2007 Passat with 2.5L 5-Cyl. Engine - ABS Coding?
Geoffzie
C?ID=309752
(Jetta 97, I messaged you yesterday in response to this)
Jetta said:
I can do this , I have much advance tool. You do not need to buy key, I would just use Transponder chip and glue it to immo coil.
It looks like I've settled upon using a MK5 Jetta cluster with a full MFD ... I'll just have to adapt it to the Passat dash so it looks "factory". Concerning the Temp/fuel gauges ... I'm using a Jetta fuel pump, and it works fine with the Passat fuel gauge. So I'm not sure why they didn't work in the Jetta cluster ... although the cluster I used WAS damaged.
How much would you charge ... and what would you need from me ... to do the transponder chip? The VIN from the Jetta Instrument Cluster I end up using? You really only need to send me a programmed chip ... I could epoxy it to the coil.
Also, I got to thinking about this ... I'll probably just mount the epoxied chip / coil assembly WITHIN the instrument cluster itself ... and wire it internally. That would eliminate any wiring.
Just let me know.
   #103
Geoffzie
C?ID=309752
I now own a "Passetta"!
Yesterday I purchased a good used 2009 Jetta cluster with a full MFD (from the guy I bought the 2.5 engine from) ... I installed it, did all the ABS basic settings, cleared all the faults, and then drove the car for a while. Everything seems to work fine, including the Temp. and fuel gauges ... although obviously, I'm still getting the "Immobilizer Active" message.
I even tested the car on a gravel parking lot to check the ABS ... and it seems to work fine.
After installing the complete Jetta cluster, it looks like it won't be that difficult after all, to modify the Passat dash to match the cluster ... I'm going to look at that in more detail today. My number one priority is that it looks "factory" and not like a "chop-job". I'll post some pictures of the dash on Flickr when I get it done.
I'm also going back to him today to see if I can get the key and key tumbler from the same car ... which would eliminate the "Immo Active" message. As I said before, I'll probably just mount the epoxied chip / key / coil assembly WITHIN the instrument cluster itself ... and wire it internally. That would eliminate any external wiring.
Once I eliminate the "Immo Active" warning, I'll have to verify that I can access the MFD menu and all of it's functions. So, other than some minor details, and the paint job and bodywork, it looks like the car is pretty much completed.
I really appreciate everyone's time, input, and assistance on this!
   #104
Geoffzie
C?ID=309752
Final scan ... NO FAULTS! (other than Satellite Radio faults)
Final scan ... NO FAULTS! (other than Satellite Radio faults).
I ended up purchasing a Jetta LowLine cluster ($20) with matching ignition key. I couldn't find a MFD cluster WITH the key ... and the cluster I purchased before, didn't have the key, and I discovered it was for a Diesel - only a 6000 RPM Tach.
I inserted the key into the key tumbler with reading coil, wired it to the cluster, mounted the key tumbler/reading coil under the dash behind the cluster and ... NO "Immobilizer Active" warning!
In the future, If I decide to install a full MFD Jetta cluster, it will be relatively easy. Just purchase a cluster with the matching ignition key ... insert the key in the tumbler behind the dash ... Install the cluster, and it should work fine!
Tuesday,19,September,2017,21:23:49:23114
VIN: WVWBA71K78W315062   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 72
VIN: WVWBA71K78W315062   Mileage: 107010km-66492miles
Address 01: Engine (CBT)       Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 BJ    HW: 07K 906 032 Q
   Component: 2,5l R5/4V      G   1567
   Revision: 1NH01---    Serial number: VWX7Z0H33N97Z2
   Coding: 0000003
   Shop #: WSC 01279 785 00200
   VCID: 72BED2CB78AA85375DE-8026
Readiness: 0110 1101
   Part No SW: 09G 927 750 GJ    HW: 09G 927 750 GJ
   Component: AQ 250 6F           0833
   Revision: 00H25000    Serial number:
   Coding: 0000584
   VCID: 7F580BFF3BF8D85F220-802A
   Revision: 00H11001
   Coding: 0021122
   Shop #: WSC 64692 001 104857
   VCID: 73B0D7CF07B08C3F568-8026
   Part No: 1K0 820 047 EB
   Component: Climatic PQ35   090 0505
   VCID: 688AB0A34E767FE7F3A-803C
   Revision: 00H46000    Serial number: 00000005468122
   Coding: 008C0F0140041A00470A00000F00000000285D035C0000
   Shop #: WSC 05311 123 12345
   VCID: 372823DF5348201FAA0-8062
   Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00063445
   Shop #: WSC 05311
   Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
   Component: 0N AIRBAG VW8R  029 2521
   Revision: 10029000    Serial number: 003A3P2W7PWA
   Coding: 0012366
   Shop #: WSC 05311 000 08193
   VCID: 2E0606BBAC12E1D7F96-807A
   Subsystem 1 - Part No: 3C0 959 339 A
   Component: BF-Gewichtsens. 006 0002
   Subsystem 2 - Serial number: 00000000032EPS
   Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME0E716159Eÿ†63
   Subsystem 5 - Serial number: 16159Eÿ†6342MSME105B60746ÿ†63
   Subsystem 6 - Serial number: B60746ÿ†6351HTS64IKQTM627ÿ†63
   Subsystem 7 - Serial number: QTM627ÿ†6361HTS6TLLE15C3Uÿ†63
   Subsystem 8 - Serial number: E15C3Uÿ†63727TS63IK2T6C39ÿ†63
   Subsystem 9 - Serial number: 2T6C39ÿ†63827TS63IKEPNQ25ÿ
   Subsystem 10 - Serial number: EPNQ25ÿ
   Part No SW: 3C0 953 549 H    HW: 3C0 953 549 H
   Revision: 00005000    Serial number: 3C9953507R
   Coding: 0102014
   Shop #: WSC 05311 000 00000
   VCID: 313C1DC7BD2CFE2FE44-8064
   Part No SW: 1K0 920 954 F    HW: 1K0 920 954 F
   Component: KOMBIINSTRUMENT 3HL 1212
   Revision: V0002000    Serial number: VWX7Z0G924F0W7
   Coding: 0023203
   VCID: 2F381BBFAB18E8DFF20-807A
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001065142381
   Coding: 3F3F03400F002002
   Shop #: WSC 00066 123 12345
   VCID: 2C020CB39A0E93C7D72-8078
   Part No SW: 3C0 919 965 A    HW: 3C0 919 965 A
   Component: Kompass         001 0002
   Revision: 00001000    Serial number: 1339817TQ3XP02
   Component: IMMO            3HL 1212
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2801
   Coding: 0001205
   VCID: 36362EDB5442D917B16-8062
   Part No: 1K1 909 144 K
   VCID: 333017CF4730CC3F968-8066
   Part No SW: 3C0 959 433 C    HW: 3C0 959 433 C
   Component:    KSG PQ46 RDK 041 0213
   Revision: 00041000    Serial number: VWZCZ000000000
   Coding: 1B900E88D103005200001C1CF00A0F0E082800
   Shop #: WSC 64713 001 104857
   VCID: 2A0E0AAB90FA8DF725E-807E
   Part No: 1K0 959 702 K
   Coding: 0001204
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7G2175822
   Coding: 0010400
   VCID: 290CF5A795FC86EF2C4-807C
02218 - Satellite Radio (R146)
   Part No: 3C9 959 703 A
   Component: Tuer-SG         021 2507
   Coding: 0000144
   Part No: 3C9 959 704 A
   Coding: 0000144
   VCID: 323E12CBB82AC5379DE-8066
End----------(Elapsed Time: 01:05, VBatt start/end: 13.9V/13.8V)-----------
