A friend of mine just bought a used Skoda Octavia MK3, on the first scan almost every module had fault codes but they mostly seemed voltage related.
After clearing the DTC's, a single fault code remains:
Anyone come across this one? Have a quick search and couldn't see any "Data Record Invalid" faults relating to the alarm.
Any suggested would be much appreciated, thanks!
Full autoscan:
262661 - Sensor for Anti-Theft Alarm System
B1330 F0 [009] - Data Record Invalid
Reset counter: 28
Mileage: 31228 km
Date: 2017.06.09
Time: 14:19:15
Full autoscan:
Friday,09,June,2017,14:27:37:12963
VCDS Version: 17.1.3.0
VIN: TMBBJ7NE4E0128090 License Plate:
Mileage: 31228km-19404mi Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 20 42 44 52 5F
VIN: TMBBJ7NE4E0128090 Mileage: 31228km-19404miles
Address 01: Engine (J623-CKFC) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 DS HW: 04L 907 309 D
Component: R4 2,0L EDC H22 5514
Revision: 83H22---
Coding: 11190012032501090000
Shop #: WSC 73430 031 00121
ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
ROD: EV_ECM20TDI01104L906021DS_002.rod
VCID: 79F9CC77F8EBF189AE-802C
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 6330300000068F
Coding: 1A078A91242209740077060941C3245851249000608224F000630070C002
Shop #: WSC 73430 031 00063
VCID: 4B9546BFE2F7B3194C-801E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5E0 907 044 E HW: 5E0 907 044 E
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 01110104000100011005000000100000
VCID: 275DDA0F5EDFB77988-8072
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011333403733
Coding: 0F000942424702FB07A04082B10C07280000000000000000000000000000
Shop #: WSC 73430 790 00121
ROD: EV_BCMBOSCH_012.rod
VCID: 7BF5D67FF2D7C399BC-802E
Subsystem 1 - Part No SW: 5E2 955 119 HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 131124 041 0570
Serial number: 131126202117
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M11D28H17M14S52S6
Coding: 02805D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY16237106P
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000058123392
Reset counter: 28
Mileage: 31228 km
Date: 2017.06.09
Time: 14:19:15
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831333600943
Coding: 0001050001
ASAM Dataset: EV_EPHVA14AU3700000 002018
ROD: EV_EPHVA14AU3700000_SK25.rod
VCID: 387F09738361288111-806C
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 012 0189
Revision: -------- Serial number: 003P4PP7H3UA
Coding: 98CCC000000000005C5400CC008800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F0D226FE6CFDFB990-802A
Subsystem 1 - Part No SW: ----------- HW: 454 001 911 13
Serial number: 3576U000000C08515E0A
Subsystem 2 - Part No SW: ----------- HW: 454 001 911 13
Serial number: 3586U0000001DB285E0K
Subsystem 3 - Part No SW: ----------- HW: 454 801 811 13
Component: SideSensor_Dr 111 0148
Serial number: 3516R4BCE6C02000000H
Subsystem 4 - Part No SW: ----------- HW: 454 801 811 13
Component: SideSensor_Pr 111 0148
Serial number: 3526R65D16C020000002
Subsystem 5 - Part No SW: ----------- HW: 454 801 411 13
Component: FrontSensor_D 114 0149
Serial number: 3556VD7080102000000
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AC HW: 5Q0 953 549
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 05121304400523
Coding: 1400
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 77FDCA4FCEFFE7F9D8-8022
Part No SW: 5E0 920 971 D HW: 5E0 920 971 D
Component: KOMBI 333 2210
Coding: 27A402002180A60001086A00000000
VCID: 2A5B233B4DCD8A1197-807E
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001353812
Coding: 030100040F087300EF000648080F00010001050000000000000000000000
ROD: EV_GatewLear_010.rod
VCID: 3F8D626FA64F1FB9D0-806A
Subsystem 2 - Part No SW: 5E0 919 719 A HW: 5E0 919 719 A
Component: E221__MFL-PR6 H04 0120
Serial number: 000000000A1773201113
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 1761951903
Address 20: High Beam Assist. (J844) Labels: 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511
Component: FLA H04 0002
Revision: AA001001
Coding: 01028F6B76765D525220343E01
VCID: 2B55263F423793196C-807E
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000084338599
Coding: 00150020D001040000001100
VCID: 44876D83CFA97C618D-8010
Serial number: 00000000000001255447
Coding: 1D0200
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 8103
ROD: EV_SteerAssisMQB_010.rod
VCID: 41896497D0BB6949A6-8014
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000084550948
VCID: 43856E9FCAA77B59B4-8016
Serial number: 00000000000001204084
Coding: 050200
Address 5F: Information Electr. (J794) Labels: 5E0-035-MIB-STD1.clb
Part No SW: 5E0 035 874 A HW: 5E0 035 874 A
Component: MU-S-ND-ER 040 0435
Serial number: S7F00812132489
Coding: 03730101FF0000001111120100A800002F0000860100010046
Shop #: WSC 73430 790 00063
ROD: EV_MUStd4CPASE_AU37.rod
VCID: 2643D70B59D5AE71B3-8072
Subsystem 1 - Part No SW: 5E0 919 605 D HW: 5E0 919 605 D
Component: ABT_Std_Nav H50 0022
Serial number: SKZ8Z9NK800PRZ
Subsystem 2 - Part No SW: 5E0 051 236 C HW: -----------
Component: ECE 2014 --- 0036
End-------------------------(Elapsed Time: 03:40)--------------------------
