Audi Q7 Trailer Hitch Retrofit
matt.severson
C?ID=270238
Installed an OEM trailer hitch and control module. I followed the steps but was unable to complete 13 since no coding table was available. I'm currently getting an error on address 13. I'm not sure what the updated code should be in order to get back braking guard and ACC.
Thanks,
matt
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 17.1.3(x64) Data version: 20170320 DS267.7
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Wednesday,14,June,2017,19:50:15:13648
VIN: WA1VMAFE2DD008287 License Plate:
Mileage: 87220km-54195mi Repair Order:
Chassis Type: FE (4F0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3C 42 46 47 4C 4F
 52 55 56 5F 62 69 6C 6D 6F 72
VIN: WA1VMAFE2DD008287 Mileage: 87220km-54195miles
Self-Diagnosis Log
Page 2
Address 01: Engine (J623-CNRB) Labels: 059-907-401-V2.clb
 Part No SW: 4L2 910 401 A HW: 4L0 907 401 E
 Component: 3.0TDI EDC17 H21 0004
 Revision: 54H21--- Serial number:
 Coding: 2A2A4012257600050000
 Shop #: WSC 31414 790 00001
 ASAM Dataset: EV_ECM30TDI0114L2910401A 001005
 ROD: EV_ECM30TDI0114L2910401A.rod
 VCID: 22082F4D35FAA151DF-8076
Readiness: 0 0 0 1 1 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb
 Part No SW: 0C8 927 750 AQ HW: 0C8 927 750 AQ
 Component: AL1000 AISIN 001 2222
 Coding: 001378
 Shop #: WSC 29122 001 1048576
 ASAM Dataset: EV_TCMAL991031 002114
 ROD: EV_TCMAL991031_002.rod
 VCID: 7BB63229F2D03099BC-802E
No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4L0-910-517-V2.clb
 Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
 Component: ESP ALLRAD MK25E1 0020
 Revision: 00H02001
 Coding: 0623713
 VCID: 3424D915570E3FE13D-8060
Self-Diagnosis Log
Page 3
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
 Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
 Component: FBSAUDIC6 ELV H08 0200
 Revision: 00H08000 Serial number: 10603702023215
 Coding: 0000135
 VCID: 25023451ECD45669BA-8070
 Component: FBSAUDIC6 EZS H04 0020
 Component: FBSAUDIC6 KSG H03 0020
No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: None
 Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
 Revision: 00---031 Serial number: 00000030261392
 Coding: 0304A036
 VCID: 250234512CD45669BA-8070
 Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
 Component: SLR-B8 H06 0007
 Serial number: 0040050511
 Coding: 070000
Self-Diagnosis Log
Page 4
 Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
 Component: ILM Fahrer H31 0400
 Coding: 0139123
 VCID: 6E900B7D79A255310B-803A
 Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
 Component: Wischer AU716 H18 0110
 Coding: 00064792
 Shop #: WSC 31414
 Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
 Coding: 00150059
 Shop #: WSC 31414
No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 4L0-919-475-7X2.clb
 Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
 Component: PARKHILFE 8K H07 0011
 Revision: 11001001 Serial number: 55961230400253
 Coding: 28011E
 ASAM Dataset: EV_EPHVA18AU7160000 001001
 ROD: EV_EPHVA18AU7160000.rod
 VCID: 3424D9159F0E3FE13D-8060
Self-Diagnosis Log
Page 5
Address 13: Auto Dist. Reg Labels: None
 Part No SW: 4L0 910 561 A HW: 4L0 907 561
 Component: ABSTANDSREGELUNGH07 0160
 Revision: -------- Serial number: 00000000000000
 Coding: 0031118
 VCID: 271E3E5996D8447988-8072
 Reset counter: 183
 Mileage: 87224 km
 Date: 2017.06.14
 Time: 19:45:14
 Temperature: 46.0°C
 Voltage: 12.03 V
 Bin. Bits: 01000
 Hex Value: 0x0411
 Hex Value: 0x0006
 Speed: -3.6 km/h
 Lateral Accel.: 0.00 m/s^2
Self-Diagnosis Log
Page 6
Address 15: Airbags Labels: 4L0-910-655.lbl
 Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
 Component: 73 AIRBAG AUDI8RH43 0230
 Revision: 07H43000 Serial number: 0038QD0A9F75
 Coding: 0014131
 VCID: 2B16C2698A3060196C-807E
 Subsystem 1 - Part No: 4L0 959 339 C
 Component: BF-Gewichtsens. H05 0040
 Subsystem 2 - Serial number: 6332QSME2F22196EQ
 Subsystem 3 - Serial number: 6342QSME3022434C6
 Subsystem 4 - Serial number: 6352QSME251A30468
 Subsystem 5 - Serial number: 6362QSME302230761
 Subsystem 6 - Serial number: 63734SME6D19316C9
 Subsystem 7 - Serial number: 63834SME6C221F76A
No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl
 Part No SW: 4F0 910 549 B HW: 4F0 953 549 F
 Component: J0527 0830
 Revision: 00H08000 Serial number: 90026121560193
 Coding: 0012252
 VCID: 281C3D659BC64B0181-807C
 Component: E0221 H03 0040
No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 4L0-920-xxx-17.clb
 Part No SW: 4L0 920 985 G HW: 4L0 920 985 G
 Component: KOMBIINSTR. H35 0316
 Revision: 00000000 Serial number: NGF50YNAD
 Coding: 8BD664040D00CF05020205
 VCID: 383CED258B66DB8111-806C
Self-Diagnosis Log
Page 7
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
 Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
 Component: GW-BEM 5CAN-M H06 0058
 Revision: MB700037 Serial number: 3700M12A060050
 Coding: 00C303
 VCID: 3FCE8639AE48ECB9D0-806A
 Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
 Component: J367-BDM H07 0125
 Serial number: 00000000002790490620
Self-Diagnosis Log
Page 8
Address 28: HVAC, Rear Labels: None
 Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
 Revision: 00---011 Serial number: 00000000351732
 Coding: 0000006
 VCID: 689C7D655B468B0141-803C
00003 - Control Module
 Fault Status: 00100011
 Mileage: 41990 km
 Date: 2015.12.28
 Time: 15:47:48
 Fault Status: 00101101
 Reset counter: 223
 Mileage: 46207 km
 Date: 2016.02.05
 Time: 19:36:45
------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None
 Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
 Component: MEM-FS H08 0064
 Revision: AA000000 Serial number: 00000041891140
 Coding: 00581B00000011110000
 VCID: 3228DF0D6D1A31D12F-8066
Self-Diagnosis Log
Page 9
 Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
 Component: J0769_SWA_MasterH02 0050
 Revision: 00H02000 Serial number: 6PZ 009 014-10
 VCID: 2E10CB7DB92215314B-807A
 Component: J0770_SWA_Slave_H02 0050
 Subsystem 3 - Serial number: 5F12.10.1200H02000AMS15367ÿ
 Subsystem 4 - Serial number: S15367ÿ
No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
 Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
 Component: TSG FA H12 0362
 Revision: Serial number: 0000043618742
 Coding: 011F57205E40440004
 VCID: 48DC9DE5FB86AB0161-801C
No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4L0-910-289.lbl
 Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
 Component: Komfortgeraet H12 0130
 Revision: 0130 --- Serial number: 01863593750000
 Coding: 3569949
 VCID: 383CED254B66DB8111-806C
Self-Diagnosis Log
Page 10
 Part No SW: 4L0 035 466 A HW: 4L0 035 466 A
 Component: BO Q7 H30 0110
 Revision: 07S00000 Serial number: 01907120007145
 Coding: 0D000001
 VCID: 291A386140CC72099E-807C
 Subsystem 1 - Part No SW: 4L0 910 465 A HW: 4L0 035 465
 Component: BO Q7 SLAVE H41 0780
 Serial number: 01109120020323
No fault code found. ------------------------------------------------------------------------------- Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
 Part No SW: 4F0 910 274 B HW: 4F0 907 274
 Component: J793 RKA+ H04 0110
 Revision: 00000519 Serial number: 00005190058721
 Coding: 0758477
 VCID: 23062A49E2E0A859D4-8076
No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
 Part No SW: 4F0 910 280 HW: 4F0 907 280 D
 Component: ILM Beifahrer H16 0100
 Revision: Serial number: 00000000126225
 Coding: 0012001
 VCID: 5EF05BBD8902C5B1BB-800A
Self-Diagnosis Log
Page 11
Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
 Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
 Component: TSG BF H12 0362
 Revision: Serial number: 0000043373390
 VCID: 47DE9ED9F698A47968-8012
 Reset counter: 183
 Mileage: 87224 km
 Date: 2017.06.14
 Time: 19:42:57
------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl
 Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
 Component: AFS 1 H01 0010
 Coding: 0000031
 Component: AFS-Modul links H07 0004
 Component: AFS-Modul rechtsH07 0004
No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail!
 Part No SW: 4G0 035 082 E HW: 4G0 035 082
 Component: Radio U SIRIU H60 0121
 Revision: AB001007 Serial number: 156JB0C7659908
 Coding: 020007010000000000
 VCID: 22082F4D3DFAA151DF-8076
Self-Diagnosis Log
Page 12
 Part No SW: 4L2 035 746 C HW: 4L2 035 746 A
 Component: H-BNT-NA H44 0624
 Revision: -------- Serial number: 224J.0C7509316
 Coding: 180200060004EBEF710003456F632003140000000100000000
 VCID: 2E10CB7D792215314B-807A
 Subsystem 1 - Part No: 8R0 060 884 BA
 Component: NAR 2013 0703
 Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
 Component: DU7 High H41 0104
 Serial number: A130JV0C2573228
 Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
 Component: E0380 Bedient H01 0060
 Serial number: 00000002045006
 Component: CD-Database 4949
No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
 Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
 Component: TSG HL H11 0362
 Revision: Serial number: 0000043516216
 Coding: 010E57204040230004
 VCID: 46C093DDF192BD7193-8012
No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels: 4E0-907-383.clb
 Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
 Component: Anhaenger H12 0100
 Revision: 2A001001 Serial number: 00000375155939
 Coding: 0200000000000000
 VCID: 312AD001681C0AC956-8064
Self-Diagnosis Log
Page 13
Address 6C: Back-up Cam. (J928) Labels: None
 Part No SW: 4L0 907 428 HW: 7P6 907 441 D
 Component: TopView H05 0293
 Revision: 11001001 Serial number: 82330JF0059308
 Coding: 020C010001000100000102000000
 ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
 ROD: EV_CamSysteCorneViewAUDI.rod
 VCID: 6E900B7DB1A255310B-803A
No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. Labels: None
 Part No SW: 4L0 910 945 HW: 4L0 827 851 E
 Component: ValeoHeckdeckel H57 0500
 Revision: --H57001 Serial number: E5030000B
 Shop #: WSC 98765 666 38354
 VCID: 6C9401754FBEA72125-8038
 Subsystem 2 - Serial number: ) ó * *** *** *** *
 Subsystem 3 - Serial number: RD26.10.12--H57001002E0258ÿ
 Subsystem 4 - Serial number: 2E0258ÿ
No fault code found. ------------------------------------------------------------------------------- Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
 Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
 Component: ILM HINTEN 2 H08 0080
 Revision: AAH08080 Serial number: 130086127-----
 Coding: 0003595
 VCID: 2600335D91D25D71B3-8072
 Component: J_245_EE16_SKB10H12 0220
 Component: J_394_EE16_SKB10H12 0220
 Component: J_392_EE16_SKB10H12 0220
Self-Diagnosis Log
Page 14
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
 Component: TSG HR H11 0362
 Revision: Serial number: 0000043516131
End----------(Elapsed Time: 02:03, VBatt start/end: 12.2V/12.2V)-----------
Hi, welcome to our forum.
Please do not use the PRINT function in VCDS to post scans here; the resulting formatting is much harder to read than the native text file you can get with the [Copy] button, or by simply opening a one of the text files from your Logs or Scans folder with Notepad and pasting the results here.
matt.severson
C?ID=270238
Here is a .txt file. Thanks.
Wednesday,14,June,2017,19:49:45:13648
VCDS Version: 17.1.3.0 (x64)  HEX-NET CB: 0.4336.4
   Coding: 001378
   Revision: 00H02001
   Coding: 0623713
   Coding: 0000135
   Coding: 0304A036
   Coding: 070000
   Coding: 0139123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 28011E
   Coding: 0031118
                    Reset counter: 183
                    Mileage: 87224 km
                    Date: 2017.06.14
                    Time: 19:45:14
                    Temperature: 46.0°C
                    Voltage: 12.03 V
                    Bin. Bits:    01000
                    Hex Value: 0x0411
                    Hex Value: 0x0006
                    Speed: -3.6 km/h
   Coding: 0014131
   Coding: 0012252
   Coding: 00C303
   Coding: 0000006
                    Mileage: 41990 km
                    Date: 2015.12.28
                    Time: 15:47:48
                    Reset counter: 223
                    Mileage: 46207 km
                    Date: 2016.02.05
                    Time: 19:36:45
   Coding: 3569949
   Coding: 0D000001
   Coding: 0758477
   Coding: 0012001
                    Reset counter: 183
                    Mileage: 87224 km
                    Date: 2017.06.14
                    Time: 19:42:57
   Coding: 0000031
ó
   Coding: 0003595
NEtech
C?ID=56995
Should be like this.
Explanation:
[Controller no.] - New coding
[10] - 29011E
[13] - 0031111
[3C] - 0010001
[6C] - 020C010001000100010102000000
matt.severson
C?ID=270238
Thanks!!! Worked perfectly. Much appreciated.
Bimbasz
Poland
C?ID=126932
Yesterday I installed the original full electric trailer hitch in the Audi Q7 4.2 TDI 2007.
I don't know how to code the 01 engine module, I have no coding hints.
I encoded the drivers 03-ABS Brakes, 13-Auto Dist. Reg, 19-CAN Gateway, 34-Level Control, 76-Park Assist, in which the module should still be coded that a trailer is installed
Tuesday,26,October,2021,09:32:48:36053
VCDS Version: 21.9.0.2 (x64)  HEX-NET2 CB: 0.4555.4
Data version: 20210903 DS330.0
VIN: WAUZZZ4LX8D......   License Plate: Q7
Mileage: 175610km-109118mi   Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 11 31 13 15 16 17 18 19 34 37 42 46
          47 4F 52 55 56 61 62 69 6D 6F 72 76 77
VIN: WAUZZZ4LX8D......   Mileage: 175610km-109118miles
   Part No SW: 4L0 910 409     HW: 4E1 907 409 B
   Component: 4.2L V8TDI  A000AGMŞ0040
   Revision: --H05---    Serial number:
   Coding: 0011779
   VCID: 6780D2DA6365196306B-8032
   VINID: 9D196AAAA11CA085000850002439A9FBEE
   Part No SW: 09D 927 750 FE    HW: 09D 927 750 FE
   Component: AL 750 6A           1050
   Revision: 00H64000    Serial number:
   Coding: 0000504
   VCID: 76BE8F9E34CFF0EB8DD-8022
   Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
   Component: ESP ALLRAD MK25E1   0010
   Revision: 00H30001
   Coding: 0627873
   VCID: 290494E2B5F1EF13D0F-807C
   Component: FBSAUDIC6 ELV   H31 0230
   Revision: 09010701    Serial number: 10601500880809
   Coding: 0000131
   VCID: 6398C6CA975D7543DA3-8036
   Subsystem 1 - Part No: 4F0 910 131 E
   Component: FBSAUDIC6 IDG   H01 0040
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L0 910 731 K    HW: 4E0 035 729
   Component: Interfacebox    H43 4220
   Revision: 00000000    Serial number: 386I$077549306
   Coding: 0002001
   VCID: 30327986962B9EDB171-8064
   Component: E0380 BedienteilH01 0060
   Subsystem 2 - Serial number: 00000000868186
   Subsystem 3 - Serial number: 0119.09.070000000100010538˙
   Subsystem 4 - Serial number: 010538˙
   Part No SW: 4L0 910 043     HW: 4L0 820 043 F
   Revision: 00---012    Serial number: 00000000132401
   Coding: 0000024
   VCID: 6194CCC28D416753C8F-8034
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H18 0250
   Coding: 0012121
   VCID: 31347C829D2197D318F-8064
   Component: Wischer AU716   H17 0100
   Coding: 00022806
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Part No SW: 4L0 910 110 A    HW: 4L0 035 110
   Component: MP3-Changer     H45 0350
   Revision: 00045006    Serial number: AUZ5ZBG1232423
   VCID: 1D6CB032F1B903B3AC7-8048
Address 11: Engine II        Labels: Redir Fail!
   Component: 4.2L V8TDI  A000AGSŞ0040
   Coding: 0011779
   Shop #: WSC 99999 999 999999
   Part No SW: 4L0 910 561     HW: 4L0 907 561
   Component: ABSTANDSREGELUNGH06 0140
   Coding: 0011161
   VCID: 669EDFDE646F006B3DD-8032
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 71 AIRBAG AUDI8RH42 0230
   Revision: 03H42000    Serial number: 00399D03JDUD
   Coding: 0014129
   VCID: 2E0E67FE8C1F882B05D-807A
   Subsystem 1 - Serial number: 6332QSME40043F157
   Subsystem 2 - Serial number: 6342QSME3B711175C
   Subsystem 3 - Serial number: 6352QSME3D572611F
   Subsystem 4 - Serial number: 6362QSME3B102E73J
   Subsystem 5 - Serial number: 63734SME3A280309-
   Subsystem 6 - Serial number: 63834SME3E4E14717
   Revision: 00H02000    Serial number: 90054072440026
   Coding: 0002152
   VCID: 270092DAA3E5D963C6B-8072
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4L0 920 930 R
   Component: KOMBIINSTR. M73 H21 0240
   Revision: 00700000    Serial number: 73D55DR97
   Coding: 3745058
   Shop #: WSC 12345 001 136936
   VCID: 231886CAD7DD35439A3-8076
Address 18: Aux. Heat        Labels: 4L0-910-105.clb
   Part No SW: 4L0 910 105     HW: 4L0 815 071 D
   Component: Heizgeraet      H08 0080
   Revision: 0000000C    Serial number: 00000009014264
   VCID: 6092C9C6864B6E5BC71-8034
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 C
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1000D07802807D
   Coding: F75BBEFF31320200
   VCID: 2D0C60F28119F3333C7-8078
Address 34: Level Control        Labels: 4L0-910-553.lbl
   Part No SW: 4L0 910 553 C    HW: 4L0 907 553
   Component: LUFTFDR.-CDC    H03 7660
   Revision: --H03001    Serial number: 15.1528-0096.2
   Coding: 0015520
   Shop #: WSC 16031 048 51725
   VCID: 2A066BEEB0F7E40BD95-807E
   Part No SW: 4E0 910 888 Q    HW: 4E0 919 887 M
   Component: MNS ECE         H50 2050
   Revision: 00000000    Serial number: 399I9077587376
   Shop #: WSC 00170 259 51600
   VCID: 3C2A5DB64A636ABBBB9-8068
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0150
   Revision: 00000000    Serial number: t
   Coding: 0000587
   VCID: 2F307AFA8B1581230EB-807A
   Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
   Component: Komfortgeraet   H07 0040
   Revision: 0040 ---    Serial number: 01064528820000
   Coding: 7610501
   VCID: 3338768A673DA5C36A3-8066
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4L0 910 223 H    HW: 4L0 035 223 C
   Component: DSP-AU716-RD  H07 0250
   Revision: S0600000
   Coding: 020000
   VCID: 290494E2B9F1EF13D0F-807C
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000285201
   Coding: 0011001
   VCID: 5EEEF73EBC3F58ABF5D-800A
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0150
   Revision: 00000000    Serial number: A
   Coding: 0000587
   Part No: 8P0 907 357 F
   Coding: 0000008
   VCID: 3D2C50B2517963B38C7-8068
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
   Revision: 00000000    Serial number: 388I3077646358
   Part No SW: 4L0 910 181 A    HW: 4L0 915 181
   Component: J0644 BEM       H12 0690
   Revision: --------    Serial number: 00000000025939
   Shop #: WSC 62448 142 67566
   VCID: 251C98D2D9E9CB73F47-8070
   Component: von TU3  0709173524
   Coding: 344630393135313035442054553330373039313733353234
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Component: TSG HL          H21 0150
   Coding: 0000010
Address 69: Trailer (J345)       Labels: None
   Part No SW: 4L0 907 383 D    HW: 4L0 907 383 D
   Revision: 2C001001    Serial number: 00000194993509
   Coding: 0101010000000000
   VCID: 3236738E9427ACCB615-8066
Address 6D: Trunk Elect.        Labels: 4L0-910-945.clb
   Part No SW: 4L0 910 945     HW: 4L0 827 851 C
   Component: ValeoHeckdeckel H24 0290
   Revision: --H24001    Serial number: E5030000B
   VCID: 6C8AADF67A833A3B6B9-8038
   Subsystem 3 - Serial number: RD22.09.07--H24001001C0090˙
   Subsystem 4 - Serial number: 1C0090˙
   Revision: AAH05061    Serial number: 003094216-----
   Coding: 0003591
   VCID: 261E9FDEA4EFC06BFDD-8072
   Component: J_245_EE16_SKB09H10 0200
   Component: J_394_EE16_SKB09H10 0200
   Component: J_392_EE16_SKB09H10 0200
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Component: TSG HR          H21 0150
   Coding: 0000010
   Part No SW: 4F0 910 283 H    HW: 4F0 919 283 H
   Component: Parkhilfe 8-Kan H12 0080
   Revision: 00H12000    Serial number: 06340726002522
   Coding: 0211146
Address 77: Telephone        Labels: 4F1-910-336.lbl
   Part No SW: 4F1 910 336 B    HW: 4F1 862 335
   Component: BTA             H09 0900
   Revision: 00H09000    Serial number: 00000007514415
   Coding: 0070011
End----(Elapsed Time: 02:08, VBatt start/end: 11.7V/11.7V. VIgn 0.0V)------
Patrick1
C?ID=9044
I am working on a 2014 Q7. I installed a factory hitch. I am having trouble with coding
the Auto Dist Reg to 003111 from 0031118. I keep getting a code not accepted. I have
changed the WSC but should I change it to the original WSC? Do I need a security code
I have tried 20103 and it does not work. Any help is good for a thank you
Patrick1
C?ID=9044
I will not have the vehicle in until Thursday and I will get a current auto scan . The hitch is installed and the lights and controller all work. It is just the cruise. I'll be back thanks
Patrick1
C?ID=9044
Patrick1
C?ID=9044
I made a road trip. Here is the info. I forgot to change the coding in the #13 Auto Dist Reg.
So I changed it fro the oo31118 to 0031111 and the cruise turned back on. I still have one issue
when I start the car the message center displays left trailer brake light right trailer brake light
and the trailer is not on the car. The brake lights on the trailer work when it is attached. I remembered
that VCDS stores scans so I have the original auto-scan before the trailer module was installed and the current auto-scan to compare. The coding changes I made are Added 69 trailer in gateway
01 Engine changed coding from 2A2A4012256600050000 to 2A2A4012257600050000
03 ABS changed coding from 0623729 to 0623713
6F Cen Conv II changed coding from 0003595 to 0003587
13 Auto Dist Reg changed coding from 0031118 to 0031111
I will put second scan from today in another post so it is not confusing
Friday,06,May,2022,12:12:33:56157
VCDS Version: 22.3.1.4
Data version: 20220407 DS337.0
VIN: WA1LMAFE8DD014179   License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3C 42 46 47 4C 4F 52
VIN: WA1LMAFE8DD014179   Mileage: 142370km-88464miles
3C-Lane Change -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
   Component: 3.0TDI FSA    H21 0014
   Revision: 54H21---    Serial number:                CVN: 1B2B250238D3FF8238D3FF820E1FC39E
   Coding: 2A2A4012256600050000
   Shop #: WSC 40845 004 1048576
   ASAM Dataset: EV_ECM30TDI0114L2910401A 001015
   VCID: A241F5ADB5142C9F79-80F6
   VINID: 9D105C751595214500044047246F6B3D39
   Component: AL1000 AISIN  002 3399
   Serial number:                CVN: 0478EC02
   Coding: 001378
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_002_AU56.rod
   VCID: FBFFE8C9723EBD571A-80AE
   Revision: 00H02001
   Coding: 0623729
   VCID: B46D03F5D7E0B22F9B-80E0
   Revision: 00H08000    Serial number: 10603702053709
   Coding: 0000131
   VCID: A54BEEB16C3ADBA71C-80F0
   Subsystem 1 - Part No: 4F0 910 132 J
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H01 0054
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AP
   Revision: 00---031    Serial number: 00000030277575
   Coding: 0300A036
   VCID: A54BEEB1AC3ADBA71C-80F0
   Part No SW: 4F0 910 279 AH    HW: 4F0 907 279 D
   Coding: 0039123
   VCID: EFE7CC99FE46D1F7A6-80BA
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
   Revision: 11001001    Serial number: 55961308000226
   Coding: 28011E
   VCID: B46D03F51FE0B22F9B-80E0
   Coding: 0031118
   VCID: A757E4B91636C9B72E-80F2
                    Reset counter: 111
                    Mileage: 142371 km
                    Date: 2022.05.06
                    Time: 11:36:46
                    Temperature: 20.0°C
                    Voltage: 11.78 V
                    Bin. Bits:    01000
                    Hex Value: 0x0411
                    Hex Value: 0x0006
   Component: 73 AIRBAG AUDI8RH44 0230
   Revision: 08H44000    Serial number: 0038QD0C3UFO
   Coding: 0014131
   VCID: AB5F18890ADEEDD7CA-80FE
   Subsystem 2 - Serial number: 6332QSME4C2D2772O
   Subsystem 3 - Serial number: 6342QSME4C2D2B7E+
   Subsystem 4 - Serial number: 6352QSME722C147CO
   Subsystem 5 - Serial number: 6362QSME4C2D0E6E0
   Subsystem 6 - Serial number: 63734SME712F105C1
   Subsystem 7 - Serial number: 63834SME712F117A3
   Revision: 00H08000    Serial number: 90026130230008
   Coding: 0002252
   VCID: A855E7851B28C6CF27-80FC
   Component: KOMBIINSTR.   H35 0317
   Revision: 00000000    Serial number: VJ541UU3E
   Coding: 8BD664040500CF05020205
   VCID: B87537C50B88564FB7-80EC
   Revision: MB700037    Serial number: 3700M133140004
   Coding: 00C303
   VCID: BF875CD92EA6617776-80EA
   Serial number: 40079515014120302765
02849 - Control Module for Lane Change Assistance (J769)
                    Reset counter: 151
                    Mileage: 142371 km
                    Date: 2022.05.06
                    Time: 11:36:48
                    Bin. Bits:    10111
                    Voltage: 11.60 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.40 s
   Revision: AA000000    Serial number: 00000054768770
   Coding: 00000000000000000000
   VCID: B26105EDEDF4BC1F89-80E6
00461 - Control Module for Seat Memory; Passenger (J521)
                    Reset counter: 111
                    Mileage: 142371 km
                    Date: 2022.05.05
                    Time: 15:03:02
   VCID: AE59119D39CC98FFED-80FA
   Subsystem 3 - Serial number: 5F15.03.1300H02000AMS15551ÿ
   Subsystem 4 - Serial number: S15551ÿ
   Revision:             Serial number: 0000056318418
   Coding: 011F07205E40440004
   VCID: C89547057B6826CFC7-809C
00947 - Trunk Lid remote Control Switch (E188)
                    Reset counter: 111
                    Mileage: 142371 km
                    Date: 2022.05.05
                    Time: 15:11:13
   Revision: 0130 ---    Serial number: 01928057480000
   Coding: 3569949
   VCID: B87537C5CB88564FB7-80EC
02960 - Lamp in Bumper; Rear Left
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 111
                    Mileage: 122356 km
                    Date: 2021.07.27
                    Time: 06:32:31
                    Bin. Bits:  010 001
02961 - Lamp in Bumper; Rear Right
                    Fault Status: 00101001
                    Reset counter: 151
                    Mileage: 142371 km
                    Date: 2022.05.06
                    Time: 11:37:35
                    Bin. Bits:  011 000
   Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H04 0160
   Revision: CH004000    Serial number: 00000000020028
   Coding: 030000
   VCID: A953E281C022FFC738-80FC
   Revision: 00000519    Serial number: 00005190079437
   Coding: 0758477
   VCID: A34FF0A9620E259772-80F6
   Revision:             Serial number: 00000000137439
   Coding: 0012001
   VCID: DEB9815D09EC487F1D-808A
   Revision:             Serial number: 0000056344103
   VCID: C7974439767629B7CE-8092
00447 - Function Limitation due to Over-Voltage
                    Reset counter: 151
   Serial number: 130322-0002-152
   Coding: 1147A71010020400
   ROD: EV_HeadlRegulBasic_AU35.rod
   VCID: C281552D55540C9F19-8096
Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
   Revision: AB001007    Serial number: 156CV0D7708023
   VCID: A241F5ADBD142C9F79-80F6
   Revision: --------    Serial number: 224CY0D7519507
   VCID: AE59119DF9CC98FFED-80FA
   Component: DU7 High  H42 0104
   Serial number: A130C+0D2694987
   Subsystem 3 - Part No SW: 4L0 919 614 B    HW: 4L0 919 614 B
   Serial number: 00000002101047
                    Reset counter: 151
                    Mileage: 142371 km
                    Date: 2022.05.06
                    Time: 11:36:57
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000100 00000000
   Revision:             Serial number: 0000056371670
   Coding: 010E07204040230004
   VCID: C689493D717C30BF35-8092
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Revision: 2A001001    Serial number: 00000194002591
   Shop #: WSC 51539 001 1048576
   VCID: B1630AE1E8F28707F0-80E4
   Revision: 11001001    Serial number: 82330JF0079272
   VCID: EED9D19D314CD8FFAD-80BA
   VCID: ECDDDB95CF502AEF83-80B8
   Subsystem 2 - Serial number: !
ó
   Subsystem 3 - Serial number: RD22.03.13--H57001002E0297ÿ
   Subsystem 4 - Serial number: 2E0297ÿ
   Revision: AAH08080    Serial number: 0082577479----
   Coding: 0003587
   Shop #: WSC 44575 001 1048576
   VCID: A649E9BD113CD0BF15-80F2
   Component: J_245_EE16_SKB10H14 0220
   Component: J_394_EE16_SKB10H14 0220
   Component: J_392_EE16_SKB10H14 0220
                    Reset counter: 151
                    Mileage: 142371 km
                    Date: 2022.05.05
                    Time: 18:25:22
                    Bin. Bits:  011 000
                    Reset counter: 151
                    Mileage: 142371 km
                    Date: 2022.05.05
                    Time: 18:25:22
                    Bin. Bits:  011 000
   Revision:             Serial number: 0000056371675
End-------------------------(Elapsed Time: 03:47)--------------------------
Patrick1
C?ID=9044
Here is todays scan.Thank you for the help
Wednesday,11,May,2022,12:26:06:56157
VIN: WA1LMAFE8DD014179   Mileage: 142580km-88595miles
9880 - NOx Sensor 2 Bank 1; Heating Circuit
          P22A7 00 [039] - Implausible Signal
                    Mileage: 142582 km
                    Date: 2022.05.11
                    Time: 12:12:11
                    Engine RPM: 678.50 /min
                    Normed load value: 22.0 %
                    Coolant temperature: 77 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 14.400 V
                    NOx sensor 2: NOx concentration: -100 ppm
                    Com r Lam Lin Rec Cat2 Ds: 0.8320
                    NOx sensor 2: feed voltage: 13760 mV
                    Target value of heating temperature of NOx sensor 2-Bits 0-7: 1
                    Com st N Ox Vld Cat2 Ds-Bits 0-7: 0
                    Exh st Lam Stat No Cat2 Ds-Bits 0-7: 1
                    Exhaust gas temperature sensor 4: 435.3 °C
   Coding: 001378
   Shop #: WSC 00078 790 12345
   Revision: 00H02001
   Coding: 0623713
   Coding: 0000131
   Coding: 0300A036
   Coding: 0039123
   Coding: 00064792
   Shop #: WSC 12345
   Coding: 00150059
   Shop #: WSC 12345
02384 - Windshield Wiper Motor Function Restricted due to Over-Voltage
                    Fault Status: 00100001
                    Reset counter: 151
                    Mileage: 142368 km
                    Date: 2022.05.07
                    Time: 15:54:00
   Coding: 29011E
   Coding: 0031111
   Coding: 0014131
   Coding: 0002252
   Coding: 00C303
00532 - Supply Voltage B+
                    Reset counter: 151
                    Mileage: 142371 km
                    Date: 2022.05.07
                    Time: 14:12:41
                    Bin. Bits:    10000
                    Voltage: 16.20 V
                    Count: 12
                    Fault Status: 00101011
                    Fault Frequency: 19
                    Reset counter: 160
                    Mileage: 142446 km
                    Date: 2022.05.07
                    Time: 20:07:45
                    Bin. Bits:    10000
                    Voltage: 12.60 V
                    Count: 12
                    Bin. Bits:    10010
                    Reset counter: 111
                    Mileage: 142371 km
                    Date: 2022.05.07
                    Time: 13:53:02
                    Reset counter: 151
                    Mileage: 142371 km
                    Date: 2022.05.07
                    Time: 14:12:40
                    Reset counter: 151
                    Mileage: 142371 km
                    Date: 2022.05.07
                    Time: 14:11:47
                    Reset counter: 151
                    Mileage: 142371 km
                    Date: 2022.05.07
                    Time: 14:12:42
   Coding: 3569949
   Coding: 030000
   Coding: 0758477
   Coding: 0012001
                    Reset counter: 151
                    Mileage: 142371 km
                    Date: 2022.05.07
                    Time: 14:11:48
                    Reset counter: 151
                    Mileage: 142371 km
                    Date: 2022.05.07
                    Time: 14:12:42
                    Reset counter: 151
                    Mileage: 142371 km
                    Date: 2022.05.07
                    Time: 14:20:41
                    Voltage: 17.20 V
                    Reset counter: 151
                    Mileage: 142371 km
                    Date: 2022.05.07
                    Time: 14:11:47
                    Reset counter: 151
                    Mileage: 142371 km
                    Date: 2022.05.07
                    Time: 14:12:41
   Coding: 0200000100000000
   Coding: 020C010001000100010102000000
ó
   Coding: 0003595
                    Reset counter: 151
                    Mileage: 142371 km
                    Date: 2022.05.07
                    Time: 13:46:11
                    Reset counter: 151
                    Mileage: 142371 km
                    Date: 2022.05.07
                    Time: 14:11:48
                    Reset counter: 151
                    Mileage: 142371 km
                    Date: 2022.05.07
                    Time: 14:12:41
End-------------------------(Elapsed Time: 03:50)--------------------------
jbain2
C?ID=44435
I'm in the process of doing the same thing. I can't get a prompt that allows me to install the module and I am continuing to get errors in the CAN segment as well as the trailer segment. In the trailer segment it states that the module is not registered. My scan is below.
Thursday,29,September,2022,12:47:57:36434
VCDS Version: 22.3.1.4 (x64)
VIN: WA1WMAFEXAD007100   License Plate:
Mileage: 261910km-162743mi   Repair Order:
Scan: 01 02 03 05 08 09 0E 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
          55 56 5F 62 69 6C 6D 6F 72 76
VIN: WA1WMAFEXAD007100   Mileage: 261910km-162743miles
69-Trailer -- Status: Not registered 0001
Address 01: Engine (CAT)       Labels:. 059-907-401-CAT1.clb
   Part No SW: 4L0 997 401 H    HW: 4L0 907 401 B
   Component: 3.0TDI FSA  G004AG  0010
   Revision: 31H09___    Serial number:
   Coding: 0121002A190F0968
   Shop #: WSC 25908 005 104857
   VCID: 366889AA41C92F3F25-8062
   VINID: 9D1067751595A115000070400091159E41
   Part No SW: 09D 927 750 LL    HW: 09D 927 750 LL
   Component: AL 750 6A           3406
   Revision: 00H92000    Serial number:
   Coding: 0001016
   Shop #: WSC 30958 003 1048576
   VCID: 030E207E429B4A97D2-8056
   Part No SW: 4L0 910 517 K    HW: 4L0 614 517 K
   Revision: 00H30001
   Coding: 0099473
   VCID: 3260B5BAADA1331F09-8066
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602601532600
   Coding: 0000135
   VCID: 254A5EE6EC6F54A79C-8070
00190 - Driver's Door Handle Touch Sensor (G415)
                    Fault Status: 01111011
                    Reset counter: 17
                    Mileage: 261893 km
                    Date: 2022.09.29
                    Time: 10:39:57
00191 - Passenger's Door Handle Touch Sensor (G416)
                    Reset counter: 17
                    Mileage: 261893 km
                    Date: 2022.09.29
                    Time: 10:39:57
                    Reset counter: 17
                    Mileage: 261893 km
                    Date: 2022.09.29
                    Time: 10:39:57
   Part No SW: 4L0 910 043 C    HW: 4L0 820 043 AC
   Component: KLIMA 4 ZONEN H12 0030
   Revision: 00---017    Serial number: 00000000228218
   Coding: 022036
   VCID: 244C43E22755ADAF8B-8070
   Subsystem 1 - Part No SW: 8K0 959 772 A    HW: 8K0 959 772
   Component: SLR-B8  H05 0003
   Serial number:           1100082216
   Coding: 070000
   Subsystem 2 - Part No SW: 8K0 959 772 A    HW: 8K0 959 772
   Serial number:           1100082249
   Coding: 070000
   Part No SW: 4F0 910 279 R    HW: 4F0 907 279
   Component: ILM Fahrer      H26 0340
   Coding: 0033123
   VCID: 387487924BDDD94F37-806C
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4F0 035 110 A    HW: 4F0 035 110
   Component: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 152A6E26FC0FC4270C-8040
   Revision: 07H43000    Serial number: 0038QD09E84%
   Coding: 0014131
   VCID: 2B5EA8DE8A8B62D74A-807E
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME1257082CC
   Subsystem 3 - Serial number: 6342QSME03564C3CL
   Subsystem 4 - Serial number: 6352QSME3D573A1AT
   Subsystem 5 - Serial number: 6362QSME3A57243EQ
   Subsystem 6 - Serial number: 63734SME4A504914
   Subsystem 7 - Serial number: 63834SME6D500A0E7
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90026100680099
   Coding: 0002142
   VCID: 275654EE966346B7AE-8072
   Component: E0221           H02 0100
   Part No SW: 4L0 920 982 P    HW: 4L0 920 982 P
   Component: KOMBIINSTR.   H08 0147
   Revision: 00200000    Serial number: DKY203L3A
   Coding: 8BD664040100CF05020201
   VCID: 3E78918AA9F9E77FFD-806A
   Part No SW: 4F0 907 468 N    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0035
   Revision: MB200030    Serial number: 3000M1030902E3
   Coding: 000303
   VCID: 3A709D9AB5D1CB5FC1-806E
   Serial number: 00000000002790146397
                    Reset counter: 16
                    Mileage: 261886 km
                    Date: 2022.09.29
                    Time: 09:59:46
                    Bin. Bits:    10111
                    Voltage: 11.80 V
                    Count: 7
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AA
   Revision: 00---010    Serial number: 00000000227534
   Coding: 0000006
   VCID: 68D417D25BFD89CF67-803C
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00001010091635
   VCID: 3162BAB668A7080770-8064
   Component: J0769_SWA_MasterH01 0050
   Revision: 00H01000    Serial number: 6PZ 009 014-10
   VCID: 2E58A1CAB99917FF6D-807A
   Component: J0770_SWA_Slave_H01 0050
   Subsystem 3 - Serial number: 5F06.03.1000H010003C910683ÿ
   Subsystem 4 - Serial number: 910683ÿ
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000103157452
   VCID: 4688F96AF129BFBFB5-8012
   Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
   Component: Komfortgeraet   H10 0110
   Revision: 0110 ---    Serial number: 01281310570000
   Coding: 3569693
   VCID: 356A8EA65CCF24272C-8060
   Part No SW: 4L0 035 223 E    HW: 4L0 035 223 E
   Component: BOSE G3 AU716 H01 0100
   Revision: AH001500    Serial number: 00000000018771
   Coding: 0D000000
   Component: J793  RKA+      H02 0110
   Revision: 00000815    Serial number: 00008151111905
   Coding: 0696013
   VCID: 234E40FEE25BAA97F2-8076
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000064375
   Coding: 0012001
   VCID: 5EB8310A89B9C77F9D-800A
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000103220781
   VCID: 458AFE66CC2FB4A7BC-8010
   Part No: 8P0 907 357 H
   Coding: 0000007
   VCID: 3F86EC8E6EF3EE77F6-806A
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335CM0A7560302
   Coding: 020000010000000000
   VCID: 1D3A7606043F9C67C4-8048
02788 - Internal Communications Error
                    Reset counter: 16
                    Mileage: 261886 km
                    Date: 2022.09.29
                    Time: 10:09:19
                    Bin. Bits: 00000001
   Part No SW: 4L0 035 664 A    HW: 4L0 035 664 A
   Component: H-BN-NA       H47 0042
   Revision: --------    Serial number: 489C%0A7527372
   Coding: 010200060004E3EF51000305EF6300030000
   VCID: 295252D6407770C7B8-807C
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Subsystem 2 - Part No SW: 4L0 910 609     HW: 4L0 919 611 C
   Component: E0380 Bedient  H05 0060
   Serial number: 00000001541519
   Subsystem 3 - Part No: 8R0 906 961 A
   Component: CD-Database  1293
00658 - Control Head
                    Fault Frequency: 11
                    Reset counter: 57
                    Mileage: 261893 km
                    Date: 2022.09.29
                    Time: 10:28:52
                    Voltage: 13.20 V
                    Reset counter: 17
                    Mileage: 261908 km
                    Date: 2022.09.29
                    Time: 11:59:29
                    Voltage: 13.00 V
                    Bin. Bits:      001
02071 - Local Databus
                    Reset counter: 16
                    Mileage: 261886 km
                    Date: 2022.09.29
                    Time: 09:59:45
                    Voltage: 12.10 V
                    Bin. Bits:       10
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 16
                    Mileage: 261886 km
                    Date: 2022.09.29
                    Time: 09:59:46
                    Voltage: 12.10 V
                    Reset counter: 17
                    Mileage: 261886 km
                    Date: 2022.09.29
                    Time: 09:59:46
                    Voltage: 12.10 V
   Revision:             Serial number: 0000103260809
   VCID: 438EE07EC21B8A9792-8016
   Revision: 2A001001    Serial number: 00000364647115
   Revision: --H04---    Serial number: 525PA8-J0340HK
   Coding: 1031201
   Component: ValeoHeckdeckel H55 0500
   Revision: --H55001    Serial number: E5030000B
   VCID: 6CDC6BC24F05A5EF03-8038
   Subsystem 3 - Serial number: RD26.03.10--H55001001B0186ÿ
   Subsystem 4 - Serial number: 1B0186ÿ
   Revision: AAH05061    Serial number: 003899850-----
   Coding: 0003595
   VCID: 264859EA91695FBF95-8072
   Revision:             Serial number: 0000103260142
   Part No SW: 4L0 910 283 E    HW: 4L0 919 283 E
   Component: Parkhilfe 8-Kan H02 0100
   Revision: 00H02000    Serial number: 85131008104659
   Coding: 0231366
   VCID: 2C5CABC28F8565EF43-8078
End-------------------------(Elapsed Time: 03:43)--------------------------
[Select]
[19-CAN Gateway]
[Installation List]
- Scroll down to 69-Trailer and put a check-mark next to it.
[Save/Write Coding]
jbain2
C?ID=44435
Thanks Uwe. Figured it out. Was able to go into the CAN module separately and find the prompt for the installation gateway and then add the trailer.
