I think I've finally convinced the Passat ... that it's REALLY a Jetta now!
Good news and bad news ...
I purchased a used 2008 Jetta Mk5 Instrument Cluster (1K0-920-974-J) with the HighLine MFD. It was somewhat damaged (plastic lens was broken out) but I got it cheap ($32), and it's returnable. I just wanted to see what would happen if I just installed an entire Jetta Mk5 Instrument Cluster.
It worked! All the indicator lights; Turn Signals, High Beam, EPC, Check-Engine, Cruise, Tach, Speedo, and MFD seemed to work OK ... with the exception of the Temp. Guage and Gas Guage ... not sure if they were damaged (since the lens was broke) ... or there's a wiring issue. Also, the light wouldn't work, obviously, the Jetta doesn't use an ... I'll have to look at the wiring.
But the most important thing ... THE WORKED!
I ran through all the basic settings for the and Steering ... then I drove the car and the ESP light went out the first time I applied the brakes! The BAD news is, the MFD lit up with a message "Immobilizer Active!" ... and instead of the mileage showing in the MFD, there was a "SAFE" message at the bottom. Also, the clock was flashing off and on, although it worked.
I then tried using the rear printed circuit board from the Jetta cluster (that's where the Immo is located) with the Passat Instrument Cluster ... It bolted right up perfectly but ... NO worky! The MFD display was blank and the Airbag light would come on for the left turn signal! Obviously, VW decided to switch pins around just for the fun of it! (And I see no easy way to fix it)
Looks like the only way this is going to work (baring any unforeseen ideas to use the Passat cluster), is use the entire Jetta Mk5 Instrument Cluster ... but since it mounts somewhat different, and is a slightly different shape ... I'll have to do some modifying to make it look "factory".
Any ideas as to how to "fool" the Immo to turn off the warning in the MFD? The MFD is kind of useless with the warning there, and you can't get rid of it! Since the Immo was disabled in the , the car starts and runs fine though.
Judging from the scan, I think I've finally convinced the Passat ... that it's REALLY a Jetta now!
I ran a scan, then cleared all the codes ... Here's what I was left with (Notice under Address 46: Central Conv .... for some reason it's looking for a "Convertible Top" and a "Trailer / Towing Sensor" ... not sure why?) ...
Thursday,07,September,2017,13:02:07:23114
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
VIN: WVWBA71K78W315062 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 72
VIN: WVWBA71K78W315062 Mileage: 247220km-153615miles
Address 01: Engine (CBT) Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 BJ HW: 07K 906 032 Q
Component: 2,5l R5/4V G 1567
Revision: 1NH01--- Serial number: VWX7Z0H33N97Z2
Coding: 0000003
Shop #: WSC 01279 785 00200
VCID: 72BED2CB78AA85375DE-8026
Readiness: 0000 0100
Part No SW: 09G 927 750 GJ HW: 09G 927 750 GJ
Component: AQ 250 6F 0833
Revision: 00H25000 Serial number:
Coding: 0000584
VCID: 7F580BFF3BF8D85F220-802A
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0021122
Shop #: WSC 64692 001 104857
VCID: 73B0D7CF07B08C3F568-8026
Part No: 1K0 820 047 EB
Component: Climatic PQ35 090 0505
VCID: 688AB0A34E767FE7F3A-803C
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000005468122
Coding: 008C0F0340041A00470A00000F00000000285D035C0000
Shop #: WSC 05311 123 12345
VCID: 372823DF5348201FAA0-8062
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 05311
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 0N AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3P2W7PWA
Coding: 0012366
Shop #: WSC 05311 000 08193
VCID: 2E0606BBAC12E1D7F96-807A
Subsystem 1 - Part No: 3C0 959 339 A
Component: BF-Gewichtsens. 006 0002
Subsystem 2 - Serial number: 00000000032EPS
Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME0E716159Eÿ†63
Subsystem 5 - Serial number: 16159Eÿ†6342MSME105B60746ÿ†63
Subsystem 6 - Serial number: B60746ÿ†6351HTS64IKQTM627ÿ†63
Subsystem 7 - Serial number: QTM627ÿ†6361HTS6TLLE15C3Uÿ†63
Subsystem 8 - Serial number: E15C3Uÿ†63727TS63IK2T6C39ÿ†63
Subsystem 9 - Serial number: 2T6C39ÿ†63827TS63IKEPNQ25ÿ
Subsystem 10 - Serial number: EPNQ25ÿ
Part No SW: 3C0 953 549 H HW: 3C0 953 549 H
Component: J0527 0015
Revision: 00005000 Serial number: 3C9953507R
Coding: 0102014
Shop #: WSC 05311 000 00000
VCID: 313C1DC7BD2CFE2FE44-8064
Part No SW: 1K0 920 974 J HW: 1K0 920 974 J
Component: KOMBIINSTRUMENT 3HL 1216
Revision: V0002000 Serial number: VWX7Z0GD24C0R0
Coding: 0023203
Shop #: WSC 03170 444 84404
VCID: 353429D74944D20FB8C-8060
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001061171325
Coding: 3F3F03400F2002
Shop #: WSC 00066 123 12345
VCID: 2A0E0AAB90FA8DF725E-807E
Part No SW: 3C0 919 965 A HW: 3C0 919 965 A
Component: Kompass 001 0002
Revision: 00001000 Serial number: 1339817TQ3XP02
Component: IMMO 3HL 1216
01176 - Key
Reset counter: 235
Mileage: 247223 km
Time: 12:55:53
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2801
Coding: 0001205
VCID: 36362EDB5442D917B16-8062
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 333017CF4730CC3F968-8066
Part No SW: 3C0 959 433 C HW: 3C0 959 433 C
Component: KSG PQ46 RDK 041 0213
Revision: 00041000 Serial number: VWZCZ000000000
Coding: 1B900E88D1032E5218041C1FF00A870E082800
Shop #: WSC 64713 001 104857
00830 - Convertible Top Control Module (J256)
Reset counter: 235
Mileage: 247223 km
Time: 12:57:05
01517 - Control Module for Trailer/Towing Sensor (J345)
Reset counter: 235
Mileage: 247223 km
Time: 12:57:05
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001204
No Fault Code Found.
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7G2175822
Coding: 0010400
VCID: 290CF5A795FC86EF2C4-807C
02218 - Satellite Radio (R146)
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 3C9 959 703 A
Component: Tuer-SG 021 2507
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 3C9 959 704 A
Coding: 0000144
VCID: 323E12CBB82AC5379DE-8066
End----------(Elapsed Time: 01:06, VBatt start/end: 12.3V/12.3V)-----------
