plug and play
overclocker
New Member
Hello
I would like to ask for any options for interior retrofits/swap thats DO NOT required reinstalling, coding/decoding etc.
im ask for vw passat 2.0 tdi 103kw 140bhp
whats interior options i have and from what model just plug and play.
jocker01
Steinbach, MB, Canada
C?ID=194603
Hi
Not many :D
Only upgrade which I have done without VCDS was led ambient lights :D I only had to order LED's and new cover from dealers, plug and play, no coding necessary :D
ps. What is reason to having this d**khead as your avatar?
Regards
Jocker01
overclocker
New Member
Thanks a lot. and ambient lights are good idea , gonna check what have in stores.
about avatar nothing personally just was 1st pic found...😉
about avatar nothing personally just was 1st pic found...��
I'll take a vaper over Adolph any time. :thumbs:
overclocker
New Member
is there any double din display from another passat i could plug and play already have saw rcd510 but it causes battery drain problem...
dont want spend a lot so if any one could explain steps for 510 fix drain...
overclocker
New Member
do all door warning light install require VCDC coding ?
already checks mine i dont have wire to this place so is just a red plastic reflectors.
my question is any why and instructs that i could make i wire to this puddle gives them lights even replaced with vw ligo but with out mess with vcdc.
i hace think isnt be posibble to take ground and pulse from in door cables?
