Hi everybody, this is my first post. I've been trying to figure out what's wrong with this 07 Continental, the control head screen, radio, hvac is all integrated into one unit (J523) and it is not turning on leaving all the controls for the system unresponsive - hvac, audio, screen, nothing happening here. The vehicle had an aftermarket radio installed before, a stereo specialist removed and returned wiring back to factory. I have double checked the wiring and it all seems to be correct. I have verified power and ground at J523 and NAV, they are ok. There is no light on the optic bus at J523 or NAV control module. I have attached a screenshot of a CAN scope on the NAV unit (connector unplugged), also a vehicle scan (after complete fault clear and ignition cycle a few times). I plan on scoping both CAN buses at J523 and uploading them as well but I have a few other vehicles that need attention right now. Will update soon.
If anybody has any ideas please fire away!
Thanks,
Ethan
I am trying to figure out a way to attach the scope screenshot, looks like I am not able to post attachments. But here is the Auto-scan just to start, will figure out a way to post the scopes later.
Thanks,
Ethan
Thursday,18,May,2017,12:54:46:51360
VCDS Version: 17.1.3.0 (x64) HEX-NET CB: 0.4336.4
Data version: 20170320
License Plate:
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
Mileage: 61200km-38027miles
Address 01: Engine Labels: 07C-906-018-BWR1.clb
Part No SW: 07C 906 018 EN HW: 07C 906 018 EC
Component: BY-6.0L-TT G ª0596
Revision: --H01--- Serial number: VWZ3Z0F7550527
Coding: 0001175
Shop #: WSC 00083 790 00000
VCID: 75A22FC01D0996E9CA-5160
Readiness: 0110 1101
Part No SW: 09E 927 760 AA HW: GS1 9.1 1.4
Component: AG6 09E 6.0L W12TT 2811
Revision: 00000001 Serial number: 0098921
Coding: 0000111
VCID: 6FAE1DA87F55AC3900-5160
Address 03: ABS Brakes Labels: 3W0-614-517-V1.lbl
Part No: 3W0 614 517 F
Component: ESP 5.7 4WD H01 0047
Coding: 0007878
Shop #: WSC 03175 000 00000
VCID: 383CE6F44A9B2B8111-51CE
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 E HW: 5WK 485 07
Component: 6C Kessy 6840
Revision: 68406418 Serial number: VWZ3Z0F7550527
Coding: 0405741
VCID: 291A33B0813182099E-5160
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No: 3W0 959 759 A
Component: CM Seat Pass. 0009
VCID: 47DE95083765547968-5160
01903 - Seat Tilt Adjustment Motor (V231)
Part No: 3W0 907 040 F
Component: Climatronic BY614 2014
Coding: 0000112
VCID: 3424D2C456F3CFE13D-5160
014 - Defective
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 H
Component: STG.Bordnetz 5101
Coding: 0000107
VCID: 2F2EDDA8BFD5EC3940-5160
Address 11: Engine II Labels: 07C-906-018-BWR2.clb
Coding: 0001175
Address 15: Airbags Labels: None
Part No SW: 3W8 909 601 HW: 3W8 909 601
Component: 16 Airbag 9.41 H13 0040
Revision: 91H13004 Serial number: 0039L0005274
Coding: 0012598
VCID: 7BB639F83B2DC099BC-5160
Subsystem 1 - Part No: 3W7 959 339
Component: BF-Gewichtsens. H02 0004
Subsystem 2 - Serial number: 009DP
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB401D4070EHÿ†63
Subsystem 5 - Serial number: 4070EHÿ†63428RB401D413337ÿ†63
Subsystem 6 - Serial number: 413337ÿ†63528RB401D4070DIÿ†63
Subsystem 7 - Serial number: 4070DIÿ†63628RB401D40676Iÿ†63
Subsystem 8 - Serial number: 40676Iÿ†63700RB4 Iÿ†63
Subsystem 9 - Serial number: Iÿ†63800RB4 Jÿ
Subsystem 10 - Serial number: Jÿ
01742 - Igniter for Knee Airbag; Drivers Side (N295)
Fault Status: 11100001
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 D
Component: Lenksäulenmodul 3401
Coding: 0000012
VCID: 2E10C0ACB8DFE5314B-5160
Address 17: Instruments Labels: 3Wx-920-xxx-17.lbl
Part No: 3W8 920 840 C
Component: KOMBIINSTRUMENT RB8 0610
Coding: 0023203
VCID: 3C34FAE47EA307A1F5-5160
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70AC1ED4626BB3C119-5160
Address 34: Level Control Labels: None
Part No: 3W0 907 553 B
Component: LUFTFDR.-CDC- 3C3V0 7205
Coding: 0005561
Shop #: WSC 03242 103 72660
VCID: 393AE3F071913289EE-5160
013 - Check DTC Memory
Part No: 3W0 959 760 A
Component: CM Seat Driver 0008
Shop #: WSC 03255 104 72657
VCID: 3FCE8DE86FB51CB9D0-5160
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 E
Component: Dachmodul 0707
Coding: 0002493
VCID: 383CE6F44A9B2B8111-5160
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 F
Component: 52 HSG 0101
Coding: 0000040
VCID: 3326D1D853FDC8D924-4B1E
Subsystem 1 - Part No: 3W8 959 701 B
Component: Tuersteuergeraet FS 1002
Subsystem 2 - Part No: 3W8 959 702 B
Component: Tuersteuergeraet BF 1002
Subsystem 3 - Part No: 3W8 959 703 B
Component: Tuersteuergeraet HL 0401
Subsystem 4 - Part No: 3W8 959 704 B
Component: Tuersteuergeraet HR 0401
Subsystem 5 - Part No: 3W0 909 610 F
Component: 14 HDSG 1809
Subsystem 6 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3W8 035 456
Component: 12K-AUDIOVERST 3000
VCID: 79BA23F03111F289AE-5160
00419 - Left Front DSP Midrange Speaker (R103)
00420 - Front Right DSP Midrange Speaker (R104)
Address 53: Parking Brake Labels: 3W0-907-801.clb
Part No SW: 3W0 907 801 D HW: 3W0 907 801 D
Component: EPB BC6HX24 HC6 X240
Coding: 0022401
VCID: 373EE5C8478524F918-5160
02443 - Control Head
012 - Electrical Fault in Circuit - MIL ON
Fault Status: 11110000
Reset counter: 35
Voltage: 11.90 V
Count: 40
Address 54: Rear Spoiler Labels: 1C0-959-733.lbl
Part No: 1C0 959 733 K
Component: Heckspoiler 0002
VCID: 3326D1D803FDC8D924-51CE
Address 65: Tire Pressure Labels: None
Part No: 3W7 907 273
Component: Reifendruckueberw. 0003
Coding: 0480311
VCID: 7DB237E02539CEA982-5160
Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W1 955 023 E
Component: Wische$
Shop #: WSC 00000 725 65552
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 D
Component: Batteriemanagement 2800
VCID: 24042284E6135F61AD-5160
Address 76: Park Assist Labels: Redir Fail!
Part No: 3W0 919 283 A
Component: 02 Einparkhilfe 0303
VCID: 3B36F9F87BAD0099FC-5160
Address 77: Telephone Labels: None
Part No SW: 3W0 035 385 S HW: 3W0 035 385 S
Component: rSAP ECU 0054
Coding: 0000272
VCID: 45C29F000D6946699A-5160
End----------(Elapsed Time: 09:21, VBatt start/end: 12.1V/11.9V)-----------
