Friday,19,May,2017,19:08:07:29015
VCDS Version: 17.5.0.0 (x64) HEX-NET CB: 0.4341.4
Data version: 20170505 DS270.4
VIN: 3VWRA7AU8FM079340 License Plate:
Mileage: 31181km-19374mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 75
VIN: 3VWRA7AU8FM079340 Mileage: 31181km-19374miles
Address 01: Engine (J623-CRUA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 C HW: 04L 907 309
Component: R4 2.0l TDI H23 9282
Revision: 85H23---
Coding: 01190012032410081000
Shop #: WSC 07437 444 00000
ASAM Dataset: EV_ECM20TDI01104L906021C 004014
ROD: EV_ECM20TDI01104L906021C_004.rod
VCID: A50DF2C2A490D16F8C-80F0
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 50365000000706
Coding: 01FA6AA124270975007A020481C32580562490004081A4B200630050C002
Shop #: WSC 01383 790 50316
VCID: C7D1584A7EDC237F5E-8092
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0358603874
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: BA3731BE3D2E4E97D1-80EE
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5GM 907 044 A HW: 5GM 907 044 A
Component: Climatronic H03 1001
Revision: 00001K01
Coding: 00020114200100000005000012111400
VCID: C2C7495E55FE065789-8096
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 087 R HW: 5Q0 937 087 R
Component: BCM PQ37BOSCH 028 0145
Revision: -------- Serial number: 86582401150792
Coding: 00110A464041A2E969E44000001407001800000000000000000000000000
Shop #: WSC 00066 790 00225
ROD: EV_BCMBOSCH_014.rod
VCID: CAD7617E6DCEDE1741-809E
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 140825 043 0581
Serial number: 150305001610
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S5Y14M12D23H08M01S17
Coding: 00A8DD
Sun Roof:
Subsystem 3 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.403 H03 0004
Serial number: 0000FST00054DRD00000
Coding: 181801
Reset counter: 224
Mileage: 31048 km
Date: 2017.03.19
Time: 12:56:04
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM01RKB.
VCID: D1E576128098EDCF00-8084
Occupant Detection:
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J150002E0V50.
Coding: 303137
Subsystem 2 - Part No SW: ----------- HW: 480 002 201 15
Serial number: 3570000000090975721C
Subsystem 3 - Part No SW: ----------- HW: 480 002 201 15
Serial number: 358000000009466DD21R
Subsystem 4 - Part No SW: ----------- HW: 480 401 601 15
Serial number: 3510002B719121A3829W
Subsystem 5 - Part No SW: ----------- HW: 480 402 001 15
Serial number: 3520002A519121A2D16U
Subsystem 6 - Part No SW: ----------- HW: 480 402 201 15
Serial number: 3550002BB192BC74D06G
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 201 15
Serial number: 3560002B9192BC71F13C
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150127400807
Coding: 0400
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB_VW37.rod
VCID: 844B8F460F6AC867FB-80D0
Part No SW: 5G1 920 841 HW: 5G1 920 841
Component: KOMBI 243 4270
Coding: 0BA41A122980CF0502086A001000000000000000
VCID: E58DB2C2E410116F4C-80B0
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 09021510000072
Coding: 0101000800087300EF00020A080F00000001050000000000000000000000
Shop #: WSC 00066 790 00200
ROD: EV_GatewConti_011.rod
VCID: F2A7D99E25DEF6D7D9-80A6
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0101
Serial number: 27150000259070125081
Coding: 30FFFF
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000355910004
Coding: 5500000000000000
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: B42B1F861F4AB8E70B-80E0
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 100215060504JQ
Coding: 003A13200000040000000000
VCID: C0C343565BF214479F-8094
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000000786810
Coding: 011000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0102
Shop #: WSC 00066 790 00202
ROD: EV_SteerAssisMQB_012.rod
VCID: C3C94C5A4AE40F5F82-8096
Part No SW: 5G0 035 456 HW: 5G0 035 456
Component: MIB_lite_amp H40 0060
Serial number: VWZ8Z1EC4027U62
Coding: 22000000AAAAAA0000
ASAM Dataset: EV_AMPMst12C1ALPI 001007
ROD: EV_AMPMst12C1ALPI.rod
VCID: E389ACDAEA246F5FA2-80B6
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 100215060504Y2
VCID: BFC140AA260C6BBFE6-80EA
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000000613803
Coding: 091000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 020A00010B000400
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 876 HW: 5G0 035 876
Component: MU-S-NS-US 014 0645
Serial number: V7B02501154013
Coding: 027300020000000021220002001800001F0100340100010546
ROD: EV_MUStd4CPASE_VW37.rod
VCID: E995BEF20808350F68-80BC
Subsystem 1 - Part No SW: 5G0 919 605 K HW: 5G0 919 605 K
Component: ABT_Std_Nav H60 0030
Serial number: VWZ8Z9PS600F7K
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0564
Coding: 02730002C2823A017F1E06000000
Shop #: WSC 00066 790 00122
ROD: EV_OCULowMQB_VW37.rod
End----------(Elapsed Time: 01:36, VBatt start/end: 12.5V/12.4V)-----------
Side note, looks like the firmware of the ECM was 8277 prior to the update.
