- Aug 10, 2016
- 3,768
- 4,182
- Netherlands, eastern part
- C?ID=284912
Check whether all control modules are coded for LHD/automatic transmission? Like engine, gateway, CECM, whatever you can find?
iichel
Friday,18,August,2017,11:46:56:23114
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
VIN: WVWBA71K78W315062 License Plate:
Chassis Type: 1K (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 6D 72
VIN: WVWBA71K78W315062 Mileage: 223620km-138951miles
Address 01: Engine (CBT) Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 BJ HW: 07K 906 032 Q
Component: 2,5l R5/4V G 1567
Revision: 1NH01--- Serial number: VWX7Z0H33N97Z2
Coding: 0000003
Shop #: WSC 01279 785 00200
VCID: 72BED2CB78AA85375DE-8026
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow
Fault Status: 01100010
Mileage: 223627 km
Date: 2017.08.18
Time: 00:42:21
RPM: 684 /min
Load: 21.6 %
Temperature: 84.0°C
Temperature: 45.0°C
Absolute Pres.: 960.0 mbar
Voltage: 14.224 V
Readiness: 0110 1101
Part No SW: 09G 927 750 LF HW: 09G 927 750 LF
Component: AQ 250 6F 1914
Revision: 00H90000 Serial number:
Coding: 0000584
Shop #: WSC 00066 000 00000
VCID: 005A88034606A7A75BA-8054
01683 - Wheel Speed Signals / Vehicle Speed
013 - Check DTC Memory
Fault Status: 00101101
Reset counter: 201
01679 - ABS Wheel Speed Signal; Front Left
Reset counter: 201
01680 - ABS Wheel Speed Signal; Front Right
Reset counter: 201
01681 - ABS Wheel Speed Signal; Rear Left
Reset counter: 201
01682 - ABS Wheel Speed Signal; Rear Right
Reset counter: 201
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
VCID: 7BA0FFEF23E0C47F0E8-802E
9 Faults Found:
Reset counter: 147
Mileage: 395016 km
Date: 2001.04.01
Time: 00:12:13
Count: 256
Count: 80
Count: 37632
Count: 195
Count: 256
Count: 20481
Count: 64
Count: 37633
Fault Status: 01100101
Reset counter: 147
Mileage: 223627 km
Date: 2017.08.18
Time: 00:45:00
Count: 16391
Count: 12
Count: 12800
Count: 279
Count: 50688
Reset counter: 147
Mileage: 223627 km
Date: 2017.08.18
Time: 00:45:00
Count: 16391
Count: 12
Count: 12800
Count: 295
Count: 50688
Reset counter: 147
Mileage: 223627 km
Date: 2017.08.18
Time: 00:45:00
Count: 16391
Count: 12
Count: 12800
Count: 270
Count: 50688
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 147
Mileage: 223627 km
Date: 2017.08.18
Time: 00:45:00
Count: 16391
Count: 12
Count: 12800
Count: 266
Count: 50688
Fault Status: 01101100
Reset counter: 147
Mileage: 223627 km
Date: 2017.08.18
Time: 00:45:01
Count: 16391
Count: 12
Count: 12800
Count: 80
Count: 50688
Count: 16384
Reset counter: 147
Mileage: 223627 km
Date: 2017.08.18
Time: 00:45:01
Count: 16391
Count: 12
Count: 12800
Count: 64
Count: 50688
Count: 16384
00285 - ABS Wheel Speed Sensor; Front Right (G45)
Reset counter: 147
Mileage: 223627 km
Date: 2017.08.18
Time: 00:45:01
Count: 16391
Count: 12
Count: 12800
Count: 48
Count: 50688
Count: 16384
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Reset counter: 147
Mileage: 223627 km
Date: 2017.08.18
Time: 00:45:01
Count: 16391
Count: 12
Count: 12800
Count: 32
Count: 50688
Count: 16384
Part No: 1K0 820 047 EB
Component: Climatic PQ35 090 0505
VCID: 688AB0A34E767FE7F3A-803C
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
01316 - ABS Control Module
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000005468122
Coding: 008C0F0340041A00470A00000F00000000285D435C0000
Shop #: WSC 05311 123 12345
VCID: 372823DF5348201FAA0-8062
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 05311
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 0N AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3P2W7PWA
Coding: 0012366
Shop #: WSC 05311 000 08193
VCID: 2E0606BBAC12E1D7F96-807A
Subsystem 1 - Part No: 3C0 959 339 A
Component: BF-Gewichtsens. 006 0002
Subsystem 2 - Serial number: 00000000032EPS
Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME0E716159Eÿ†63
Subsystem 5 - Serial number: 16159Eÿ†6342MSME105B60746ÿ†63
Subsystem 6 - Serial number: B60746ÿ†6351HTS64IKQTM627ÿ†63
Subsystem 7 - Serial number: QTM627ÿ†6361HTS6TLLE15C3Uÿ†63
Subsystem 8 - Serial number: E15C3Uÿ†63727TS63IK2T6C39ÿ†63
Subsystem 9 - Serial number: 2T6C39ÿ†63827TS63IKEPNQ25ÿ
Subsystem 10 - Serial number: EPNQ25ÿ
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 H HW: 3C0 953 549 H
Component: J0527 0015
Revision: 00005000 Serial number: 3C9953507R
Coding: 0102014
Shop #: WSC 05311 000 00000
VCID: 313C1DC7BD2CFE2FE44-8064
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 970 R HW: 3C0 920 970 R
Component: KOMBIINSTRUMENT VD1 4240
Revision: V0033000 Serial number: 00000000000000
Coding: 0007205
Shop #: WSC 01119 067 57207
VCID: 333017CF4730CC3F968-8066
Fault Status: 01101101
Reset counter: 147
Mileage: 223627 km
Date: 2017.08.18
Time: 00:45:00
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C0631304F6
Coding: 3FFC0C0CD22002
VCID: 211CED87EDCC4EAF744-8074
Part No SW: 3C0 919 965 A HW: 3C0 919 965 A
Component: Kompass 001 0002
Revision: 00001000 Serial number: 1339817TQ3XP02
Part No SW: 3C0 959 433 C HW: 3C0 959 433 C
Component: IMMO 041 0364
Revision: 00041000 Serial number: VWZCZ000000000
Shop #: WSC 64713 001 1048576
VCID: 2A0E0AAB90FA8DF725E-807E
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
02827 - Wake-Up request via ESP
Reset counter: 147
Mileage: 223627 km
Date: 2017.08.18
Time: 00:45:03
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2801
Coding: 0001205
VCID: 36362EDB5442D917B16-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
00625 - Vehicle Speed Signal
Mileage: 3600 km
Temperature: 39.0°C
Voltage: 14.30 V
Voltage: 14.10 V
Component: KSG PQ46 RDK 041 0213
Coding: 1B900E88D1032E521804141FF00A0F0E082C00
Reset counter: 147
Mileage: 223627 km
Date: 2017.08.18
Time: 00:46:21
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001204
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 A HW: 1K0 035 161 A
Component: Radio DE2 012 0015
Revision: 00012000 Serial number: VWZ4Z7F6117447
Coding: 0040400
VCID: 1D64D177D1B46A4F50C-8048
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 3C9 959 703 A
Component: Tuer-SG 021 2507
Coding: 0000144
Address 6D: Trunk Elect. Labels: None
Part No SW: 3C9 827 383 B HW: 3C9 827 383 C
Component: J605 HECKDECKEL 0405
Revision: 00H20001
Shop #: WSC 23250 384 715754
VCID: 303A18C3B626F727EBA-8064
Subsystem 1 - Part No: 3C9 827 384 B
Component: J756 HECKDECKEL 0405
Subsystem 2 - Serial number: 0600H20001001C0055ÿ
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 3C9 959 704 A
Coding: 0000144
VCID: 323E12CBB82AC5379DE-8066
End----------(Elapsed Time: 01:14, VBatt start/end: 14.2V/14.1V)-----------
It pre-supposes that the ABS cares what phyiscal module the VIN comes from. Fact is your car has an Immo that knows the VIN. Does it really matter that 25 is actually in 46 as opposed to the more common 17? TBH, I don't know. You're in uncharted territory with much of this.Is this true? Is it even possible to code this module WITHOUT the VIN being in Address 17: Instruments?
Chassis Type: 1K (1K0)
VIN: WVWBA71K78W315062 Mileage: 225610km-140187miles
Saturday,02,September,2017,11:41:20:23114
VIN: WVWBA71K78W315062 Mileage: 225680km-140231miles
Coding: 0000003
Readiness: 0010 1100
Part No SW: 09G 927 750 GJ HW: 09G 927 750 GJ
Component: AQ 250 6F 0833
Revision: 00H25000 Serial number:
Coding: 0000072
VCID: 7F580BFF3BF8D85F220-802A
Revision: 00H11001
Coding: 0021122
Shop #: WSC 64692 001 104857
VCID: 73B0D7CF07B08C3F568-8026
Coding: 008C0F0340041A00470A00000F00000000285D035C0000
Coding: 00063445
Shop #: WSC 05311
Coding: 0012366
Coding: 0102014
Coding: 0007205
Coding: 0001205
Coding: 0001204
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7G2175822
Coding: 0010400
VCID: 290CF5A795FC86EF2C4-807C
02218 - Satellite Radio (R146)
Coding: 0000144
Revision: 00H20001
Coding: 0000144
End----------(Elapsed Time: 01:12, VBatt start/end: 13.6V/13.6V)-----------
Yes, the CAN Gateway is the module from which VCDS makes its initial chassis determination. That's also where the Gateway Installation List is stored, in other words this stuff at the very top of the Auto-Scan that I changed to blue in your scan a few posts up (post#74).But here's the interesting part ... with the Jetta CANbus installed ... the chassis type is listed as 1K0! So, apparently, the CANbus is what determines chassis type? ...
Well NZDubNurd ... YOU WERE RIGHT!
If you get the weird trans happenings... just install an earlier jetta trans too... then an early jetta ecu, cluster, gateway, bcm, loom......
