12 jetta 2.5l abs module coding (MK60EC1)
protekorl
C?ID=310356
Friday,16,June,2017,15:02:39:57792
VCDS Version: Release 17.1.3 (x64)
Address 25: Immobilizer
Control Module Part Number: 5K0 953 234
Component and/or Version: IMMO H04 0604
Software Coding: 000000
Work Shop Code: WSC 00000
VCID: 6A9827F38D9E291157-803E
Advanced Identification/FAZIT
Identification: ZYS-000
Date: 03.10.11
Manufacturer number: 4131
Test stand number: 1042
Flash Status
Flash Date: 00.00.00
Software
OSEK-OS: 03.14.00
HiSpd Net: 01.12.01
Misc.
Hardware number: 5K0 953 234
Workshop System Name: J334
Equipment/PR Code: 2D2D2D2D2D2D2D2D
Dataset Number: -----------
Dataset Version: ----
End of Line Equipment Level: ------------------
ASAM Dataset: EV_Immo_UDS_VDD_RM09
ASAM Dataset Revision: A03009
Car Info
Chassis Number: 3VWDP7AJ6CM129727
Immobilizer
Transponder ID (Current val.): F09B5499
Transponder ID 1: F09B5499
VCDS Info:
Labels: 5K0-920-xxx-25.clb
   #23
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Is this VIN same on Car : 3VWDP7AJ6CM129727?
If it is , then tell customer go back to dealer and tell them to finish what they started .
ABS coding is part of the cluster adaptation.
   #24
protekorl
C?ID=310356
I will check if so i tell customer to go back to dealer
   #26
protekorl
C?ID=310356
Thanks guys jetta 97 and jack i check vin is the same i try the latest coding and is not working i will.send itbto tge dealer but thaks for your time guys...
   #27
Please post the solution if you can to help others when they are done coding it.
