: 07H43000 Serial number: 0038QD0A9F75
Coding: 0014131
VCID: 2B16C2698A3060196C-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME2F22196EQ
Subsystem 3 - Serial number: 6342QSME3022434C6
Subsystem 4 - Serial number: 6352QSME251A30468
Subsystem 5 - Serial number: 6362QSME302230761
Subsystem 6 - Serial number: 63734SME6D19316C9
Subsystem 7 - Serial number: 63834SME6C221F76A
No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 B HW: 4F0 953 549 F
Component: J0527 0830
Revision: 00H08000 Serial number: 90026121560193
Coding: 0012252
VCID: 281C3D659BC64B0181-807C
Component: E0221 H03 0040
No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 G HW: 4L0 920 985 G
Component: KOMBIINSTR. H35 0316
Revision: 00000000 Serial number: NGF50YNAD
Coding: 8BD664040D00CF05020205
VCID: 383CED258B66DB8111-806C
Self-Diagnosis Log
Page 7
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB700037 Serial number: 3700M12A060050
Coding: 00C303
VCID: 3FCE8639AE48ECB9D0-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000002790490620
Self-Diagnosis Log
Page 8
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---011 Serial number: 00000000351732
Coding: 0000006
VCID: 689C7D655B468B0141-803C
00003 - Control Module
Fault Status: 00100011
Mileage: 41990 km
Date: 2015.12.28
Time: 15:47:48
Fault Status: 00101101
Reset counter: 223
Mileage: 46207 km
Date: 2016.02.05
Time: 19:36:45
------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00000041891140
Coding: 00581B00000011110000
VCID: 3228DF0D6D1A31D12F-8066
Self-Diagnosis Log
Page 9
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH02 0050
Revision: 00H02000 Serial number: 6PZ 009 014-10
Coding: 0000001
VCID: 2E10CB7DB92215314B-807A
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H02 0050
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F12.10.1200H02000AMS15367ÿ
Subsystem 4 - Serial number: S15367ÿ
No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000043618742
Coding: 011F57205E40440004
VCID: 48DC9DE5FB86AB0161-801C
No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 01863593750000
Coding: 3569949
VCID: 383CED254B66DB8111-806C
Self-Diagnosis Log
Page 10
Part No SW: 4L0 035 466 A HW: 4L0 035 466 A
Component: BO Q7 H30 0110
Revision: 07S00000 Serial number: 01907120007145
Coding: 0D000001
VCID: 291A386140CC72099E-807C
Subsystem 1 - Part No SW: 4L0 910 465 A HW: 4L0 035 465
Component: BO Q7 SLAVE H41 0780
Serial number: 01109120020323
No fault code found. ------------------------------------------------------------------------------- Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005190058721
Coding: 0758477
VCID: 23062A49E2E0A859D4-8076
No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000126225
Coding: 0012001
VCID: 5EF05BBD8902C5B1BB-800A
Self-Diagnosis Log
Page 11
Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000043373390
VCID: 47DE9ED9F698A47968-8012
02126 - Central Locking Button; Exterior Door Handle
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 183
Mileage: 87224 km
Date: 2017.06.14
Time: 19:42:57
------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Coding: 0000031
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 E HW: 4G0 035 082
Component: Radio U SIRIU H60 0121
Revision: AB001007 Serial number: 156JB0C7659908
Coding: 020007010000000000
VCID: 22082F4D3DFAA151DF-8076
Self-Diagnosis Log
Page 12
Part No SW: 4L2 035 746 C HW: 4L2 035 746 A
Component: H-BNT-NA H44 0624
Revision: -------- Serial number: 224J.0C7509316
Coding: 180200060004EBEF710003456F632003140000000100000000
VCID: 2E10CB7D792215314B-807A
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130JV0C2573228
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002045006
Component: CD-Database 4949
No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000043516216
Coding: 010E57204040230004
VCID: 46C093DDF192BD7193-8012
No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels: 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H12 0100
Revision: 2A001001 Serial number: 00000375155939
Coding: 0200000000000000
Shop #: WSC 12345 123 12345
VCID: 312AD001681C0AC956-8064
Self-Diagnosis Log
Page 13
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0059308
Coding: 020C010001000100000102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6E900B7DB1A255310B-803A
No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H57 0500
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C9401754FBEA72125-8038
Subsystem 2 - Serial number: ) ó * *** *** *** *
Subsystem 3 - Serial number: RD26.10.12--H57001002E0258ÿ
Subsystem 4 - Serial number: 2E0258ÿ
No fault code found. ------------------------------------------------------------------------------- Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 130086127-----
Coding: 0003595
VCID: 2600335D91D25D71B3-8072
Component: J_245_EE16_SKB10H12 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H12 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H12 0220
Self-Diagnosis Log
Page 14
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000043516131
End----------(Elapsed Time: 02:03, VBatt start/end: 12.2V/12.2V)-----------
